[ Upstream commit 1928b36cfa4df1aeedf5f2644d0c33f3a1fcfd7b ]
Fix kconfig warning for arch/arc/plat-eznps/Kconfig allmodconfig:
WARNING: unmet direct dependencies detected for CLKSRC_NPS
Depends on [n]: GENERIC_CLOCKEVENTS [=y] && !PHYS_ADDR_T_64BIT [=y]
Selected by [y]:
- ARC_PLAT_EZNPS [=y]
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Ofer Levi <oferle@mellanox.com>
Cc: linux-snps-arc@lists.infradead.org
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 5effc09c4907901f0e71e68e5f2e14211d9a203f upstream.
8-letter strings representing ARC perf events are stores in two
32-bit registers as ASCII characters like that: "IJMP", "IALL", "IJMPTAK" etc.
And the same order of bytes in the word is used regardless CPU endianness.
Which means in case of big-endian CPU core we need to swap bytes to get
the same order as if it was on little-endian CPU.
Otherwise we're seeing the following error message on boot:
------------------------->8----------------------
ARC perf : 8 counters (32 bits), 40 conditions, [overflow IRQ support]
sysfs: cannot create duplicate filename '/devices/arc_pct/events/pmji'
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.18 #3
Stack Trace:
arc_unwind_core+0xd4/0xfc
dump_stack+0x64/0x80
sysfs_warn_dup+0x46/0x58
sysfs_add_file_mode_ns+0xb2/0x168
create_files+0x70/0x2a0
WARNING: CPU: 0 PID: 1 at kernel/events/core.c:12144 perf_event_sysfs_init+0x70/0xa0
Failed to register pmu: arc_pct, reason -17
Modules linked in:
Stack Trace:
__warn+0x9c/0xd4
warn_slowpath_fmt+0x22/0x2c
---[ end trace a75fb9a9837bd1ec ]---
What happens here we're trying to register more than one raw perf event
with the same name "PMJI". Why? Because ARC perf events are 4 to 8 letters
and encoded into two 32-bit words. In this particular case we deal with 2
events:
* "IJMP____" which counts all jump & branch instructions
* "IJMPC___" which counts only conditional jumps & branches
Those strings are split in two 32-bit words this way "IJMP" + "____" &
"IJMP" + "C___" correspondingly. Now if we read them swapped due to CPU core
being big-endian then we read "PMJI" + "____" & "PMJI" + "___C".
And since we interpret read array of ASCII letters as a null-terminated string
on big-endian CPU we end up with 2 events of the same name "PMJI".
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: stable@vger.kernel.org
commit fd5de2721ea7d16e2b16c4049ac49f229551b290 upstream.
As kernelci.org reports, this function is not used in
vdk_hs38_defconfig:
arch/arc/kernel/unwind.c:188:14: warning: 'unw_hdr_alloc' defined but not used [-Wunused-function]
Fixes: bc79c9a72165 ("ARC: dw2 unwind: Reinstante unwinding out of modules")
Link: https://kernelci.org/build/id/5d1cae3f59b514300340c132/logs/
commit af1be2e21203867cb958aaceed5366e2e24b88e8 upstream.
ARC gcc prior to GNU 2018.03 release didn't have a target specific
__builtin_trap() implementation, generating default abort() call.
Implement the abort() call - emulating what newer gcc does for the same,
as suggested by Arnd.
[ Upstream commit 4c70850aeb2e40016722cd1abd43c679666d3ca0 ]
Add the binding for RX/TX fifo size of GMAC node.
Cc: Joao Pinto <jpinto@synopsys.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Tested-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Jose Abreu <joabreu@synopsys.com>
[ Upstream commit ecc906a11c2a0940e1a380debd8bd5bc09faf454 ]
GMAC controller on HSDK boards supports 256 Hash Table size so we need to
add the multicast filter bins property. This allows for the Hash filter
to work properly using stmmac driver.
Cc: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
[ Upstream commit 89c92142f75eb80064f5b9f1111484b1b4d81790 ]
| arch/arc/mm/tlb.c:914:2: warning: variable length array 'pd0' is used [-Wvla]
| arch/arc/include/asm/cmpxchg.h:95:29: warning: value computed is not used [-Wunused-value]
[ Upstream commit 0728aeb7ead99a9b0dac2f3c92b3752b4e02ff97 ]
We have now a HSDK device in our kernelci lab, but kernel builded via
the hsdk_defconfig lacks ramfs supports, so it cannot boot kernelci jobs
yet.
So this patch enable CONFIG_BLK_DEV_RAM in hsdk_defconfig.
Signed-off-by: Corentin Labbe <clabbe@baylibre.com>
[ Upstream commit edb64bca50cd736c6894cc6081d5263c007ce005 ]
In case of devboards we really often disable bootloader and load
Linux image in memory via JTAG. Even if kernel tries to verify
uboot_tag and uboot_arg there is sill a chance that we treat some
garbage in registers as valid u-boot arguments in JTAG case.
E.g. it is enough to have '1' in r0 to treat any value in r2 as
a boot command line.
So check that magic number passed from u-boot is correct and drop
u-boot arguments otherwise. That helps to reduce the possibility
of using garbage as u-boot arguments in JTAG case.
We can safely check U-boot magic value (0x0) in linux passed via
r1 register as U-boot pass it from the beginning. So there is no
backward-compatibility issues.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
[ Upstream commit e494239a007e601448110ac304fe055951f9de3b ]
There's a hardware bug which affects the HSDK platform, triggered by
micro-ops for auto-saving regfile on taken interrupt. The workaround is
to inhibit autosave.
[ Upstream commit d5e3c55e01d8b1774b37b4647c30fb22f1d39077 ]
Newer ARC gcc handles lp_start, lp_end in a different way and doesn't
like them in the clobber list.
[ Upstream commit f8a15f97664178f27dfbf86a38f780a532cb6df0 ]
ARCv2 optimized memcpy uses PREFETCHW instruction for prefetching the
next cache line but doesn't ensure that the line is not past the end of
the buffer. PRETECHW changes the line ownership and marks it dirty,
which can cause data corruption if this area is used for DMA IO.
Fix the issue by avoiding the PREFETCHW. This leads to performance
degradation but it is OK as we'll introduce new memcpy implementation
optimized for unaligned memory access using.
We also cut off all PREFETCH instructions at they are quite useless
here:
* we call PREFETCH right before LOAD instruction call.
* we copy 16 or 32 bytes of data (depending on CONFIG_ARC_HAS_LL64)
in a main logical loop. so we call PREFETCH 4 times (or 2 times)
for each L1 cache line (in case of 64B L1 cache Line which is
default case). Obviously this is not optimal.
[ Upstream commit 4e868f8419cb4cb558c5d428e7ab5629cef864c7 ]
| CC mm/nobootmem.o
|In file included from ./include/asm-generic/bug.h:18:0,
| from ./arch/arc/include/asm/bug.h:32,
| from ./include/linux/bug.h:5,
| from ./include/linux/mmdebug.h:5,
| from ./include/linux/gfp.h:5,
| from ./include/linux/slab.h:15,
| from mm/nobootmem.c:14:
|mm/nobootmem.c: In function '__free_pages_memory':
|./include/linux/kernel.h:845:29: warning: comparison of distinct pointer types lacks a cast
| (!!(sizeof((typeof(x) *)1 == (typeof(y) *)1)))
|./include/linux/kernel.h:859:4: note: in expansion of macro '__typecheck'
| (__typecheck(x, y) && __no_side_effects(x, y))
|./include/linux/kernel.h:869:24: note: in expansion of macro '__safe_cmp'
| __builtin_choose_expr(__safe_cmp(x, y), \
|./include/linux/kernel.h:878:19: note: in expansion of macro '__careful_cmp'
| #define min(x, y) __careful_cmp(x, y, <)
|mm/nobootmem.c:104:11: note: in expansion of macro 'min'
| order = min(MAX_ORDER - 1UL, __ffs(start));
Change __ffs return value from 'int' to 'unsigned long' as it
is done in other implementations (like asm-generic, x86, etc...)
to avoid build-time warnings in places where type is strictly
checked.
As __ffs may return values in [0-31] interval changing return
type to unsigned is valid.
commit b6835ea77729e7faf4656ca637ba53f42b8ee3fd upstream.
The default value of ARCH_SLAB_MINALIGN in "include/linux/slab.h" is
"__alignof__(unsigned long long)" which for ARC unexpectedly turns out
to be 4. This is not a compiler bug, but as defined by ARC ABI [1]
Thus slab allocator would allocate a struct which is 32-bit aligned,
which is generally OK even if struct has long long members.
There was however potetial problem when it had any atomic64_t which
use LLOCKD/SCONDD instructions which are required by ISA to take
64-bit addresses. This is the problem we ran into
[ 4.015732] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.167881] Misaligned Access
[ 4.172356] Path: /bin/busybox.nosuid
[ 4.176004] CPU: 2 PID: 171 Comm: rm Not tainted 4.19.14-yocto-standard #1
[ 4.182851]
[ 4.182851] [ECR ]: 0x000d0000 => Check Programmer's Manual
[ 4.190061] [EFA ]: 0xbeaec3fc
[ 4.190061] [BLINK ]: ext4_delete_entry+0x210/0x234
[ 4.190061] [ERET ]: ext4_delete_entry+0x13e/0x234
[ 4.202985] [STAT32]: 0x80080002 : IE K
[ 4.207236] BTA: 0x9009329c SP: 0xbe5b1ec4 FP: 0x00000000
[ 4.212790] LPS: 0x9074b118 LPE: 0x9074b120 LPC: 0x00000000
[ 4.218348] r00: 0x00000040 r01: 0x00000021 r02: 0x00000001
[ 4.270510] Stack Trace:
[ 4.274510] ext4_delete_entry+0x13e/0x234
[ 4.278695] ext4_rmdir+0xe0/0x238
[ 4.282187] vfs_rmdir+0x50/0xf0
[ 4.285492] do_rmdir+0x9e/0x154
[ 4.288802] EV_Trap+0x110/0x114
The fix is to make sure slab allocations are 64-bit aligned.
Do note that atomic64_t is __attribute__((aligned(8)) which means gcc
does generate 64-bit aligned references, relative to beginning of
container struct. However the issue is if the container itself is not
64-bit aligned, atomic64_t ends up unaligned which is what this patch
ensures.
[1] https://github.com/foss-for-synopsys-dwc-arc-processors/toolchain/wiki/files/ARCv2_ABI.pdf
Cc: <stable@vger.kernel.org> # 4.8+
[vgupta: reworked changelog, added dependency on LL64+LLSC]
commit a66f2e57bd566240d8b3884eedf503928fbbe557 upstream.
Handle U-boot arguments paranoidly:
* don't allow to pass unknown tag.
* try to use external device tree blob only if corresponding tag
(TAG_DTB) is set.
* don't check uboot_tag if kernel build with no ARC_UBOOT_SUPPORT.
NOTE:
If U-boot args are invalid we skip them and try to use embedded device
tree blob. We can't panic on invalid U-boot args as we really pass
invalid args due to bug in U-boot code.
This happens if we don't provide external DTB to U-boot and
don't set 'bootargs' U-boot environment variable (which is default
case at least for HSDK board) In that case we will pass
{r0 = 1 (bootargs in r2); r1 = 0; r2 = 0;} to linux which is invalid.
While I'm at it refactor U-boot arguments handling code.
Tested-by: Corentin LABBE <clabbe@baylibre.com>
commit 252f6e8eae909bc075a1b1e3b9efb095ae4c0b56 upstream.
It is currently done in arc_init_IRQ() which might be too late
considering gcc 7.3.1 onwards (GNU 2018.03) generates unaligned
memory accesses by default
Cc: stable@vger.kernel.org #4.4+
[vgupta: rewrote changelog]
commit 3affbf0e154ee351add6fcc254c59c3f3947fa8f upstream.
So far we've mapped branches to "ijmp" which also counts conditional
branches NOT taken. This makes us different from other architectures
such as ARM which seem to be counting only taken branches.
So use "ijmptak" hardware condition which only counts (all jump
instructions that are taken)
'ijmptak' event is available on both ARCompact and ARCv2 ISA based
cores.
[vgupta: reworked changelog]
commit a3010a0465383300f909f62b8a83f83ffa7b2517 upstream.
In setup_arch_memory we reserve the memory area wherein the kernel
is located. Current implementation may reserve more memory than
it actually required in case of CONFIG_LINUX_LINK_BASE is not
equal to CONFIG_LINUX_RAM_BASE. This happens because we calculate
start of the reserved region relatively to the CONFIG_LINUX_RAM_BASE
and end of the region relatively to the CONFIG_LINUX_RAM_BASE.
For example in case of HSDK board we wasted 256MiB of physical memory:
------------------->8------------------------------
Memory: 770416K/1048576K available (5496K kernel code,
240K rwdata, 1064K rodata, 2200K init, 275K bss,
278160K reserved, 0K cma-reserved)
Fix that.
Fixes: 9ed68785f7f2b ("ARC: mm: Decouple RAM base address from kernel link addr")
Cc: stable@vger.kernel.org #4.14+
commit e6a72b7daeeb521753803550f0ed711152bb2555 upstream.
ARCv2 optimized memset uses PREFETCHW instruction for prefetching the
which can cause issues in SMP config when next line was already owned by
other core. Fix the issue by avoiding the PREFETCHW
Some more details:
The current code has 3 logical loops (ignroing the unaligned part)
(a) Big loop for doing aligned 64 bytes per iteration with PREALLOC
(b) Loop for 32 x 2 bytes with PREFETCHW
(c) any left over bytes
loop (a) was already eliding the last 64 bytes, so PREALLOC was
safe. The fix was removing PREFETCW from (b).
Another potential issue (applicable to configs with 32 or 128 byte L1
cache line) is that PREALLOC assumes 64 byte cache line and may not do
the right thing specially for 32b. While it would be easy to adapt,
there are no known configs with those lie sizes, so for now, just
compile out PREALLOC in such cases.
[vgupta: rewrote changelog, used asm .macro vs. "C" macro]
[ Upstream commit 10d443431dc2bb733cf7add99b453e3fb9047a2e ]
Some ARC CPU's do not support unaligned loads/stores. Currently, generic
implementation of reads{b/w/l}()/writes{b/w/l}() is being used with ARC.
This can lead to misfunction of some drivers as generic functions do a
plain dereference of a pointer that can be unaligned.
Let's use {get/put}_unaligned() helpers instead of plain dereference of
pointer in order to fix. The helpers allow to get and store data from an
unaligned address whilst preserving the CPU internal alignment.
According to [1], the use of these helpers are costly in terms of
performance so we added an initial check for a buffer already aligned so
that the usage of the helpers can be avoided, when possible.
[1] Documentation/unaligned-memory-access.txt
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Tested-by: Vitor Soares <soares@synopsys.com>
commit 6b04114f6fae5e84d33404c2970b1949c032546e upstream.
By default NFSv3 doesn't support ACL (Access Control Lists)
which might be quite convenient to have so that
mounted NFS behaves exactly as any other local file-system.
In particular missing support of ACL makes umask useless.
This among other thigs fixes Glibc's "nptl/tst-umask1".
Cc: Cupertino Miranda <cmiranda@synopsys.com>
commit b7cc40c32a8bfa6f2581a71747f6a7d491fe43ba upstream.
Change the default defconfig (used with 'make defconfig') to the ARCv2
nsim_hs_defconfig, and also switch the default Kconfig ISA selection to
ARCv2.
This allows several default defconfigs (e.g. make defconfig, make
allnoconfig, make tinyconfig) to all work with ARCv2 by default.
Note since we change default architecture from ARCompact to ARCv2
it's required to explicitly mention architecture type in ARCompact
defconfigs otherwise ARCv2 will be implied and binaries will be
generated for ARCv2.
Cc: <stable@vger.kernel.org> # 4.4.x
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
commit 40660f1fcee8d524a60b5101538e42b1f39f106d upstream.
There's not much sense in doing that because if user or
his build-system didn't set CROSS_COMPILE we still may
very well make incorrect guess.
But as it turned out setting CROSS_COMPILE is not as harmless
as one may think: with recent changes that implemented automatic
discovery of __host__ gcc features unconditional setup of
CROSS_COMPILE leads to failures on execution of "make xxx_defconfig"
with absent cross-compiler, for more info see [1].
Set CROSS_COMPILE as well gets in the way if we want only to build
.dtb's (again with absent cross-compiler which is not really needed
for building .dtb's), see [2].
Note, we had to change LIBGCC assignment type from ":=" to "="
so that is is resolved on its usage, otherwise if it is resolved
at declaration time with missing CROSS_COMPILE we're getting this
error message from host GCC:
| gcc: error: unrecognized command line option -mmedium-calls
| gcc: error: unrecognized command line option -mno-sdata
[1] http://lists.infradead.org/pipermail/linux-snps-arc/2018-September/004308.html
[2] http://lists.infradead.org/pipermail/linux-snps-arc/2018-September/004320.html
Cc: Rob Herring <robh@kernel.org>
commit 615f64458ad890ef94abc879a66d8b27236e733a upstream.
This check is very naive: we simply test if GCC invoked without
"-mcpu=XXX" has ARC700 define set. In that case we think that GCC
was built with "--with-cpu=arc700" and has libgcc built for ARC700.
Otherwise if ARC700 is not defined we think that everythng was built
for ARCv2.
But in reality our life is much more interesting.
1. Regardless of GCC configuration (i.e. what we pass in "--with-cpu"
it may generate code for any ARC core).
2. libgcc might be built with explicitly specified "--mcpu=YYY"
That's exactly what happens in case of multilibbed toolchains:
- GCC is configured with default settings
- All the libs built for many different CPU flavors
I.e. that check gets in the way of usage of multilibbed
toolchains. And even non-multilibbed toolchains are affected.
OpenEmbedded also builds GCC without "--with-cpu" because
each and every target component later is compiled with explicitly
set "-mcpu=ZZZ".
Acked-by: Rob Herring <robh@kernel.org>
commit c58a584f05e35d1d4342923cd7aac07d9c3d3d16 upstream.
Per ARC TLS ABI, r25 is designated TP (thread pointer register).
However so far kernel didn't do any special treatment, like setting up
usermode r25, even for CLONE_SETTLS. We instead relied on libc runtime
to do this, in say clone libc wrapper [1]. This was deliberate to keep
kernel ABI agnostic (userspace could potentially change TP, specially
for different ARC ISA say ARCompact vs. ARCv2 with different spare
registers etc)
However userspace setting up r25, after clone syscall opens a race, if
child is not scheduled and gets a signal instead. It starts off in
userspace not in clone but in a signal handler and anything TP sepcific
there such as pthread_self() fails which showed up with uClibc
testsuite nptl/tst-kill6 [2]
Fix this by having kernel populate r25 to TP value. So this locks in
ABI, but it was not going to change anyways, and fwiw is same for both
ARCompact (arc700 core) and ARCvs (HS3x cores)
[1] https://cgit.uclibc-ng.org/cgi/cgit/uclibc-ng.git/tree/libc/sysdeps/linux/arc/clone.S
[2] https://github.com/wbx-github/uclibc-ng-test/blob/master/test/nptl/tst-kill6.c
Fixes: ARC STAR 9001378481
Reported-by: Nikita Sobolev <sobolev@synopsys.com>
[ Upstream commit 3fcbb8260a87efb691d837e8cd24e81f65b3eb70 ]
In 4.19-rc1, Eugeniy reported weird boot and IO errors on ARC HSDK
| INFO: task syslogd:77 blocked for more than 10 seconds.
| Not tainted 4.19.0-rc1-00007-gf213acea4e88 #40
| "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this
| message.
| syslogd D 0 77 76 0x00000000
| Stack Trace:
| __switch_to+0x0/0xac
| __schedule+0x1b2/0x730
| io_schedule+0x5c/0xc0
| __lock_page+0x98/0xdc
| find_lock_entry+0x38/0x100
| shmem_getpage_gfp.isra.3+0x82/0xbfc
| shmem_fault+0x46/0x138
| handle_mm_fault+0x5bc/0x924
| do_page_fault+0x100/0x2b8
| ret_from_exception+0x0/0x8
He bisected to 84c6591103db ("locking/atomics,
asm-generic/bitops/lock.h: Rewrite using atomic_fetch_*()")
This commit however only unmasked the real issue introduced by commit
4aef66c8ae9 ("locking/atomic, arch/arc: Fix build") which missed the
retry-if-scond-failed branch in atomic_fetch_##op() macros.
The bisected commit started using atomic_fetch_##op() macros for building
the rest of atomics.
Fixes: 4aef66c8ae9 ("locking/atomic, arch/arc: Fix build")
Reported-by: Eugeniy Paltsev <paltsev@synopsys.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
[vgupta: wrote changelog]
commit c83532fb0fe053d2e43e9387354cb1b52ba26427 upstream.
SWAP support on ARC was fixed earlier by
commit 6e3761145a9b ("ARC: Fix CONFIG_SWAP")
so now we may safely enable it on platforms that
have external media like USB and SD-card.
Note: it was already allowed for HSDK
Cc: stable@vger.kernel.org # 6e3761145a9b: ARC: Fix CONFIG_SWAP
[ Upstream commit ec837d620c750c0d4996a907c8c4f7febe1bbeee ]
Fix type warnings in arch/arc/mm/cache.c.
../arch/arc/mm/cache.c: In function 'flush_anon_page':
../arch/arc/mm/cache.c:1062:55: warning: passing argument 2 of '__flush_dcache_page' makes integer from pointer without a cast [-Wint-conversion]
__flush_dcache_page((phys_addr_t)page_address(page), page_address(page));
../arch/arc/mm/cache.c:1013:59: note: expected 'long unsigned int' but argument is of type 'void *'
void __flush_dcache_page(phys_addr_t paddr, unsigned long vaddr)
Cc: Elad Kanfi <eladkan@mellanox.com>
Cc: Leon Romanovsky <leonro@mellanox.com>
[ Upstream commit 2423665ec53f2a29191b35382075e9834288a975 ]
Fix build errors in arch/arc/'s delay.h:
- add "extern unsigned long loops_per_jiffy;"
- add <asm-generic/types.h> for "u64"
In file included from ../drivers/infiniband/hw/cxgb3/cxio_hal.c:32:
../arch/arc/include/asm/delay.h: In function '__udelay':
../arch/arc/include/asm/delay.h:61:12: error: 'u64' undeclared (first use in this function)
loops = ((u64) usecs * 4295 * HZ * loops_per_jiffy) >> 32;
../arch/arc/include/asm/delay.h:63:37: error: 'loops_per_jiffy' undeclared (first use in this function)
[ Upstream commit 9e2ea405543d9ddfe05b351f1679e53bd9c11f80 ]
Fix printk format warning in arch/arc/plat-eznps/mtm.c:
In file included from ../include/linux/printk.h:7,
from ../include/linux/kernel.h:14,
from ../include/linux/list.h:9,
from ../include/linux/smp.h:12,
from ../arch/arc/plat-eznps/mtm.c:17:
../arch/arc/plat-eznps/mtm.c: In function 'set_mtm_hs_ctr':
../include/linux/kern_levels.h:5:18: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long int' [-Wformat=]
#define KERN_SOH "\001" /* ASCII Start Of Header */
../include/linux/kern_levels.h:11:18: note: in expansion of macro 'KERN_SOH'
#define KERN_ERR KERN_SOH "3" /* error conditions */
../include/linux/printk.h:308:9: note: in expansion of macro 'KERN_ERR'
printk(KERN_ERR pr_fmt(fmt), ##__VA_ARGS__)
../arch/arc/plat-eznps/mtm.c:166:3: note: in expansion of macro 'pr_err'
pr_err("** Invalid @nps_mtm_hs_ctr [%d] needs to be [%d:%d] (incl)\n",
../arch/arc/plat-eznps/mtm.c:166:40: note: format string is defined here
%ld
The hs_ctr variable can just be int instead of long, so also change
kstrtol() to kstrtoint() and leave the format string as %d.
Also add 2 header files since they are used in mtm.c and we prefer
not to depend on accidental/indirect #includes.
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
[ Upstream commit b1f32ce1c3d2c11959b7e6a2c58dc5197c581966 ]
Add <linux/types.h> to fix build errors.
Both ctop.h and <soc/nps/common.h> use u32 types and cause many
errors.
Examples:
../include/soc/nps/common.h:71:4: error: unknown type name 'u32'
u32 __reserved:20, cluster:4, core:4, thread:4;
../include/soc/nps/common.h:76:3: error: unknown type name 'u32'
u32 value;
../include/soc/nps/common.h:124:4: error: unknown type name 'u32'
u32 base:8, cl_x:4, cl_y:4,
../include/soc/nps/common.h:127:3: error: unknown type name 'u32'
u32 value;
../arch/arc/plat-eznps/include/plat/ctop.h:83:4: error: unknown type name 'u32'
u32 gen:1, gdis:1, clk_gate_dis:1, asb:1,
../arch/arc/plat-eznps/include/plat/ctop.h:86:3: error: unknown type name 'u32'
u32 value;
../arch/arc/plat-eznps/include/plat/ctop.h:93:4: error: unknown type name 'u32'
u32 csa:22, dmsid:6, __reserved:3, cs:1;
../arch/arc/plat-eznps/include/plat/ctop.h:95:3: error: unknown type name 'u32'
u32 value;
[ Upstream commit 05b466bf846d2e8d2f0baf8dfd81a42cc933e237 ]
Fixing compilation issue caused by missing struct nps_host_reg_aux_dpc
definition.
Fixes: 3f9cd874dcc87 ("ARC: [plat-eznps] avoid toggling of DPC register")
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Ofer Levi <oferle@mellanox.com>
[ Upstream commit eb2777397fd83a4a7eaa26984d09d3babb845d2a ]
As for today we don't setup SMP_CACHE_BYTES and cache_line_size for
ARC, so they are set to L1_CACHE_BYTES by default. L1 line length
(L1_CACHE_BYTES) might be easily smaller than L2 line (which is
usually the case BTW). This breaks code.
For example this breaks ethernet infrastructure on HSDK/AXS103 boards
with IOC disabled, involving manual cache flushes
Functions which alloc and manage sk_buff packet data area rely on
SMP_CACHE_BYTES define. In the result we can share last L2 cache
line in sk_buff linear packet data area between DMA buffer and
some useful data in other structure. So we can lose this data when
we invalidate DMA buffer.
| skb->end skb->tail
V | |
V V
packet data | <tail padding> | <useful data in other struct>
SLC line | SLC (L2 cache) line (128B) |
These cache lines will be invalidated when we invalidate skb
linear packet data area before DMA transaction starting.
This leads to issues painful to debug as it reproduces only if
(sk_buff->end - sk_buff->tail) < SLC_LINE_SIZE and
if we have some useful data right after sk_buff->end.
Fix that by hardcode SMP_CACHE_BYTES to max line length we may have.
[ Upstream commit e8708786d4fe21c043d38d760f768949a3d71185 ]
This is used in configs lacking hardware atomics to emulate atomic r-m-w
for user space, implemented by disabling preemption in kernel.
However there are issues in current implementation:
1. Process not terminated if invalid user pointer passed:
i.e. __get_user() failed.
2. The reason for this patch was __put_user() failure not being handled
either, specifically for the COW break scenario.
The zero page is initially wired up and read from __get_user()
succeeds. A subsequent write by __put_user() induces a
Protection Violation, but COW can't finish as Linux page fault
handler is disabled due to preempt disable.
And what's worse is we silently return the stale value to user space.
Fix this specific case by re-enabling preemption and explicitly
fixing up the fault and retrying the whole sequence over.
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
[vgupta: rewrote the changelog]
[ Upstream commit 2f24ef7413a4d91657ef04e77c27ce0b313e6c95 ]
machine_desc->init_per_cpu() hook is supposed to be per cpu
initialization and would seem to apply equally to UP and/or SMP.
Infact the comment in header file seems to suggest it works for
UP too, which was not the case and this patch.
This enables !CONFIG_SMP build for platforms such as hsdk.
[vgupta: trimmeed changelog]
[ Upstream commit 74c11e300c103af47db5b658fdcf28002421e250 ]
GCC built for arc*-*-linux has "-mmedium-calls" implicitly enabled by default
thus we don't see any problems during Linux kernel compilation.
----------------------------->8------------------------
arc-linux-gcc -mcpu=arc700 -Q --help=target | grep calls
-mlong-calls [disabled]
-mmedium-calls [enabled]
But if we try to use so-called Elf32 toolchain with GCC configured for
arc*-*-elf* then we'd see the following failure:
init/do_mounts.o: In function 'init_rootfs':
do_mounts.c:(.init.text+0x108): relocation truncated to fit: R_ARC_S21W_PCREL
against symbol 'unregister_filesystem' defined in .text section in fs/filesystems.o
arc-elf32-ld: final link failed: Symbol needs debug section which does not exist
make: *** [vmlinux] Error 1
That happens because neither "-mmedium-calls" nor "-mlong-calls" are enabled in
Elf32 GCC:
arc-elf32-gcc -mcpu=arc700 -Q --help=target | grep calls
-mmedium-calls [disabled]
Now to make it possible to use Elf32 toolchain for building Linux kernel
we're explicitly add "-mmedium-calls" to CFLAGS.
And since we add "-mmedium-calls" to the global CFLAGS there's no point in
having per-file copies thus removing them.
commit 93312b6da4df31e4102ce5420e6217135a16c7ea upstream.
mprotect(EXEC) was failing for stack mappings as default vm flags was
missing MAYEXEC.
This was triggered by glibc test suite nptl/tst-execstack testcase
What is surprising is that despite running LTP for years on, we didn't
catch this issue as it lacks a directed test case.
gcc dejagnu tests with nested functions also requiring exec stack work
fine though because they rely on the GNU_STACK segment spit out by
compiler and handled in kernel elf loader.
This glibc case is different as the stack is non exec to begin with and
a dlopen of shared lib with GNU_STACK segment triggers the exec stack
proceedings using a mprotect(PROT_EXEC) which was broken.
CC: stable@vger.kernel.org
commit 64234961c145606b36eaa82c47b11be842b21049 upstream.
We used to have pre-set CONFIG_INITRAMFS_SOURCE with local path
to intramfs in ARC defconfigs. This was quite convenient for
in-house development but not that convenient for newcomers
who obviusly don't have folders like "arc_initramfs" next to
the Linux source tree. Which leads to quite surprising failure
of defconfig building:
------------------------------->8-----------------------------
../scripts/gen_initramfs_list.sh: Cannot open '../../arc_initramfs_hs/'
../usr/Makefile:57: recipe for target 'usr/initramfs_data.cpio.gz' failed
make[2]: *** [usr/initramfs_data.cpio.gz] Error 1
So now when more and more people start to deal with our defconfigs
let's make their life easier with removal of CONFIG_INITRAMFS_SOURCE.
Cc: Kevin Hilman <khilman@baylibre.com>
commit 6e3761145a9ba3ce267c330b6bff51cf6a057b06 upstream.
swap was broken on ARC due to silly copy-paste issue.
We encode offset from swapcache page in __swp_entry() as (off << 13) but
were not decoding back in __swp_offset() as (off >> 13) - it was still
(off << 13).
This finally fixes swap usage on ARC.
| # mkswap /dev/sda2
| # swapon -a -e /dev/sda2
| Adding 500728k swap on /dev/sda2. Priority:-2 extents:1 across:500728k
| # free
| total used free shared buffers cached
| Mem: 765104 13456 751648 4736 8 4736
| -/+ buffers/cache: 8712 756392
| Swap: 500728 0 500728
commit af1fc5baa724c63ce1733dfcf855bad5ef6078e3 upstream.
This manifsted as strace segfaulting on HSDK because gcc was targetting
the accumulator registers as GPRs, which kernek was not saving/restoring
by default.
[ Upstream commit a29a25275452c97fe35815f1eb9564f2a07a1965 ]
As we have option in u-boot to set CPU mask for running linux,
we want to pass information to kernel about CPU cores should
be brought up. So we patch kernel dtb in u-boot to set
possible-cpus property.
This also allows us to have correctly setuped MCIP debug mask.
[ Upstream commit f3205de98db2fc8083796dd5ad81b191e436fab8 ]
As of today we use hardcoded MCIP debug mask, so if we launch
kernel via debugger and kick fever cores than HW has all cpus
hang at the momemt of setup MCIP debug mask.
So update MCIP debug mask when the new cpu came online, instead of
use hardcoded MCIP debug mask.
[ Upstream commit 07423d00a2b2a71a97e4287d9262cb83c4c4c89f ]
In SMP systems, GFRC is used for clocksource. However by default the
counter keeps running even when core is halted (say when debugging via a
JTAG debugger). This confuses Linux timekeeping and triggers flase RCU stall
splat such as below:
| [ARCLinux]# while true; do ./shm_open_23-1.run-test ; done
| Running with 1000 processes for 1000 objects
| hrtimer: interrupt took 485060 ns
| create_cnt: 1000
| [ARCLinux]# INFO: rcu_preempt self-detected stall on CPU
| 2-...: (1 GPs behind) idle=a01/1/0 softirq=135770/135773 fqs=0
| INFO: rcu_preempt detected stalls on CPUs/tasks:
| 0-...: (1 GPs behind) idle=71e/0/0 softirq=135264/135264 fqs=0
| 3-...: (1 GPs behind) idle=4e0/0/0 softirq=134304/134304 fqs=0
| (detected by 1, t=13648 jiffies, g=31493, c=31492, q=1)
Starting from ARC HS v3.0 it's possible to tie GFRC to state of up-to 4
ARC cores with help of GFRC's CORE register where we set a mask for
cores which state we need to rely on.
We update cpu mask every time new cpu came online instead of using
hardcoded one or using mask generated from "possible_cpus" as we
want it set correctly even if we run kernel on HW which has fewer cores
than expected (or we launch kernel via debugger and kick fever cores
than HW has)
Note that GFRC halts when all cores have halted and thus relies on
programming of Inter-Core-dEbug register to halt all cores when one
halts.
[ Upstream commit 173a3efd3edb2ef6ef07471397c5f542a360e9c1 ]
Looking at functions with large stack frames across all architectures
led me discovering that BUG() suffers from the same problem as
fortify_panic(), which I've added a workaround for already.
In short, variables that go out of scope by calling a noreturn function
or __builtin_unreachable() keep using stack space in functions
afterwards.
A workaround that was identified is to insert an empty assembler
statement just before calling the function that doesn't return. I'm
adding a macro "barrier_before_unreachable()" to document this, and
insert calls to that in all instances of BUG() that currently suffer
from this problem.
The files that saw the largest change from this had these frame sizes
before, and much less with my patch:
fs/ext4/inode.c:82:1: warning: the frame size of 1672 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/namei.c:434:1: warning: the frame size of 904 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/super.c:2279:1: warning: the frame size of 1160 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/xattr.c:146:1: warning: the frame size of 1168 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/f2fs/inode.c:152:1: warning: the frame size of 1424 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:1195:1: warning: the frame size of 1068 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:395:1: warning: the frame size of 1084 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:298:1: warning: the frame size of 928 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:418:1: warning: the frame size of 908 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_lblcr.c:718:1: warning: the frame size of 960 bytes is larger than 800 bytes [-Wframe-larger-than=]
drivers/net/xen-netback/netback.c:1500:1: warning: the frame size of 1088 bytes is larger than 800 bytes [-Wframe-larger-than=]
In case of ARC and CRIS, it turns out that the BUG() implementation
actually does return (or at least the compiler thinks it does),
resulting in lots of warnings about uninitialized variable use and
leaving noreturn functions, such as:
block/cfq-iosched.c: In function 'cfq_async_queue_prio':
block/cfq-iosched.c:3804:1: error: control reaches end of non-void function [-Werror=return-type]
include/linux/dmaengine.h: In function 'dma_maxpq':
include/linux/dmaengine.h:1123:1: error: control reaches end of non-void function [-Werror=return-type]
This makes them call __builtin_trap() instead, which should normally
dump the stack and kill the current process, like some of the other
architectures already do.
I tried adding barrier_before_unreachable() to panic() and
fortify_panic() as well, but that had very little effect, so I'm not
submitting that patch.
Vineet said:
: For ARC, it is double win.
: 1. Fixes 3 -Wreturn-type warnings
: | ../net/core/ethtool.c:311:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../kernel/sched/core.c:3246:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../include/linux/sunrpc/svc_xprt.h:180:1: warning: control reaches end of
: non-void function [-Wreturn-type]
: 2. bloat-o-meter reports code size improvements as gcc elides the
: generated code for stack return.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=82365
Link: http://lkml.kernel.org/r/20171219114112.939391-1-arnd@arndb.de
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Tested-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Christopher Li <sparse@chrisli.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: "Steven Rostedt (VMware)" <rostedt@goodmis.org>
[ Upstream commit 827cc2fa024dd6517d62de7a44c7b42f32af371b ]
'default N' should be 'default n', though they happen to have the same
effect here, due to undefined symbols (N in this case) evaluating to n
in a tristate sense.
Remove the default from ARC_EMUL_UNALIGNED instead of changing it. bool
and tristate symbols implicitly default to n.
Discovered with the
https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_ulfalizer_Kconfiglib_blob_master_examples_list-5Fundefined.py&d=DwIBAg&c=DPL6_X_6JkXFx7AXWqB0tg&r=c14YS-cH-kdhTOW89KozFhBtBJgs1zXscZojEZQ0THs&m=WxxD8ozR7QQUVzNCBksiznaisBGO_crN7PBOvAoju8s&s=1LmxsNqxwT-7wcInVpZ6Z1J27duZKSoyKxHIJclXU_M&e=
script.
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
commit 10b62a2f785ab55857380f0c63d9fa468fd8c676 upstream.
Most of DT files are compiled under arch/*/boot/dts/, but we have some
other directories, like drivers/of/unittest-data/. We often miss to
add gitignore patterns per directory. Since there are no source files
that end with .dtb or .dtb.S, we can ignore the patterns globally.
Signed-off-by: Rob Herring <robh@kernel.org>
commit 79435ac78d160e4c245544d457850a56f805ac0d upstream.
This used to setup the LP_COUNT register automatically, but now has been
removed.
There was an earlier fix 3c7c7a2fc8811 which fixed instance in delay.h but
somehow missed this one as gcc change had not made its way into
production toolchains and was not pedantic as it is now !
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
Many user space API headers have licensing information, which is either
incomplete, badly formatted or just a shorthand for referring to the
license under which the file is supposed to be. This makes it hard for
Update these files with an SPDX license identifier. The identifier was
chosen based on the license information in the file.
GPL/LGPL licensed headers get the matching GPL/LGPL SPDX license
identifier with the added 'WITH Linux-syscall-note' exception, which is
the officially assigned exception identifier for the kernel syscall
exception:
NOTE! This copyright does *not* cover user programs that use kernel
services by normal system calls - this is merely considered normal use
of the kernel, and does *not* fall under the heading of "derived work".
This exception makes it possible to include GPL headers into non GPL
code, without confusing license compliance tools.
Headers which have either explicit dual licensing or are just licensed
under a non GPL license are updated with the corresponding SPDX
identifier and the GPLv2 with syscall exception identifier. The format
is:
((GPL-2.0 WITH Linux-syscall-note) OR SPDX-ID-OF-OTHER-LICENSE)
SPDX license identifiers are a legally binding shorthand, which can be
used instead of the full boiler plate text. The update does not remove
existing license information as this has to be done on a case by case
basis and the copyright holders might have to be consulted. This will
happen in a separate step.
Philippe Ombredanne. See the previous patch in this series for the
methodology of how this patch was researched.
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
