While working on the 32-bit ARM port of UEFI, I noticed a strange
corruption in the kernel log. The following snprintf() statement
(in drivers/firmware/efi/efi.c:efi_md_typeattr_format())
snprintf(pos, size, "|%3s|%2s|%2s|%2s|%3s|%2s|%2s|%2s|%2s]",
was producing the following output in the log:
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | |WB|WT|WC|UC]*
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | | | | |UC]
As it turns out, this is caused by incorrect code being emitted for
the string() function in lib/vsprintf.c. The following code
if (!(spec.flags & LEFT)) {
while (len < spec.field_width--) {
if (buf < end)
*buf = ' ';
++buf;
for (i = 0; i < len; ++i) {
if (buf < end)
*buf = *s;
++buf; ++s;
if (buf < end)
*buf = ' ';
++buf;
when called with len == 0, triggers an issue in the GCC SRA optimization
pass (Scalar Replacement of Aggregates), which handles promotion of signed
struct members incorrectly. This is a known but as yet unresolved issue.
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65932). In this particular
case, it is causing the second while loop to be executed erroneously a
single time, causing the additional space characters to be printed.
So disable the optimization by passing -fno-ipa-sra.
Cc: <stable@vger.kernel.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
(cherry picked from commit a077224fd35b2f7fbc93f14cf67074fc792fbac2)
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
MAINTAINERS: add maintainer of CSR SiRFprimaII machine
ARM: CSR: initializing L2 cache
ARM: CSR: mapping early DEBUG_LL uart
ARM: CSR: Adding CSR SiRFprimaII board support
OMAP4: clocks: Update the clock tree with 4460 clock nodes
OMAP4: PRCM: OMAP4460 specific PRM and CM register bitshifts
OMAP4: ID: add omap_has_feature for max freq supported
OMAP: ID: introduce chip detection for OMAP4460
ARM: Xilinx: merge board file into main platform code
ARM: Xilinx: Adding Xilinx board support
Fix up conflicts in arch/arm/mach-omap2/cm-regbits-44xx.h
Add a make rule to compile dt blobs for ARM.
Acked-by: Shawn Guo <shawn.guo@freescale.com>
Tested-by: Jason Liu <jason.hui@linaro.org>
This was introduced more than 3 years ago, and since then only generic
janitorial changes were made without further addition of actual support
for "real" devices. This is therefore a cost with no benefits to keep
in the tree. If someone wishes to revive this code, it is always
possible to retrieve it from the Git repository.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
CC: Ke Wei <kewei@marvell.com>
CC: Saeed Bishara <saeed@marvell.com>
CC: Lennert Buytenhek <buytenh@wantstofly.org>
On Tue, 28 Jun 2011, Ben Dooks wrote:
> On Tue, Jun 28, 2011 at 11:22:57PM +0200, Arnd Bergmann wrote:
> > On a related note, what about mach-s3c2400? It seems to be even more
> > incomplete.
> Probably the same fate awaits that. It is so old that there's little
> incentive to do anything with it.
So out it goes as well.
The PORT_S3C2400 definition in include/linux/serial_core.h is left there
to prevent a reuse of the same number for another port type.
Commit bcae8aeb32 "[ARM] S3C24A0: Initial architecture support files"
brought in a bunch of files while explicitly leaving out the corresponding
Kconfig entry, stating that the series is not complete.
More than 2.5 years later, the support for this has not seen any progress.
This is therefore dead code. If someone wants to revive this code, it is
always possible to retrieve it from the Git repository.
Acked-by: Ben Dooks <ben-linux@fluff.org>
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc into next/soc
arch/arm/Kconfig
arch/arm/mm/Kconfig
SiRFprimaII is the latest generation application processor from CSR’s
Multifunction SoC product family. Designed around an ARM cortex A9 core,
high-speed memory bus, advanced 3D accelerator and full-HD multi-format
video decoder, SiRFprimaII is able to meet the needs of complicated
applications for modern multifunction devices that require heavy concurrent
applications and fluid user experience. Integrated with GPS baseband,
analog and PMU, this new platform is designed to provide a cost effective
solution for Automotive and Consumer markets.
This patch adds the basic support for this SoC and EVB board based on device
tree. It is following the ZYNQ of Xilinx in some degree.
Signed-off-by: Binghua Duan <Binghua.Duan@csr.com>
Signed-off-by: Rongjun Ying <Rongjun.Ying@csr.com>
Signed-off-by: Zhiwu Song <Zhiwu.Song@csr.com>
Signed-off-by: Yuping Luo <Yuping.Luo@csr.com>
Signed-off-by: Bin Shi <Bin.Shi@csr.com>
Signed-off-by: Huayi Li <Huayi.Li@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
The 1st board support is minimal to get a system up and running
on the Xilinx platform.
This platform reuses the clock implementation from plat-versatile, and
it depends entirely on CONFIG_OF support. There is only one board
support file which obtains all device information from a device tree
dtb file which is passed to the kernel at boot time.
Signed-off-by: John Linn <john.linn@xilinx.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable
arch/arm/Kconfig
arch/arm/mach-exynos4/mach-nuri.c
arch/arm/Kconfig
arch/arm/mach-ns9xxx/include/mach/uncompress.h
and 'spear' into for-linus
Fixing a few "please, no space before tabs" and "empty line at end of
file" warnings on the way.
LAKML-Reference: 1299271882-2130-6-git-send-email-u.kleine-koenig@pengutronix.de
Since support for mxc91231 was introduced 2009 it only saw patches that
were part of (mxc or arm) global cleanups. The only supported machine
only had 4 devices (2x UART, sdhc, watchdog).
Cc: Dmitriy Taychenachev <dimichxp@gmail.com>
LAKML-Reference: 1302211482-17926-1-git-send-email-u.kleine-koenig@pengutronix.de
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Now that both users of plat-stmp have been deleted in previous patches,
delete the platform, too.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
This mach has not seen any updates since the initial inclusion besides
generic cleanup. Furthermore:
- The i.MX23 covered in mach-mxs is just a renamed version of the
STMP378x.
- mach-stmp378x has a lot of reinvented interfaces, leaking all sorts of
mach-related includes into the drivers. One example is the dmaengine
which does not use the linux dmaengine-API but some privately exported
symbols. So drivers cannot be reused. mach-mxs does it better.
- There is only one board defined (which I couldn't find any trace of
despite being a development board). It has been converted to
mach-mxs in a previous patch.
Since the only user of this mach was converted, it means that
mach-stmp378x can go.
- It has a lot of reinvented interfaces, leaking all sorts of
symbols. So, drivers cannot be reused. mach-mxs is very similar and
does it better.
- It can be doubted that this worked at all. Check the DMA routines in
stmp37xx.c for copy/paste bugs. A lot of APBX-related stuff is
actually writing into registers for APBH.
despite being a development board). In this board, only two devices
have resources, the debug uart and the application uart. Neither of
those have the needed custom drivers merged (and never will). debug
uart is amba-pl011 which has an in-kernel driver without the
mach-specific-stuff. appuart has a driver which was introduced for
mach-mxs, and this one is reusable for a properly done mach.
So, this single board registers only unsupported devices and the
generic code looks suspicious and has poor design. Delete this
stuff. If there is interest, it is wiser to restart using
mach-mxs.
The port is actually unmaintained and only received global
cleanups and a few build fixes since mid 2008.
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits)
davinci: DM644x EVM: register MUSB device earlier
davinci: add spi devices on tnetv107x evm
davinci: add ssp config for tnetv107x evm board
davinci: add tnetv107x ssp platform device
spi: add ti-ssp spi master driver
mfd: add driver for sequencer serial port
ARM: EXYNOS4: Implement Clock gating for System MMU
ARM: EXYNOS4: Enhancement of System MMU driver
ARM: EXYNOS4: Add support for gpio interrupts
ARM: S5P: Add function to register gpio interrupt bank data
ARM: S5P: Cleanup S5P gpio interrupt code
ARM: EXYNOS4: Add missing GPYx banks
ARM: S3C64XX: Fix section mismatch from cpufreq init
ARM: EXYNOS4: Add keypad device to the SMDKV310
ARM: EXYNOS4: Update clocks for keypad
ARM: EXYNOS4: Update keypad base address
ARM: EXYNOS4: Add keypad device helpers
ARM: EXYNOS4: Add support for SATA on ARMLEX4210
plat-nomadik: make GPIO interrupts work with cpuidle ApSleep
mach-u300: define a dummy filter function for coh901318
Fix up various conflicts in
- arch/arm/mach-exynos4/cpufreq.c
- arch/arm/mach-mxs/gpio.c
- drivers/net/Kconfig
- drivers/tty/serial/Kconfig
- drivers/tty/serial/Makefile
- drivers/usb/gadget/fsl_mxc_udc.c
- drivers/video/Kconfig
* 'remove' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6629/2: aaec2000: remove support for mach-aaec2000
ARM: lh7a40x: remove unmaintained platform support
Fix up trivial conflicts in
- arch/arm/mach-{aaec2000,lh7a40x}/include/mach/memory.h (removed)
- drivers/usb/gadget/Kconfig (USB_[GADGET_]LH7A40X removed, others added)
arch/arm/include/asm/cacheflush.h
arch/arm/include/asm/proc-fns.h
arch/arm/mm/Kconfig
arch/arm/Kconfig
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
Various binutils versions can resolve Thumb-2 branches to
locally-defined, preemptible global symbols as short-range "b.n"
branch instructions.
This is a problem, because there's no guarantee the final
destination of the symbol, or any candidate locations for a
trampoline, are within range of the branch. For this reason, the
kernel does not support fixing up the R_ARM_THM_JUMP11 (102)
relocation in modules at all, and it makes little sense to add
support.
The symptom is that the kernel fails with an "unsupported
relocation" error when loading some modules.
Until fixed tools are available, passing
-fno-optimize-sibling-calls to gcc should prevent gcc generating
code which hits this problem, at the cost of a bit of extra runtime
stack usage in some cases.
The problem is described in more detail at:
https://bugs.launchpad.net/binutils-linaro/+bug/725126
Only Thumb-2 kernels are affected.
This patch adds a new CONFIG_THUMB2_AVOID_R_ARM_THM_JUMP11 config
option which adds -fno-optimize-sibling-calls to CFLAGS_MODULE
when building a Thumb-2 kernel.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
We have 'install' and 'zinstall' for installing Image and zImage
kernels, so add 'uinstall' to complete the set.
This allows developers to have a ~/bin/installkernel script which (eg)
copies the kernel to the tftp server automatically once the kernel
has built, resulting in a better workflow.
This patch changes the Kconfig and Makefile for the new ARCH_EXYNOS4.
It also updates arch/arm/Kconfig, Makeifile and arch/arm/mm/Kconfig
to include support for the new ARCH_EXYNOS4.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Commit 18991197b4b588255ccabf472ebc84db7b66a19c added --build-id
linker option when toolchain supports it. ARM one does, but for some
reason places the section at 0 when linker script doesn't mention it
explicitly.
The 1e621a8e3752367d4aae78a8ab00a18fb2793f34 worked around the problem
removing this section from binary image with explicit objcopy options,
but it still exists in vmlinux, confusing tools like debuggers and perf.
This problem was discussed here:
http://lists.infradead.org/pipermail/linux-arm-kernel/2010-May/015994.html
but the proposed changes to the linker script were substantial.
This patch simply places NOTES (36 bytes long, at least when compiled
with CodeSourcery toolchain) between data and bss, which seem to be
the right place (and suggested by the sample linker script in
include/asm-generic/vmlinux.lds.h).
It is enough to place it correctly in vmlinux (so debuggers are happy):
Section Headers:
[11] .data PROGBITS c07ce000 7ce000 020fc0 00 WA 0 0 32
[12] .notes NOTE c07eefc0 7eefc0 000024 00 AX 0 0 4
[13] .bss NOBITS c07ef000 7eefe4 01e628 00 WA 0 0 32
Program Headers:
LOAD 0x008000 0xc0008000 0xc0008000 0x7e6fe4 0x805628 RWE 0x8000
NOTE 0x7eefc0 0xc07eefc0 0xc07eefc0 0x00024 0x00024 R E 0x4
Section to Segment mapping:
Segment Sections...
00 <...> .data .notes .bss
01 .notes
and to get it exposed as /sys/kernel/notes used by perf tools.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
mach-aaec2000 is no longer actively maintained and is only receiving
fixups to remain building with other kernel updates.
Cc: Bellido Nicolas <ml@acolin.be>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Introduce a CPU_V6K configuration option for platforms to select if they
have a V6K CPU core. This allows us to identify whether we need to
support ARMv6 CPUs without the V6K SMP extensions at build time.
Currently CPU_V6K is just an alias for CPU_V6, and all places which
reference CPU_V6 are replaced by (CPU_V6 || CPU_V6K).
Select CPU_V6K from platforms which are known to be V6K-only.
Tested-by: Sourav Poddar <sourav.poddar@ti.com>
Tested-by: Will Deacon <will.deacon@arm.com>
This adds support for the family of Systems-on-Chip produced initially
by VIA and now its subsidiary WonderMedia that have recently become
widespread in lower-end Chinese ARM-based tablets and netbooks.
Support is included for both VT8500 and WM8505, selectable by a
configuration switch at kernel build time.
Included are basic machine initialization files, register and
interrupt definitions, support for the on-chip interrupt controller,
high-precision OS timer, GPIO lines, necessary macros for early debug,
pulse-width-modulated outputs control, as well as platform device
configurations for the specific drivers implemented elsewhere.
Signed-off-by: Alexey Charkov <alchark@gmail.com>
lh7a40x has only been receiving updates for updates to generic code.
The last involvement from the maintainer according to the git logs was
in 2006. As such, it is a maintainence burden with no benefit.
This gets rid of two defconfigs.
into imx-for-2.6.38-new
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
arch/arm/mach-at91/include/mach/system.h
arch/arm/mach-imx/mach-cpuimx27.c
AT91 conflict resolution:
Acked-by: Anders Larsen <al@alarsen.net>
IMX conflict resolution confirmed by Uwe Kleine-König.
This patch updates the Kconfig and Makefile for the S5P6440 and S5P6450
machines. It also updates arch/arm/ Kconfig and Makefile to include for
support ARCH_S5P64X0 with one kernel image.
devel-stable
This allows for board specific issues to override decisions made in generic
code that might not be suitable due to some errata or the like, by making
the initcall hooks from those board specific files run after the core ones,
therefore avoiding ugly #ifdef's in core code.
Tested-by: Dave Martin <dave.martin@linaro.org>
Tested-by: Jason Hui <jason.hui@linaro.org>
This patch introduces support for the tcc platform by creating an
arch/arm/plat-tcc and arch/arm/mach-tcc8k directories and adding
basic include files plus Kconfig and Makefile.
Signed-off-by: "Hans J. Koch" <hjk@linutronix.de>
Commit d0679c7 restricted this workaround to powerpc only, but it turns
out that ARM needs it as well. Fixes
https://bugzilla.kernel.org/show_bug.cgi?id=16310 .
Reported-and-Tested-by: Robert Nelson <robertcnelson@gmail.com>
Acked-by: Mikael Pettersson <mikpe@it.uu.se>
arch/arm/Kconfig
arch/arm/mm/Kconfig
arch/arm/Kconfig
v2: Fixes from Mike Rapoport
- remove unused header files (mach/dma.h and mach/nand.h)
- remove tegra 1 references from Makefile.boot
v2: fixes from Russell King
- remove mach/io.h include from mach/iomap.h
- fix whitespace in Kconfig
v2: from Colin Cross
- fix invalid immediate in debug-macro.S
v3:
- allow selection of multiple boards
Signed-off-by: Colin Cross <ccross@android.com>
Signed-off-by: Erik Gilling <konkers@android.com>
This patch adds the Kconfig and Makefile for the new S5PV310 SoC.
It also updates arch/arm Kconfig, Makefile and arch/arm/mm/Kconfig
to include support for the new S5PV310.
Signed-off-by: Changhwan Youn <chaos.youn@samsung.com>
arch/arm/kernel/entry-armv.S
arch/arm/kernel/setup.c
arch/arm/mm/init.c
devel-stable
into devel-stable
Add LPC32XX support in arch/arm/Kconfig and arch/arm/Makefile
Signed-off-by: Kevin Wells <wellsk40@gmail.com>
