faulty ASID
commit cdf357f1e13a08a11261edacb3083746f65c1ed9 upstream.
On versions of the Cortex-A9 prior to r2p0, performing TLB invalidations by
ASID match can result in the incorrect ASID being broadcast to other CPUs.
As a consequence of this, the targetted TLB entries are not invalidated
across the system.
This workaround changes the TLB flushing routines to invalidate entries
regardless of the ASID.
Tested-by: Rob Clark <rob@ti.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
This adds the TCM interface to Linux, when active, it will
detect and report TCM memories and sizes early in boot if
present, introduce generic TCM memory handling, provide a
generic TCM memory pool and select TCM memory for the U300
platform.
See the Documentation/arm/tcm.txt for documentation.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
MAINTAINERS
arch/arm/mm/fault.c
'w90x900' into devel
Add the ARM implementation of highpte, which allows PTE tables to be
placed in highmem. Unfortunately, we do not offer highpte support
when support for L2 cache is enabled.
devel-stable
S5PC100 is a new SoC with ARM coretex-A8 and numerous peripherals. This SoC is
successor of S3C64XX. S5PC100 has peripherals which are still similar to S3C
families so some drivers in "arch/arm/plat-s3c" can be shared. S5PC100 specific
drivers will be added in "arch/arm/plat-s5pcxx" or "arch/arm/mach-s5pc100"
Signed-off-by: Byungho Min <bhmin@samsung.com>
[ben-linux@fluff.org: tidy and edit description]
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
into devel-stable
add bcmring option in Kconfig and add entry in Makefile
in arch/arm directory
Signed-off-by: Leo Chen <leochen@broadcom.com>
Provide more useful introduction for w90x900
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
Add clocksource/clockevent support for w90p910 platform.
The changes introduced by this change are:
- drivers/mtd/Kconfig doesn't depend on ALIGNMENT_TRAP ||
!CPU_CP15_MMU any more
- the following files are sourced additionally:
+ drivers/macintosh/Kconfig
completely depends on PPC || MAC || X86
+ drivers/telephony/Kconfig
new
+ drivers/pps/Kconfig
new
+ drivers/infiniband/Kconfig
new
+ drivers/edac/Kconfig
depends on X86 || PPC
+ drivers/vlynq/Kconfig
depends on AR7 && EXPERIMENTAL (that is ARCH_MIPS)
+ drivers/xen/Kconfig
everything depends on XEN
+ drivers/platform/Kconfig
depends on X86
- drivers/regulator/Kconfig is sourced later as is
drivers/accessibility/Kconfig
before this patch ARM had it's own definition of CONFIG_PREEMPT.
Instead of that use the general definition provided in
kernel/Kconfig.preempt.
This patch changes the available options in *config. Namely PREEMPT
isn't a stand alone bool anymore, but part of a 'choice' the
following Kconfig symbols are added:
PREEMPT_NONE
PREEMPT_VOLUNTARY
Selecting PREEMPT_NONE now produces exactly the code as not selecting
PREEMPT before (apart from a comment in
/sys/kernel/debug/tracing/(per_cpu/cpuX/)?trace). The only difference
PREEMPT_VOLUNTARY does is that might_resched might reschedule. Both
should't introduce regressions.
Add debugfs support for the cpufreq driver to allow
information about the system state to be exported to
the user.
Signed-off-by: Ben Dooks <ben@simtec.co.uk>
Add the S3C24XX to the main ARM CPUFreq Kconfig support list.
Add ARCH_HAS_CPUFREQ so that each machine config can select
it if they have CPUFREQ driver support. This means that the
CPUFREQ specific area does not need the if statement updating
each time a new machine is added.
MMU option is now selectable.
Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com>
This patch adds the necessary entries to the Makefile and Kconfig
files for building the Thumb-2 kernel.
This patch adds various C and assembler macros that help with using
the unified assembler syntax for compiling files to either ARM or
Thumb-2 modes.
Add HAVE_CLK depends on for w90p910 platform.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
This patch adds the basic infrastructure for the Nomadik 8815
CPU and the "Nomadik Hardware Kit" NHK8815. This patch only
includes the serial console and core stuff, no drivers.
This patch provides initial support for CPU frequency scaling on the
Samsung S3C ARM processors. Currently only S3C6410 processors are
supported, though addition of another data table with supported clock
rates should be sufficient to enable support for further CPUs.
Use the regulator framework to provide optional support for DVFS in
the S3C cpufreq driver. When a software controllable regulator is
configured the driver will use it to lower the supply voltage when
running at a lower frequency, giving improved power savings.
When regulator support is disabled or no regulator can be obtained
for VDDARM the driver will fall back to scaling only the frequency.
arch/arm/Makefile
Updates:
arch/arm/mach-u300/core.c
arch/arm/mach-u300/timer.c
arch/arm/Kconfig
arch/arm/kernel/smp.c
arch/arm/mach-realview/Makefile
arch/arm/mach-realview/platsmp.c
Add clock api for w90p910 platform.
Add gpio api for w90p910 platform.
git://dev.omapzoom.org/pub/scm/santosh/kernel-omap4-base into devel
This patch enables SMP on OMAP4430 SDP platform.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Erik Benada <erikbenada@yahoo.ca>
[ nico: fix locking, additional cleanups ]
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Kconfig entries default to n, so there's no need for this to be
explicitly specified.
Signed-off-by: Colin Tuckley <Colin.Tuckley@arm.com>
This is a RealView platform supporting core tiles with ARM11MPCore,
Cortex-A8 or Cortex-A9 (multicore) processors. It has support for MMC,
CompactFlash, PCI-E.
Signed-off-by: Colin Tuckley <colin.tuckley@arm.com>
This implements {copy_to,clear}_user() by faulting in the userland
pages and then using the regular kernel mem{cpy,set}() to copy the
data (while holding the page table lock). This is a win if the regular
mem{cpy,set}() implementations are faster than the user copy functions,
which is the case e.g. on Feroceon, where 8-word STMs (which memcpy()
uses under the right conditions) give significantly higher memory write
throughput than a sequence of individual 32bit stores.
Here are numbers for page sized buffers on some Feroceon cores:
- copy_to_user on Orion5x goes from 51 MB/s to 83 MB/s
- clear_user on Orion5x goes from 89MB/s to 314MB/s
- copy_to_user on Kirkwood goes from 240 MB/s to 356 MB/s
- clear_user on Kirkwood goes from 367 MB/s to 1108 MB/s
- copy_to_user on Disco-Duo goes from 248 MB/s to 398 MB/s
- clear_user on Disco-Duo goes from 328 MB/s to 1741 MB/s
Because the setup cost is non negligible, this is worthwhile only if
the amount of data to copy is large enough. The operation falls back
to the standard implementation when the amount of data is below a certain
threshold. This threshold was determined empirically, however some targets
could benefit from a lower runtime determined value for optimal results
eventually.
In the copy_from_user() case, this technique does not provide any
worthwhile performance gain due to the fact that any kind of read access
allocates the cache and subsequent 32bit loads are just as fast as the
equivalent 8-word LDM.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Tested-by: Martin Michlmayr <tbm@cyrius.com>
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci into devel
Provide a generic SRAM allocator using genalloc, and vaguely
modeled after what AVR32 uses. This builds on top of the
static CPU mapping set up in the previous patch, and returns
DMA mappings as requested (if possible).
Compared to its OMAP cousin, there's no current support for
(currently non-existent) DaVinci power management code running
in SRAM; and this has ways to deallocate, instead of being
allocate-only.
The initial user of this should probably be the audio code,
because EDMA from DDR is subject to various dropouts on at
least DM355 and DM6446 chips.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
into devel
arch/arm/Kconfig
arch/arm/Makefile
holes V2
pfn_valid() is meant to be able to tell if a given PFN has valid memmap
associated with it or not. In FLATMEM, it is expected that holes always
have valid memmap as long as there is valid PFNs either side of the hole.
In SPARSEMEM, it is assumed that a valid section has a memmap for the
entire section.
However, ARM and maybe other embedded architectures in the future free
memmap backing holes to save memory on the assumption the memmap is never
used. The page_zone linkages are then broken even though pfn_valid()
returns true. A walker of the full memmap must then do this additional
check to ensure the memmap they are looking at is sane by making sure the
zone and PFN linkages are still valid. This is expensive, but walkers of
the full memmap are extremely rare.
This was caught before for FLATMEM and hacked around but it hits again for
SPARSEMEM because the page_zone linkages can look ok where the PFN linkages
are totally screwed. This looks like a hatchet job but the reality is that
any clean solution would end up consumning all the memory saved by punching
these unexpected holes in the memmap. For example, we tried marking the
memmap within the section invalid but the section size exceeds the size of
the hole in most cases so pfn_valid() starts returning false where valid
memmap exists. Shrinking the size of the section would increase memory
consumption offsetting the gains.
This patch identifies when an architecture is punching unexpected holes
in the memmap that the memory model cannot automatically detect and sets
ARCH_HAS_HOLES_MEMORYMODEL. At the moment, this is restricted to EP93xx
which is the model sub-architecture this has been reported on but may expand
later. When set, walkers of the full memmap must call memmap_valid_within()
for each PFN and passing in what it expects the page and zone to be for
that PFN. If it finds the linkages to be broken, it assumes the memmap is
invalid for that PFN.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
