git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/soc
The i.MX SoC changes for 4.3:
- Add i.MX6 Ultralite SoC support, which is the newest addition to
i.MX6 family. It integrates a single Cortex-A7 core and a power
management module that reduces the complexity of external power
supply and simplifies power sequencing.
- Change SNVS RTC driver to use syscon interface for register access,
and add SNVS power key driver support.
- Add a second clock for mxc rtc driver, and support device tree probe
for the driver.
- Add FEC MAC reference clock and phy fixup initialization for i.MX6UL
platform.
* tag 'imx-soc-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux:
rtc: snvs: select option REGMAP_MMIO
ARM: imx6ul: add fec MAC refrence clock and phy fixup init
ARM: imx6ul: add fec bits to GPR syscon definition
rtc: mxc: add support of device tree
dt-binding: document the binding for mxc rtc
rtc: mxc: use a second rtc clock
input: snvs_pwrkey: use "wakeup-source" as deivce tree property name
Document: devicetree: input: imx: i.mx snvs power device tree bindings
input: keyboard: imx: add snvs power key driver
Document: dt: fsl: snvs: change support syscon
rtc: snvs: use syscon to access register
ARM: imx: add low-level debug support for i.mx6ul
ARM: imx: add i.mx6ul msl support
Add Kconfig entries, header file changes and addition to the documentation.
The early debug infrastructure is also added for easy development.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Enable low-level debug support for i.MX6UL by adding the
debug port definitions for the SoC.
Singed-off-by: Anson Huang <b20788@freescale.com>
Signed-off-by: Fugang Duan <B38611@freescale.com>
Signed-off-by: Frank Li <Frank.Li@freescale.com>
randconfig testing reveals that DEBUG_SET_MODULE_RONX needs to depend on
MMU otherwise these build errors are observed:
kernel/built-in.o: In function `set_section_ro_nx':
kernel/module.c:1738: undefined reference to `set_memory_nx'
kernel/built-in.o: In function `set_page_attributes':
kernel/module.c:1709: undefined reference to `set_memory_ro'
This is because the pageattr functions are not built for !MMU configs as
they don't have page tables.
Pull ARM updates from Russell King:
"Bigger items included in this update are:
- A series of updates from Arnd for ARM randconfig build failures
- Updates from Dmitry for StrongARM SA-1100 to move IRQ handling to
drivers/irqchip/
- Move ARMs SP804 timer to drivers/clocksource/
- Perf updates from Mark Rutland in preparation to move the ARM perf
code into drivers/ so it can be shared with ARM64.
- MCPM updates from Nicolas
- Add support for taking platform serial number from DT
- Re-implement Keystone2 physical address space switch to conform to
architecture requirements
- Clean up ARMv7 LPAE code, which goes in hand with the Keystone2
changes.
- L2C cleanups to avoid unlocking caches if we're prevented by the
secure support to unlock.
- Avoid cleaning a potentially dirty cache containing stale data on
CPU initialisation
- Add ARM-only entry point for secondary startup (for machines that
can only call into a Thumb kernel in ARM mode). Same thing is also
done for the resume entry point.
- Provide arch_irqs_disabled via asm-generic
- Enlarge ARMv7M vector table
- Always use BFD linker for VDSO, as gold doesn't accept some of the
options we need.
- Fix an incorrect BSYM (for Thumb symbols) usage, and convert all
BSYM compiler macros to a "badr" (for branch address).
- Shut up compiler warnings provoked by our cmpxchg() implementation.
- Ensure bad xchg sizes fail to link"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (75 commits)
ARM: Fix build if CLKDEV_LOOKUP is not configured
ARM: fix new BSYM() usage introduced via for-arm-soc branch
ARM: 8383/1: nommu: avoid deprecated source register on mov
ARM: 8391/1: l2c: add options to overwrite prefetching behavior
ARM: 8390/1: irqflags: Get arch_irqs_disabled from asm-generic
ARM: 8387/1: arm/mm/dma-mapping.c: Add arm_coherent_dma_mmap
ARM: 8388/1: tcm: Don't crash when TCM banks are protected by TrustZone
ARM: 8384/1: VDSO: force use of BFD linker
ARM: 8385/1: VDSO: group link options
ARM: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
ARM: remove __bad_xchg definition
ARM: 8369/1: ARMv7M: define size of vector table for Vybrid
ARM: 8382/1: clocksource: make ARM_TIMER_SP804 depend on GENERIC_SCHED_CLOCK
ARM: 8366/1: move Dual-Timer SP804 driver to drivers/clocksource
ARM: 8365/1: introduce sp804_timer_disable and remove arm_timer.h inclusion
ARM: 8364/1: fix BE32 module loading
ARM: 8360/1: add secondary_startup_arm prototype in header file
ARM: 8359/1: correct secondary_startup_arm mode
ARM: proc-v7: sanitise and document registers around errata
ARM: proc-v7: clean up MIDR access
The i.MX SoC updates for 4.2:
- Add new SoC i.MX7D support, which integrates two Cortex-A7 and one
Cortex-M4 cores.
- Support suspend from IRAM on i.MX53, so that DDR pins can be set to
high impedance for more power saving during suspend.
- Move i.MX clock drivers from arch/arm/mach-imx to drivers/clk/imx.
- Move i.MX GPT timer driver from arch/arm/mach-imx into
drivers/clocksource.
- A couple of clock driver update for VF610 and i.MX6Q.
- A few random code correction and improvement.
* tag 'imx-soc-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (44 commits)
ARM: imx: imx7d requires anatop
clocksource: timer-imx-gpt: remove include of <asm/mach/time.h>
ARM: imx: move timer driver into drivers/clocksource
ARM: imx: remove platform headers from timer driver
ARM: imx: provide gpt device specific irq functions
ARM: imx: get rid of variable timer_base
ARM: imx: define gpt register offset per device type
ARM: imx: move clock event variables into imx_timer
ARM: imx: set up .set_next_event hook via imx_gpt_data
ARM: imx: setup tctl register in device specific function
ARM: imx: initialize gpt device type for DT boot
ARM: imx: define an enum for gpt timer device type
ARM: imx: move timer resources into a structure
ARM: imx: use relaxed IO accessor in timer driver
ARM: imx: make imx51/3 suspend optional
ARM: clk-imx6q: refine sata's parent
ARM: imx: clk-v610: Add clock for I2C2 and I2C3
ARM: mach-imx: iomux-imx31: Use DECLARE_BITMAP
ARM: imx: add imx7d clk tree support
ARM: clk: imx: update pllv3 to support imx7
arch/arm/mach-imx/Kconfig
Add low level uart debug support for imx7d
Signed-off-by: Bai Ping <b51503@freescale.com>
Signed-off-by: Anson Huang <b20788@freescale.com>
It's obviously pointless to dump page tables when the MMU is disabled,
and even trying to build this code results in numerous build errors
like these:
../arch/arm/mm/dump.c:56:11: error: 'L_PTE_USER' undeclared here (not in a function)
.mask = L_PTE_USER,
../arch/arm/mm/dump.c:61:11: error: 'L_PTE_RDONLY' undeclared here (not in a function)
.mask = L_PTE_RDONLY,
../arch/arm/mm/dump.c:66:11: error: 'L_PTE_XN' undeclared here (not in a function)
.mask = L_PTE_XN,
Use the new config symbol ARM_SINGLE_ARMV7M which groups config
symbols used by modern ARMv7-M platforms. This allows supporting
multiple ARMv7-M platforms in one kernel image. However, a common
kernel image requires the combined platforms to share the same
main memory layout to be bootable.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Joachim Eastwood <manabian@gmail.com>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
This introduces a new top level config symbol ARM_SINGLE_ARMV7M
for non-MMU, ARMv7-M platforms. It also support multiple ARMv7-M
platforms in one kernel image since the cores share the same
basic memory layout and interrupt controller. However, this works
only if the combined platforms also have a similar (main) memory
layout.
Using a dedicated symbol for low-level debugging instead of the
arch symbol will make this platform play nice when enabled on a
kernel that supports multiple platforms.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Use the UART0 peripheral for low level debug. Only the UART port 0 is
currently supported.
Signed-off-by: Jun Nie <jun.nie@linaro.org>
Add support for NXP's LPC18xx (Cortex-M3) and LPC43xx (Cortex-M4)
SoCs. These SoCs are NXP's high preformance MCU line and can run at
clock speeds up to 180 MHz for LPC18xx and 204 MHz for LPC43xx.
LPC43xx is more or less a LPC18xx with a Cortex-M4F core and a few
extra peripherals. The LPC43xx series also features one or two
Cortex-M0 cores that can be used to offload the main M4 core.
Reviewed-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Add support for hardware uart1 for earlyprintk support on Arria10 devkit.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Pull ARM SoC multiplatform code changes from Olof Johansson:
"The changes here belong to two main platforms:
- Atmel At91 is flipping the bit and going multiplatform. This
includes some cleanups and removal of code, and the final flip of
config dependencies
- Shmobile has several platforms that are going multiplatform, but
this branch also contains a bunch of cleanups that they weren't
able to keep separate in a good way. THere's also a removal of one
of their SoCs and the corresponding boards (sh7372 and mackerel)"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
ARM: at91/pm: move AT91_MEMCTRL_* to pm.h
ARM: at91/pm: move the standby functions to pm.c
ARM: at91: fix pm_suspend.S compilation when ARMv6 is selected
ARM: at91: add a Kconfig dependency on multi-platform
ARM: at91: drop AT91_TIMER_HZ
ARM: at91: remove hardware.h
ARM: at91: remove SoC headers
ARM: at91: remove useless mach/cpu.h
ARM: at91: remove unused headers
ARM: at91: switch at91_dt_defconfig to multiplatform
ARM: at91: switch to multiplatform
ARM: shmobile: r8a7778: enable multiplatform target
ARM: shmobile: bockw: add sound to DT
ARM: shmobile: r8a7778: add sound to DT
ARM: shmobile: bockw: add devices hooked up to i2c0 to DT
DT: i2c: add trivial binding for OKI ML86V7667 video decoder
ARM: shmobile: r8a7778: common clock framework CPG driver
ARM: shmobile: bockw dts: set extal clock frequency
ARM: shmobile: bockw dts: Move Ethernet node to BSC
ARM: shmobile: r8a73a4: Remove legacy code
Pull ARM SoC platform updates from Olof Johansson:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. In this case, that includes:
- support for the new Annapurna Labs "Alpine" platform
- a rework greatly simplifying adding new platform support to the
MCPM subsystem (Multi-cluster power management)
- cpuidle and PM improvements for Exynos3250
- misc updates for Renesas, OMAP, Meson, i.MX. Some of these could
have gone in other branches but ended up here for various reasons"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits)
ARM: alpine: add support for generic pci
ARM: Exynos: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: DCSCB: tighten CPU validity assertion
ARM: vexpress: migrate TC2 to the new MCPM backend abstraction
ARM: MCPM: move the algorithmic complexity to the core code
ARM: EXYNOS: allow cpuidle driver usage on Exynos3250 SoC
ARM: EXYNOS: add AFTR mode support for Exynos3250
ARM: EXYNOS: add code for setting/clearing boot flag
ARM: EXYNOS: fix CPU1 hotplug on Exynos3250
ARM: S3C64XX: Use fixed IRQ bases to avoid conflicts on Cragganmore
ARM: cygnus: fix const declaration bcm_cygnus_dt_compat
ARM: DRA7: hwmod: Fix the hwmod class for GPTimer4
ARM: DRA7: hwmod: Add data for GPTimers 13 through 16
ARM: EXYNOS: Remove left over 'extra_save'
ARM: EXYNOS: Constify exynos_pm_data array
ARM: EXYNOS: use static in suspend.c
ARM: EXYNOS: Use platform device name as power domain name
ARM: EXYNOS: add support for async-bridge clocks for pm_domains
ARM: omap-device: add missed callback for suspend-to-disk
Pull ARM SoC cleanups from Olof Johansson:
"We've got a fairly large cleanup branch this time. The bulk of this
is removal of non-DT platforms of several flavors:
- Atmel at91 platforms go full-DT, with removal of remaining
board-file based support
- OMAP removes legacy board files for three more platforms
- removal of non-DT mach-msm, newer Qualcomm platforms now live in
mach-qcom
- Freescale i.MX25 also removes non-DT platform support"
Most of the rest of the changes here are fallout from the above, i.e. for
example removal of drivers that now lack platforms, etc.
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits)
mmc: Remove msm_sdcc driver
gpio: Remove gpio-msm-v1 driver
ARM: Remove mach-msm and associated ARM architecture code
ARM: shmobile: cpuidle: Remove the pointless default driver
ARM: davinci: dm646x: Add interrupt resource for McASPs
ARM: davinci: irqs: Correct McASP1 TX interrupt definition for DM646x
ARM: davinci: dm646x: Clean up the McASP DMA resources
ARM: davinci: devices-da8xx: Add support for McASP2 on da830
ARM: davinci: devices-da8xx: Clean up and correct the McASP device creation
ARM: davinci: devices-da8xx: Add interrupt resource to McASP structs
ARM: davinci: devices-da8xx: Add resource name for the McASP DMA request
ARM: OMAP2+: Remove legacy support for omap3 TouchBook
ARM: OMAP3: Remove legacy support for devkit8000
ARM: OMAP3: Remove legacy support for EMA-Tech Stalker board
ARM: shmobile: Consolidate the pm code for R-Car Gen2
ARM: shmobile: r8a7791: Correct SYSCIER value
ARM: shmobile: r8a7790: Correct SYSCIER value
ARM: at91: remove old setup
ARM: at91: sama5d4: remove useless map_io
ARM: at91: sama5 use SoC detection infrastructure
git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom into next/cleanup
Merge "qcom cleanup changes for 4.1" from Kumar Gala:
General cleanups for MSM/QCOM for 4.1
* Removal of mach-msm and associated drivers cleanups that have been
ack'd by associated maintainers
* tag 'qcom-cleanup-for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom:
+ Linux 4.0-rc3
Keeping drivers related to HW tracing on ARM, i.e coresight,
under "drivers/coresight" doesn't make sense when other
architectures start rolling out technologies of the same
nature.
As such creating a new "drivers/hwtracing" directory where all
drivers of the same kind can reside, reducing namespace
pollution under "drivers/".
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Most CoreSight blocks are 64-bit ready. As such move configuration
entries from "arch/arm/Kconfig.config" to the driver's subdirectory
and source the newly created Kconfig from architecture specific
Kconfig.debug files.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
The maintainers for mach-msm no longer have any plans to support
or test the platforms supported by this architecture[1]. Most likely
there aren't any active users of this code anyway, so let's
delete it.
[1] http://lkml.kernel.org/r/20150307031212.GA8434@fifo99.com
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Alpine platform includes UART8250 that can be used for early prints.
Signed-off-by: Saeed Bishara <saeed@annapurnalabs.com>
Signed-off-by: Tsahee Zidenberg <tsahee@annapurnalabs.com>
Remove the stray closing parenthesis in the config description for the
DEBUG_RCAR_GEN2_SCIF0 option.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/multiplatform
Pull "Renesas ARM Based SoC sh7372 SoC Removal Updates for v4.1" from Simon Horman:
* Remove the sh7372 SoC and its mackerel board
* tag 'renesas-sh7372-soc-removal-for-v4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
Documentation: Remove ZBOOT MMC/SDHI utility and docs
ARM: shmobile: sh7372 dtsi: Remove Legacy DTSI file
ARM: shmobile: sh7372: Remove DT binding documentation
ARM: shmobile: sh7372: Remove Legacy C SoC code
ARM: shmobile: sh7372: Remove ZBOOT MMC/SDHI support
ARM: shmobile: mackerel: Remove from MAINTAINERS
ARM: shmobile: mackerel: Remove defconfig
ARM: shmobile: mackerel: Remove mach-type entry
ARM: shmobile: mackerel: Remove DT binding documentation
ARM: shmobile: mackerel dts: Remove Legacy DTS file
ARM: shmobile: mackerel: Remove Legacy C board code
ARM: shmobile: mackerel: Remove ZBOOT code
[arnd: The sh7372 platform is rather dated and is believed to
have no active users on modern kernels. It stands in the way
of converting all of mach-shmobile to be multiplatform capable,
as adding pinctrl and common-clock support for it would be more
work than it's worth. As always, should any legitimate upstream
users show up in the future, we will revert this removal]
Convert ARCH_SHMOBILE_LEGACY to make use of <debug/uncompress.h>
and remove the now unused <mach/uncompress.h>.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Remove support for the legacy Cortex-A8 based sh7372 SoC.
The Linux kernel still lacks DT bindings for the sh7372 INTC
interrupt controller so DT multiplatform support is not possibile.
Also, the sh7372 SoC never went into mass production anyway so to
aid migration to DT multiplatform simply get rid of sh7372 support.
Pull ARM SoC platform changes from Olof Johansson:
"New and updated SoC support. Also included are some cleanups where
the platform maintainers hadn't separated cleanups from new developent
in separate branches.
Some of the larger things worth pointing out:
- A large set of changes from Alexandre Belloni and Nicolas Ferre
preparing at91 platforms for multiplatform and cleaning up quite a
bit in the process.
- Removal of CSR's "Marco" SoC platform that never made it out to the
market. We love seeing these since it means the vendor published
support before product was out, which is exactly what we want!
New platforms this release are:
- Conexant Digicolor (CX92755 SoC)
- Hisilicon HiP01 SoC
- CSR/sirf Atlas7 SoC
- ST STiH418 SoC
- Common code changes for Nvidia Tegra132 (64-bit SoC)
We're seeing more and more platforms having a harder time labelling
changes as cleanups vs new development -- which is a good sign that
we've come quite far on the cleanup effort. So over time we might
start combining the cleanup and new-development branches more"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits)
ARM: at91/trivial: unify functions and machine names
ARM: at91: remove at91_dt_initialize and machine init_early()
ARM: at91: change board files into SoC files
ARM: at91: remove at91_boot_soc
ARM: at91: move alternative initial mapping to board-dt-sama5.c
ARM: at91: merge all SOC_AT91SAM9xxx
ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init()
ARM: digicolor: select syscon and timer
ARM: zynq: Simplify SLCR initialization
ARM: zynq: PM: Fixed simple typo.
ARM: zynq: Setup default gpio number for Xilinx Zynq
ARM: digicolor: add low level debug support
ARM: initial support for Conexant Digicolor CX92755 SoC
ARM: OMAP2+: Add dm816x hwmod support
ARM: OMAP2+: Add clock domain support for dm816x
ARM: OMAP2+: Add board-generic.c entry for ti81xx
ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage
ARM: at91: remove unused mach/system_rev.h
ARM: at91: stop using HAVE_AT91_DBGUx
ARM: at91: fix ordering of SRAM and PM initialization
"This is a good healthy set of various code removals. Total net delta
is 8100 lines removed.
Among the larger cleanups are:
- Removal of old Samsung S3C DMA infrastructure by Arnd
- Removal of the non-DT version of the 'lager' board by Magnus Damm
- General stale code removal on OMAP and Davinci by Rickard Strandqvist
- Removal of non-DT support on am3517 platforms by Tony Lindgren
... plus several other cleanups of various platforms across the board"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (47 commits)
ARM: sirf: drop redundant function and marco declaration
arm: omap: specify PMUs are for ARMv7 CPUs
arm: shmobile: specify PMUs are for ARMv7 CPUs
arm: iop: specify PMUs are for XScale CPUs
arm: pxa: specify PMUs are for XScale CPUs
arm: realview: specify PMU types
ARM: SAMSUNG: remove unused DMA infrastructure
ARM: OMAP3: Add back Kconfig option MACH_OMAP3517EVM for ASoC
ARM: davinci: Remove CDCE949 driver
ARM: at91: remove useless at91rm9200_set_type()
ARM: at91: remove useless at91rm9200_dt_initialize()
ARM: at91: move debug-macro.S into the common space
ARM: at91: remove useless at91_sysirq_mask_rtx
ARM: at91: remove useless config MACH_AT91SAM9_DT
ARM: at91: remove useless config MACH_AT91RM9200_DT
ARM: at91: remove unused mach/memory.h
ARM: at91: remove useless header file includes
ARM: at91: remove unneeded header file
rtc: at91/Kconfig: remove useless options
ARM: at91/Documentation: add a README for Atmel SoCs
Use the USART peripheral as UART for low level debug. Only the UA0 port is
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91 into next/soc
Merge "at91: cleanup/soc for 3.20 #3 (bis) from Nicolas Ferre:
Third batch of cleanup/soc for 3.20:
- several fixes and adjustments following the last cleanup batch
- removal of some unused Kconfig options
- slight PM and pm_idle rework to ease future rework
- removal of unneeded mach/system_rev.h
* tag 'at91-cleanup3' of git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91:
ARM: at91: sam9: set arm_pm_idle from sam9_dt_device_init
ARM: at91: fix sam9n12 and sam9x5 arm_pm_idle
ARM: at91: mark const init data with __initconst instead of __initdata
ARM: at91: fix PM initialization for newer SoCs
ARM: at91: fix Kconfig.debug by adding DEBUG_AT91_UART option
In order to remove SOC_SAM9xxx options, stop using HAVE_AT91_DBGUx.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The DEBUG_AT91_UART Kconfig option was forgotten when moving the
AT91 debug-macro.S file. Add it and use it for the at91.S compilation.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom into next/soc
merge "qcom SoC changes for v3.20-2" from Kumar Gala:
Qualcomm ARM Based SoC Updates for v3.20-2
* Various bug fixes and minor feature additions to scm code
* Added big-endian support to debug MSM uart
* Added big-endian support to ARCH_QCOM
* Cleaned up some Kconfig options associated with ARCH_QCOM
* Added Andy Gross as co-maintainer
* tag 'qcom-soc-for-3.20-2' of git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom:
MAINTAINERS: Add co-maintainer for ARM/Qualcomm Support
ARM: qcom: Drop unnecessary selects from ARCH_QCOM
ARM: qcom: Fix SCM interface for big-endian kernels
ARM: qcom: scm: Clarify boot interface
ARM: qcom: Add SCM warmboot flags for quad core targets.
ARM: qcom: scm: Add logging of actual return code from scm call
ARM: qcom: scm: Flush the command buffer only instead of the entire cache
ARM: qcom: scm: Get cacheline size from CTR
ARM: qcom: scm: Fix incorrect cache invalidation
ARM: qcom: Select ARCH_SUPPORTS_BIG_ENDIAN
ARM: debug: msm: Support big-endian CPUs
ARM: debug: Update MSM and QCOM DEBUG_LL help
next/soc
Merge "ARM: mediatek: soc changes for v3.20" from Matthias Brugger:
This adds config options for the different Mediatek SoC. We need this so that
the pinctrl driver does not bloat the kernel binary.
Apart we change the Kconfig description and add the config option for mt6592
low-level debug option.
* tag 'v3.20-next-soc1' of https://github.com/mbgg/linux-mediatek:
ARM: mediatek: Low-level-debug for mt6592
ARM: mediatek: Add config options for mediatek SoCs.
Merge "at91: cleanup for 3.20 #2" from Nicolas Ferre:
Second batch of cleanup for 3.20:
- By reworking the PM code, we can remove the AT91 more specific initialization
- We are using DT for SRAM initialization now, so we can remove its explicit
mapping
- The PMC clock driver now hosts IDLE function for at91rm9200 with other
SoCs ones.
* tag 'at91-cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91: (37 commits)
ARM: at91: move at91rm9200_idle() to clk/at91/pmc.c
ARM: at91: remove unused at91_init_sram
ARM: at91: sama5d4: remove useless call to at91_init_sram
ARM: at91: remove useless map_io
ARM: at91: pm: prepare for multiplatform
ARM: at91: pm: add UDP and UHP checks to newer SoCs
ARM: at91: pm: use the mmio-sram pool to access SRAM
ARM: at91: pm: rework cpu detection
ARM: at91: dts: sama5d3: add ov2640 camera sensor support
ARM: at91: dts: sama5d3: change name of pinctrl of ISI_MCK
ARM: at91: dts: sama5d3: change name of pinctrl_isi_{power,reset}
ARM: at91: dts: sama5d3: move the isi mck pin to mb
ARM: at91: dts: sama5d3: add missing pins of isi
ARM: at91: dts: sama5d3: split isi pinctrl
ARM: at91: dts: sama5d3: add isi clock
ARM: at91/dt: ethernut5: use at91sam9xe.dtsi
ARM: at91/dt: Add a dtsi for at91sam9xe
ARM: at91/dt: add SRAM nodes
ARM: at91/dt: at91rm9200ek: enable RTC
ARM: at91/dt: rm9200: add RTC node
Add the support of Hisilicon HiP01 debug uart.
The uart of hip01 is 8250 compatible.
Signed-off-by: Wang Long <long.wanglong@huawei.com>
Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux into next/soc
Merge "CSR atlas7 debug ports for 3.20" from Barry Song:
add debug ports for CSRatlas7 SoC
Because Marco chip has never shipped to customers and has been replaced
by Atlas7, so we do the below
- drop Marco's debug port
- add debug ports for Atlas7
* tag 'atlas7-lldebug-for-3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux:
ARM: sirf: add two debug ports for CSRatlas7 SoC
ARM: sirf: drop Marco low-level debug port
When building a multi_v7_defconfig kernel it is not possible to configure
DEBUG_LL to use any serial device except a ARM Primecell PL01X, or more
accurately and worse, it is possible to configure a different serial
device but KConfig does not honour this request. In fact this also
overrides the user selection for some of the single platform kernels, for
example I don't think DEBUG_LL can be targeted at ICE or semihosted
supervisor for ARCH_VERSATILE.
This happens because DEBUG_UART_PL01X is automatically enabled by
some architectures and this means user decisions made regarding
the DEBUG_LL backend will be overridden. Problem is fixed by removing the
automatic enabling of this option.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
On EP93XX uncompress.h uses CONFIG_DEBUG_UART_PHYS instead of a hard
coded serial port. This means the build breaks when DEBUG_LL
(and DEBUG_LL_UART_PL01X) is not enabled.
This is fixed by adding a new dependency.
As part of the migration we introduce DEBUG_UART_PHYS/DEBUG_UART_VIRT
which default to UART1 but allow a user to configure UART2 or UART3.
We also introduce symbolic names for the registers and flags.
Acked-by: Arnd Bergmann <arnd.bergmann@linaro.org>
The omap1's debug-macro.S is similar to the generic 8250 code. Compared to
the 8520 code the omap1 macro automatically determines what UART to use
based on breadcrumbs left by the bootloader and automatically copes with
the eccentric register layout on OMAP7XX.
This patch drops both these features and relies instead on the generic
8250 macros:
1. Dropping support for the bootloader breadcrumbs is identical to the
way the migration was handled for OMAP2 (see 808b7e07464d...).
2. Support for OMAP7XX still exists but it must be configured by hand
(DEBUG_OMAP7XXUART1/2/3) rather than handled at runtime.
Cc: Arnd Bergmann <arnd.bergmann@linaro.org>
Cc: linux-omap@vger.kernel.org
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
As part of the migration a couple of uart definitions have been copied
from of the platform specific header files.
Cc: Greg Ungerer <gerg@uclinux.org>
Only a very small handful of platforms support DEBUG_LL_UART_NONE but it
lurks in the menus of every single platform config ready to break the
build. This is an especial problem for defconfig/oldconfig since it is
often selected by default.
This patch solves the problem by removing this option. Any platforms
still depending upon this option must be migrated.
The default value for DEBUG_CNS3xxx appears twice. This patch removes
the one with the wrong sort order.
This patch changes the description of the low-level-debug port. SoC mt8127 and
mt6592 have the same uart port and the same mapping. We just change the
description to add low-level-debug to mt6592.
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
this patch adds UART0 and UART1 as LLUART port, as the new Atlas7
registers layout are different, it also refines some names of old
hard-coded MARCOs and uses CONFIG_DEBUG_UART_PHYS/DEBUG_UART_VIRT
to define different base addresses for multiple ports.
Signed-off-by: Guo Zeng <Guo.Zeng@csr.com>
Signed-off-by: Zhiwu Song <Zhiwu.Song@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
Add another SoC address for apq8064 and use DEBUG_UART_VIRT
instead of DEBUG_UART_BASE because the former actually exists.
Move debug-macro.S from include/mach/ to include/debug where all other common
debug macros are.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Marco will not be supported any more. it has been replaced by CSR
Atlas7.
