git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
Removal of these started in 2.3.43pre3, ca. 10 years ago.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
This implements hardware performance events for the EV67 and later CPUs
within the Linux performance events subsystem. Only using the performance
monitoring unit in HP/Compaq's so called "Aggregrate mode" is supported.
The code has been implemented in a manner that makes extension to other
older Alpha CPUs relatively straightforward should some mug wish to
indulge themselves.
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Jay Estabrook <jay.estabrook@hp.com>
The following patches implement hardware performance events for the Alpha
EV67 and later CPUs. I have had this running on a Compaq XP1000 (EV67,
single CPU) for a few days now. Pretty cool -- discovered that the glibc
exp2() library routine uses on average 985 cycles to execute 777 CPU
instructions whereas Compaq's CPML library version of exp2() uses on
average 32 cycles to execute 47 CPU instructions to achieve the same
thing!
This patch:
Add performance monitor interrupt counternd and export the count to user
space via /proc/interrupts.
We'll need the path to implement the flags field for statvfs support.
We do have it available in all callers except:
- ecryptfs_statfs. This one doesn't actually need vfs_statfs but just
needs to do a caller to the lower filesystem statfs method.
- sys_ustat. Add a non-exported statfs_by_dentry helper for it which
doesn't won't be able to fill out the flags field later on.
In addition rename the helpers for statfs vs fstatfs to do_*statfs instead
of the misleading vfs prefix.
Architectures don't need to define ISA_DMA_THRESHOLD anymore.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: James Bottomley <James.Bottomley@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
* 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
um: Fix read_persistent_clock fallout
kgdb: Do not access xtime directly
powerpc: Clean up obsolete code relating to decrementer and timebase
powerpc: Rework VDSO gettimeofday to prevent time going backwards
clocksource: Add __clocksource_updatefreq_hz/khz methods
x86: Convert common clocksources to use clocksource_register_hz/khz
timekeeping: Make xtime and wall_to_monotonic static
hrtimer: Cleanup direct access to wall_to_monotonic
um: Convert to use read_persistent_clock
timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset
powerpc: Cleanup xtime usage
powerpc: Simplify update_vsyscall
time: Kill off CONFIG_GENERIC_TIME
time: Implement timespec_add
x86: Fix vtime/file timestamp inconsistencies
Trivial conflicts in Documentation/feature-removal-schedule.txt
Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as
per Thomas' earlier merge commit 47916be4e28c ("Merge branch
'powerpc.cherry-picks' into timers/clocksource")
Now that all arches have been converted over to use generic time via
clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME
config option and simplify the generic code.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com>
Reason: Further changes conflict with upstream fixes
This patch probes for the Super IO chip and reserves the IO range when
found. It avoids enabling the IDE interface on the Avanti family, since
none has IDE. It enables the Enhanced Parallel Port v1.9 feature.
Signed-off-by: Morten H. Larsen <m-larsen@post6.tele.dk>
Signed-off-by: Matt Turner <mattst88@gmail.com>
Caused by 2c3c8bea608866d8bd9dcf92657d57fdcac011c5 which was clearly not
even compile tested.
Typo in 1527bc8b928dd1399c3d3467dd47d9ede210978a renamed hweight32 to
__arch_weight32.
On 64bit, local_t is of size long, and thus we make local64_t an alias.
On 32bit, we fall back to atomic64_t. (architecture can provide optimized
32-bit version)
(This new facility is to be used by perf events optimizations.)
LKML-Reference: <new-submission>
There are more architectures that don't support ARCH_HAS_SG_CHAIN than
those that support it. This removes removes ARCH_HAS_SG_CHAIN in
asm-generic/scatterlist.h and lets arhictectures to define it.
It's clearer than defining ARCH_HAS_SG_CHAIN asm-generic/scatterlist.h and
undefing it in arhictectures that don't support it.
Acked-by: Matt Turner <mattst88@gmail.com>
This reverts commit b3b77c8caef1750ebeea1054e39e358550ea9f55, which was
also totally broken (see commit 0d2daf5cc858 that reverted the crc32
version of it). As reported by Stephen Rothwell, it causes problems on
big-endian machines:
> In file included from fs/jfs/jfs_types.h:33,
> from fs/jfs/jfs_incore.h:26,
> from fs/jfs/file.c:22:
> fs/jfs/endian24.h:36:101: warning: "__LITTLE_ENDIAN" is not defined
The kernel has never had that crazy "__BYTE_ORDER == __LITTLE_ENDIAN"
model. It's not how we do things, and it isn't how we _should_ do
things. So don't go there.
Requested-by: Stephen Rothwell <sfr@canb.auug.org.au>
Search only the first 100 bits instead of 140, saving a couple
instructions. The resulting code is about 1/3 faster (40K ticks/1000
iterations down to 30K ticks/1000 iterations).
Cc: linux-alpha@vger.kernel.org
Acked-by: Richard Henderson <rth@twiddle.net>
As explained in commit 1c0fe6e3bd, we want to call the architecture
independent oom killer when getting an unexplained OOM from
handle_mm_fault, rather than simply killing current.
[mattst88: kill now unused 'survive' label]
Acked-by: David Rientjes <rientjes@google.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Alpha has a tsc like rpcc counter that it uses to manage time.
This can be converted to an actual clocksource instead of utilizing
the arch_gettimeoffset method that is really only there for legacy
systems with no continuous counter.
Further cleanups could be made if alpha converted to the clockevent
model.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Richard Henderson <rth@twiddle.net>
Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Tested-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Linux does not define __BYTE_ORDER in its endian header files which makes
some header files bend backwards to get at the current endian. Lets
#define __BYTE_ORDER in big_endian.h/litte_endian.h to make it easier for
header files that are used in user space too.
In userspace the convention is that
1. _both_ __LITTLE_ENDIAN and __BIG_ENDIAN are defined,
2. you have to test for e.g. __BYTE_ORDER == __BIG_ENDIAN.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
* 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
avr32: Fix typo in read_persistent_clock()
sparc: Convert sparc to use read/update_persistent_clock
cris: Convert cris to use read/update_persistent_clock
m68k: Convert m68k to use read/update_persistent_clock
m32r: Convert m32r to use read/update_peristent_clock
blackfin: Convert blackfin to use read/update_persistent_clock
ia64: Convert ia64 to use read/update_persistent_clock
avr32: Convert avr32 to use read/update_persistent_clock
h8300: Convert h8300 to use read/update_persistent_clock
frv: Convert frv to use read/update_persistent_clock
mn10300: Convert mn10300 to use read/update_persistent_clock
alpha: Convert alpha to use read/update_persistent_clock
xtensa: Fix unnecessary setting of xtime
time: Clean up direct xtime usage in xen
* 'core-hweight-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, hweight: Use a 32-bit popcnt for __arch_hweight32()
arch, hweight: Fix compilation errors
x86: Add optimized popcnt variants
bitops: Optimize hweight() by making use of compile-time evaluation
In preparation for removing volatile from the atomic_t definition, this
patch adds a volatile cast to all the atomic read functions.
Signed-off-by: Andreas Dilger <adilger@dilger.ca>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Rename the extisting runtime hweight() implementations to
__arch_hweight(), rename the compile-time versions to __const_hweight()
and then have hweight() pick between them.
Suggested-by: H. Peter Anvin <hpa@zytor.com>
LKML-Reference: <20100318111929.GB11152@aftab>
Acked-by: H. Peter Anvin <hpa@zytor.com>
LKML-Reference: <1265028224.24455.154.camel@laptop>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The commit c186caca3dbe7f44da624cb4f9d78e1b1dfb13b8 leads to the
following errors with CONFIG_ALPHA_{TSUNAMI, TITAN, RAWHIDE, MARVEL}:
/home/fujita/git/linux-2.6/include/asm-generic/dma-mapping-common.h: In
function `dma_map_sg_attrs':
/home/fujita/git/linux-2.6/include/asm-generic/dma-mapping-common.h:49:
error: implicit declaration of function `for_each_sg'
/home/fujita/git/linux-2.6/include/asm-generic/dma-mapping-common.h:50:
error: syntax error before "kmemcheck_mark_initialized"
Reported-by: Michael Cree <mcree@orcon.net.nz>
Signed-off-by: Frans Pop <elendil@planet.nl>
Replace open-coded rate limiting logic with __ratelimit().
This patch converts the alpha architecture to use the generic
read_persistent_clock and update_persistent_clock interfaces, reducing
the amount of arch specific code we have to maintain, and allowing for
further cleanups in the future.
I have not built or tested this patch, so help from arch maintainers
would be appreciated.
LKML-Reference: <1267675049-12337-2-git-send-email-johnstul@us.ibm.com>
This converts Alpha to use include/linux/pci-dma-compat.h. Alpha is the
only architecutre that implements the PCI DMA API in the own way. That
makes it difficult to implement the generic DMA API via the PCI bus
specific DMA API.
The generic DMA API calls the PCI DMA API implementation in
arch/alpha/kernel/pci_iommu.c on non Jensen systems. It calls the DMA API
in arch/alpha/kernel/pci-noop.c on Jensen systems.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Greg KH <greg@kroah.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
All the architectures properly set NEED_DMA_MAP_STATE now so we can safely
add linux/pci-dma.h to linux/pci.h and remove the linux/pci-dma.h
inclusion in arch's asm/pci.h
dma_sync_single_for_cpu/for_device supports a partial sync so there is no
point to have dma_sync_single_range (also dma_sync_single was obsoleted
long ago, replaced with dma_sync_single_for_cpu/for_device).
There is no user of dma_sync_single_range() in mainline and only Alpha
architecture supports dma_sync_single_range(). So it's unlikely that
someone out of the tree uses it.
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT,
PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining
arch_has_single_step in <asm/ptrace.h> and implementing the
user_enable_single_step and user_disable_single_step functions, which also
causes the breakpoint information to be cleared on fork, which could be
considered a bug fix.
Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which
it previously wasn't, which is consistent with all architectures using the
modern ptrace code.
Cc: Roland McGrath <roland@redhat.com>
The initial -EINVAL value is overwritten by `retval = PTR_ERR(name)'. If
this isn't an error pointer and typenr is not 1, 6 or 9, then this retval,
a pointer cast to a long, is returned.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: add __percpu sparse annotations to what's left
percpu: add __percpu sparse annotations to fs
percpu: add __percpu sparse annotations to core kernel subsystems
local_t: Remove leftover local.h
this_cpu: Remove pageset_notifier
this_cpu: Page allocator conversion
percpu, x86: Generic inc / dec percpu instructions
local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c
module: Use this_cpu_xx to dynamically allocate counters
local_t: Remove cpu_local_xx macros
percpu: refactor the code in pcpu_[de]populate_chunk()
percpu: remove compile warnings caused by __verify_pcpu_ptr()
percpu: make accessors check for percpu pointer in sparse
percpu: add __percpu for sparse.
percpu: make access macros universal
percpu: remove per_cpu__ prefix.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits)
ARM: Eliminate decompressor -Dstatic= PIC hack
ARM: 5958/1: ARM: U300: fix inverted clk round rate
ARM: 5956/1: misplaced parentheses
ARM: 5955/1: ep93xx: move timer defines into core.c and document
ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c
ARM: 5953/1: ep93xx: fix broken build of clock.c
ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig
ARM: 5949/1: NUC900 add gpio virtual memory map
ARM: 5948/1: Enable timer0 to time4 clock support for nuc910
ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk
ARM: make_coherent(): fix problems with highpte, part 2
MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself
ARM: 5945/1: ep93xx: include correct irq.h in core.c
ARM: 5933/1: amba-pl011: support hardware flow control
ARM: 5930/1: Add PKMAP area description to memory.txt.
ARM: 5929/1: Add checks to detect overlap of memory regions.
ARM: 5928/1: Change type of VMALLOC_END to unsigned long.
ARM: 5927/1: Make delimiters of DMA area globally visibly.
ARM: 5926/1: Add "Virtual kernel memory..." printout.
ARM: 5920/1: OMAP4: Enable L2 Cache
Fix up trivial conflict in arch/arm/mach-mx25/clock.c
Now that we return the new resource start position, there is no
need to update "struct resource" inside the align function.
Therefore, mark the struct resource as const.
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
As suggested by Linus, align functions should return the start
of a resource, not void. An update of "res->start" is no longer
necessary.
On VIVT ARM, when we have multiple shared mappings of the same file
in the same MM, we need to ensure that we have coherency across all
copies. We do this via make_coherent() by making the pages
uncacheable.
This used to work fine, until we allowed highmem with highpte - we
now have a page table which is mapped as required, and is not available
for modification via update_mmu_cache().
Ralf Beache suggested getting rid of the PTE value passed to
update_mmu_cache():
On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables
to construct a pointer to the pte again. Passing a pte_t * is much
more elegant. Maybe we might even replace the pte argument with the
pte_t?
Ben Herrenschmidt would also like the pte pointer for PowerPC:
Passing the ptep in there is exactly what I want. I want that
-instead- of the PTE value, because I have issue on some ppc cases,
for I$/D$ coherency, where set_pte_at() may decide to mask out the
_PAGE_EXEC.
So, pass in the mapped page table pointer into update_mmu_cache(), and
remove the PTE value, updating all implementations and call sites to
suit.
Includes a fix from Stephen Rothwell:
sparc: fix fallout from update_mmu_cache API change
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
CC: linux-alpha@vger.kernel.org
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Andrew Morton <akpm@linux-foundation.org>
These macros have not been used for awhile now.
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Use the new unreachable() macro instead of for(;;);
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
In the kernel the patch enables configuration of the perf event
option, adds the perf_event_open syscall, and includes a minimal
architecture specific asm/perf_event.h header file.
This wire up the: fallocate, timerfd_create, timerfd_settime,
timerfd_gettime, signalfd4, eventfd2, epoll_create1, dup3, pipe2,
inotify_init1, preadv, pwritev and rt_tgsigqueueinfo syscalls for
the alpha port.
For umount2, alpha have an "old" and "new" version called: oldumount and
umount; so ignore umount2.
Rebased on top of 6e17e8b9fb74b9fb9f6ea331f7f4a049c5b4c4b8 by Matt
Turner.
Signed-off-by: Daniele Calore <orkaan@orkaan.org>
