Signed-off-by: Jon Medhurst <tixy@yxit.co.uk>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
The barriers implemented in arch/arm/mach-tegra/mach/barriers.h
are exactly the same as the default barriers implemented in
arch/arm/include/asm/system.h. Remove barriers.h from Tegra,
and don't select ARCH_HAS_BARRIERS.
Signed-off-by: Colin Cross <ccross@android.com>
Acked-by: Olof Johansson <olof@lixom.net>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
clocksource support. This achieves several things:
1. It means we get rid of all these helper functions which frankly should
never have been necessary.
2. It means omap_readl() inside these helper functions does not appear in
ftrace output.
Another plus is that we avoid the overhead of calculating the address to
read each time, but a minus is that we use readl() which has a barrier.
[tony@atomide.com: updated to use ioremap]
SiRFprimaII is the latest generation application processor from CSR’s
Multifunction SoC product family. Designed around an ARM cortex A9 core,
high-speed memory bus, advanced 3D accelerator and full-HD multi-format
video decoder, SiRFprimaII is able to meet the needs of complicated
applications for modern multifunction devices that require heavy concurrent
applications and fluid user experience. Integrated with GPS baseband,
analog and PMU, this new platform is designed to provide a cost effective
solution for Automotive and Consumer markets.
This patch adds the basic support for this SoC and EVB board based on device
tree. It is following the ZYNQ of Xilinx in some degree.
Signed-off-by: Binghua Duan <Binghua.Duan@csr.com>
Signed-off-by: Rongjun Ying <Rongjun.Ying@csr.com>
Signed-off-by: Zhiwu Song <Zhiwu.Song@csr.com>
Signed-off-by: Yuping Luo <Yuping.Luo@csr.com>
Signed-off-by: Bin Shi <Bin.Shi@csr.com>
Signed-off-by: Huayi Li <Huayi.Li@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
CNS3XXX is based on MPCore, so select the right CPU option for it.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
The patch converts mxc tzic interrupt controller to use generic irq
chip.
The scu_power_mode function can be used on UP builds as it drives signals
to an SOC power controller. So make it selectable for !SMP.
Use the generic power domains support introduced by the previous
patch to implement support for power domains on SH7372.
Acked-by: Paul Mundt <lethal@linux-sh.org>
This allows a ROM-able zImage to be written to eSD and for SuperH Mobile
ARM to boot directly from the SDHI hardware block.
This is achieved by the MaskROM loading the first portion of the image into
MERAM and then jumping to it. This portion contains loader code which
copies the entire image to SDRAM and jumps to it. From there the zImage
boot code proceeds as normal, uncompressing the image into its final
location and then jumping to it.
Acked-by: Magnus Damm <magnus.damm@gmail.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
The 1st board support is minimal to get a system up and running
on the Xilinx platform.
This platform reuses the clock implementation from plat-versatile, and
it depends entirely on CONFIG_OF support. There is only one board
support file which obtains all device information from a device tree
dtb file which is passed to the kernel at boot time.
Signed-off-by: John Linn <john.linn@xilinx.com>
Allow SoCs to enable the scatterlist chaining support, which allows
scatterlist tables to be broken up into smaller allocations.
As support for this feature depends on the implementation details of
the users of the scatterlists, we can't enable this globally without
auditing all the users, which is a very big task. Instead, let SoCs
progressively switch over to using this.
SoC drivers using scatterlists and SoC DMA implementations need
auditing before this option can be enabled for the SoC.
Hotplug support was added in 9f1890a (msm: hotplug: support cpu hotplug
on msm, 2010-12-02)
Signed-off-by: Jeff Ohlstein <johlstei@codeaurora.org>
In commit eb33575c ("[ARM] Double check memmap is actually valid with a
memmap has unexpected holes V2"), a new function, memmap_valid_within,
was introduced to mmzone.h so that holes in the memmap which pass
pfn_valid in SPARSEMEM configurations can be detected and avoided.
The fix to this problem checks that the pfn <-> page linkages are
correct by calculating the page for the pfn and then checking that
page_to_pfn on that page returns the original pfn. Unfortunately, in
SPARSEMEM configurations, this results in reading from the page flags to
determine the correct section. Since the memmap here has been freed,
junk is read from memory and the check is no longer robust.
In the best case, reading from /proc/pagetypeinfo will give you the
wrong answer. In the worst case, you get SEGVs, Kernel OOPses and hung
CPUs. Furthermore, ioremap implementations that use pfn_valid to
disallow the remapping of normal memory will break.
This patch allows architectures to provide their own pfn_valid function
instead of using the default implementation used by sparsemem. The
architecture-specific version is aware of the memmap state and will
return false when passed a pfn for a freed page within a valid section.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
devel-stable
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable
arch/arm/Kconfig
arch/arm/mach-exynos4/mach-nuri.c
select ARM_PATCH_PHYS_VIRT
as with ARM_PATCH_PHYS_VIRT you can patch boot_params at runtime or any recent
bootloader will provide a valid atags pointer in r2
as point out by Russell on AT91 we never use XIP
so se do not need PLAT_PHYS_OFFSET
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
we do not change the clock naming convention so does not need to switch
the AVR32 yet
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
into devel-stable
arch/arm/Kconfig
arch/arm/mach-ns9xxx/include/mach/uncompress.h
and 'spear' into for-linus
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
bcmring has a set of four sp804 timers incorporated, yet it has its
own copy of the sp804 code. Convert its clocksource implementation
to the standard sp804 support code.
Cc: Jiandong Zheng <jdzheng@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Convert the MXS timrotv2 32-bit down counting clocksource to the
generic clocksource infrastructure.
Cc: Sascha Hauer <kernel@pengutronix.de>
Acked-by: Shawn Guo <shawn.guo@freescale.com>
Convert SPEAr platforms 16-bit up counting clocksource, which requires
a 16-bit register access read rather than 32-bit.
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Convert the W90x900 24-bit down-counting clocksource to the generic
mmio clocksource infrastructure
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Convert SP804, MXC, Nomadik and Orion 32-bit down-counting clocksources
to generic mmio clocksource infrastructure.
Cc: Alessandro Rubini <rubini@unipv.it>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300
to use the generic mmio clocksource recently introduced.
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: "Hans J. Koch" <hjk@hansjkoch.de>
Acked-by: Colin Cross <ccross@android.com>
Cc: Erik Gilling <konkers@android.com>
Cc: Olof Johansson <olof@lixom.net>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
As a result of c42321c (genirq: Make generic irq chip depend on
CONFIG_GENERIC_IRQ_CHIP), we now need those platforms using this in
my tree to select this symbol.
Acked-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Kevin Hilman <khilman@ti.com>
The current mainline codes of ARCH_S5PC100 cannot support
suspend to ram. So needs this for preventing build error.
Cc: Russell King <rmk+kernel at arm.linux.org.uk>
Signed-off-by: Kukjin Kim <kgene.kim at samsung.com>
This patch allows the provided CONFIG_CMDLINE to be concatenated
with the one provided by the boot loader. This is useful to
merge the static values defined in CONFIG_CMDLINE with the
boot loader's (possibly) more dynamic values, such as startup
reasons and more.
Signed-off-by: Victor Boivie <victor.boivie@sonyericsson.com>
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonyericsson.com>
Signed-off-by: Oskar Andero <oskar.andero@sonyericsson.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Improve the Kconfig help texts for the phys-to-virt patching feature.
Highmem on ARM has been around for a while now, without any major issues
being raised. So, drop the experimental status of this feature.
SMP on ARM has been around for a while now, without any major issues
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Add some basic empty infrastructure for DT support on ARM.
v5: - Fix off-by-one error in size calculation of initrd
- Stop mucking with cmd_line, and load command line from dt into
boot_command_line instead which matches the behaviour of ATAGS booting
v3: - moved cmd_line export and initrd setup to this patch to make the
series bisectable.
- switched to alloc_bootmem_align() for allocation when
unflattening the device tree. memblock_alloc() was not the
right interface.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Disabled legacy support for ARMv6 architecture on Dove platform.
Latest Dove HW uses only ARMv7 model.
Signed-off-by: Konstantin Porotchkin <kostap@marvell.com>
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
Now that both users of plat-stmp have been deleted in previous patches,
delete the platform, too.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
The port is actually unmaintained and only received global
cleanups and a few build fixes since mid 2008.
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into fixes
The HIGHPTE config option depends on !OUTER_CACHE. However, there is no
set_pte_ext() function that does outer cache maintenance by physical
address, hence no need for such restriction.
Offering CONFIG_PM_SLEEP for CPUs which do not support suspend leads to
build errors, so only set CONFIG_ARCH_SUSPEND_POSSIBLE if we have a CPU
selected which supports suspend.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits)
ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support
ARM: 6838/1: etm: fix section mismatch warning
ARM: 6837/1: remove unused pci_fixup_prpmc1100
ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC
Fix the broken build for Marvell Dove platform.
ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency
ARM: 6834/1: perf: reset counters on all CPUs during initialisation
ARM: 6833/1: perf: add required isbs() to ARMv7 backend
ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues
ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile
arm: mach-mx3: pcm043: add write-protect and card-detect for SD1
eukrea_mbimxsd51: add SD Card detect
eukrea_mbimxsd25-baseboard: add SD card detect
mx3/eukrea_mbimxsd-baseboard: add SD card detect support
mx3/eukrea_mbimxsd-baseboard: fix gpio request
ARM: mxs/mx28evk: add mmc device
ARM: mxs/mx23evk: add mmc device
ARM: mxs: dynamically allocate mmc device
ARM: mx51_efika: update platform data for new mfd changes
mx2/iomux: Set direction for CSPI2 pins
Use the generic version and just keep the arch specific output.
devel-stable
The current mainline codes of ARCH_S5P64X0 and ARCH_S5P6442
can not support suspend to ram. So needs this for preventing
build error on them.
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Len Brown <len.brown@intel.com>
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (35 commits)
ARM: Update (and cut down) mach-types
ARM: 6771/1: vexpress: add support for multiple core tiles
ARM: 6797/1: hw_breakpoint: Fix newlines in WARNings
ARM: 6751/1: vexpress: select applicable errata workarounds in Kconfig
ARM: 6753/1: omap4: Enable ARM local timers with OMAP4430 es1.0 exception
ARM: 6759/1: smp: Select local timers vs broadcast timer support runtime
ARM: pgtable: add pud-level code
ARM: 6673/1: LPAE: use phys_addr_t instead of unsigned long for start of membanks
ARM: Use long long format when printing meminfo physical addresses
ARM: integrator: add Integrator/CP sched_clock support
ARM: realview/vexpress: consolidate SMP bringup code
ARM: realview/vexpress: consolidate localtimer support
ARM: integrator/versatile: consolidate FPGA IRQ handling code
ARM: rationalize versatile family Kconfig/Makefile
ARM: realview: remove old AMBA device DMA definitions
ARM: versatile: remove old AMBA device DMA definitions
ARM: vexpress: use new init_early for clock tree and sched_clock init
ARM: realview: use new init_early for clock tree and sched_clock init
ARM: versatile: use new init_early for clock tree and sched_clock init
ARM: integrator: use new init_early for clock tree init
