path: root/arch/arc/kernel/disasm.c
2014-10-13ARC: rename kconfig option for unaligned emulationVineet Gupta
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-05-09Merge tag 'arc-v3.10-rc1-part1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC port updates from Vineet Gupta: "Support for two new platforms based on ARC700: - Abilis TB10x SoC [Chritisian/Pierrick] - Simulator only System-C Model [Mischa] ARC specific MM improvements: - Avoid full TLB flush (ASID increment) on munmap (even single page) - VIPT Cache Flushing improvements + Delayed dcache flush for non-aliasing dcache (big performance boost) + icache flush aliasing agnostic (no need to kill all possible aliases) Others: - Avoid needless rebuild of DTB files for every kernel build - Remove builtin cmdline as that is already provided by DeviceTree/bootargs - Fixing unaligned access emulation corner case - checkpatch fixes [Sachin] - Various fixlets [Noam] - Minor build failures/cleanups" * tag 'arc-v3.10-rc1-part1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (35 commits) ARC: [mm] Lazy D-cache flush (non aliasing VIPT) ARC: [mm] micro-optimize page size icache invalidate ARC: [mm] remove the pessimistic all-alias-invalidate icache helpers ARC: [mm] consolidate icache/dcache sync code ARC: [mm] optimise icache flush for kernel mappings ARC: [mm] optimise icache flush for user mappings ARC: [mm] optimize needless full mm TLB flush on munmap ARC: Add support for nSIM OSCI System C model ARC: [TB10x] Adapt device tree to new compatible string ARC: [TB10x] Add support for TB10x platform ARC: [TB10x] Device tree of TB100 and TB101 Development Kits ARC: Prepare interrupt code for external controllers ARC: Allow embedded arc-intc to be properly placed in DT intc hierarchy ARC: [cmdline] Don't overwrite u-boot provided bootargs ARC: [cmdline] Remove CONFIG_CMDLINE ARC: [plat-arcfpga] defconfig update ARC: unaligned access emulation broken if callee-reg dest of LD/ST ARC: unaligned access emulation error handling consolidation ARC: Debug/crash-printing Improvements ARC: fix typo with clock speed ...
2013-04-09ARC: Use <linux/*> headers instead of <asm/*>Sachin Kamat
Silences the following checkpatch warnings: WARNING: Use #include <linux/ptrace.h> instead of <asm/ptrace.h> WARNING: Use #include <linux/kprobes.h> instead of <asm/kprobes.h> WARNING: Use #include <linux/kgdb.h> instead of <asm/kgdb.h> WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h> WARNING: Use #include <linux/cache.h> instead of <asm/cache.h> Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2013-03-18arc: fix incorrect ifdef commentPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-15ARC: Unaligned access emulationVineet Gupta
ARC700 doesn't natively support unaligned access, but can be emulated -Unaligned Access Exception -Disassembly at the Fault address to find the exact insn (long/short) Also per Arnd's comment, we runtime control it using 2 sysctl knobs: * SYSCTL_ARCH_UNALIGN_ALLOW: Runtime enable/disble * SYSCTL_ARCH_UNALIGN_NO_WARN: Warn on each emulation attempt Originally contributed by Tim Yao <tim.yao@amlogic.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Tim Yao <tim.yao@amlogic.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-02-15ARC: kprobes supportVineet Gupta
Origin port done by Rajeshwar Ranga Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Rajeshwar Ranga <rajeshwar.ranga@gmail.com>
2013-02-15ARC: disassembly (needed by kprobes/kgdb/unaligned-access-emul)Vineet Gupta
In-kernel disassembler Due Credits * Orig written by Rajeshwar Ranga * Consolidation/cleanups by Mischa Jonker Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Rajeshwar Ranga <rajeshwar.ranga@gmail.com> Cc: Mischa Jonker <mjonker@synopsys.com>
