path: root/arch/arm/Kconfig.debug
2009-07-24Thumb-2: Add Thumb-2 support to the build filesCatalin Marinas
This patch adds the necessary entries to the Makefile and Kconfig files for building the Thumb-2 kernel. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-06-23[ARM] S3C: Remove unused CONFIG_DEBUG_S3C_PORTBen Dooks
Remove the unused CONFIG_DEBUG_S3C_PORT as we currently only have support for using the S3C UARTs via the low-level debug code. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-02-27[ARM] 5412/1: XSCALE: add ice dcc supportJean-Christop PLAGNIOL-VILLARD
SCALE: add ice dcc support Tested on the ixp425 with the ice PEEDI Ack-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-19[ARM] 5386/2: unwind: Add Makefile and Kconfig entries for ARM stack unwindingCatalin Marinas
This patch also makes the frame pointer default to y only if !ARM_UNWIND. LOCKDEP no longer selects FRAME_POINTER if ARM_UNWIND is enabled. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] CONFIG_DEBUG_STACK_USAGESascha Hauer
In early 2.6 days stack utilization instrumentation was made configurable. Seems that arm misses the DEBUG_STACK_USAGE option. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4514/1: S3C: Rename DEBUG_S3C2410_PORT and DEBUG_S3C_UARTBen Dooks
Rename DEBUG_S3C2410_PORT to DEBUG_S3C_PORT as well as DEBUG_S3C2410_UART to DEBUG_S3C_UART as part of the updates to moving to plat-s3c for S3C base support. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORTBen Dooks
Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT to be CONFIG_S3C_LOWLEVEL_UART_PORT as we move to using plat-s3c for base of S3C operations. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove DEBUG_WAITQRussell King
DEBUG_WAITQ appears to have been removed by others, but no one removed the configuration option from ARM. Remote it from both Kconfig.debug and all default configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-04[ARM] Trivial typo fixesEgry Gabor
Trivial typo fixes in Kconfig files (ARM). Signed-off-by: Egry Gabor <gaboregry@t-online.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-09[ARM] Fix typo in arch/arm/Kconfig.debugRussell King
It's called printch, not printchar Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
