path: root/arch/alpha/kernel/time.c
2011-07-22Merge branch 'timers-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mips: Fix i8253 clockevent fallout i8253: Cleanup outb/inb magic arm: Footbridge: Use common i8253 clockevent mips: Use common i8253 clockevent x86: Use common i8253 clockevent i8253: Create common clockevent implementation i8253: Export i8253_lock unconditionally pcpskr: MIPS: Make config dependencies finer grained pcspkr: Cleanup Kconfig dependencies i8253: Move remaining content and delete asm/i8253.h i8253: Consolidate definitions of PIT_LATCH x86: i8253: Consolidate definitions of global_clock_event i8253: Alpha, PowerPC: Remove unused asm/8253pit.h alpha: i8253: Cleanup remaining users of i8253pit.h i8253: Remove I8253_LOCK config i8253: Make pcsp sound driver use the shared i8253_lock i8253: Make pcspkr input driver use the shared i8253_lock i8253: Consolidate all kernel definitions of i8253_lock i8253: Unify all kernel declarations of i8253_lock i8253: Create linux/i8253.h and use it in all 8253 related files
2011-07-01irq_work, alpha: Fix up arch hooksPeter Zijlstra
Commit e360adbe29 ("irq_work: Add generic hardirq context callbacks") fouled up the Alpha bit, not properly naming the arch specific function that raises the 'self-IPI'. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: stable@kernel.org # 37+ Link: http://lkml.kernel.org/n/tip-gukh0txmql2l4thgrekzzbfy@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-09alpha: i8253: Cleanup remaining users of i8253pit.hRalf Baechle
The Alpha <asm/i8253pit.h> header is empty so this inclusion can just be removed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Link: http://lkml.kernel.org/r/20110601180610.608083130@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-13alpha: convert to clocksource_register_hzJohn Stultz
Converts alpha to use clocksource_register_hz. Signed-off-by: John Stultz <johnstul@us.ibm.com> CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-04-17alpha: Fix uninitialized value in read_persistent_clock.Richard Henderson
Signed-off-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-31alpha: Change do_timer() to xtime_update()Torben Hohn
xtime_update() takes the xtime_lock itself. timer_interrupt() is only called on the boot cpu. See do_entInt(). So "state" in timer_interrupt does not require protection by xtime_lock. Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: hch@infradead.org Cc: yong.zhang0@gmail.com LKML-Reference: <20110127145915.23248.20919.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-13set_rtc_mmss: show warning message only onceStephen Hemminger
Occasionally the system gets into a state where the CMOS clock has gotten slightly ahead of current time and the periodic update of RTC fails. The message is a nuisance and repeats spamming the log. See: http://www.ntp.org/ntpfaq/NTP-s-trbl-spec.htm#Q-LINUX-SET-RTC-MMSS Rather than just removing the message, make it show only once and reduce severity since it indicates a normal and non urgent condition. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-18alpha: Shift perf event pending work earlier in timer interruptMichael Cree
Pending work from the performance event subsystem is executed in the timer interrupt. This patch shifts the call to perf_event_do_pending() before the call to update_process_times() as the latter may call back into the perf event subsystem and it is prudent to have the pending work executed first. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-08-09alpha: implement HW performance events on the EV67 and later CPUsMichael Cree
This implements hardware performance events for the EV67 and later CPUs within the Linux performance events subsystem. Only using the performance monitoring unit in HP/Compaq's so called "Aggregrate mode" is supported. The code has been implemented in a manner that makes extension to other older Alpha CPUs relatively straightforward should some mug wish to indulge themselves. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jay Estabrook <jay.estabrook@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26Convert alpha to use clocksources instead of arch_gettimeoffsetJohn Stultz
Alpha has a tsc like rpcc counter that it uses to manage time. This can be converted to an actual clocksource instead of utilizing the arch_gettimeoffset method that is really only there for legacy systems with no continuous counter. Further cleanups could be made if alpha converted to the clockevent model. CC: Thomas Gleixner <tglx@linutronix.de> CC: Richard Henderson <rth@twiddle.net> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Tested-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Matt Turner <mattst88@gmail.com> Signed-off-by: John Stultz <johnstul@us.ibm.com>
2010-03-13alpha: Convert alpha to use read/update_persistent_clockJohn Stultz
This patch converts the alpha architecture to use the generic read_persistent_clock and update_persistent_clock interfaces, reducing the amount of arch specific code we have to maintain, and allowing for further cleanups in the future. I have not built or tested this patch, so help from arch maintainers would be appreciated. igned-off-by: John Stultz <johnstul@us.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1267675049-12337-2-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-09-22alpha: convert to use arch_gettimeoffset()john stultz
Converts alpha to use GENERIC_TIME via the arch_getoffset() infrastructure, reducing the amount of arch specific code we need to maintain. I suspect the alpha arch could even be further improved to provide and rpcc() based clocksource, but not having the hardware, I don't feel comfortable attempting the more complicated conversion (but I'd be glad to help if anyone else is interested). [akpm@linux-foundation.org: fix build] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15alpha: fix RTC on marvelIvan Kokshaysky
Unlike other alphas, marvel doesn't have real PC-style CMOS clock hardware - RTC accesses are emulated via PAL calls. Unfortunately, for unknown reason these calls work only on CPU #0. So current implementation for arbitrary CPU makes CMOS_READ/WRITE to be executed on CPU #0 via IPI. However, for obvious reason this doesn't work with standard get/set_rtc_time() functions, where a bunch of CMOS accesses is done with disabled interrupts. Solved by making the IPI calls for entire get/set_rtc_time() functions, not for individual CMOS accesses. Which is also a lot more effective performance-wise. The patch is largely based on the code from Jay Estabrook. My changes: - tweak asm-generic/rtc.h by adding a couple of #defines to avoid a massive code duplication in arch/alpha/include/asm/rtc.h; - sys_marvel.c: fix get/set_rtc_time() return values (Jay's FIXMEs). NOTE: this fixes *only* LIB_RTC drivers. Legacy (CONFIG_RTC) driver wont't work on marvel. Actually I think that we should just disable CONFIG_RTC on alpha (maybe in 2.6.30?), like most other arches - AFAIK, all modern distributions use LIB_RTC anyway. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20alpha: use bcd2bin/bin2bcdAdrian Bunk
Change alpha to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13xtime_lock vs update_process_timesPeter Zijlstra
Commit d3d74453c34f8fd87674a8cf5b8a327c68f22e99 ("hrtimer: fixup the HRTIMER_CB_IRQSAFE_NO_SOFTIRQ fallback") broke several archs, and since only Russell bothered to merge the fix, and Greg to ACK his arch, I'm sending this for merger. I have confirmation that the Alpha bit results in a booting kernel. That leaves: blackfin, frv, sh and sparc untested. The deadlock in question was found by Russell: IRQ handle -> timer_tick() - xtime seqlock held for write -> update_process_times() -> run_local_timers() -> hrtimer_run_queues() -> hrtimer_get_softirq_time() - tries to get a read lock Now, Thomas assures me the fix is trivial, only do_timer() needs to be done under the xtime_lock, and update_process_times() can savely be removed from under it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Greg Ungerer <gerg@uclinux.org> CC: Richard Henderson <rth@twiddle.net> CC: Bryan Wu <bryan.wu@analog.com> CC: David Howells <dhowells@redhat.com> CC: Paul Mundt <lethal@linux-sh.org> CC: William Irwin <wli@holomorphy.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16alpha: fix trivial section mismatch warningsSam Ravnborg
Fix the following section mismatch warnings: WARNING: arch/alpha/kernel/built-in.o(.text+0x7c78): Section mismatch: reference to .init.text:init_rtc_irq (between 'common_init_rtc' and 'timer_interrupt') WARNING: arch/alpha/kernel/built-in.o(.text+0x7c7c): Section mismatch: reference to .init.text:init_rtc_irq (between 'common_init_rtc' and 'timer_interrupt') WARNING: arch/alpha/kernel/built-in.o(.data+0x2c30): Section mismatch: reference to .init.text:srm_console_setup (between 'srmcons' and 'tsunami_pci_ops') In all three cases functions marked __init was called outside __init context. So the fix was to just drop the __init attribute. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Meelis Roos <mroos@linux.ee> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Consolidate default sched_clock()Alexey Dobriyan
Use attribute(weak). Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-11[PATCH] alpha_ksyms.c cleanupAl Viro
taken exports to actual definitions of symbols being exported. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-07[PATCH] minimal alpha pt_regs fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] kill wall_jiffiesAtsushi Nemoto
With 2.6.18-rc4-mm2, now wall_jiffies will always be the same as jiffies. So we can kill wall_jiffies completely. This is just a cleanup and logically should not change any real behavior except for one thing: RTC updating code in (old) ppc and xtensa use a condition "jiffies - wall_jiffies == 1". This condition is never met so I suppose it is just a bug. I just remove that condition only instead of kill the whole "if" block. [heiko.carstens@de.ibm.com: s390 build fix and cleanup] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] simplify update_times (avoid jiffies/jiffies_64 aliasing problem)Atsushi Nemoto
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390 timer interrupt handler with this change. Currently update_times() calculates ticks by "jiffies - wall_jiffies", but callers of do_timer() should know how many ticks to update. Passing ticks get rid of this redundant calculation. Also there are another redundancy pointed out by Martin Schwidefsky. This cleanup make a barrier added by 5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes it. As a bonus, this cleanup make wall_jiffies can be removed easily, since now wall_jiffies is always synced with jiffies. (This patch does not really remove wall_jiffies. It would be another cleanup patch) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] arch/alpha: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of the macro. Also remove some trailing whitespaces and needless braces. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] RTC: Remove RTC UIP synchronization on AlphaMatt Mackall
The sync may still be needed for CPU clock calibration but we don't sync in the regular case. Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
