commit 18b43e89d295cc65151c505c643c98fb2c320e59 upstream.
trace_hardirqs_on_caller() in lockdep.c expects to be called before, not
after interrupts are actually enabled.
The following comment in kernel/locking/lockdep.c substantiates this
claim:
* We're enabling irqs and according to our state above irqs weren't
* already enabled, yet we find the hardware thinks they are in fact
* enabled.. someone messed up their IRQ state tracing.
An example can be found in include/linux/irqflags.h:
do { trace_hardirqs_on(); raw_local_irq_enable(); } while (0)
Without this change, we hit the following DEBUG_LOCKS_WARN_ON.
[ 7.760000] ------------[ cut here ]------------
[ 7.760000] WARNING: CPU: 0 PID: 1 at kernel/locking/lockdep.c:2711 resume_user_mode_begin+0x48/0xf0
[ 7.770000] DEBUG_LOCKS_WARN_ON(!irqs_disabled())
[ 7.780000] Modules linked in:
[ 7.780000] CPU: 0 PID: 1 Comm: init Not tainted 4.7.0-00003-gc668bb9-dirty #366
[ 7.790000]
[ 7.790000] Stack Trace:
[ 7.790000] arc_unwind_core.constprop.1+0xa4/0x118
[ 7.800000] warn_slowpath_fmt+0x72/0x158
[ 7.800000] resume_user_mode_begin+0x48/0xf0
[ 7.810000] ---[ end trace 6f6a7a8fae20d2f0 ]---
Signed-off-by: Daniel Mentz <danielmentz@google.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 86147e3cfa5e118b61e78f4f0bf29e920dcbd477 upstream.
User mode callee regs are explicitly collected before signal delivery or
breakpoint trap. r25 is special for kernel as it serves as task pointer,
so user mode value is clobbered very early. It is saved in pt_regs where
generally only scratch (aka caller saved) regs are saved.
The code to access the corresponding pt_regs location had a subtle bug as
it was using load/store with scaling of offset, whereas the offset was already
byte wise correct. So fix this by replacing LD.AS with a standard LD
Signed-off-by: Liav Rehana <liavr@mellanox.com>
Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
[vgupta: rewrote title and commit log]
commit 20d780374c81cf237834af2202c26df2100ddd69 upstream.
ARC architecture has 2 instruction sets: ARCompact/ARCv2.
While same gcc supports compiling for either (using appropriate toggles),
we can't use the same toolchain to build kernel because libgcc needs
to be unique and the toolchian (uClibc based) is not multilibed.
uClibc toolchain is convenient since it allows all userspace and
kernel to be built with a single install for an ISA.
This however means 2 gnu installs (with same triplet prefix) are needed
for building for 2 ISA and need to be in PATH.
As developers we keep switching the builds, but would occassionally fail
to update the PATH leading to usage of wrong tools. And this would only
show up at the end of kernel build when linking incompatible libgcc.
So the initial solution was to have gcc define a special preprocessor macro
DEFAULT_CPU_xxx which is unique for default toolchain configuration.
Claudiu proposed using grep for an existing preprocessor macro which is
again uniquely defined per ISA.
Cc: Michal Marek <mmarek@suse.cz>
Suggested-by: Claudiu Zissulescu <claziss@synopsys.com>
commit 3925a16ae980c79d1a8fd182d7f9487da1edd4dc upstream.
LTP madvise05 was generating mm splat
| [ARCLinux]# /sd/ltp/testcases/bin/madvise05
| BUG: Bad page map in process madvise05 pte:80e08211 pmd:9f7d4000
| page:9fdcfc90 count:1 mapcount:-1 mapping: (null) index:0x0 flags: 0x404(referenced|reserved)
| page dumped because: bad pte
| addr:200b8000 vm_flags:00000070 anon_vma: (null) mapping: (null) index:1005c
| file: (null) fault: (null) mmap: (null) readpage: (null)
| CPU: 2 PID: 6707 Comm: madvise05
And for newer kernels, the system was rendered unusable afterwards.
The problem was mprotect->pte_modify() clearing PTE_SPECIAL (which is
set to identify the special zero page wired to the pte).
When pte was finally unmapped, special casing for zero page was not
done, and instead it was treated as a "normal" page, tripping on the
map counts etc.
This fixes ARC STAR 9001053308
commit e5bc0478ab6cf565619224536d75ecb2aedca43b upstream.
While reviewing a different change to asm-generic/io.h Arnd spotted that
ARC ioread32 and ioread32be both of which come from asm-generic versions
are not symmetrical in terms of calling the io barriers.
generic ioread32 -> ARC readl() [ has barriers]
generic ioread32be -> __be32_to_cpu(__raw_readl()) [ lacks barriers]
While generic ioread32be is being remediated to call readl(), that involves
a swab32(), causing double swaps on ioread32be() on Big Endian systems.
So provide our versions of big endian IO accessors to ensure io barrier
calls while also keeping them optimal
Suggested-by: Arnd Bergmann <arnd@arndb.de>
commit 2a41b6dc28dc71c1a3f1622612a26edc58f7561e upstream.
commit 80f420842ff42 removed the ARC bitops microoptimization but failed
to prune the comments to same effect
Fixes: 80f420842ff42 ("ARC: Make ARC bitops "safer" (add anti-optimization)")
commit f778cc65717687a3d3f26dd21bef62cd059f1b8b upstream.
read{l,w}() write{l,w}() primitives should use le{16,32}_to_cpu() and
cpu_to_le{16,32}() respectively to ensure device registers are read
correctly in Big Endian CPU configuration.
Per Arnd Bergmann
| Most drivers using readl() or readl_relaxed() expect those to perform byte
| swaps on big-endian architectures, as the registers tend to be fixed endian
This was needed for getting UART to work correctly on a Big Endian ARC.
The ARC accessors originally were fine, and the bug got introduced
inadventently by commit b8a033023994 ("ARCv2: barriers")
Fixes: b8a033023994 ("ARCv2: barriers")
Link: http://lkml.kernel.org/r/201603100845.30602.arnd@arndb.de
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Lada Trimasova <ltrimas@synopsys.com>
[vgupta: beefed up changelog, added Fixes/stable tags]
commit bb143f814ea488769ca2e79e0b376139cb5f134b upstream.
ARConnect/MCIP Inter-Core-Interrupt module can't send interrupt to
local core. So use core intc capability to trigger software
interrupt to self, using an unsued IRQ #21.
This showed up as csd deadlock with LTP trace_sched on a dual core
system. This test acts as scheduler fuzzer, triggering all sorts of
schedulting activity. Trouble starts with IPI to self, which doesn't get
delivered (effectively lost due to H/w capability), but the msg intended
to be sent remain enqueued in per-cpu @ipi_data.
All subsequent IPIs to this core from other cores get elided due to the
IPI coalescing optimization in ipi_send_msg_one() where a pending msg
implies an IPI already sent and assumes other core is yet to ack it.
After the elided IPI, other core simply goes into csd_lock_wait()
but never comes out as this core never sees the interrupt.
Fixes STAR 9001008624
ARC700 cores with MMU v2 don't have IC_PTAG AUX register and so we only
define ARC_REG_IC_PTAG for MMU versions >= 3.
But current implementation of cache_line_loop_vX() routines assumes
availability of all of them (v2, v3 and v4) simultaneously.
And given undefined ARC_REG_IC_PTAG if CONFIG_MMU_VER=2 we're seeing
compilation problem:
---------------------------------->8-------------------------------
CC arch/arc/mm/cache.o
arch/arc/mm/cache.c: In function '__cache_line_loop_v3':
arch/arc/mm/cache.c:270:13: error: 'ARC_REG_IC_PTAG' undeclared (first use in this function)
aux_tag = ARC_REG_IC_PTAG;
arch/arc/mm/cache.c:270:13: note: each undeclared identifier is reported only once for each function it appears in
scripts/Makefile.build:258: recipe for target 'arch/arc/mm/cache.o' failed
The simples fix is to have ARC_REG_IC_PTAG defined regardless MMU
version being used.
We don't use it in cache_line_loop_v2() anyways so who cares.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Makes it similar to smp_ops which also has callback with same name
This will better reflect its description i.e. "any needed setup..."
and not just do an "IPI request".
Signed-off-by: Noam Camus <noamc@ezchip.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
The fix which removed linear searching of dwarf (because binary lookup
data always exists) missed out on the fact that modules don't get the
binary lookup tables info. This caused unwinding out of modules to stop
working.
So add binary lookup header setup (equivalent of eh_frame_hdr setup) to
modules as well.
While at it, confine the header setup to within unwinder code,
reducing one API exposed out of unwinder code.
Fixes: 2e22502c080f ARC: dw2 unwind: Remove falllback linear search thru FDE entries
Cc: <stable@vger.kernel.org>
Although kernel doesn't support the multiple IRQ priority levels provided
by HS38x core intc yet, ensure that the default prio value is used
anyways by relevant code.
SLEEP insn needs to be provided the IRQ priority level which can
interrupt it. This needs to be the default level which maynot
necessarily be 0 as assumed by current code.
This change allows a kernel with ARCV2_IRQ_DEF_PRIO = 1 to boot fine.
No semantical changes, prepares for ARCv2 specific change in next commit
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc
Pull ARC fixes from Vineet Gupta:
"Found a couple of brown paper bag bugs with the prev pull request
(including a SMP build breakage report from Guenter). Since these are
urgent I also decided to send over a bunch of other pending fixes
which could have otherwise waited an rc or two.
Summary:
- A bunch of brown paper bag bugs (MAINTAINERS list email, SMP build
failure)
- cpu_relax() now compiler barrier for UP as well
- handling of userspace Bus Errors for ARCompact builds"
* tag 'arc-4.4-rc1-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc:
ARC: Fix silly typo in MAINTAINERS file
ARC: cpu_relax() to be compiler barrier even for UP
ARC: use ASL assembler mnemonic
ARC: [arcompact] Handle bus error from userspace as Interrupt not exception
ARC: remove extraneous header include
ARCv2: lib: memcpy: use local symbols
cpu_relax() on ARC has been barrier only for SMP (and no-op for UP). Per
recent discussions, it is safer to make it a compiler barrier
unconditionally.
Link: http://lkml.kernel.org/r/53A7D3AA.9020100@synopsys.com
Acked-by: Peter Zijlstra <peterz@infradead.org>
Pull locking changes from Ingo Molnar:
"The main changes in this cycle were:
- More gradual enhancements to atomic ops: new atomic*_read_ctrl()
ops, synchronize atomic_{read,set}() ordering requirements between
architectures, add atomic_long_t bitops. (Peter Zijlstra)
- Add _{relaxed|acquire|release}() variants for inc/dec atomics and
use them in various locking primitives: mutex, rtmutex, mcs, rwsem.
This enables weakly ordered architectures (such as arm64) to make
use of more locking related optimizations. (Davidlohr Bueso)
- Implement atomic[64]_{inc,dec}_relaxed() on ARM. (Will Deacon)
- Futex kernel data cache footprint micro-optimization. (Rasmus
Villemoes)
- pvqspinlock runtime overhead micro-optimization. (Waiman Long)
- misc smaller fixlets"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ARM, locking/atomics: Implement _relaxed variants of atomic[64]_{inc,dec}
locking/rwsem: Use acquire/release semantics
locking/mcs: Use acquire/release semantics
locking/rtmutex: Use acquire/release semantics
locking/mutex: Use acquire/release semantics
locking/asm-generic: Add _{relaxed|acquire|release}() variants for inc/dec atomics
atomic: Implement atomic_read_ctrl()
atomic, arch: Audit atomic_{read,set}()
atomic: Add atomic_long_t bitops
futex: Force hot variables into a single cache line
locking/pvqspinlock: Kick the PV CPU unconditionally when _Q_SLOW_VAL
locking/osq: Relax atomic semantics
locking/qrwlock: Rename ->lock to ->wait_lock
locking/Documentation/lockstat: Fix typo - lokcing -> locking
locking/atomics, cmpxchg: Privatize the inclusion of asm/cmpxchg.h
This is the first working implementation of 40-bit physical address
extension on ARCv2.
That way a single flip of phys_addr_t to 64 bit ensures all places
dealing with physical addresses get correct data
Implement kmap* API for ARC.
This enables
- permanent kernel maps (pkmaps): :kmap() API
- fixmap : kmap_atomic()
We use a very simple/uniform approach for both (unlike some of the other
arches). So fixmap doesn't use the customary compile time address stuff.
The important semantic is sleep'ability (pkmap) vs. not (fixmap) which
the API guarantees.
Note that this patch only enables highmem for subsequent PAE40 support
as there is no real highmem for ARC in pure 32-bit paradigm as explained
below.
ARC has 2:2 address split of the 32-bit address space with lower half
being translated (virtual) while upper half unstranslated
(0x8000_0000 to 0xFFFF_FFFF). kernel itself is linked at base of
unstranslated space (i.e. 0x8000_0000 onwards), which is mapped to say
DDR 0x0 by external Bus Glue logic (outside the core). So kernel can
potentially access 1.75G worth of memory directly w/o need for highmem.
(the top 256M is taken by uncached peripheral space from 0xF000_0000 to
0xFFFF_FFFF)
In PAE40, hardware can address memory beyond 4G (0x1_0000_0000) while
the logical/virtual addresses remain 32-bits. Thus highmem is required
for kernel proper to be able to access these pages for it's own purposes
(user space is agnostic to this anyways).
Before we plug in highmem support, some of code needs to be ready for it
- copy_user_highpage() needs to be using the kmap_atomic API
- mk_pte() can't assume page_address()
- do_page_fault() can't assume VMALLOC_END is end of kernel vaddr space
MCIP now registers it's own per cpu setup routine (for IPI IRQ request)
using smp_ops.init_irq_cpu().
So no need for platforms to do that. This now completely decouples
platforms from MCIP.
Note this is not part of platform owned static machine_desc,
but more of device owned plat_smp_ops (rather misnamed) which a IPI
provider or some such typically defines.
This will help us seperate out the IPI registration from platform
specific init_cpu_smp() into device specific init_irq_cpu()
This conveys better that it is called for each cpu
MCIP now registers it's own probe callback with smp_ops.init_early_smp()
which is called by ARC common code, so no need for platforms to do that.
This decouples the platforms and MCIP and helps confine MCIP details
to it's own file.
This adds a platform agnostic early SMP init hook which is called on
Master core before calling setup_processor()
setup_arch()
smp_init_cpus()
setup_processor()
How this helps:
- Used for one time init of certain SMP centric IP blocks, before
calling setup_processor() which probes various bits of core,
possibly including this block
- Currently platforms need to call this IP block init from their
init routines, which doesn't make sense as this is specific to ARC
core and not platform and otherwise requires copy/paste in all
(and hence a possible point of failure)
e.g. MCIP init is called from 2 platforms currently (axs10x and sim)
which will go away once we have this.
This change only adds the hooks but they are empty for now. Next commit
will populate them and remove the explicit init calls from platforms.
These are not in use for ARC platforms. Moreover DT mechanims exist to
probe them w/o explicit platform calls.
- clocksource drivers can use CLOCKSOURCE_OF_DECLARE()
- intc IRQCHIP_DECLARE() calls + cascading inside DT allows external
intc to be probed automatically
The reason this was not done so far was lack of genuine IPI_IRQ for
ARC700, as we don't have a SMP version of core yet (which might change
soon thx to EZChip). Nevertheles to increase the build coverage, we
need to allow CONFIG_SMP for ARC700 and still be able to run it on a
UP platform (nsim or AXS101) with a UP Device Tree (SMP-on-UP)
The build itself requires some define for IPI_IRQ and even a dummy
value is fine since that code won't run anyways.
This frees up some bits to hold more high level info such as PAE being
present, w/o increasing the size of already bloated cpuinfo struct
It was generating warnings when called as write_aux_reg(x, paddr >> 32)
The requirement is to
- Reenable Exceptions (AE cleared)
- Reenable Interrupts (E1/E2 set)
We need to do wiggle these bits into ERSTATUS and call RTIE.
Prev version used the pre-exception STATUS32 as starting point for what
goes into ERSTATUS. This required explicit fixups of U/DE/L bits.
Instead, use the current (in-exception) STATUS32 as starting point.
Being in exception handler U/DE/L can be safely assumed to be correct.
Only AE/E1/E2 need to be fixed.
So the new implementation is slightly better
-Avoids read form memory
-Is 4 bytes smaller for the typical 1 level of intr configuration
-Depicts the semantics more clearly
Historically this was done by ARC IDE driver, which is long gone.
IRQ core is pretty robust now and already checks if IRQs are enabled
in hard ISRs. Thus no point in checking this in arch code, for every
call of irq enabled.
Further if some driver does do that - let it bring down the system so we
notice/fix this sooner than covering up for sucker
This makes local_irq_enable() - for L1 only case atleast simple enough
so we can inline it.
Implement the TLB flush routine to evict a sepcific Super TLB entry,
vs. moving to a new ASID on every such flush.
MMUv4 in HS38x cores supports Super Pages which are basis for Linux THP
support.
Normal and Super pages can co-exist (ofcourse not overlap) in TLB with a
new bit "SZ" in TLB page desciptor to distinguish between them.
Super Page size is configurable in hardware (4K to 16M), but fixed once
RTL builds.
The exact THP size a Linx configuration will support is a function of:
- MMU page size (typical 8K, RTL fixed)
- software page walker address split between PGD:PTE:PFN (typical
11:8:13, but can be changed with 1 line)
So for above default, THP size supported is 8K * 256 = 2M
Default Page Walker is 2 levels, PGD:PTE:PFN, which in THP regime
reduces to 1 level (as PTE is folded into PGD and canonically referred
to as PMD).
Thus thp PMD accessors are implemented in terms of PTE (just like sparc)
Needed for THP, but will also come in handy for fast GUP later
ARC is the only arch with unsigned long type (vs. struct page *).
Historically this was done to avoid the page_address() calls in various
arch hooks which need to get the virtual/logical address of the table.
Some arches alternately define it as pte_t *, and is as efficient as
unsigned long (generated code doesn't change)
Suggested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
changes
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull strscpy string copy function implementation from Chris Metcalf.
Chris sent this during the merge window, but I waffled back and forth on
the pull request, which is why it's going in only now.
The new "strscpy()" function is definitely easier to use and more secure
than either strncpy() or strlcpy(), both of which are horrible nasty
interfaces that have serious and irredeemable problems.
strncpy() has a useless return value, and doesn't NUL-terminate an
overlong result. To make matters worse, it pads a short result with
zeroes, which is a performance disaster if you have big buffers.
strlcpy(), by contrast, is a mis-designed "fix" for strlcpy(), lacking
the insane NUL padding, but having a differently broken return value
which returns the original length of the source string. Which means
that it will read characters past the count from the source buffer, and
you have to trust the source to be properly terminated. It also makes
error handling fragile, since the test for overflow is unnecessarily
subtle.
strscpy() avoids both these problems, guaranteeing the NUL termination
(but not excessive padding) if the destination size wasn't zero, and
making the overflow condition very obvious by returning -E2BIG. It also
doesn't read past the size of the source, and can thus be used for
untrusted source data too.
So why did I waffle about this for so long?
Every time we introduce a new-and-improved interface, people start doing
these interminable series of trivial conversion patches.
And every time that happens, somebody does some silly mistake, and the
conversion patch to the improved interface actually makes things worse.
Because the patch is mindnumbing and trivial, nobody has the attention
span to look at it carefully, and it's usually done over large swatches
of source code which means that not every conversion gets tested.
So I'm pulling the strscpy() support because it *is* a better interface.
But I will refuse to pull mindless conversion patches. Use this in
places where it makes sense, but don't do trivial patches to fix things
that aren't actually known to be broken.
* 'strscpy' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tile: use global strscpy() rather than private copy
string: provide strscpy()
Make asm/word-at-a-time.h available on all architectures
This patch makes sure that atomic_{read,set}() are at least
{READ,WRITE}_ONCE().
We already had the 'requirement' that atomic_read() should use
ACCESS_ONCE(), and most archs had this, but a few were lacking.
All are now converted to use READ_ONCE().
And, by a symmetry and general paranoia argument, upgrade atomic_set()
to use WRITE_ONCE().
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: james.hogan@imgtec.com
Cc: oleg@redhat.com
Cc: will.deacon@arm.com
Pull locking and atomic updates from Ingo Molnar:
"Main changes in this cycle are:
- Extend atomic primitives with coherent logic op primitives
(atomic_{or,and,xor}()) and deprecate the old partial APIs
(atomic_{set,clear}_mask())
The old ops were incoherent with incompatible signatures across
architectures and with incomplete support. Now every architecture
supports the primitives consistently (by Peter Zijlstra)
- Generic support for 'relaxed atomics':
- _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return()
- atomic_read_acquire()
- atomic_set_release()
This came out of porting qwrlock code to arm64 (by Will Deacon)
- Clean up the fragile static_key APIs that were causing repeat bugs,
by introducing a new one:
DEFINE_STATIC_KEY_TRUE(name);
DEFINE_STATIC_KEY_FALSE(name);
which define a key of different types with an initial true/false
value.
Then allow:
static_branch_likely()
static_branch_unlikely()
to take a key of either type and emit the right instruction for the
case. To be able to know the 'type' of the static key we encode it
in the jump entry (by Peter Zijlstra)
- Static key self-tests (by Jason Baron)
- qrwlock optimizations (by Waiman Long)
- small futex enhancements (by Davidlohr Bueso)
- ... and misc other changes"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits)
jump_label/x86: Work around asm build bug on older/backported GCCs
locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations
locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h
locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics
locking/qrwlock: Implement queue_write_unlock() using smp_store_release()
locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition
locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t'
locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication
locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations
locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic
locking/static_keys: Make verify_keys() static
jump label, locking/static_keys: Update docs
locking/static_keys: Provide a selftest
jump_label: Provide a self-test
s390/uaccess, locking/static_keys: employ static_branch_likely()
x86, tsc, locking/static_keys: Employ static_branch_likely()
locking/static_keys: Add selftest
locking/static_keys: Add a new static_key interface
locking/static_keys: Rework update logic
locking/static_keys: Add static_key_{en,dis}able() helpers
With all features in place, the ARC HS pct block can now be effectively
allowed to be probed/used
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
In times of ARC 700 performance counters didn't have support of
interrupt an so for ARC we only had support of non-sampling events.
Put simply only "perf stat" was functional.
Now with ARC HS we have support of interrupts in performance counters
which this change introduces support of.
ARC performance counters act in the following way in regard of
interrupts generation.
[1] A counter counts starting from value set in PCT_COUNT register pair
[2] Once counter reaches value set in PCT_INT_CNT interrupt is raised
Basic setup look like this:
[1] PCT_COUNT = 0;
[2] PCT_INT_CNT = __limit_value__;
[3] Enable interrupts for that counter and let it run
[4] Let counter reach its limit
[5] Handle interrupt when it happens
Note that PCT HW block is build in CPU core and so ints interrupt
line (which is basically OR of all counters IRQs) is wired directly to
top-level IRQC. That means do de-assert PCT interrupt it's required to
reset IRQs from all counters that have reached their limit values.
The number of counters in PCT can never be more than 32 (while
countable conditions could be 100+) for both ARCompact and ARCv2
And while at it update copyright dates.
