path: root/arch/alpha
2011-01-21alpha: Use generic irq KconfigThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net>
2011-01-21genirq: Remove __do_IRQThomas Gleixner
All architectures are finally converted. Remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Michal Simek <monstr@monstr.eu> Acked-by: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com>
2011-01-17alpha: fix WARN_ON in __local_bh_enable()Ivan Kokshaysky
Interrupts ought to be disabled _before_ irq_enter(). Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Matt Turner <mattst88@monolith.freenet-rz.de>
2011-01-17alpha: fix breakage caused by df9ee29270Ivan Kokshaysky
Commit df9ee29270 made arch_local_irq_save and arch_local_irq_restore static inline which with -Werror trips up on __set_hae() and _set_hae() which are extern inline. The naive solution is to make __set_hae() and set_hae() static inline but for reasons described in commit d559d4a24a3fe this breaks the generic kernel build. Instead, since this is architecture specific code, this patch hard wires in the architecture specific method f disabling and enabling interrupts. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: add GENERIC_HARDIRQS_NO__DO_IRQ to KconfigMatt Turner
Acked-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha/osf_sys: remove unused MAX_SELECT_SECONDSNamhyung Kim
Remove the leftover from the commit 14e2acd86865 ("select: fix alpha OSF wrapper"). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: change to new Makefile flag variablesmatt mooney
Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: kill off alpha_do_IRQKyle McMartin
Good riddance... Nuke a pile of redundant handlers that the generic code takes care of as well. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: irq clean upKyle McMartin
Stop touching irq_desc[irq] directly, instead use accessor functions provided. Use irq_has_action instead of directly testing the irq_desc. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-17alpha: use set_irq_chip and push down __do_IRQ to the machine typesKyle McMartin
Also kill superfluous IRQ_DISABLED initialization, since that's the default state of the irq_desc[i].status field. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-01-13thp: mm: define MADV_NOHUGEPAGEAndrea Arcangeli
Define MADV_NOHUGEPAGE. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: mm: define MADV_HUGEPAGEAndrea Arcangeli
Define MADV_HUGEPAGE. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13set_rtc_mmss: show warning message only onceStephen Hemminger
Occasionally the system gets into a state where the CMOS clock has gotten slightly ahead of current time and the periodic update of RTC fails. The message is a nuisance and repeats spamming the log. See: http://www.ntp.org/ntpfaq/NTP-s-trbl-spec.htm#Q-LINUX-SET-RTC-MMSS Rather than just removing the message, make it show only once and reduce severity since it indicates a normal and non urgent condition. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) serial: apbuart: Fixup apbuart_console_init() TTY: Add tty ioctl to figure device node of the system console. tty: add 'active' sysfs attribute to tty0 and console device drivers: serial: apbuart: Handle OF failures gracefully Serial: Avoid unbalanced IRQ wake disable during resume tty: fix typos/errors in tty_driver.h comments pch_uart : fix warnings for 64bit compile 8250: fix uninitialized FIFOs ip2: fix compiler warning on ip2main_pci_tbl specialix: fix compiler warning on specialix_pci_tbl rocket: fix compiler warning on rocket_pci_ids 8250: add a UPIO_DWAPB32 for 32 bit accesses 8250: use container_of() instead of casting serial: omap-serial: Add support for kernel debugger serial: fix pch_uart kconfig & build drivers: char: hvc: add arm JTAG DCC console support RS485 documentation: add 16C950 UART description serial: ifx6x60: fix memory leak serial: ifx6x60: free IRQ on error Serial: EG20T: add PCH_UART driver ... Fixed up conflicts in drivers/serial/apbuart.c with evil merge that makes the code look fairly sane (unlike either side).
2010-12-16TTY: Add tty ioctl to figure device node of the system console.Werner Fink
This has been in the SuSE kernels for a very long time. Signed-off-by: Werner Fink <werner@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-16perf: Dynamic pmu typesPeter Zijlstra
Extend the perf_pmu_register() interface to allow for named and dynamic pmu types. Because we need to support the existing static types we cannot use dynamic types for everything, hence provide a type argument. If we want to enumerate the PMUs they need a name, provide one. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101117222056.259707703@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-26perf, arch: Cleanup perf-pmu init vs lockup-detectorPeter Zijlstra
The perf hardware pmu got initialized at various points in the boot, some before early_initcall() some after (notably arch_initcall). The problem is that the NMI lockup detector is ran from early_initcall() and expects the hardware pmu to be present. Sanitize this by moving all architecture hardware pmu implementations to initialize at early_initcall() and move the lockup detector to an explicit initcall right after that. Cc: paulus <paulus@samba.org> Cc: davem <davem@davemloft.net> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290707759.2145.119.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-27alpha: remove dma64_addr_t usageFUJITA Tomonori
dma_addr_t is always 64 bit on alpha. So let's use dma_addr_t instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26alpha: use single HAE window on T2 core logic (gamma, sable)Ivan Kokshaysky
T2 are the only alpha SMP systems that do HAE switching at runtime, which is fundamentally racy on SMP. This patch limits MMIO space on T2 to HAE0 only, like we did on MCPCIA (rawhide) long ago. This leaves us with only 112 Mb of PCI MMIO (128 Mb HAE aperture minus 16 Mb reserved for EISA), but since linux PCI allocations are reasonably tight, it should be enough for sane hardware configurations. Also, fix a typo in MCPCIA_FROB_MMIO macro which shouldn't call set_hae() if MCPCIA_ONE_HAE_WINDOW is defined. It's more for correctness, as set_hae() is a no-op anyway in that case. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26alpha: enable ARCH_DMA_ADDR_T_64BITFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflagsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags: Fix IRQ flag handling naming MIPS: Add missing #inclusions of <linux/irq.h> smc91x: Add missing #inclusion of <linux/irq.h> Drop a couple of unnecessary asm/system.h inclusions SH: Add missing consts to sys_execve() declaration Blackfin: Rename IRQ flags handling functions Blackfin: Add missing dep to asm/irqflags.h Blackfin: Rename DES PC2() symbol to avoid collision Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header Blackfin: Split PLL code from mach-specific cdef headers
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-12Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
We need to revert the temporary hack in 71ebc01, hence the merge.
2010-10-08Merge commit 'v2.6.36-rc7' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/module.c Merge reason: Resolve the conflict, pick up fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2010-09-30Fix up more fallout form alpha signal cleanupsLinus Torvalds
Commit c52c2ddc1dfa ("alpha: switch osf_sigprocmask() to use of sigprocmask()") had several problems. The more obvious compile issues got fixed in commit 0f44fbd297e1 ("alpha: fix compile problem in arch/alpha/kernel/signal.c"), but it also caused a regression. Since _BLOCKABLE is already the set of signals that can be blocked, the code should do "newmask & _BLOCKABLE" rather than inverting _BLOCKABLE before masking. Reported-by: Michael Cree <mcree@orcon.net.nz> Patch-by: Al Viro <viro@zeniv.linux.org.uk> Patch-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-28alpha: fix compile problem in arch/alpha/kernel/signal.cLinus Torvalds
Tssk. Apparently Al hadn't checked commit c52c2ddc1dfa ("alpha: switch osf_sigprocmask() to use of sigprocmask()") at all. It doesn't compile. Fixed as per suggestions from Michael Cree. Reported-by: Michael Cree <mcree@orcon.net.nz> Cc: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-27alpha: __get_user/__put_user results need to be checked...Al Viro
2010-09-27alpha: switch osf_sigprocmask() to use of sigprocmask()Al Viro
get rid of a useless wrapper, while we are at it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-25alpha: fix usp value in multithreaded coredumpsAl Viro
rdusp() gives us the right value only for the current thread... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-25alpha: fix hae_cache race in RESTORE_ALLAl Viro
We want interrupts disabled on all paths leading to RESTORE_ALL; otherwise, we are risking an IRQ coming between the updates of alpha_mv->hae_cache and *alpha_mv->hae_register and set_hae() within the IRQ getting badly confused. RESTORE_ALL used to play with disabling IRQ itself, but that got removed back in 2002, without making sure we had them disabled on all paths. It's cheaper to make sure we have them disabled than to revert to original variant... Remove the detritus left from that commit back in 2002; we used to need a reload of $0 and $1 since swpipl would change those, but doing that had become pointless when we stopped doing swpipl in there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-21Merge commit 'v2.6.36-rc5' into perf/coreIngo Molnar
Merge reason: Pick up the latest fixes in -rc5. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-19kbuild: migrate all arch to the kconfig mainmenu upgradeArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-09-18alpha: deal with multiple simultaneously pending signalsAl Viro
Unlike the other targets, alpha sets _one_ sigframe and buggers off until the next syscall/interrupt, even if more signals are pending. It leads to quite a few unpleasant inconsistencies, starting with SIGSEGV potentially arriving not where it should and including e.g. mess with sigsuspend(); consider two pending signals blocked until sigsuspend() unblocks them. We pick the first one; then, if we are hit by interrupt while in the handler, we process the second one as well. If we are not, and if no syscalls had been made, we get out of the first handler and leave the second signal pending; normally sigreturn() would've picked it anyway, but here it starts with restoring the original mask and voila - the second signal is blocked again. On everything else we get both delivered consistently. It's actually easy to fix; the only thing to watch out for is prevention of double syscall restart. Fortunately, the idea I've nicked from arm fix by rmk works just fine... Testcase demonstrating the behaviour in question; on alpha we get one or both flags set (usually one), on everything else both are always set. #include <signal.h> #include <stdio.h> int had1, had2; void f1(int sig) { had1 = 1; } void f2(int sig) { had2 = 1; } main() { sigset_t set1, set2; sigemptyset(&set1); sigemptyset(&set2); sigaddset(&set2, 1); sigaddset(&set2, 2); signal(1, f1); signal(2, f2); sigprocmask(SIG_SETMASK, &set2, NULL); raise(1); raise(2); sigsuspend(&set1); printf("had1:%d had2:%d\n", had1, had2); } Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: fix a 14 years old bug in sigreturn tracingAl Viro
The way sigreturn() is implemented on alpha breaks PTRACE_SYSCALL, all way back to 1.3.95 when alpha has grown PTRACE_SYSCALL support. What happens is direct return to ret_from_syscall, in order to bypass mangling of a3 (error indicator) and prevent other mutilations of registers (e.g. by syscall restart). That's fine, but... the entire TIF_SYSCALL_TRACE codepath is kept separate on alpha and post-syscall stopping/notifying the tracer is after the syscall. And the normal path we are forcibly switching to doesn't have it. So we end up with *one* stop in traced sigreturn() vs. two in other syscalls. And yes, strace is visibly broken by that; try to strace the following #include <signal.h> #include <stdio.h> void f(int sig) {} main() { signal(SIGHUP, f); raise(SIGHUP); write(1, "eeeek\n", 6); } and watch the show. The close(1) = 405 in the end of strace output is coming from return value of write() (6 == __NR_close on alpha) and syscall number of exit_group() (__NR_exit_group == 405 there). The fix is fairly simple - the only thing we end up missing is the call of syscall_trace() and we can tell whether we'd been called from the SYSCALL_TRACE path by checking ra value. Since we are setting the switch_stack up (that's what sys_sigreturn() does), we have the right environment for calling syscall_trace() - just before we call undo_switch_stack() and return. Since undo_switch_stack() will overwrite s0 anyway, we can use it to store the result of "has it been called from SYSCALL_TRACE path?" check. The same thing applies in rt_sigreturn(). Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: unb0rk sigsuspend() and rt_sigsuspend()Al Viro
Old code used to set regs->r0 and regs->r19 to force the right return value. Leaving that after switch to ERESTARTNOHAND was a Bad Idea(tm), since now that screws the restart - if we hit the case when get_signal_to_deliver() returns 0, we will step back to syscall insn, with v0 set to EINTR and a3 to 1. The latter won't matter, since EINTR is 4, aka __NR_write. Testcase: #include <signal.h> #define _GNU_SOURCE #include <unistd.h> #include <sys/syscall.h> main() { sigset_t mask; sigemptyset(&mask); sigaddset(&mask, SIGCONT); sigprocmask(SIG_SETMASK, &mask, NULL); kill(0, SIGCONT); syscall(__NR_sigsuspend, 1, "b0rken\n", 7); } results on alpha in immediate message to stdout... Fix is obvious; moreover, since we don't need regs anymore, we can switch to normal prototypes for these guys and lose the wrappers. Even better, rt_sigsuspend() is identical to generic version in kernel/signal.c now. Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: belated ERESTART_RESTARTBLOCK race fixAl Viro
same thing as had been done on other targets back in 2003 - move setting ->restart_block.fn into {rt_,}sigreturn(). Tested-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: Shift perf event pending work earlier in timer interruptMichael Cree
Pending work from the performance event subsystem is executed in the timer interrupt. This patch shifts the call to perf_event_do_pending() before the call to update_process_times() as the latter may call back into the perf event subsystem and it is prudent to have the pending work executed first. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: wire up fanotify and prlimit64 syscallsMikael Pettersson
The 2.6.36-rc kernel added three new system calls: fanotify_init, fanotify_mark, and prlimit64. This patch wires them up on Alpha. Built and booted on an XP900. Untested beyond that. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: kill big kernel lockArnd Bergmann
All uses of the BKL on alpha are totally bogus, nothing is really protected by this. Remove the remaining users so we don't have to mark alpha as 'depends on BKL'. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: linux-alpha@vger.kernel.org Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: fix build breakage in asm/cacheflush.hTejun Heo
Alpha SMP flush_icache_user_range() is implemented as an inline function inside include/asm/cacheflush.h. It dereferences @current but doesn't include linux/sched.h and thus causes build failure if linux/sched.h wasn't included previously. Fix it by including the needed header file explicitly. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: remove unnecessary cast from void* in assignment.matt mooney
Acked-by: Jan-Benedict Glaw <jbglaw@lug-owl.de> Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-18alpha: Use static const char * const where possibleJoe Perches
Acked-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-15alpha: Fix HW performance counters to be stopped properlyMichael Cree
Also fix a few compile errors due to undefined and duplicated variables. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1284269844-23251-1-git-send-email-mcree@orcon.net.nz> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-15Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2010-09-09perf: Remove the sysfs bitsPeter Zijlstra
Neither the overcommit nor the reservation sysfs parameter were actually working, remove them as they'll only get in the way. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus <paulus@samba.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-09perf: Rework the PMU methodsPeter Zijlstra
Replace pmu::{enable,disable,start,stop,unthrottle} with pmu::{add,del,start,stop}, all of which take a flags argument. The new interface extends the capability to stop a counter while keeping it scheduled on the PMU. We replace the throttled state with the generic stopped state. This also allows us to efficiently stop/start counters over certain code paths (like IRQ handlers). It also allows scheduling a counter without it starting, allowing for a generic frozen state (useful for rotating stopped counters). The stopped state is implemented in two different ways, depending on how the architecture implemented the throttled state: 1) We disable the counter: a) the pmu has per-counter enable bits, we flip that b) we program a NOP event, preserving the counter state 2) We store the counter state and ignore all read/overflow events Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus <paulus@samba.org> Cc: stephane eranian <eranian@googlemail.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Yanmin <yanmin_zhang@linux.intel.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Michael Cree <mcree@orcon.net.nz> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
