path: root/arch/alpha
2015-11-05mm: mlock: add mlock flags to enable VM_LOCKONFAULT usageEric B Munson
The previous patch introduced a flag that specified pages in a VMA should be placed on the unevictable LRU, but they should not be made present when the area is created. This patch adds the ability to set this state via the new mlock system calls. We add MLOCK_ONFAULT for mlock2 and MCL_ONFAULT for mlockall. MLOCK_ONFAULT will set the VM_LOCKONFAULT modifier for VM_LOCKED. MCL_ONFAULT should be used as a modifier to the two other mlockall flags. When used with MCL_CURRENT, all current mappings will be marked with VM_LOCKED | VM_LOCKONFAULT. When used with MCL_FUTURE, the mm->def_flags will be marked with VM_LOCKED | VM_LOCKONFAULT. When used with both MCL_CURRENT and MCL_FUTURE, all current mappings and mm->def_flags will be marked with VM_LOCKED | VM_LOCKONFAULT. Prior to this patch, mlockall() will unconditionally clear the mm->def_flags any time it is called without MCL_FUTURE. This behavior is maintained after adding MCL_ONFAULT. If a call to mlockall(MCL_FUTURE) is followed by mlockall(MCL_CURRENT), the mm->def_flags will be cleared and new VMAs will be unlocked. This remains true with or without MCL_ONFAULT in either mlockall() invocation. munlock() will unconditionally clear both vma flags. munlockall() unconditionally clears for VMA flags on all VMAs and in the mm->def_flags field. Signed-off-by: Eric B Munson <emunson@akamai.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-20Merge tag 'v4.3-rc6' into locking/core, to pick up fixes before applying new ↵Ingo Molnar
changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-06word-at-a-time.h: support zero_bytemask() on alpha and tileChris Metcalf
Both alpha and tile needed implementations of zero_bytemask. The alpha version is untested. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
2015-10-06Merge tag 'v4.3-rc4' into locking/core, to pick up fixes before applying new ↵Ingo Molnar
2015-09-25Merge tag 'pci-v4.3-fixes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "These are fixes for things we merged for v4.3 (VPD, MSI, and bridge window management), and a new Renesas R8A7794 SoC device ID. Details: Resource management: - Revert pci_read_bridge_bases() unification (Bjorn Helgaas) - Clear IORESOURCE_UNSET when clipping a bridge window (Bjorn Helgaas) MSI: - Fix MSI IRQ domains for VFs on virtual buses (Alex Williamson) Renesas R-Car host bridge driver: - Add R8A7794 support (Sergei Shtylyov) Miscellaneous: - Fix devfn for VPD access through function 0 (Alex Williamson) - Use function 0 VPD only for identical functions (Alex Williamson)" * tag 'pci-v4.3-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: rcar: Add R8A7794 support PCI: Use function 0 VPD for identical functions, regular VPD for others PCI: Fix devfn for VPD access through function 0 PCI/MSI: Fix MSI IRQ domains for VFs on virtual buses PCI: Clear IORESOURCE_UNSET when clipping a bridge window PCI: Revert "PCI: Call pci_read_bridge_bases() from core instead of arch code"
2015-09-23atomic, arch: Audit atomic_{read,set}()Peter Zijlstra
This patch makes sure that atomic_{read,set}() are at least {READ,WRITE}_ONCE(). We already had the 'requirement' that atomic_read() should use ACCESS_ONCE(), and most archs had this, but a few were lacking. All are now converted to use READ_ONCE(). And, by a symmetry and general paranoia argument, upgrade atomic_set() to use WRITE_ONCE(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: james.hogan@imgtec.com Cc: linux-kernel@vger.kernel.org Cc: oleg@redhat.com Cc: will.deacon@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-18Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "This is a rather large update post rc1 due to the final steps of cleanups and API changes which had to wait for the preparatory patches to hit your tree. - Regression fixes for ARM GIC irqchips - Regression fixes and lockdep anotations for renesas irq chips - The leftovers of the cleanup and preparatory patches which have been ignored by maintainers - Final conversions of the newly merged users of obsolete APIs - Final removal of obsolete APIs - Final removal of ARM artifacts which had been introduced during the conversion of ARM to the generic interrupt code. - Final split of the irq_data into chip specific and common data to reflect the needs of hierarchical irq domains. - Treewide removal of the first argument of interrupt flow handlers, i.e. the irq number, which is not used by the majority of handlers and simple to retrieve from the other argument the irq descriptor. - A few comment updates and build warning fixes" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) arm64: Remove ununsed set_irq_flags ARM: Remove ununsed set_irq_flags sh: Kill off set_irq_flags usage irqchip: Kill off set_irq_flags usage gpu/drm: Kill off set_irq_flags usage genirq: Remove irq argument from irq flow handlers genirq: Move field 'msi_desc' from irq_data into irq_common_data genirq: Move field 'affinity' from irq_data into irq_common_data genirq: Move field 'handler_data' from irq_data into irq_common_data genirq: Move field 'node' from irq_data into irq_common_data irqchip/gic-v3: Use IRQD_FORWARDED_TO_VCPU flag irqchip/gic: Use IRQD_FORWARDED_TO_VCPU flag genirq: Provide IRQD_FORWARDED_TO_VCPU status flag genirq: Simplify irq_data_to_desc() genirq: Remove __irq_set_handler_locked() pinctrl/pistachio: Use irq_set_handler_locked gpio: vf610: Use irq_set_handler_locked powerpc/mpc8xx: Use irq_set_handler_locked() powerpc/ipic: Use irq_set_handler_locked() powerpc/cpm2: Use irq_set_handler_locked() ...
2015-09-17alpha: lib: export __delaySudip Mukherjee
__delay was not exported as a result while building with allmodconfig we were getting build error of undefined symbol. __delay is being used by: drivers/net/phy/mdio-octeon.c Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-17alpha: io: define ioremap_ucSudip Mukherjee
ioremap_uc was not defined and as a result while building with allmodconfig were getting build error of: implicit declaration of function 'ioremap_uc'. Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-15PCI: Revert "PCI: Call pci_read_bridge_bases() from core instead of arch code"Bjorn Helgaas
Revert dff22d2054b5 ("PCI: Call pci_read_bridge_bases() from core instead of arch code"). Reading PCI bridge windows is not arch-specific in itself, but there is PCI core code that doesn't work correctly if we read them too early. For example, Hannes found this case on an ARM Freescale i.mx6 board: pci_bus 0000:00: root bus resource [mem 0x01000000-0x01efffff] pci 0000:00:00.0: PCI bridge to [bus 01-ff] pci 0000:00:00.0: BAR 8: no space for [mem size 0x01000000] (mem window) pci 0000:01:00.0: BAR 2: failed to assign [mem size 0x00200000] pci 0000:01:00.0: BAR 1: failed to assign [mem size 0x00004000] pci 0000:01:00.0: BAR 0: failed to assign [mem size 0x00000100] The 00:00.0 mem window needs to be at least 3MB: the 01:00.0 device needs 0x204100 of space, and mem windows are megabyte-aligned. Bus sizing can increase a bridge window size, but never *decrease* it (see d65245c3297a ("PCI: don't shrink bridge resources")). Prior to dff22d2054b5, ARM didn't read bridge windows at all, so the "original size" was zero, and we assigned a 3MB window. After dff22d2054b5, we read the bridge windows before sizing the bus. The firmware programmed a 16MB window (size 0x01000000) in 00:00.0, and since we never decrease the size, we kept 16MB even though we only needed 3MB. But 16MB doesn't fit in the host bridge aperture, so we failed to assign space for the window and the downstream devices. I think this is a defect in the PCI core: we shouldn't rely on the firmware to assign sensible windows. Ray reported a similar problem, also on ARM, with Broadcom iProc. Issues like this are too hard to fix right now, so revert dff22d2054b5. Reported-by: Hannes <oe5hpm@gmail.com> Reported-by: Ray Jui <rjui@broadcom.com> Link: http://lkml.kernel.org/r/CAAa04yFQEUJm7Jj1qMT57-LG7ZGtnhNDBe=PpSRa70Mj+XhW-A@mail.gmail.com Link: http://lkml.kernel.org/r/55F75BB8.4070405@broadcom.com Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
2015-09-10dma-mapping: consolidate dma_set_maskChristoph Hellwig
Almost everyone implements dma_set_mask the same way, although some time that's hidden in ->set_dma_mask methods. This patch consolidates those into a common implementation that either calls ->set_dma_mask if present or otherwise uses the default implementation. Some architectures used to only call ->set_dma_mask after the initial checks, and those instance have been fixed to do the full work. h8300 implemented dma_set_mask bogusly as a no-ops and has been fixed. Unfortunately some architectures overload unrelated semantics like changing the dma_ops into it so we still need to allow for an architecture override for now. [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10dma-mapping: consolidate dma_supportedChristoph Hellwig
Most architectures just call into ->dma_supported, but some also return 1 if the method is not present, or 0 if no dma ops are present (although that should never happeb). Consolidate this more broad version into common code. Also fix h8300 which inorrectly always returned 0, which would have been a problem if it's dma_set_mask implementation wasn't a similarly buggy noop. As a few architectures have much more elaborate implementations, we still allow for arch overrides. [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10dma-mapping: cosolidate dma_mapping_errorChristoph Hellwig
Currently there are three valid implementations of dma_mapping_error: (1) call ->mapping_error (2) check for a hardcoded error code (3) always return 0 This patch provides a common implementation that calls ->mapping_error if present, then checks for DMA_ERROR_CODE if defined or otherwise returns 0. [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10dma-mapping: consolidate dma_{alloc,free}_noncoherentChristoph Hellwig
Most architectures do not support non-coherent allocations and either define dma_{alloc,free}_noncoherent to their coherent versions or stub them out. Openrisc uses dma_{alloc,free}_attrs to implement them, and only Mips implements them directly. This patch moves the Openrisc version to common code, and handles the DMA_ATTR_NON_CONSISTENT case in the mips dma_map_ops instance. Note that actual non-coherent allocations require a dma_cache_sync implementation, so if non-coherent allocations didn't work on an architecture before this patch they still won't work after it. [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent}Christoph Hellwig
Since 2009 we have a nice asm-generic header implementing lots of DMA API functions for architectures using struct dma_map_ops, but unfortunately it's still missing a lot of APIs that all architectures still have to duplicate. This series consolidates the remaining functions, although we still need arch opt outs for two of them as a few architectures have very non-standard implementations. This patch (of 5): The coherent DMA allocator works the same over all architectures supporting dma_map operations. This patch consolidates them and converges the minor differences: - the debug_dma helpers are now called from all architectures, including those that were previously missing them - dma_alloc_from_coherent and dma_release_from_coherent are now always called from the generic alloc/free routines instead of the ops dma-mapping-common.h always includes dma-coherent.h to get the defintions for them, or the stubs if the architecture doesn't support this feature - checks for ->alloc / ->free presence are removed. There is only one magic instead of dma_map_ops without them (mic_dma_ops) and that one is x86 only anyway. Besides that only x86 needs special treatment to replace a default devices if none is passed and tweak the gfp_flags. An optional arch hook is provided for that. [linux@roeck-us.net: fix build] [jcmvbkbc@gmail.com: fix xtensa] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking and atomic updates from Ingo Molnar: "Main changes in this cycle are: - Extend atomic primitives with coherent logic op primitives (atomic_{or,and,xor}()) and deprecate the old partial APIs (atomic_{set,clear}_mask()) The old ops were incoherent with incompatible signatures across architectures and with incomplete support. Now every architecture supports the primitives consistently (by Peter Zijlstra) - Generic support for 'relaxed atomics': - _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return() - atomic_read_acquire() - atomic_set_release() This came out of porting qwrlock code to arm64 (by Will Deacon) - Clean up the fragile static_key APIs that were causing repeat bugs, by introducing a new one: DEFINE_STATIC_KEY_TRUE(name); DEFINE_STATIC_KEY_FALSE(name); which define a key of different types with an initial true/false value. Then allow: static_branch_likely() static_branch_unlikely() to take a key of either type and emit the right instruction for the case. To be able to know the 'type' of the static key we encode it in the jump entry (by Peter Zijlstra) - Static key self-tests (by Jason Baron) - qrwlock optimizations (by Waiman Long) - small futex enhancements (by Davidlohr Bueso) - ... and misc other changes" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits) jump_label/x86: Work around asm build bug on older/backported GCCs locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics locking/qrwlock: Implement queue_write_unlock() using smp_store_release() locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t' locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic locking/static_keys: Make verify_keys() static jump label, locking/static_keys: Update docs locking/static_keys: Provide a selftest jump_label: Provide a self-test s390/uaccess, locking/static_keys: employ static_branch_likely() x86, tsc, locking/static_keys: Employ static_branch_likely() locking/static_keys: Add selftest locking/static_keys: Add a new static_key interface locking/static_keys: Rework update logic locking/static_keys: Add static_key_{en,dis}able() helpers ...
2015-09-01Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "This updated pull request does not contain the last few GIC related patches which were reported to cause a regression. There is a fix available, but I let it breed for a couple of days first. The irq departement provides: - new infrastructure to support non PCI based MSI interrupts - a couple of new irq chip drivers - the usual pile of fixlets and updates to irq chip drivers - preparatory changes for removal of the irq argument from interrupt flow handlers - preparatory changes to remove IRQF_VALID" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits) irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2 irqchip: Add documentation for the bcm2836 interrupt controller irqchip/bcm2835: Add support for being used as a second level controller irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ PCI: xilinx: Fix typo in function name irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance irqchip/gic: Only allow the primary GIC to set the CPU map PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove unicore32/irq: Prepare puv3_gpio_handler for irq argument removal tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal m68k/irq: Prepare irq handlers for irq argument removal C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal blackfin: Prepare irq handlers for irq argument removal arc/irq: Prepare idu_cascade_isr for irq argument removal sparc/irq: Use access helper irq_data_get_affinity_mask() sparc/irq: Use helper irq_data_get_irq_handler_data() parisc/irq: Use access helper irq_data_get_affinity_mask() mn10300/irq: Use access helper irq_data_get_affinity_mask() irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal ...
2015-09-01Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "Rather large, but nothing exiting: - new range check for settimeofday() to prevent that boot time becomes negative. - fix for file time rounding - a few simplifications of the hrtimer code - fix for the proc/timerlist code so the output of clock realtime timers is accurate - more y2038 work - tree wide conversion of clockevent drivers to the new callbacks" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (88 commits) hrtimer: Handle failure of tick_init_highres() gracefully hrtimer: Unconfuse switch_hrtimer_base() a bit hrtimer: Simplify get_target_base() by returning current base hrtimer: Drop return code of hrtimer_switch_to_hres() time: Introduce timespec64_to_jiffies()/jiffies_to_timespec64() time: Introduce current_kernel_time64() time: Introduce struct itimerspec64 time: Add the common weak version of update_persistent_clock() time: Always make sure wall_to_monotonic isn't positive time: Fix nanosecond file time rounding in timespec_trunc() timer_list: Add the base offset so remaining nsecs are accurate for non monotonic timers cris/time: Migrate to new 'set-state' interface kernel: broadcast-hrtimer: Migrate to new 'set-state' interface xtensa/time: Migrate to new 'set-state' interface unicore/time: Migrate to new 'set-state' interface um/time: Migrate to new 'set-state' interface sparc/time: Migrate to new 'set-state' interface sh/localtimer: Migrate to new 'set-state' interface score/time: Migrate to new 'set-state' interface s390/time: Migrate to new 'set-state' interface ...
2015-08-31Merge branch 'timers-nohz-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull NOHZ updates from Ingo Molnar: "The main changes, mostly written by Frederic Weisbecker, include: - Fix some jiffies based cputime assumptions. (No real harm because the concerned code isn't used by full dynticks.) - Simplify jiffies <-> usecs conversions. Remove dead code. - Remove early hacks on nohz full code that avoided messing up idle nohz internals. Now nohz integrates well full and idle and such hack have become needless. - Restart nohz full tick from irq exit. (A simplification and a preparation for future optimization on scheduler kick to nohz full) - Code cleanups. - Tile driver isolation enhancement on top of nohz. (Chris Metcalf)" * 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: nohz: Remove useless argument on tick_nohz_task_switch() nohz: Move tick_nohz_restart_sched_tick() above its users nohz: Restart nohz full tick from irq exit nohz: Remove idle task special case nohz: Prevent tilegx network driver interrupts alpha: Fix jiffies based cputime assumption apm32: Fix cputime == jiffies assumption jiffies: Remove HZ > USEC_PER_SEC special case
2015-08-31Merge tag 'pci-v4.3-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v4.3 merge window: Enumeration: - Allocate ATS struct during enumeration (Bjorn Helgaas) - Embed ATS info directly into struct pci_dev (Bjorn Helgaas) - Reduce size of ATS structure elements (Bjorn Helgaas) - Stop caching ATS Invalidate Queue Depth (Bjorn Helgaas) - iommu/vt-d: Cache PCI ATS state and Invalidate Queue Depth (Bjorn Helgaas) - Move MPS configuration check to pci_configure_device() (Bjorn Helgaas) - Set MPS to match upstream bridge (Keith Busch) - ARM/PCI: Set MPS before pci_bus_add_devices() (Murali Karicheri) - Add pci_scan_root_bus_msi() (Lorenzo Pieralisi) - ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() (Lorenzo Pieralisi) Resource management: - Call pci_read_bridge_bases() from core instead of arch code (Lorenzo Pieralisi) PCI device hotplug: - pciehp: Remove unused interrupt events (Bjorn Helgaas) - pciehp: Remove ignored MRL sensor interrupt events (Bjorn Helgaas) - pciehp: Handle invalid data when reading from non-existent devices (Jarod Wilson) - pciehp: Simplify pcie_poll_cmd() (Yijing Wang) - Use "slot" and "pci_slot" for struct hotplug_slot and struct pci_slot (Yijing Wang) - Protect pci_bus->slots with pci_slot_mutex, not pci_bus_sem (Yijing Wang) - Hold pci_slot_mutex while searching bus->slots list (Yijing Wang) Power management: - Disable async suspend/resume for JMicron multi-function SATA/AHCI (Zhang Rui) Virtualization: - Add ACS quirks for Intel I219-LM/V (Alex Williamson) - Restore ACS configuration as part of pci_restore_state() (Alexander Duyck) MSI: - Add pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu) - x86: Implement pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu) - Add helpers to manage pci_dev->irq and pci_dev->irq_managed (Jiang Liu) - Free legacy IRQ when enabling MSI/MSI-X (Jiang Liu) - ARM/PCI: Remove msi_controller from struct pci_sys_data (Lorenzo Pieralisi) - Remove unused pcibios_msi_controller() hook (Lorenzo Pieralisi) Generic host bridge driver: - Remove dependency on ARM-specific struct hw_pci (Jayachandran C) - Build setup-irq.o for arm64 (Jayachandran C) - Add arm64 support (Jayachandran C) APM X-Gene host bridge driver: - Add APM X-Gene PCIe 64-bit prefetchable window (Duc Dang) - Add support for a 64-bit prefetchable memory window (Duc Dang) - Drop owner assignment from platform_driver (Krzysztof Kozlowski) Broadcom iProc host bridge driver: - Allow BCMA bus driver to be built as module (Hauke Mehrtens) - Delete unnecessary checks before phy calls (Markus Elfring) - Add arm64 support (Ray Jui) Synopsys DesignWare host bridge driver: - Don't complain missing *config* reg space if va_cfg0 is set (Murali Karicheri) TI DRA7xx host bridge driver: - Disable pm_runtime on get_sync failure (Kishon Vijay Abraham I) - Add PM support (Kishon Vijay Abraham I) - Clear MSE bit during suspend so clocks will idle (Kishon Vijay Abraham I) - Add support to make GPIO drive PERST# line (Kishon Vijay Abraham I) Xilinx AXI host bridge driver: - Check for MSI interrupt flag before handling as INTx (Russell Joyce) Miscellaneous: - Fix Intersil/Techwell TW686[4589] AV capture class code (Krzysztof Hałasa) - Use PCI_CLASS_SERIAL_USB instead of bare number (Bjorn Helgaas) - Fix generic NCR 53c810 class code quirk (Bjorn Helgaas) - Fix TI816X class code quirk (Bjorn Helgaas) - Remove unused "pci_probe" flags (Bjorn Helgaas) - Host bridge driver code simplifications (Fabio Estevam) - Add dev_flags bit to access VPD through function 0 (Mark Rustad) - Add VPD function 0 quirk for Intel Ethernet devices (Mark Rustad) - Kill off set_irq_flags() usage (Rob Herring) - Remove Intel Cherrytrail D3 delays (Srinidhi Kasagar) - Clean up pci_find_capability() (Wei Yang)" * tag 'pci-v4.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (72 commits) PCI: Disable async suspend/resume for JMicron multi-function SATA/AHCI PCI: Set MPS to match upstream bridge PCI: Move MPS configuration check to pci_configure_device() PCI: Drop references acquired by of_parse_phandle() PCI/MSI: Remove unused pcibios_msi_controller() hook ARM/PCI: Remove msi_controller from struct pci_sys_data ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() PCI: Add pci_scan_root_bus_msi() ARM/PCI: Replace panic with WARN messages on failures PCI: generic: Add arm64 support PCI: Build setup-irq.o for arm64 PCI: generic: Remove dependency on ARM-specific struct hw_pci PCI: imx6: Simplify a trivial if-return sequence PCI: spear: Use BUG_ON() instead of condition followed by BUG() PCI: dra7xx: Remove unneeded use of IS_ERR_VALUE() PCI: Remove pci_ats_enabled() PCI: Stop caching ATS Invalidate Queue Depth PCI: Move ATS declarations to linux/pci.h so they're all together PCI: Clean up ATS error handling PCI: Use pci_physfn() rather than looking up physfn by hand ...
2015-08-30alpha: select CONFIG_ARCH_USE_CMPXCHG_LOCKREF.Matt Turner
On Alpha we have spinlocks that are 32b in size and an efficient cmpxchg64 implementation, so we qualify to make use of cmpxchg backed lockrefs. Select the ARCH_USE_CMPXCHG_LOCKREF Kconfig symbol and provide a trivial implementation of arch_spin_value_unlocked to satisfy the lockref code. Using Linus' simple testcase from http://article.gmane.org/gmane.linux.file-systems/77466 on a dual CPU ES47 system I see around an 8% gain: N Min Max Median Avg Stddev x 30 6194580 6295654 6272504 6272514 17694.232 + 30 6731164 6786334 6767982 6764274 13738.863 Difference at 95.0% confidence 491760 +/- 8188.17 7.83992% +/- 0.130541% (Student's t, pooled s = 15840.5) Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-08-10alpha/time: Migrate to new 'set-state' interfaceViresh Kumar
Migrate alpha driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. rtc clockevent device wasn't doing anything in set-mode and so its set-state callbacks aren't implemented. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: linux-alpha@vger.kernel.org Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-07-30Merge branch 'linus' into irq/coreThomas Gleixner
Pull in upstream fixes before applying conflicting changes
2015-07-29alpha: Fix jiffies based cputime assumptionFrederic Weisbecker
That code wrongly assumes that cputime_t wraps jiffies_t. Lets use the correct accessors/mutators. In practice there should be no harm yet because alpha currently only support tick based cputime accounting which is always jiffies based. Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Christoph Lameter <cl@linux.com> Cc: Ingo Molnar <mingo@kernel.org> Cc; John Stultz <john.stultz@linaro.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2015-07-27atomic: Provide atomic_{or,xor,and}Peter Zijlstra
Implement atomic logic ops -- atomic_{or,xor,and}. These will replace the atomic_{set,clear}_mask functions that are available on some archs. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-27alpha: Provide atomic_{or,xor,and}Peter Zijlstra
2015-07-27alpha/irq: Use access helper irq_data_get_affinity_mask()Jiang Liu
This is a preparatory patch for moving irq_data struct members. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Matt Turner <mattst88@gmail.com> Link: http://lkml.kernel.org/r/20150713075508.821878421@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-23PCI: Call pci_read_bridge_bases() from core instead of arch codeLorenzo Pieralisi
When we scan a PCI bus, we read PCI-PCI bridge window registers with pci_read_bridge_bases() so we can validate the resource hierarchy. Most architectures call pci_read_bridge_bases() from pcibios_fixup_bus(), but PCI-PCI bridges are not arch-specific, so this doesn't need to be in arch-specific code. Call pci_read_bridge_bases() directly from the PCI core instead of from arch code. For alpha and mips, we now call pci_read_bridge_bases() always; previously we only called it if PCI_PROBE_ONLY was set. [bhelgaas: changelog] Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: Ralf Baechle <ralf@linux-mips.org> CC: James E.J. Bottomley <jejb@parisc-linux.org> CC: Michael Ellerman <mpe@ellerman.id.au> CC: Bjorn Helgaas <bhelgaas@google.com> CC: Richard Henderson <rth@twiddle.net> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: David Howells <dhowells@redhat.com> CC: Russell King <linux@arm.linux.org.uk> CC: Tony Luck <tony.luck@intel.com> CC: David S. Miller <davem@davemloft.net> CC: Ingo Molnar <mingo@redhat.com> CC: Guenter Roeck <linux@roeck-us.net> CC: Michal Simek <monstr@monstr.eu> CC: Chris Zankel <chris@zankel.net>
2015-07-17mm: clean up per architecture MM hook header filesLaurent Dufour
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty header file (mm-arch-hooks.h) for every architecture, even those which doesn't need to define mm hooks. As suggested by Geert Uytterhoeven, this could be cleaned through the use of a generic header file included via each per architecture asm/include/Kbuild file. The PowerPC architecture is not impacted here since this architecture has to defined the arch_remap MM hook. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-26Merge tag 'tty-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the tty and serial driver patches for 4.2-rc1. A number of individual driver updates, some code cleanups, and other minor things, full details in the shortlog. All have been in linux-next for a while with no reported issues" * tag 'tty-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (152 commits) Doc: serial-rs485.txt: update RS485 driver interface Doc: tty.txt: remove mention of the BKL MAINTAINERS: tty: add serial docs directory serial: sprd: check for NULL after calling devm_clk_get serial: 8250_pci: Correct uartclk for xr17v35x expansion chips serial: 8250_pci: Add support for 12 port Exar boards serial: 8250_uniphier: add bindings document for UniPhier UART serial: core: cleanup in uart_get_baud_rate() serial: stm32-usart: Add STM32 USART Driver tty/serial: kill off set_irq_flags usage tty: move linux/gsmmux.h to uapi doc: dt: add documentation for nxp,lpc1850-uart serial: 8250: add LPC18xx/43xx UART driver serial: 8250_uniphier: add UniPhier serial driver serial: 8250_dw: support ACPI platforms with integrated DMA engine serial: of_serial: check the return value of clk_prepare_enable() serial: of_serial: use devm_clk_get() instead of clk_get() serial: earlycon: Add support for big-endian MMIO accesses serial: sirf: use hrtimer for data rx serial: sirf: correct the fifo empty_bit ...
2015-06-25Merge branch 'for-4.2/sg' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull asm/scatterlist.h removal from Jens Axboe: "We don't have any specific arch scatterlist anymore, since parisc finally switched over. Kill the include" * 'for-4.2/sg' of git://git.kernel.dk/linux-block: remove scatterlist.h generation from arch Kbuild files remove <asm/scatterlist.h>
2015-06-24mm: new mm hook frameworkLaurent Dufour
CRIU is recreating the process memory layout by remapping the checkpointee memory area on top of the current process (criu). This includes remapping the vDSO to the place it has at checkpoint time. However some architectures like powerpc are keeping a reference to the vDSO base address to build the signal return stack frame by calling the vDSO sigreturn service. So once the vDSO has been moved, this reference is no more valid and the signal frame built later are not usable. This patch serie is introducing a new mm hook framework, and a new arch_remap hook which is called when mremap is done and the mm lock still hold. The next patch is adding the vDSO remap and unmap tracking to the powerpc architecture. This patch (of 3): This patch introduces a new set of header file to manage mm hooks: - per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h) - a generic header (include/linux/mm-arch-hooks.h) The architecture which need to overwrite a hook as to redefine it in its header file, while architecture which doesn't need have nothing to do. The default hooks are defined in the generic header and are used in the case the architecture is not defining it. In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should be moved here. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23Merge tag 'pci-v4.2-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v4.2 merge window: Enumeration - Move pci_ari_enabled() to global header (Alex Williamson) - Account for ARI in _PRT lookups (Alex Williamson) - Remove unused pci_scan_bus_parented() (Yijing Wang) Resource management - Use host bridge _CRS info on systems with >32 bit addressing (Bjorn Helgaas) - Use host bridge _CRS info on Foxconn K8M890-8237A (Bjorn Helgaas) - Fix pci_address_to_pio() conversion of CPU address to I/O port (Zhichang Yuan) - Add pci_bus_addr_t (Yinghai Lu) PCI device hotplug - Wait for pciehp command completion where necessary (Alex Williamson) - Drop pointless ACPI-based "slot detection" check (Rafael J. Wysocki) - Check ignore_hotplug for all downstream devices (Rafael J. Wysocki) - Propagate the "ignore hotplug" setting to parent (Rafael J. Wysocki) - Inline pciehp "handle event" functions into the ISR (Bjorn Helgaas) - Clean up pciehp debug logging (Bjorn Helgaas) Power management - Remove redundant PCIe port type checking (Yijing Wang) - Add dev->has_secondary_link to track downstream PCIe links (Yijing Wang) - Use dev->has_secondary_link to find downstream links for ASPM (Yijing Wang) - Drop __pci_disable_link_state() useless "force" parameter (Bjorn Helgaas) - Simplify Clock Power Management setting (Bjorn Helgaas) Virtualization - Add ACS quirks for Intel 9-series PCH root ports (Alex Williamson) - Add function 1 DMA alias quirk for Marvell 9120 (Sakari Ailus) MSI - Disable MSI at enumeration even if kernel doesn't support MSI (Michael S. Tsirkin) - Remove unused pci_msi_off() (Bjorn Helgaas) - Rename msi_set_enable(), msix_clear_and_set_ctrl() (Michael S. Tsirkin) - Export pci_msi_set_enable(), pci_msix_clear_and_set_ctrl() (Michael S. Tsirkin) - Drop pci_msi_off() calls during probe (Michael S. Tsirkin) APM X-Gene host bridge driver - Add APM X-Gene v1 PCIe MSI/MSIX termination driver (Duc Dang) - Add APM X-Gene PCIe MSI DTS nodes (Duc Dang) - Disable Configuration Request Retry Status for v1 silicon (Duc Dang) - Allow config access to Root Port even when link is down (Duc Dang) Broadcom iProc host bridge driver - Allow override of device tree IRQ mapping function (Hauke Mehrtens) - Add BCMA PCIe driver (Hauke Mehrtens) - Directly add PCI resources (Hauke Mehrtens) - Free resource list after registration (Hauke Mehrtens) Freescale i.MX6 host bridge driver - Add speed change timeout message (Troy Kisky) - Rename imx6_pcie_start_link() to imx6_pcie_establish_link() (Bjorn Helgaas) Freescale Layerscape host bridge driver - Use dw_pcie_link_up() consistently (Bjorn Helgaas) - Factor out ls_pcie_establish_link() (Bjorn Helgaas) Marvell MVEBU host bridge driver - Remove mvebu_pcie_scan_bus() (Yijing Wang) NVIDIA Tegra host bridge driver - Remove tegra_pcie_scan_bus() (Yijing Wang) Synopsys DesignWare host bridge driver - Consolidate outbound iATU programming functions (Jisheng Zhang) - Use iATU0 for cfg and IO, iATU1 for MEM (Jisheng Zhang) - Add support for x8 links (Zhou Wang) - Wait for link to come up with consistent style (Bjorn Helgaas) - Use pci_scan_root_bus() for simplicity (Yijing Wang) TI DRA7xx host bridge driver - Use dw_pcie_link_up() consistently (Bjorn Helgaas) Miscellaneous - Include <linux/pci.h>, not <asm/pci.h> (Bjorn Helgaas) - Remove unnecessary #includes of <asm/pci.h> (Bjorn Helgaas) - Remove unused pcibios_select_root() (again) (Bjorn Helgaas) - Remove unused pci_dma_burst_advice() (Bjorn Helgaas) - xen/pcifront: Don't use deprecated function pci_scan_bus_parented() (Arnd Bergmann)" * tag 'pci-v4.2-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (58 commits) PCI: pciehp: Inline the "handle event" functions into the ISR PCI: pciehp: Rename queue_interrupt_event() to pciehp_queue_interrupt_event() PCI: pciehp: Make queue_interrupt_event() void PCI: xgene: Allow config access to Root Port even when link is down PCI: xgene: Disable Configuration Request Retry Status for v1 silicon PCI: pciehp: Clean up debug logging x86/PCI: Use host bridge _CRS info on systems with >32 bit addressing PCI: imx6: Add #define PCIE_RC_LCSR PCI: imx6: Use "u32", not "uint32_t" PCI: Remove unused pci_scan_bus_parented() xen/pcifront: Don't use deprecated function pci_scan_bus_parented() PCI: imx6: Add speed change timeout message PCI/ASPM: Simplify Clock Power Management setting PCI: designware: Wait for link to come up with consistent style PCI: layerscape: Factor out ls_pcie_establish_link() PCI: layerscape: Use dw_pcie_link_up() consistently PCI: dra7xx: Use dw_pcie_link_up() consistently x86/PCI: Use host bridge _CRS info on Foxconn K8M890-8237A PCI: pciehp: Wait for hotplug command completion where necessary PCI: Remove unused pci_dma_burst_advice() ...
2015-06-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes are: - lockless wakeup support for futexes and IPC message queues (Davidlohr Bueso, Peter Zijlstra) - Replace spinlocks with atomics in thread_group_cputimer(), to improve scalability (Jason Low) - NUMA balancing improvements (Rik van Riel) - SCHED_DEADLINE improvements (Wanpeng Li) - clean up and reorganize preemption helpers (Frederic Weisbecker) - decouple page fault disabling machinery from the preemption counter, to improve debuggability and robustness (David Hildenbrand) - SCHED_DEADLINE documentation updates (Luca Abeni) - topology CPU masks cleanups (Bartosz Golaszewski) - /proc/sched_debug improvements (Srikar Dronamraju)" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) sched/deadline: Remove needless parameter in dl_runtime_exceeded() sched: Remove superfluous resetting of the p->dl_throttled flag sched/deadline: Drop duplicate init_sched_dl_class() declaration sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target sched/deadline: Make init_sched_dl_class() __init sched/deadline: Optimize pull_dl_task() sched/preempt: Add static_key() to preempt_notifiers sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration sched/stop_machine: Fix deadlock between multiple stop_two_cpus() sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched sched/debug: Replace vruntime with wait_sum in /proc/sched_debug sched/debug: Properly format runnable tasks in /proc/sched_debug sched/numa: Only consider less busy nodes as numa balancing destinations Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced") sched/fair: Prevent throttling in early pick_next_task_fair() preempt: Reorganize the notrace definitions a bit preempt: Use preempt_schedule_context() as the official tracing preemption point sched: Make preempt_schedule_context() function-tracing safe x86: Remove cpu_sibling_mask() and cpu_core_mask() x86: Replace cpu_**_mask() with topology_**_cpumask() ...
2015-06-22Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The main changes are: - 'qspinlock' support, enabled on x86: queued spinlocks - these are now the spinlock variant used by x86 as they outperform ticket spinlocks in every category. (Waiman Long) - 'pvqspinlock' support on x86: paravirtualized variant of queued spinlocks. (Waiman Long, Peter Zijlstra) - 'qrwlock' support, enabled on x86: queued rwlocks. Similar to queued spinlocks, they are now the variant used by x86: CONFIG_ARCH_USE_QUEUED_SPINLOCKS=y CONFIG_QUEUED_SPINLOCKS=y CONFIG_ARCH_USE_QUEUED_RWLOCKS=y CONFIG_QUEUED_RWLOCKS=y - various lockdep fixlets - various locking primitives cleanups, further WRITE_ONCE() propagation" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) locking/lockdep: Remove hard coded array size dependency locking/qrwlock: Don't contend with readers when setting _QW_WAITING lockdep: Do not break user-visible string locking/arch: Rename set_mb() to smp_store_mb() locking/arch: Add WRITE_ONCE() to set_mb() rtmutex: Warn if trylock is called from hard/softirq context arch: Remove __ARCH_HAVE_CMPXCHG locking/rtmutex: Drop usage of __HAVE_ARCH_CMPXCHG locking/qrwlock: Rename QUEUE_RWLOCK to QUEUED_RWLOCKS locking/pvqspinlock: Rename QUEUED_SPINLOCK to QUEUED_SPINLOCKS locking/pvqspinlock: Replace xchg() by the more descriptive set_mb() locking/pvqspinlock, x86: Enable PV qspinlock for Xen locking/pvqspinlock, x86: Enable PV qspinlock for KVM locking/pvqspinlock, x86: Implement the paravirt qspinlock call patching locking/pvqspinlock: Implement simple paravirt support for the qspinlock locking/qspinlock: Revert to test-and-set on hypervisors locking/qspinlock: Use a simple write to grab the lock locking/qspinlock: Optimize for smaller NR_CPUS locking/qspinlock: Extract out code snippets for the next patch locking/qspinlock: Add pending bit ...
2015-06-08Merge 4.1-rc7 into tty-nextGreg Kroah-Hartman
This fixes up a merge issue with the amba-pl011.c driver, and we want the fixes in this branch as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-08PCI: Remove unused pci_dma_burst_advice()Bjorn Helgaas
pci_dma_burst_advice() was added by e24c2d963a60 ("[PATCH] PCI: DMA bursting advice") but apparently never used. Remove it. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Michal Simek <monstr@monstr.eu> # microblaze CC: David S. Miller <davem@davemloft.net>
2015-06-08PCI: Remove unnecessary #includes of <asm/pci.h>Bjorn Helgaas
In include/linux/pci.h, we already #include <asm/pci.h>, so we don't need to include <asm/pci.h> directly. Remove the unnecessary includes. All the files here already include <linux/pci.h>. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> # sh Acked-by: Ralf Baechle <ralf@linux-mips.org>
2015-06-02Merge branch 'linus' into sched/core, to resolve conflictIngo Molnar
Conflicts: arch/sparc/include/asm/topology_64.h Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-26alpha: kernel: osf_sys: Set 'kts.tv_nsec' only when 'tv' has effectChen Gang
The related warning: CC init/do_mounts.o arch/alpha/kernel/osf_sys.c: In function 'SyS_osf_settimeofday': arch/alpha/kernel/osf_sys.c:1028:14: warning: 'kts.tv_nsec' may be used uninitialized in this function [-Wmaybe-uninitialized] kts.tv_nsec *= 1000; ^ arch/alpha/kernel/osf_sys.c:1016:18: note: 'kts' was declared here struct timespec kts; ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-26alpha: Wire up all missing implemented syscallsChen Gang
And still left the missing unimplemented syscalls as warnings. The related warnings for missing implemented syscalls: CALL scripts/checksyscalls.sh <stdin>:1241:2: warning: #warning syscall getrandom not implemented [-Wcpp] <stdin>:1244:2: warning: #warning syscall memfd_create not implemented [-Wcpp] <stdin>:1250:2: warning: #warning syscall execveat not implemented [-Wcpp] Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-26alpha: Fix bootpfile and bootpzfile make targetsHelge Deller
Fix the bootpfile and bootpzfile make targets to creat BOOTP images. Both targets were broken due to some missing defines to re-map ELF constants. In addition the old code used the generic vsprintf function of the kernel which we now replace by a simple and much smaller implementation for the bootloader. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-26alpha: copy_thread(): rename 'arg' argument to 'kthread_arg'Alex Dowad
The 'arg' argument to copy_thread() is only ever used when forking a new kernel thread. Hence, rename it to 'kthread_arg' for clarity (and consistency with do_fork() and other arch-specific implementations of copy_thread()). Signed-off-by: Alex Dowad <alexinbeijing@gmail.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-26alpha: delete non-required instances of <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Acked-by: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: linux-alpha@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-26alpha: don't use module_init for non-modular core codePaul Gortmaker
The srm console is always built in. It will never be modular, so using module_init as an alias for __initcall is rather misleading. Fix this up now, so that we can relocate module_init from init.h into module.h in the future. If we don't do this, we'd have to add module.h to obviously non-modular code, and that would be a worse thing. Direct use of __initcall is discouraged, vs prioritized ones. Use of device_initcall is consistent with what __initcall maps onto, and hence does not change the init order, making the impact of this change zero. Should someone with real hardware for boot testing want to change it later to arch_initcall or console_initcall, they can do that at a later date. Reviewed-by: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Matt Turner <mattst88@gmail.com> Cc: linux-alpha@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-26smp, alpha: kill SMP single function call interruptJiang Liu
Commit 9a46ad6d6df3b54 "smp: make smp_call_function_many() use logic similar to smp_call_function_single()" has unified the way to handle single and multiple cross-CPU function calls. Now only one interrupt is needed for architecture specific code to support generic SMP function call interfaces, so kill the redundant single function call interrupt. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Shaohua Li <shli@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Kosina <trivial@kernel.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Matt Turner <mattst88@gmail.com> Cc: linux-alpha@vger.kernel.org Signed-off-by: Jiang Liu <liuj97@gmail.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-26alpha: Remove #include <uapi/asm/types.h> from <asm/types.h>Geert Uytterhoeven
Everything in arch/alpha/include/uapi/asm/types.h is protected by "#ifndef __KERNEL__", so it's unused for kernelspace. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Matt Turner <mattst88@gmail.com> Cc: linux-alpha@vger.kernel.org Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-26alpha: clean up unnecessary MSI/MSI-X capability findYijing Wang
PCI core will initialize device MSI/MSI-X capability in pci_msi_init_pci_dev(). So device driver should use pci_dev->msi_cap/msix_cap to determine whether the device support MSI/MSI-X instead of using pci_find_capability(pci_dev, PCI_CAP_ID_MSI/MSIX). Access to PCIe device config space again will consume more time. Signed-off-by: Yijing Wang <wangyijing@huawei.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Matt Turner <mattst88@gmail.com> Cc: Phil Carmody <pc+lkml@asdf.org> Cc: linux-alpha@vger.kernel.org Signed-off-by: Matt Turner <mattst88@gmail.com>
2015-05-19remove scatterlist.h generation from arch Kbuild filesChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jens Axboe <axboe@fb.com>
