Patch from Alessandro Zummo
This patches add the 1-wire drivers
to the ARM Kconfig.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Patch from Catalin Marinas
Chapter B2.7.3 in the latest ARM ARM (with v6 information) states that
the completion of a TLB maintenance operation is only guaranteed by
the execution of a DSB (Data Syncronization Barrier, formerly Data
Write Barrier or Drain Write Buffer).
Note that a DSB is only needed in the flush_tlb_kernel_* functions
since the completion is guaranteed by a mode change (i.e. switching
back to user mode) for the flush_tlb_user_* functions.
Manual conflict merge of arch/arm/Kconfig
Patch from Nicolas Pitre
Although OABI_COMPAT works fine in most cases, it is still experimental
and could be for ever since it is nearly impossible to handle
everything, e.g. ioctls.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Patch from Martin Michlmayr
Minor typographical and spelling fixes in Konfig
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Kconfig | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
Add help descriptions to ARCH config items that don't have one.
Kconfig | 32 ++++++++++++++++++++++++++++++--
mach-clps711x/Kconfig | 2 ++
2 files changed, 32 insertions(+), 2 deletions(-)
MTD_XIP depends on having working asm/mtd-xip.h; it's not just per-architecture
(arm-only, as current Kconfig would have it), but actually per-subarch as
well. Introduced a new symbol (ARCH_MTD_XIP) set by arch Kconfig; MTD_XIP
depends on it.
Enjoy !
kernel
We need NWFPE if we want to support execution of legacy binaries with
an EABI kernel.
This adds the configuration option, and disables any FPA floating point
emulators which are not EABI compatible.
It also disables Acorn RISC OS/Arthur binary support when CONFIG_EABI=y
since it is incompatible with an EABI kernel.
This is the core of a small SPI framework, implementing the model of a
queue of messages which complete asynchronously (with thin synchronous
wrappers on top).
- It's still less than 2KB of ".text" (ARM). If there's got to be a
mid-layer for something so simple, that's the right size budget. :)
- The guts use board-specific SPI device tables to build the driver
model tree. (Hardware probing is rarely an option.)
- This version of Kconfig includes no drivers. At this writing there
are two known master controller drivers (PXA/SSP, OMAP MicroWire)
and three protocol drivers (CS8415a, ADS7846, DataFlash) with LKML
mentions of other drivers in development.
- No userspace API. There are several implementations to compare.
Implement them like any other driver, and bind them with sysfs.
The changes from last version posted to LKML (on 11-Nov-2005) are minor,
and include:
- One bugfix (removes a FIXME), with the visible effect of making device
names be "spiB.C" where B is the bus number and C is the chipselect.
- The "caller provides DMA mappings" mechanism now has kerneldoc, for
DMA drivers that want to be fancy.
- Hey, the framework init can be subsys_init. Even though board init
logic fires earlier, at arch_init ... since the framework init is
for driver support, and the board init support uses static init.
- Various additional spec/doc clarifications based on discussions
with other folk. It adds a brief "thank you" at the end, for folk
who've helped nudge this framework into existence.
As I've said before, I think that "protocol tweaking" is the main support
that this driver framework will need to evolve.
Update the SPI framework to remove a potential priority inversion case by
reverting to kmalloc if the pre-allocated DMA-safe buffer isn't available.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Other machines may wish to make use of the VIC support code, so
move it to arch/arm/common.
Patch from SAN People
Following changes were made to clock.c:
1) Replaced <asm/hardware/clock.h> with <linux/clk.h>
2) Removed old unused clk_enable & clk_disable.
3) Replaced clk_use/clk_unuse with clk_enable/clk_disable.
Otherwise it's the same as the previous patch.
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
Configurable 16-bit UID and friends support
This allows turning off the legacy 16 bit UID interfaces on embedded platforms.
3330172 529036 190556 4049764 3dcb64 vmlinux-baseline
3328268 529040 190556 4047864 3dc3f8 vmlinux
UID16 was accidentially disabled for !EMBEDDED.
Signed-off-by: Matt Mackall <mpm@selenic.com>
EPXA10DB seems to be uncared for:
- the "PLD" code has never been merged
- no one has reported that this platform has been broken since
at least 2.6.10
- interest seems to have dried up around March 2003.
Therefore, remove EPXA10DB support.
Patch from Richard Purdie
ARM doesn't use ACPI so ARM's apm implementation has no need to depend
on PM_LEGACY. This patch removes that dependency.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
ISA_DMA_API tells the rest of the kernel if the ISA DMA API is
available. Select this symbol only on machine types which make
use of the ISA DMA API.
Make building of arch/arm/kernel/dma.c depend on this symbol -
if a machine does not support the ISA DMA API, it's pointless
building this file.
Rather than defining our own PM option, use kernel/power/Kconfig.
This fixes build errors introduced by
bca73e4bf8563d83f7856164caa44d5f42e44cca
This fixes compilation for collie after -rc1 platform_device
changes. And yes, it even boots.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Patch from Tony Lindgren
This patch adds support for omap24xx series of processors.
The files live in arch/arm/mach-omap2, and share common
files with omap15xx and omap16xx processors in
arch/arm/plat-omap.
Omap24xx support was originally added for 2.6.9 by TI.
This code was then improved and integrated to share common
code with omap15xx and omap16xx processors by various
omap developers, such as Paul Mundt, Juha Yrjola, Imre Deak,
Tony Lindgren, Richard Woodruff, Nishant Menon, Komal Shah
et al.
Add platform specific parts for local timer support for the
Realview board.
Add infrastructure for supporting per-cpu local timers to update
the profiling information and update system time accounting.
This patch puts into place the final piece of the puzzle for SMP
support on ARM.
Patch from Lennert Buytenhek
nwfpe extended precision emulation used to be broken on big-endian
and was therefore disabled. This patch fixes nwfpe so that it copies
extended precision floats to/from userspace in the proper word order
(similar to patch #2046, see the description of that patch for an
explanation) and reenables the Kconfig option.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
No longer maintained
This patch adds the infrastructure to support hotplug CPU on ARM
platforms.
Support for RealView EB.
Patch from Bellido Nicolas
The AAEC-2000 has an ARM PrimeCell PL110 Color LCD Controller.
This patch contains the platform glue that will be used by specific boards.
Signed-off-by: Nicolas Bellido <ml@acolin.be>
Patch from Jon Ringle
Updated 2898/1 per comments:
- Removed fixup
- Moved code in mach-mp1000/ to mach-clps711x/
- Cleaned up code in mp1000-seprom.c. Eliminated code that displayed the contents of the eeprom
Please comment.
Signed-off-by: Jon Ringle
Randy cleaned out the bulk of these stale references to the now long gone
Documentation/smp.tex back in 2004. I followed this up with a few more
sweeps. Somehow, these have managed to sneak back in since.
I can't seem to figure out a contact point for M32R (no one listed in
MAINTAINERS!), but, these patches are only but trivial.
Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Sanitized and fixed floppy dependencies: split the messy dependencies for
BLK_DEV_FD by introducing a new symbol (ARCH_MAY_HAVE_PC_FDC), making
BLK_DEV_FD depend on that one and taking declarations of ARCH_MAY_HAVE_PC_FDC
to arch/*/Kconfig. While we are at it, fixed several obvious cases when
BLK_DEV_FD should have been excluded (architectures lacking asm/floppy.h
are *not* going to have floppy.c compile, let alone work).
If you can come up with better name for that ("this architecture might
have working PC-compatible floppy disk controller"), you are more than
welcome - just s/ARCH_MAY_HAVE_PC_FDC/your_prefered_name/g in the patch
below...
This kills i386-specific stuff from arm Kconfig. Please apply,
SMP is broken on arm; marked as such
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
Add support for the core of the multimedia communication port
framework. This is a port used to communicate with devices
with two DMA paths and a control path.
Create a new top-level menu named "Networking" thus moving
net related options and protocol selection way from the drivers
menu and up on the top-level where they belong.
To implement this all architectures has to source "net/Kconfig" before
drivers/*/Kconfig in their Kconfig file. This change has been
implemented for all architectures.
Device drivers for ordinary NIC's are still to be found
in the Device Drivers section, but Bluetooth, IrDA and ax25
are located with their corresponding menu entries under the new
networking menu item.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Part 1: Configuration files and Makefiles.
This patch adds minimal cpufreq support for OMAP
taking advantage of the clock framework.
This patch by various OMAP developers syncs the OMAP
specific arch files with the linux-omap tree.
This patch was suggested by RMK, and adds a warning on the accuracy
of timekeeping when using dynamic tick on some platforms. Depending
on the timer implementation, dynamic tick may affect the accuracy of
timekeeping.
Currently at least OMAP is known to have accurate timekeeping with
dynamic tick.
This patch adds support for Dynamic Tick Timer for ARM. Dynamic Tick is
also known as VST (Variable Scheduling Timeouts).
Dynamic Tick has been in use in the OMAP tree since last October. The
patch is not intrusive, and does not do anything unless CONFIG_NO_IDLE_HZ
is defined. This patch has the following fixed based on comments from
RMK:
- Time is updated before calling interrupt handlers.
- Added new interrupt flag SA_TIMER to avoid duplicate timer interrupts
- Moved struct dyn_tick_timer to time.h until we at some point probably
have an arch independent dyn-tick.h
- Cleaned up testing for DYN_TICK_ENABLED in irq.c
I've cleaned up this patch to fix some remaining issues:
- Call the timer tick handler with irqs disabled, as it would be from
a normal interrupt
- if we have a dyn_tick, we better implement all methods.
- generic timer_dyn_reprogram() call, to be called before sleeping
- added command line option - "dyntick=" to allow boot-time control
of this feature
-- rmk
The merge of sparsemem broke ARM discontigmem. Fix it.
For all architectures, this just means that you'll see a "Memory Model"
choice in your architecture menu. For those that implement DISCONTIGMEM,
you may eventually want to make your ARCH_DISCONTIGMEM_ENABLE a "def_bool
y" and make your users select DISCONTIGMEM right out of the new choice
menu. The only disadvantage might be if you have some specific things that
you need in your help option to explain something about DISCONTIGMEM.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
