path: root/arch/arm/Kconfig
2015-02-17Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New and updated SoC support. Also included are some cleanups where the platform maintainers hadn't separated cleanups from new developent in separate branches. Some of the larger things worth pointing out: - A large set of changes from Alexandre Belloni and Nicolas Ferre preparing at91 platforms for multiplatform and cleaning up quite a bit in the process. - Removal of CSR's "Marco" SoC platform that never made it out to the market. We love seeing these since it means the vendor published support before product was out, which is exactly what we want! New platforms this release are: - Conexant Digicolor (CX92755 SoC) - Hisilicon HiP01 SoC - CSR/sirf Atlas7 SoC - ST STiH418 SoC - Common code changes for Nvidia Tegra132 (64-bit SoC) We're seeing more and more platforms having a harder time labelling changes as cleanups vs new development -- which is a good sign that we've come quite far on the cleanup effort. So over time we might start combining the cleanup and new-development branches more" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (124 commits) ARM: at91/trivial: unify functions and machine names ARM: at91: remove at91_dt_initialize and machine init_early() ARM: at91: change board files into SoC files ARM: at91: remove at91_boot_soc ARM: at91: move alternative initial mapping to board-dt-sama5.c ARM: at91: merge all SOC_AT91SAM9xxx ARM: at91: at91rm9200: set idle and restart from rm9200_dt_device_init() ARM: digicolor: select syscon and timer ARM: zynq: Simplify SLCR initialization ARM: zynq: PM: Fixed simple typo. ARM: zynq: Setup default gpio number for Xilinx Zynq ARM: digicolor: add low level debug support ARM: initial support for Conexant Digicolor CX92755 SoC ARM: OMAP2+: Add dm816x hwmod support ARM: OMAP2+: Add clock domain support for dm816x ARM: OMAP2+: Add board-generic.c entry for ti81xx ARM: at91: pm: remove warning to remove SOC_AT91SAM9263 usage ARM: at91: remove unused mach/system_rev.h ARM: at91: stop using HAVE_AT91_DBGUx ARM: at91: fix ordering of SRAM and PM initialization ...
2015-02-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: - clang assembly fixes from Ard - optimisations and cleanups for Aurora L2 cache support - efficient L2 cache support for secure monitor API on Exynos SoCs - debug menu cleanup from Daniel Thompson to allow better behaviour for multiplatform kernels - StrongARM SA11x0 conversion to irq domains, and pxa_timer - kprobes updates for older ARM CPUs - move probes support out of arch/arm/kernel to arch/arm/probes - add inline asm support for the rbit (reverse bits) instruction - provide an ARM mode secondary CPU entry point (for Qualcomm CPUs) - remove the unused ARMv3 user access code - add driver_override support to AMBA Primecell bus * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (55 commits) ARM: 8256/1: driver coamba: add device binding path 'driver_override' ARM: 8301/1: qcom: Use secondary_startup_arm() ARM: 8302/1: Add a secondary_startup that assumes ARM mode ARM: 8300/1: teach __asmeq that r11 == fp and r12 == ip ARM: kprobes: Fix compilation error caused by superfluous '*' ARM: 8297/1: cache-l2x0: optimize aurora range operations ARM: 8296/1: cache-l2x0: clean up aurora cache handling ARM: 8284/1: sa1100: clear RCSR_SMR on resume ARM: 8283/1: sa1100: collie: clear PWER register on machine init ARM: 8282/1: sa1100: use handle_domain_irq ARM: 8281/1: sa1100: move GPIO-related IRQ code to gpio driver ARM: 8280/1: sa1100: switch to irq_domain_add_simple() ARM: 8279/1: sa1100: merge both GPIO irqdomains ARM: 8278/1: sa1100: split irq handling for low GPIOs ARM: 8291/1: replace magic number with PAGE_SHIFT macro in fixup_pv code ARM: 8290/1: decompressor: fix a wrong comment ARM: 8286/1: mm: Fix dma_contiguous_reserve comment ARM: 8248/1: pm: remove outdated comment ARM: 8274/1: Fix DEBUG_LL for multi-platform kernels (without PL01X) ARM: 8273/1: Seperate DEBUG_UART_PHYS from DEBUG_LL on EP93XX ...
2015-02-10Merge branch 'devel-stable' into for-nextRussell King
2015-01-29Merge tag 'zynq-soc-for-3.20' of https://github.com/Xilinx/linux-xlnx into ↵Olof Johansson
next/soc Merge "Zynq SoC changes for 3.20" from Michal Simek: arm: Xilinx Zynq SoC patches for v3.20 - Enable pincontrol - Simplified SLCR initialization - Setup default ARCH_NR_GPIO * tag 'zynq-soc-for-3.20' of https://github.com/Xilinx/linux-xlnx: ARM: zynq: Simplify SLCR initialization ARM: zynq: PM: Fixed simple typo. ARM: zynq: Setup default gpio number for Xilinx Zynq ARM: zynq: Enable pinctrl Signed-off-by: Olof Johansson <olof@lixom.net>
2015-01-29ARM: zynq: Setup default gpio number for Xilinx ZynqMichal Simek
2015-01-27ARM: initial support for Conexant Digicolor CX92755 SoCBaruch Siach
Add initial support for the Conexant CX92755 SoC. The CX92755 is one of the Digicolor series of SoCs, all sharing many of the same peripherals. The code was tested on the CX92755 evaluation kit, AKA Equinox. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-01-16ARM: 8287/1: add bitrev.h file to support rbit instructionYalin Wang
This patch add bitrev.h file to support rbit instruction, so that we can do bitrev operation by hardware. Signed-off-by: Yalin Wang <yalin.wang@sonymobile.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-01-13ARM: kprobes: enable OPTPROBES for ARM 32Wang Nan
This patch introduce kprobeopt for ARM 32. Limitations: - Currently only kernel compiled with ARM ISA is supported. - Offset between probe point and optinsn slot must not larger than 32MiB. Masami Hiramatsu suggests replacing 2 words, it will make things complex. Futher patch can make such optimization. Kprobe opt on ARM is relatively simpler than kprobe opt on x86 because ARM instruction is always 4 bytes aligned and 4 bytes long. This patch replace probed instruction by a 'b', branch to trampoline code and then calls optimized_callback(). optimized_callback() calls opt_pre_handler() to execute kprobe handler. It also emulate/simulate replaced instruction. When unregistering kprobe, the deferred manner of unoptimizer may leave branch instruction before optimizer is called. Different from x86_64, which only copy the probed insn after optprobe_template_end and reexecute them, this patch call singlestep to emulate/simulate the insn directly. Futher patch can optimize this behavior. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Will Deacon <will.deacon@arm.com> Reviewed-by: Jon Medhurst (Tixy) <tixy@linaro.org> Signed-off-by: Jon Medhurst <tixy@linaro.org>
2014-12-27ARM/PCI: Move to generic PCI domainsLorenzo Pieralisi
Most if not all ARM PCI host controller device drivers either ignore the domain field in the pci_sys_data structure or just increment it every time a host controller is probed, using it as a domain counter. Therefore, instead of relying on pci_sys_data to stash the domain number in a standard location, ARM pcibios code can be moved to the newly introduced generic PCI domains code, implemented in commits: 41e5c0f81d3e ("of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr()") 670ba0c8883b ("PCI: Add generic domain handling") ARM code is made to select PCI_DOMAINS_GENERIC by default, which builds core PCI code that assigns the domain number through the generic function: void pci_bus_assign_domain_nr(...) that relies on a DT property to define the domain number or falls back to a counter according to a predefined logic; its usage replaces the current domain assignment code in PCI host controllers present in the kernel. Tested-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Yijing Wang <wangyijing@huawei.com> Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> # mvebu Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Lucas Stach <l.stach@pengutronix.de> Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Phil Edworthy <phil.edworthy@renesas.com> Acked-by: Arnd Bergmann <arnd@arndb.de> CC: Mohit Kumar <mohit.kumar@st.com>
2014-12-13Merge branch 'akpm' (second patch-bomb from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - the rest of MM - misc fs fixes - add execveat() syscall - new ratelimit feature for fault-injection - decompressor updates - ipc/ updates - fallocate feature creep - fsnotify cleanups - a few other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (99 commits) cgroups: Documentation: fix trivial typos and wrong paragraph numberings parisc: percpu: update comments referring to __get_cpu_var percpu: update local_ops.txt to reflect this_cpu operations percpu: remove __get_cpu_var and __raw_get_cpu_var macros fsnotify: remove destroy_list from fsnotify_mark fsnotify: unify inode and mount marks handling fallocate: create FAN_MODIFY and IN_MODIFY events mm/cma: make kmemleak ignore CMA regions slub: fix cpuset check in get_any_partial slab: fix cpuset check in fallback_alloc shmdt: use i_size_read() instead of ->i_size ipc/shm.c: fix overly aggressive shmdt() when calls span multiple segments ipc/msg: increase MSGMNI, remove scaling ipc/sem.c: increase SEMMSL, SEMMNI, SEMOPM ipc/sem.c: change memory barrier in sem_lock() to smp_rmb() lib/decompress.c: consistency of compress formats for kernel image decompress_bunzip2: off by one in get_next_block() usr/Kconfig: make initrd compression algorithm selection not expert fault-inject: add ratelimit option ratelimit: add initialization macro ...
2014-12-13gcov: enable GCOV_PROFILE_ALL from ARCH KconfigsRiku Voipio
Following the suggestions from Andrew Morton and Stephen Rothwell, Dont expand the ARCH list in kernel/gcov/Kconfig. Instead, define a ARCH_HAS_GCOV_PROFILE_ALL bool which architectures can enable. set ARCH_HAS_GCOV_PROFILE_ALL on Architectures where it was previously allowed + ARM64 which I tested. Signed-off-by: Riku Voipio <riku.voipio@linaro.org> Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "The major updates included in this update are: - Clang compatible stack pointer accesses by Behan Webster. - SA11x0 updates from Dmitry Eremin-Solenikov. - kgdb handling of breakpoints with read-only text/modules - Support for Privileged-no-execute feature on ARMv7 to prevent userspace code execution by the kernel. - AMBA primecell bus handling of irq-safe runtime PM - Unwinding support for memset/memzero/memmove/memcpy functions - VFP fixes for Krait CPUs and improvements in detecting the VFP architecture - A number of code cleanups (using pr_*, removing or reducing the severity of a couple of kernel messages, splitting ftrace asm code out to a separate file, etc.) - Add machine name to stack dump output" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (62 commits) ARM: 8247/2: pcmcia: sa1100: make use of device clock ARM: 8246/2: pcmcia: sa1111: provide device clock ARM: 8245/1: pcmcia: soc-common: enable/disable socket clocks ARM: 8244/1: fbdev: sa1100fb: make use of device clock ARM: 8243/1: sa1100: add a clock alias for sa1111 pcmcia device ARM: 8242/1: sa1100: add cpu clock ARM: 8221/1: PJ4: allow building in Thumb-2 mode ARM: 8234/1: sa1100: reorder IRQ handling code ARM: 8233/1: sa1100: switch to hwirq usage ARM: 8232/1: sa1100: merge GPIO multiplexer IRQ to "normal" irq domain ARM: 8231/1: sa1100: introduce irqdomains support ARM: 8230/1: sa1100: shift IRQs by one ARM: 8229/1: sa1100: replace irq numbers with names in irq driver ARM: 8228/1: sa1100: drop entry-macro.S ARM: 8227/1: sa1100: switch to MULTI_IRQ_HANDLER ARM: 8241/1: Update processor_modes for hyp and monitor mode ARM: 8240/1: MCPM: document mcpm_sync_init() ARM: 8239/1: Introduce {set,clear}_pte_bit ARM: 8238/1: mm: Refine set_memory_* functions ARM: 8237/1: fix flush_pfn_alias ...
2014-12-09Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Arnd Bergmann: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. The largest single change here this time around is the Tegra iommu/memory controller driver, which gets updated to the new iommu DT binding. More drivers like this are likely to follow for the following merge window, but we should be able to do those through the iommu maintainer. Other notable changes are: - reset controller drivers from the reset maintainer (socfpga, sti, berlin) - fixes for the keystone navigator driver merged last time - at91 rtc driver changes related to the at91 cleanups - ARM perf driver changes from Will Deacon - updates for the brcmstb_gisb driver" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits) clocksource: arch_timer: Allow the device tree to specify uninitialized timer registers clocksource: arch_timer: Fix code to use physical timers when requested memory: Add NVIDIA Tegra memory controller support bus: brcmstb_gisb: Add register offset tables for older chips bus: brcmstb_gisb: Look up register offsets in a table bus: brcmstb_gisb: Introduce wrapper functions for MMIO accesses bus: brcmstb_gisb: Make the driver buildable on MIPS of: Add NVIDIA Tegra memory controller binding ARM: tegra: Move AHB Kconfig to drivers/amba amba: Add Kconfig file clk: tegra: Implement memory-controller clock serial: samsung: Fix serial config dependencies for exynos7 bus: brcmstb_gisb: resolve section mismatch ARM: common: edma: edma_pm_resume may be unused ARM: common: edma: add suspend resume hook powerpc/iommu: Rename iommu_[un]map_sg functions rtc: at91sam9: add DT bindings documentation rtc: at91sam9: use clk API instead of relying on AT91_SLOW_CLOCK ARM: at91: add clk_lookup entry for RTT devices rtc: at91sam9: rework the Kconfig description ...
2014-12-09Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support, notable changes include: - bcm: brcmstb SMP support initial iproc/cygnus support - exynos: Exynos4415 SoC support PMU and suspend support for Exynos5420 PMU support for Exynos3250 pm related maintenance - imx: new LS1021A SoC support vybrid 610 global timer support - integrator: convert to using multiplatform configuration - mediatek: earlyprintk support for mt8127/mt8135 - meson: meson8 soc and l2 cache controller support - mvebu: Armada 38x CPU hotplug support drop support for prerelease Armada 375 Z1 stepping extended suspend support, now works on Armada 370/XP - omap: hwmod related maintenance prcm cleanup - pxa: initial pxa27x DT handling - rockchip: SMP support for rk3288 add cpu frequency scaling support - shmobile: r8a7740 power domain support various small restart, timer, pci apmu changes - sunxi: Allwinner A80 (sun9i) earlyprintk support - ux500: power domain support Overall, a significant chunk of changes, coming mostly from the usual suspects: omap, shmobile, samsung and mvebu, all of which already contain a lot of platform specific code in arch/arm" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (187 commits) ARM: mvebu: use the cpufreq-dt platform_data for independent clocks soc: integrator: Add terminating entry for integrator_cm_match ARM: mvebu: add SDRAM controller description for Armada XP ARM: mvebu: adjust mbus controller description on Armada 370/XP ARM: mvebu: add suspend/resume DT information for Armada XP GP ARM: mvebu: synchronize secondary CPU clocks on resume ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume ARM: mvebu: Armada XP GP specific suspend/resume code ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume ARM: mvebu: implement suspend/resume support for Armada XP clk: mvebu: add suspend/resume for gatable clocks bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration bus: mvebu-mbus: suspend/resume support clocksource: time-armada-370-xp: add suspend/resume support irqchip: armada-370-xp: Add suspend/resume support ARM: add lolevel debug support for asm9260 ARM: add mach-asm9260 ARM: EXYNOS: use u8 for val[] in struct exynos_pmu_conf power: reset: imx-snvs-poweroff: add power off driver for i.mx6 ARM: imx: temporarily remove CONFIG_SOC_FSL from LS1021A ...
2014-12-08Merge branch 'at91/cleanup5' into next/driversArnd Bergmann
The at91 cleanups changed a lot of files, this merges in the latest cleanups to resolve the conflicts Conflicts: arch/arm/mach-at91/at91sam9260.c arch/arm/mach-at91/at91sam9261.c arch/arm/mach-at91/at91sam9263.c arch/arm/mach-at91/clock.c arch/arm/mach-at91/clock.h drivers/rtc/Kconfig Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-12-03ARM: 8231/1: sa1100: introduce irqdomains supportDmitry Eremin-Solenikov
Use irqdomains to manage both system and GPIO interrupts on SA1100 SoC family. This opens path to further cleanup and unification in sa1100 IRQ drivers. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-12-03ARM: 8227/1: sa1100: switch to MULTI_IRQ_HANDLERDmitry Eremin-Solenikov
Add sa1100_handle_irq implementating handle_irq for sa1100 platform. It is more or less a translation of old assembly code from assembler to plain C. Also install this irq handler from sa1100_init_irq(). Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-11-28Merge tag 'at91-cleanup4' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91 into next/cleanup Pull "Fourth batch of cleanup/SoC for 3.19" from Nicolas Ferre: - removal of legacy board support for the last SoC having board C files: at91rm9200 - removal or modification of some Kconfig options - switch to USE_OF for all the AT91 SoCs - removal of the old AT91-specific clocks and IRQ drivers * tag 'at91-cleanup4' of git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91: ARM: at91: remove unused IRQ function declarations ARM: at91: remove legacy IRQ driver and related code ARM: at91: remove old at91-specific clock driver ARM: at91: remove clock data in at91sam9n12.c and at91sam9x5.c files ARM: at91: remove all !DT related configuration options ARM: at91/trivial: update Kconfig comment to mention SAMA5 ARM: at91: always USE_OF from now on ARM: at91/Kconfig: remove ARCH_AT91RM9200 option for drivers ARM: at91: switch configuration option to SOC_AT91RM9200 ARM: at91: remove at91rm9200 legacy board support ARM: at91: remove at91rm9200 legacy boards files Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-11-28ARM: vexpress: Remove non-DT codePawel Moll
Now, with the CLCD DT support available, there is no more reason to keep the non-DT support for V2P-CA9. Removed, together with "some" supporting code. It was necessary to make PLAT_VERSATILE_SCHED_CLOCK optional and selected by the machines still interested in it. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-11-28ARM: add mach-asm9260Oleksij Rempel
it is low cost (?) SoC targeted for market in China and India which trying to compete with AT91SAM9G25. Here is some info: http://www.alphascale.com/index.asp?ics/615.html One of products: http://www.aliexpress.com/store/product/2014-hot-sales-FREE-SHIPPING-new-Purple-core-ARM9-development-board-ASM9260T-SDRAM-power-line/433637_1931495721.html In some cases this SoC looks similar to iMX23/iMX28. But currently it makes no sense to merge mach code of this devices. Especially because most differences are already collected mach-mxs folder. Signed-off-by: Oleksij Rempel <linux@rempel-privat.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-11-26ARM: at91/trivial: update Kconfig comment to mention SAMA5Nicolas Ferre
Cortex-A5 SAMA5 processors were not listed, add this in the AT91 comment. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
2014-11-26ARM: at91: always USE_OF from now onNicolas Ferre
As we always use Device Tree now, we can add the configuration here. Also remove the condition for PINCTRL_AT91. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
2014-11-26amba: Add Kconfig fileThierry Reding
Rather than duplicate the ARM_AMBA Kconfig symbol in both 32-bit and 64-bit ARM architectures, move the common definition to drivers/amba where dependent drivers will be located. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-10-22ARM: integrator: make the Integrator multiplatformLinus Walleij
This converts the ARM Integrator reference designs to be fully multiplatform. V4T, V5 and V6 multiplatform builds become possible after this patch. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-11Merge tag 'stable/for-linus-3.18-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from David Vrabel: "Features and fixes: - Add pvscsi frontend and backend drivers. - Remove _PAGE_IOMAP PTE flag, freeing it for alternate uses. - Try and keep memory contiguous during PV memory setup (reduces SWIOTLB usage). - Allow front/back drivers to use threaded irqs. - Support large initrds in PV guests. - Fix PVH guests in preparation for Xen 4.5" * tag 'stable/for-linus-3.18-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (22 commits) xen: remove DEFINE_XENBUS_DRIVER() macro xen/xenbus: Remove BUG_ON() when error string trucated xen/xenbus: Correct the comments for xenbus_grant_ring() x86/xen: Set EFER.NX and EFER.SCE in PVH guests xen: eliminate scalability issues from initrd handling xen: sync some headers with xen tree xen: make pvscsi frontend dependant on xenbus frontend arm{,64}/xen: Remove "EXPERIMENTAL" in the description of the Xen options xen-scsifront: don't deadlock if the ring becomes full x86: remove the Xen-specific _PAGE_IOMAP PTE flag x86/xen: do not use _PAGE_IOMAP PTE flag for I/O mappings x86: skip check for spurious faults for non-present faults xen/efi: Directly include needed headers xen-scsiback: clean up a type issue in scsiback_make_tpg() xen-scsifront: use GFP_ATOMIC under spin_lock MAINTAINERS: Add xen pvscsi maintainer xen-scsiback: Add Xen PV SCSI backend driver xen-scsifront: Add Xen PV SCSI frontend driver xen: Add Xen pvSCSI protocol description xen/events: support threaded irqs for interdomain event channels ...
2014-10-09arm: mm: enable RCU fast_gupSteve Capper
Activate the RCU fast_gup for ARM. We also need to force THP splits to broadcast an IPI s.t. we block in the fast_gup page walker. As THP splits are comparatively rare, this should not lead to a noticeable performance degradation. Some pre-requisite functions pud_write and pud_page are also added. Signed-off-by: Steve Capper <steve.capper@linaro.org> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Dann Frazier <dann.frazier@canonical.com> Cc: Hugh Dickins <hughd@google.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Will Deacon <will.deacon@arm.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09arm: mm: enable HAVE_RCU_TABLE_FREE logicSteve Capper
In order to implement fast_get_user_pages we need to ensure that the page table walker is protected from page table pages being freed from under it. This patch enables HAVE_RCU_TABLE_FREE, any page table pages belonging to address spaces with multiple users will be call_rcu_sched freed. Meaning that disabling interrupts will block the free and protect the fast gup page walker. Signed-off-by: Steve Capper <steve.capper@linaro.org> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Dann Frazier <dann.frazier@canonical.com> Cc: Hugh Dickins <hughd@google.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Will Deacon <will.deacon@arm.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09arm: use genalloc for the atomic poolLaura Abbott
ARM currently uses a bitmap for tracking atomic allocations. genalloc already handles this type of memory pool allocation so switch to using that instead. Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David Riley <davidriley@chromium.org> Cc: Olof Johansson <olof@lixom.net> Cc: Ritesh Harjain <ritesh.harjani@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "The irq departement delivers: - a cleanup series to get rid of mindlessly copied code. - another bunch of new pointlessly different interrupt chip drivers. Adding homebrewn irq chips (and timers) to SoCs must provide a value add which is beyond the imagination of mere mortals. - the usual SoC irq controller updates, IOW my second cat herding project" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) irqchip: gic-v3: Implement CPU PM notifier irqchip: gic-v3: Refactor gic_enable_redist to support both enabling and disabling irqchip: renesas-intc-irqpin: Add minimal runtime PM support irqchip: renesas-intc-irqpin: Add helper variable dev = &pdev->dev irqchip: atmel-aic5: Add sama5d4 support irqchip: atmel-aic5: The sama5d3 has 48 IRQs Documentation: bcm7120-l2: Add Broadcom BCM7120-style L2 binding irqchip: bcm7120-l2: Add Broadcom BCM7120-style Level 2 interrupt controller irqchip: renesas-irqc: Add binding docs for new R-Car Gen2 SoCs irqchip: renesas-irqc: Add DT binding documentation irqchip: renesas-intc-irqpin: Document SoC-specific bindings openrisc: Get rid of handle_IRQ arm64: Get rid of handle_IRQ ARM: omap2: irq: Convert to handle_domain_irq ARM: imx: tzic: Convert to handle_domain_irq ARM: imx: avic: Convert to handle_domain_irq irqchip: or1k-pic: Convert to handle_domain_irq irqchip: atmel-aic5: Convert to handle_domain_irq irqchip: atmel-aic: Convert to handle_domain_irq irqchip: gic-v3: Convert to handle_domain_irq ...
2014-10-08Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support. Among the things new for this release are: - at91: Added support for the new SAMA5D4 SoC, following the earlier SAMA5D3 - bcm: Added support for BCM63XX family of DSL SoCs - hisi: Added support for HiP04 server-class SoC - meson: Initial support for the Amlogic Meson6 (aka 8726MX) platform - shmobile: added support for new r8a7794 (R-Car E2) automotive SoC Noteworthy changes to existing SoC support are: - imx: convert i.MX1 to device tree - omap: lots of power management work - omap: base support to enable moving to standard UART driver - shmobile: lots of progress for multiplatform support, still ongoing" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (171 commits) ARM: hisi: depend on ARCH_MULTI_V7 CNS3xxx: Fix debug UART. ARM: at91: fix nommu build regression ARM: meson: add basic support for MesonX SoCs ARM: meson: debug: add debug UART for earlyprintk support irq: Export handle_fasteoi_irq ARM: mediatek: Add earlyprintk support for mt6589 ARM: hisi: Fix platmcpm compilation when ARMv6 is selected ARM: debug: fix alphanumerical order on debug uarts ARM: at91: document Atmel SMART compatibles ARM: at91: add sama5d4 support to sama5_defconfig ARM: at91: dt: add device tree file for SAMA5D4ek board ARM: at91: dt: add device tree file for SAMA5D4 SoC ARM: at91: SAMA5D4 SoC detection code and low level routines ARM: at91: introduce basic SAMA5D4 support clk: at91: add a driver for the h32mx clock ARM: pxa3xx: provide specific platform_devices for all ssp ports ARM: pxa: ssp: provide platform_device_id for PXA3xx ARM: OMAP4+: Remove static iotable mappings for SRAM ARM: OMAP4+: Move SRAM data to DT ...
2014-10-03arm{,64}/xen: Remove "EXPERIMENTAL" in the description of the Xen optionsJulien Grall
The Xen ARM API is stable since Xen 4.4 and everything has been upstreamed in Linux for ARM and ARM64. Therefore we can drop "EXPERIMENTAL" from the Xen option in the both Kconfig. Signed-off-by: Julien Grall <julien.grall@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org
2014-09-25ARM: meson: add basic support for MesonX SoCsCarlo Caione
This patch adds the basic machine file for the MesonX SoCs. Only Meson6 is populated. Signed-off-by: Carlo Caione <carlo@caione.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-09-24Merge tag 'imx-cleanup-3.18' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/cleanup Merge "ARM: imx: cleanup for 3.18" from Shawn Guo: The i.MX cleanup for 3.18: - Reomve a few i.MX27 and i.MX1 board files - Remove imx_scu_standby_enable() since core code handles scu standby now - Remove unnecessary iomux declaration - Remove useless sound card property from vf610-twr dts * tag 'imx-cleanup-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: ARM: imx: Remove mach-mxt_td60 board file ARM: i.MX: Remove i.MX1 ADS board support ARM: dts: vf610-twr: remove useless property for sound card. ARM: imx: remove imx_scu_standby_enable() ARM: i.MX: Remove Phytec i.MX27 PCM038/PCM970 board files ARM: i.MX: Remove mach-cpuimx27sd board file ARM: imx: iomux: Do not export symbol without public declaration Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-23Merge tag 'D01-for-3.18' of git://github.com/hisilicon/linux-hisi into next/socOlof Johansson
Merge "pull request for hisilicon hip04 soc and D01 board updates" from Wei Xu: ARM: mach-hisi: Hisilicon hip04 soc and D01 board updates for 3.18 - Add the CONFIG_MCPM_QUAD_CLUSTER configuration to enlarge cluster number from 2 to 4 - Enable MCPM on HiP04 SoC - Enable 16 cores on HiP04 SoC - Add platform & Fabric controller devicetree binding document for HiP04 SoC - Add hip04.dtsi & hip04-d01.dts for hip04 SoC platform and D01 board - Enable HiP04 SoC in both hi3xxx_defconfig & multi_v7_defconfig - Add the support of Hisilicon HiP04 debug uart * tag 'D01-for-3.18' of git://github.com/hisilicon/linux-hisi: ARM: debug: add HiP04 debug uart ARM: config: enable hisilicon hip04 ARM: dts: add hip04 dts document: dt: add the binding on HiP04 ARM: hisi: enable HiP04 ARM: hisi: enable MCPM implementation ARM: mcpm: support 4 clusters Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-23Merge tag 'soc-for-v3.18' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/soc SoC related changes for omaps for v3.18 merge window: - PM changes to make the code easier to use on newer SoCs - PM changes for newer SoCs suspend and resume and wake-up events - Minor clean-up to remove dead Kconfig options Note that these have a dependency to the fixes-v3.18-not-urgent tag and is based on a commit in that series. * tag 'soc-for-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (514 commits) ARM: OMAP5+: Reuse OMAP4 PM code for OMAP5 and DRA7 ARM: dts: OMAP3+: Add PRM interrupt ARM: omap: Remove stray ARCH_HAS_OPP references ARM: DRA7: Add hook in SoC initcalls to enable pm initialization ARM: OMAP5: Add hook in SoC initcalls to enable pm initialization ARM: OMAP5 / DRA7: Enable CPU RET on suspend ARM: OMAP5 / DRA7: PM: Provide a dummy startup function for CPU hotplug ARM: OMAP5 / DRA7: PM: Avoid all SAR saves ARM: OMAP5 / DRA7: PM: Enable Mercury retention mode on CPUx powerdomains ARM: OMAP5 / DRA7: PM / wakeupgen: Enables ES2 PM mode by default ARM: OMAP5 / DRA7: PM: Set MPUSS-EMIF clock-domain static dependency ARM: OMAP5 / DRA7: PM: Update CPU context register offset ARM: AM437x: use pdata quirks for pinctrl information ARM: DRA7: use pdata quirks for pinctrl information ARM: OMAP5: use pdata quirks for pinctrl information ARM: OMAP4+: PM: Use only valid low power state for CPU hotplug ARM: OMAP4+: PM: use only valid low power state for suspend ARM: OMAP4+: PM: Make logic state programmable ARM: OMAP2+: powerdomain: introduce logic for finding valid power domain ARM: OMAP2+: powerdomain: pwrdm_for_each_clkdm iterate only valid clkdms ...
2014-09-04ARM: clps711x: Add SOC BUS supportAlexander Shiyan
Add SOC BUS support with CPU family, machine name and unique ID. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-09-03ARM: mcpm: support 4 clustersHaojian Zhuang
Add the CONFIG_MCPM_QUAD_CLUSTER configuration to enlarge cluster number from 2 to 4. Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
2014-09-03ARM: Convert handle_IRQ to use __handle_domain_irqMarc Zyngier
In order to limit code duplication, convert the architecture specific handle_IRQ to use the generic __handle_domain_irq function. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1409047421-27649-4-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-09-02ARM: shmobile: Consolidate Legacy SH_CLK_CPG KconfigMagnus Damm
Consolidate SH_CLK_CPG under ARCH_SHMOBILE_LEGACY so it can be shared by the legacy ARM mach-shmobile support code. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2014-09-02ARM: shmobile: Consolidate Legacy CPU_V7 KconfigMagnus Damm
Consolidate CPU_V7 under ARCH_SHMOBILE_LEGACY so it can be shared by the legacy ARM mach-shmobile support code. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2014-08-29kexec: remove CONFIG_KEXEC dependency on cryptoVivek Goyal
New system call depends on crypto. As it did not have a separate config option, CONFIG_KEXEC was modified to select CRYPTO and CRYPTO_SHA256. But now previous patch introduced a new config option for new syscall. So CONFIG_KEXEC does not require crypto. Remove that dependency. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Shaun Ruffell <sruffell@digium.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08Merge branch 'akpm' (second patchbomb from Andrew Morton)Linus Torvalds
Merge more incoming from Andrew Morton: "Two new syscalls: memfd_create in "shm: add memfd_create() syscall" kexec_file_load in "kexec: implementation of new syscall kexec_file_load" And: - Most (all?) of the rest of MM - Lots of the usual misc bits - fs/autofs4 - drivers/rtc - fs/nilfs - procfs - fork.c, exec.c - more in lib/ - rapidio - Janitorial work in filesystems: fs/ufs, fs/reiserfs, fs/adfs, fs/cramfs, fs/romfs, fs/qnx6. - initrd/initramfs work - "file sealing" and the memfd_create() syscall, in tmpfs - add pci_zalloc_consistent, use it in lots of places - MAINTAINERS maintenance - kexec feature work" * emailed patches from Andrew Morton <akpm@linux-foundation.org: (193 commits) MAINTAINERS: update nomadik patterns MAINTAINERS: update usb/gadget patterns MAINTAINERS: update DMA BUFFER SHARING patterns kexec: verify the signature of signed PE bzImage kexec: support kexec/kdump on EFI systems kexec: support for kexec on panic using new system call kexec-bzImage64: support for loading bzImage using 64bit entry kexec: load and relocate purgatory at kernel load time purgatory: core purgatory functionality purgatory/sha256: provide implementation of sha256 in purgaotory context kexec: implementation of new syscall kexec_file_load kexec: new syscall kexec_file_load() declaration kexec: make kexec_segment user buffer pointer a union resource: provide new functions to walk through resources kexec: use common function for kimage_normal_alloc() and kimage_crash_alloc() kexec: move segment verification code in a separate function kexec: rename unusebale_pages to unusable_pages kernel: build bin2c based on config option CONFIG_BUILD_BIN2C bin2c: move bin2c in scripts/basic shm: wait for pins to be released when sealing ...
2014-08-08kexec: load and relocate purgatory at kernel load timeVivek Goyal
Load purgatory code in RAM and relocate it based on the location. Relocation code has been inspired by module relocation code and purgatory relocation code in kexec-tools. Also compute the checksums of loaded kexec segments and store them in purgatory. Arch independent code provides this functionality so that arch dependent bootloaders can make use of it. Helper functions are provided to get/set symbol values in purgatory which are used by bootloaders later to set things like stack and entry point of second kernel etc. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Dave Young <dyoung@redhat.com> Cc: WANG Chao <chaowang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08lib/scatterlist: make ARCH_HAS_SG_CHAIN an actual KconfigLaura Abbott
Rather than have architectures #define ARCH_HAS_SG_CHAIN in an architecture specific scatterlist.h, make it a proper Kconfig option and use that instead. At same time, remove the header files are are now mostly useless and just include asm-generic/scatterlist.h. [sfr@canb.auug.org.au: powerpc files now need asm/dma.h] Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> [x86] Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc] Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08Merge tag 'dt-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device-tree changes from Olof Johansson: "Unlike the board branch, this keeps having large sets of changes for every release, but that's quite expected and is so far working well. Most of this is plumbing for various device bindings and new platforms, but there's also a bit of cleanup and code removal for things that are moved from platform code to DT contents (some OMAP clock code in particular). There's also a pinctrl driver for tegra here (appropriately acked), that's introduced this way to make it more bisectable. I'm happy to say that there were no conflicts at all with this branch this release, which means that changes are flowing through our tree as expected instead of merged through driver maintainers (or at least not done with conflicts). There are several new boards added, and a couple of SoCs. In no particular order: - Rockchip RK3288 SoC support, including DTS for a dev board that they have seeded with some community developers. - Better support for Hardkernel Exynos4-based ODROID boards. - CCF conversions (and dtsi contents) for several Renesas platforms. - Gumstix Pepper (TI AM335x) board support - TI eval board support for AM437x - Allwinner A23 SoC, very similar to existing ones which mostly has resulted in DT changes for support. Also includes support for an Ippo tablet with the chipset. - Allwinner A31 Hummingbird board support, not to be confused with the SolidRun i.MX-based Hummingboard. - Tegra30 Apalis board support" * tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits) ARM: dts: Enable USB host0 (EHCI) on rk3288-evb ARM: dts: add rk3288 ehci usb devices ARM: dts: Turn on USB host vbus on rk3288-evb ARM: tegra: apalis t30: fix device tree compatible node ARM: tegra: paz00: Fix some indentation inconsistencies ARM: zynq: DT: Clarify Xilinx Zynq platform ARM: dts: rockchip: add watchdog node ARM: dts: rockchip: remove pinctrl setting from radxarock uart2 ARM: dts: Add missing pinctrl for uart0/1 for exynos3250 ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250 ARM: dts: Add TMU dt node to monitor the temperature for exynos3250 ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250 ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only ARM: dts: max77686 is exynos5250-snow only ARM: zynq: DT: Remove DMA from board DTs ARM: zynq: DT: Add CAN node ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table ARM: dts: Add PMU DT node for exynos5260 SoC ARM: EXYNOS: Add support for Exynos5410 PMU ARM: dts: Add PMU to exynos5410 ...
2014-08-08Merge tag 'soc-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This is the bulk of new SoC enablement and other platform changes for 3.17: - Samsung S5PV210 has been converted to DT and multiplatform - Clock drivers and bindings for some of the lower-end i.MX 1/2 platforms - Kirkwood, one of the popular Marvell platforms, is folded into the mvebu platform code, removing mach-kirkwood - Hwmod data for TI AM43xx and DRA7 platforms - More additions of Renesas shmobile platform support - Removal of plat-samsung contents that can be removed with S5PV210 being multiplatform/DT-enabled and the other two old platforms being removed New platforms (most with only basic support right now): - Hisilicon X5HD2 settop box chipset is introduced - Mediatek MT6589 (mobile chipset) is introduced - Broadcom BCM7xxx settop box chipset is introduced + as usual a lot other pieces all over the platform code" * tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits) ARM: hisi: remove smp from machine descriptor power: reset: move hisilicon reboot code ARM: dts: Add hix5hd2-dkb dts file. ARM: debug: Rename Hi3716 to HIX5HD2 ARM: hisi: enable hix5hd2 SoC ARM: hisi: add ARCH_HISI MAINTAINERS: add entry for Broadcom ARM STB architecture ARM: brcmstb: select GISB arbiter and interrupt drivers ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs ARM: configs: enable SMP in bcm_defconfig ARM: add SMP support for Broadcom mobile SoCs Documentation: arm: misc updates to Marvell EBU SoC status Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC ARM: mvebu: fix build without platforms selected ARM: mvebu: add cpuidle support for Armada 38x ARM: mvebu: add cpuidle support for Armada 370 cpuidle: mvebu: add Armada 38x support cpuidle: mvebu: add Armada 370 support cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7 ARM: mvebu: export the SCU address ...
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-08-05Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer and time updates from Thomas Gleixner: "A rather large update of timers, timekeeping & co - Core timekeeping code is year-2038 safe now for 32bit machines. Now we just need to fix all in kernel users and the gazillion of user space interfaces which rely on timespec/timeval :) - Better cache layout for the timekeeping internal data structures. - Proper nanosecond based interfaces for in kernel users. - Tree wide cleanup of code which wants nanoseconds but does hoops and loops to convert back and forth from timespecs. Some of it definitely belongs into the ugly code museum. - Consolidation of the timekeeping interface zoo. - A fast NMI safe accessor to clock monotonic for tracing. This is a long standing request to support correlated user/kernel space traces. With proper NTP frequency correction it's also suitable for correlation of traces accross separate machines. - Checkpoint/restart support for timerfd. - A few NOHZ[_FULL] improvements in the [hr]timer code. - Code move from kernel to kernel/time of all time* related code. - New clocksource/event drivers from the ARM universe. I'm really impressed that despite an architected timer in the newer chips SoC manufacturers insist on inventing new and differently broken SoC specific timers. [ Ed. "Impressed"? I don't think that word means what you think it means ] - Another round of code move from arch to drivers. Looks like most of the legacy mess in ARM regarding timers is sorted out except for a few obnoxious strongholds. - The usual updates and fixlets all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) timekeeping: Fixup typo in update_vsyscall_old definition clocksource: document some basic timekeeping concepts timekeeping: Use cached ntp_tick_length when accumulating error timekeeping: Rework frequency adjustments to work better w/ nohz timekeeping: Minor fixup for timespec64->timespec assignment ftrace: Provide trace clocks monotonic timekeeping: Provide fast and NMI safe access to CLOCK_MONOTONIC seqcount: Add raw_write_seqcount_latch() seqcount: Provide raw_read_seqcount() timekeeping: Use tk_read_base as argument for timekeeping_get_ns() timekeeping: Create struct tk_read_base and use it in struct timekeeper timekeeping: Restructure the timekeeper some more clocksource: Get rid of cycle_last clocksource: Move cycle_last validation to core code clocksource: Make delta calculation a function wireless: ath9k: Get rid of timespec conversions drm: vmwgfx: Use nsec based interfaces drm: i915: Use nsec based interfaces timekeeping: Provide ktime_get_raw() hangcheck-timer: Use ktime_get_ns() ...
2014-08-05Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in this update: - perf updates from Will Deacon: The main changes are callchain stability fixes from Jean Pihet and event mapping and PMU name rework from Mark Rutland The latter is preparatory work for enabling some code re-use with arm64 in the future. - updates for nommu from Uwe Kleine-König: Two different fixes for the same problem making some ARM nommu configurations not boot since 3.6-rc1. The problem is that user_addr_max returned the biggest available RAM address which makes some copy_from_user variants fail to read from XIP memory. - deprecate legacy OMAP DMA API, in preparation for it's removal. The popular drivers have been converted over, leaving a very small number of rarely used drivers, which hopefully can be converted during the next cycle with a bit more visibility (and hopefully people popping out of the woodwork to help test) - more tweaks for BE systems, particularly with the kernel image format. In connection with this, I've cleaned up the way we generate the linker script for the decompressor. - removal of hard-coded assumptions of the kernel stack size, making everywhere depend on the value of THREAD_SIZE_ORDER. - MCPM updates from Nicolas Pitre. - Make it easier for proper CPU part number checks (which should always include the vendor field). - Assembly code optimisation - use the "bx" instruction when returning from a function on ARMv6+ rather than "mov pc, reg". - Save the last kernel misaligned fault location and report it via the procfs alignment file. - Clean up the way we create the initial stack frame, which is a repeated pattern in several different locations. - Support for 8-byte get_user(), needed for some DRM implementations. - mcs locking from Will Deacon. - Save and restore a few more Cortex-A9 registers (for errata workarounds) - Fix various aspects of the SWP emulation, and the ELF hwcap for the SWP instruction. - Update LPAE logic for pte_write and pmd_write to make it more correct. - Support for Broadcom Brahma15 CPU cores. - ARM assembly crypto updates from Ard Biesheuvel" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (53 commits) ARM: add comments to the early page table remap code ARM: 8122/1: smp_scu: enable SCU standby support ARM: 8121/1: smp_scu: use macro for SCU enable bit ARM: 8120/1: crypto: sha512: add ARM NEON implementation ARM: 8119/1: crypto: sha1: add ARM NEON implementation ARM: 8118/1: crypto: sha1/make use of common SHA-1 structures ARM: 8113/1: remove remaining definitions of PLAT_PHYS_OFFSET from <mach/memory.h> ARM: 8111/1: Enable erratum 798181 for Broadcom Brahma-B15 ARM: 8110/1: do CPU-specific init for Broadcom Brahma15 cores ARM: 8109/1: mm: Modify pte_write and pmd_write logic for LPAE ARM: 8108/1: mm: Introduce {pte,pmd}_isset and {pte,pmd}_isclear ARM: hwcap: disable HWCAP_SWP if the CPU advertises it has exclusives ARM: SWP emulation: only initialise on ARMv7 CPUs ARM: SWP emulation: always enable when SMP is enabled ARM: 8103/1: save/restore Cortex-A9 CP15 registers on suspend/resume ARM: 8098/1: mcs lock: implement wfe-based polling for MCS locking ARM: 8091/2: add get_user() support for 8 byte types ARM: 8097/1: unistd.h: relocate comments back to place ARM: 8096/1: Describe required sort order for textofs-y (TEXT_OFFSET) ARM: 8090/1: add revision info for PL310 errata 588369 and 727915 ...
2014-08-05Merge branches 'fixes' and 'misc' into for-nextRussell King
Conflicts: arch/arm/kernel/iwmmxt.S arch/arm/mm/cache-l2x0.c arch/arm/mm/mmu.c
