While working on the 32-bit ARM port of UEFI, I noticed a strange
corruption in the kernel log. The following snprintf() statement
(in drivers/firmware/efi/efi.c:efi_md_typeattr_format())
snprintf(pos, size, "|%3s|%2s|%2s|%2s|%3s|%2s|%2s|%2s|%2s]",
was producing the following output in the log:
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | |WB|WT|WC|UC]*
| | | | | |WB|WT|WC|UC]
| | | | | |WB|WT|WC|UC]
|RUN| | | | | | | |UC]
As it turns out, this is caused by incorrect code being emitted for
the string() function in lib/vsprintf.c. The following code
if (!(spec.flags & LEFT)) {
while (len < spec.field_width--) {
if (buf < end)
*buf = ' ';
++buf;
for (i = 0; i < len; ++i) {
if (buf < end)
*buf = *s;
++buf; ++s;
if (buf < end)
*buf = ' ';
++buf;
when called with len == 0, triggers an issue in the GCC SRA optimization
pass (Scalar Replacement of Aggregates), which handles promotion of signed
struct members incorrectly. This is a known but as yet unresolved issue.
(https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65932). In this particular
case, it is causing the second while loop to be executed erroneously a
single time, causing the additional space characters to be printed.
So disable the optimization by passing -fno-ipa-sra.
Cc: <stable@vger.kernel.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
U-Boot is often used to boot the kernel on ARM boards, but uImage
is not built by "make all", so we are often inclined to do
"make all uImage" to generate DTBs, modules and uImage in a single
command, but we should notice a pitfall behind it. In fact,
"make all uImage" could generate an invalid uImage if it is run with
the parallel option (-j).
You can reproduce this problem with the following procedure:
[1] First, build "all" and "uImage" separately.
You will get a valid uImage
$ git clean -f -x -d
$ export CROSS_COMPILE=<your-tools-prefix>
$ make -s -j8 ARCH=arm multi_v7_defconfig
$ make -s -j8 ARCH=arm all
$ make -j8 ARCH=arm UIMAGE_LOADADDR=0x80208000 uImage
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
CHK include/generated/timeconst.h
CHK include/generated/bounds.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
Kernel: arch/arm/boot/Image is ready
Kernel: arch/arm/boot/zImage is ready
UIMAGE arch/arm/boot/uImage
Image Name: Linux-4.2.0-rc5-00156-gdd2384a-d
Created: Sat Aug 8 23:21:35 2015
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 6138648 Bytes = 5994.77 kB = 5.85 MB
Load Address: 80208000
Entry Point: 80208000
Image arch/arm/boot/uImage is ready
$ ls -l arch/arm/boot/*Image
-rwxrwxr-x 1 masahiro masahiro 13766656 Aug 8 23:20 arch/arm/boot/Image
-rw-rw-r-- 1 masahiro masahiro 6138712 Aug 8 23:21 arch/arm/boot/uImage
-rwxrwxr-x 1 masahiro masahiro 6138648 Aug 8 23:20 arch/arm/boot/zImage
[2] Update some source file(s)
$ touch init/main.c
[3] Then, re-build "all" and "uImage" simultaneously.
You will get an invalid uImage at random.
$ make -j8 ARCH=arm UIMAGE_LOADADDR=0x80208000 all uImage
CC init/main.o
LD init/built-in.o
LINK vmlinux
LD vmlinux.o
MODPOST vmlinux.o
GEN .version
UPD include/generated/compile.h
CC init/version.o
LD init/built-in.o
KSYM .tmp_kallsyms1.o
KSYM .tmp_kallsyms2.o
LD vmlinux
SORTEX vmlinux
SYSMAP System.map
OBJCOPY arch/arm/boot/Image
Building modules, stage 2.
GZIP arch/arm/boot/compressed/piggy.gzip
AS arch/arm/boot/compressed/piggy.gzip.o
LD arch/arm/boot/compressed/vmlinux
OBJCOPY arch/arm/boot/zImage
Created: Sat Aug 8 23:23:14 2015
Data Size: 26472 Bytes = 25.85 kB = 0.03 MB
MODPOST 192 modules
-rwxrwxr-x 1 masahiro masahiro 13766656 Aug 8 23:23 arch/arm/boot/Image
-rw-rw-r-- 1 masahiro masahiro 26536 Aug 8 23:23 arch/arm/boot/uImage
-rwxrwxr-x 1 masahiro masahiro 6138648 Aug 8 23:23 arch/arm/boot/zImage
Please notice the uImage is extremely small when this issue is
encountered. Besides, "Kernel: arch/arm/boot/zImage is ready" is
displayed twice, before and after the uImage log.
The root cause of this is the race condition between zImage and
uImage. Actually, uImage depends on zImage, but the dependency
between the two is only described in arch/arm/boot/Makefile.
Because arch/arm/boot/Makefile is not included from the top-level
Makefile, it cannot know the dependency between zImage and uImage.
Consequently, when we run make with the parallel option, Kbuild
updates vmlinux first, and then two different threads descends into
the arch/arm/boot/Makefile almost at the same time, one for updating
zImage and the other for uImage. While one thread is re-generating
zImage, the other also tries to update zImage before creating uImage
on top of that. zImage is overwritten by the slower thread and then
uImage is created based on the half-written zImage.
This is the reason why "Kernel: arch/arm/boot/zImage is ready" is
displayed twice, and a broken uImage is created.
The same problem could happen on bootpImage.
This commit adds dependencies among Image, zImage, uImage, and
bootpImage to arch/arm/Makefile, which is included from the
top-level Makefile.
Pull ARM updates from Russell King:
"Bigger items included in this update are:
- A series of updates from Arnd for ARM randconfig build failures
- Updates from Dmitry for StrongARM SA-1100 to move IRQ handling to
drivers/irqchip/
- Move ARMs SP804 timer to drivers/clocksource/
- Perf updates from Mark Rutland in preparation to move the ARM perf
code into drivers/ so it can be shared with ARM64.
- MCPM updates from Nicolas
- Add support for taking platform serial number from DT
- Re-implement Keystone2 physical address space switch to conform to
architecture requirements
- Clean up ARMv7 LPAE code, which goes in hand with the Keystone2
changes.
- L2C cleanups to avoid unlocking caches if we're prevented by the
secure support to unlock.
- Avoid cleaning a potentially dirty cache containing stale data on
CPU initialisation
- Add ARM-only entry point for secondary startup (for machines that
can only call into a Thumb kernel in ARM mode). Same thing is also
done for the resume entry point.
- Provide arch_irqs_disabled via asm-generic
- Enlarge ARMv7M vector table
- Always use BFD linker for VDSO, as gold doesn't accept some of the
options we need.
- Fix an incorrect BSYM (for Thumb symbols) usage, and convert all
BSYM compiler macros to a "badr" (for branch address).
- Shut up compiler warnings provoked by our cmpxchg() implementation.
- Ensure bad xchg sizes fail to link"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (75 commits)
ARM: Fix build if CLKDEV_LOOKUP is not configured
ARM: fix new BSYM() usage introduced via for-arm-soc branch
ARM: 8383/1: nommu: avoid deprecated source register on mov
ARM: 8391/1: l2c: add options to overwrite prefetching behavior
ARM: 8390/1: irqflags: Get arch_irqs_disabled from asm-generic
ARM: 8387/1: arm/mm/dma-mapping.c: Add arm_coherent_dma_mmap
ARM: 8388/1: tcm: Don't crash when TCM banks are protected by TrustZone
ARM: 8384/1: VDSO: force use of BFD linker
ARM: 8385/1: VDSO: group link options
ARM: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
ARM: remove __bad_xchg definition
ARM: 8369/1: ARMv7M: define size of vector table for Vybrid
ARM: 8382/1: clocksource: make ARM_TIMER_SP804 depend on GENERIC_SCHED_CLOCK
ARM: 8366/1: move Dual-Timer SP804 driver to drivers/clocksource
ARM: 8365/1: introduce sp804_timer_disable and remove arm_timer.h inclusion
ARM: 8364/1: fix BE32 module loading
ARM: 8360/1: add secondary_startup_arm prototype in header file
ARM: 8359/1: correct secondary_startup_arm mode
ARM: proc-v7: sanitise and document registers around errata
ARM: proc-v7: clean up MIDR access
Add basic code for ZTE ZX296702 platform.
[arnd: removed unused zx296702_init_machine function, and changed
l2c aux val to default]
Signed-off-by: Jun Nie <jun.nie@linaro.org>
Add support for NXP's LPC18xx (Cortex-M3) and LPC43xx (Cortex-M4)
SoCs. These SoCs are NXP's high preformance MCU line and can run at
clock speeds up to 180 MHz for LPC18xx and 204 MHz for LPC43xx.
LPC43xx is more or less a LPC18xx with a Cortex-M4F core and a few
extra peripherals. The LPC43xx series also features one or two
Cortex-M0 cores that can be used to offload the main M4 core.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Reviewed-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
STMicrolectronics's STM32 series is a family of Cortex-M
microcontrollers. It is used in various applications, and
proposes a wide range of peripherals.
Tested-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Initial commit for a new SoC family, UniPhier, developed by
Socionext Inc. (formerly, System LSI Business Division of
Panasonic Corporation).
This commit includes a minimal set of components for booting the
kernel, including SMP support.
Loading modules far away from the kernel in memory is problematic
because the 'bl' instruction only has limited reach, and modules are not
built with PLTs. Instead of using the -mlong-calls option (which affects
all compiler emitted bl instructions, but not the ones in assembler),
this patch allocates some additional space at module load time, and
populates it with PLT like veneers when encountering relocations that
are out of range.
This should work with all relocations against symbols exported by the
kernel, including those resulting from GCC generated implicit function
calls for ftrace etc.
The module memory size increases by about 5% on average, regardless of
whether any PLT entries were actually needed. However, due to the page
based rounding that occurs when allocating module memory, the average
memory footprint increase is negligible.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Pull ARM SoC platform updates from Olof Johansson:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. In this case, that includes:
- support for the new Annapurna Labs "Alpine" platform
- a rework greatly simplifying adding new platform support to the
MCPM subsystem (Multi-cluster power management)
- cpuidle and PM improvements for Exynos3250
- misc updates for Renesas, OMAP, Meson, i.MX. Some of these could
have gone in other branches but ended up here for various reasons"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits)
ARM: alpine: add support for generic pci
ARM: Exynos: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: DCSCB: tighten CPU validity assertion
ARM: vexpress: migrate TC2 to the new MCPM backend abstraction
ARM: MCPM: move the algorithmic complexity to the core code
ARM: EXYNOS: allow cpuidle driver usage on Exynos3250 SoC
ARM: EXYNOS: add AFTR mode support for Exynos3250
ARM: EXYNOS: add code for setting/clearing boot flag
ARM: EXYNOS: fix CPU1 hotplug on Exynos3250
ARM: S3C64XX: Use fixed IRQ bases to avoid conflicts on Cragganmore
ARM: cygnus: fix const declaration bcm_cygnus_dt_compat
ARM: DRA7: hwmod: Fix the hwmod class for GPTimer4
ARM: DRA7: hwmod: Add data for GPTimers 13 through 16
ARM: EXYNOS: Remove left over 'extra_save'
ARM: EXYNOS: Constify exynos_pm_data array
ARM: EXYNOS: use static in suspend.c
ARM: EXYNOS: Use platform device name as power domain name
ARM: EXYNOS: add support for async-bridge clocks for pm_domains
ARM: omap-device: add missed callback for suspend-to-disk
Pull ARM SoC cleanups from Olof Johansson:
"We've got a fairly large cleanup branch this time. The bulk of this
is removal of non-DT platforms of several flavors:
- Atmel at91 platforms go full-DT, with removal of remaining
board-file based support
- OMAP removes legacy board files for three more platforms
- removal of non-DT mach-msm, newer Qualcomm platforms now live in
mach-qcom
- Freescale i.MX25 also removes non-DT platform support"
Most of the rest of the changes here are fallout from the above, i.e. for
example removal of drivers that now lack platforms, etc.
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits)
mmc: Remove msm_sdcc driver
gpio: Remove gpio-msm-v1 driver
ARM: Remove mach-msm and associated ARM architecture code
ARM: shmobile: cpuidle: Remove the pointless default driver
ARM: davinci: dm646x: Add interrupt resource for McASPs
ARM: davinci: irqs: Correct McASP1 TX interrupt definition for DM646x
ARM: davinci: dm646x: Clean up the McASP DMA resources
ARM: davinci: devices-da8xx: Add support for McASP2 on da830
ARM: davinci: devices-da8xx: Clean up and correct the McASP device creation
ARM: davinci: devices-da8xx: Add interrupt resource to McASP structs
ARM: davinci: devices-da8xx: Add resource name for the McASP DMA request
ARM: OMAP2+: Remove legacy support for omap3 TouchBook
ARM: OMAP3: Remove legacy support for devkit8000
ARM: OMAP3: Remove legacy support for EMA-Tech Stalker board
ARM: shmobile: Consolidate the pm code for R-Car Gen2
ARM: shmobile: r8a7791: Correct SYSCIER value
ARM: shmobile: r8a7790: Correct SYSCIER value
ARM: at91: remove old setup
ARM: at91: sama5d4: remove useless map_io
ARM: at91: sama5 use SoC detection infrastructure
arch/arm/mm/proc-macros.S
When building a very large kernel, it is up to the linker to decide
when and where to insert stubs to allow calls to functions that are
out of range for the ordinary b/bl instructions.
However, since the kernel is built as a position dependent binary,
these stubs (aka veneers) may contain absolute addresses, which will
break far calls performed with the MMU off.
For instance, the call from __enable_mmu() in the .head.text section
to __turn_mmu_on() in the .idmap.text section may be turned into
something like this:
c0008168 <__enable_mmu>:
c0008168: f020 0002 bic.w r0, r0, #2
c000816c: f420 5080 bic.w r0, r0, #4096
c0008170: f000 b846 b.w c0008200 <____turn_mmu_on_veneer>
c0008200 <____turn_mmu_on_veneer>:
c0008200: 4778 bx pc
c0008202: 46c0 nop
c0008204: e59fc000 ldr ip, [pc]
c0008208: e12fff1c bx ip
c000820c: c13dfae1 teqgt sp, r1, ror #21
c13dfae0 <__turn_mmu_on>:
c13dfae0: 4600 mov r0, r0
After adding --pic-veneer to the LDFLAGS, the veneer is emitted like
this instead:
c0008202: 46c0 nop
c0008204: e59fc004 ldr ip, [pc, #4]
c0008208: e08fc00c add ip, pc, ip
c000820c: e12fff1c bx ip
c0008210: 013d7d31 teqeq sp, r1, lsr sp
c0008214: 00000000 andeq r0, r0, r0
Note that this particular example is best addressed by moving
.head.text and .idmap.text closer together, but this issue could
potentially affect any code that needs to execute with the
MMU off.
Allow users to enable the vdso in Kconfig; include the vdso in the
build if CONFIG_VDSO is enabled. Add 'vdso_install' target.
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
The maintainers for mach-msm no longer have any plans to support
or test the platforms supported by this architecture[1]. Most likely
there aren't any active users of this code anyway, so let's
delete it.
[1] http://lkml.kernel.org/r/20150307031212.GA8434@fifo99.com
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
This patch introduces initial architecture and device-tree support.
Signed-off-by: Saeed Bishara <saeed@annapurnalabs.com>
Signed-off-by: Tsahee Zidenberg <tsahee@annapurnalabs.com>
Make the digicolor specific DT_MACHINE_START entry visible.
Fixes: df8d742e929 (ARM: initial support for Conexant Digicolor CX92755 SoC)
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
In discussion on LKML (https://lkml.org/lkml/2014/11/28/158), Russell
King suggests to move all probe related code to arch/arm/probes. This
patch does the work. Due to dependency on 'arch/arm/kernel/patch.h', this
patch also moves patch.h to 'arch/arm/include/asm/patch.h', and related
'#include' directives are also midified to '#include <asm/patch.h>'.
Following is an overview of this patch:
./arch/arm/kernel/ ./arch/arm/probes/
|-- Makefile |-- Makefile
|-- probes-arm.c ==> |-- decode-arm.c
|-- probes-arm.h ==> |-- decode-arm.h
|-- probes-thumb.c ==> |-- decode-thumb.c
|-- probes-thumb.h ==> |-- decode-thumb.h
|-- probes.c ==> |-- decode.c
|-- probes.h ==> |-- decode.h
| |-- kprobes
| | |-- Makefile
|-- kprobes-arm.c ==> | |-- actions-arm.c
|-- kprobes-common.c ==> | |-- actions-common.c
|-- kprobes-thumb.c ==> | |-- actions-thumb.c
|-- kprobes.c ==> | |-- core.c
|-- kprobes.h ==> | |-- core.h
|-- kprobes-test-arm.c ==> | |-- test-arm.c
|-- kprobes-test.c ==> | |-- test-core.c
|-- kprobes-test.h ==> | |-- test-core.h
|-- kprobes-test-thumb.c ==> | `-- test-thumb.c
| `-- uprobes
| |-- Makefile
|-- uprobes-arm.c ==> |-- actions-arm.c
|-- uprobes.c ==> |-- core.c
|-- uprobes.h ==> `-- core.h
`-- patch.h ==> arch/arm/include/asm/patch.h
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Signed-off-by: Jon Medhurst <tixy@linaro.org>
The machine description is not needed to build dtb files.
Signed-off-by: Robert Richter <rrichter@cavium.com>
Add dtb files to build targets and let kbuild handle them. Thus,
special dtbs rules can be removed. This eases Makefiles and the
implementation of the support of vendor dtb subdirectories.
Move dtbs install rules to Makefile.dtbinst. This change is needed to
implement support for dts vendor subdirs. The change makes Makefiles
easier and smaller as no longer the dtbs_install rule needs to be
defined. Another advantage is that install goals are not encoded in
targets anymore (%.dtb_dtbinst_).
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild changes from Michal Marek:
- fix for handling dependencies of *-objs targets by Masahiro Yamada
- lots of cleanups in the kbuild machinery, also by Masahiro
- fixes for the kconfig build to use an UTF-8 capable ncurses library
if possible and to build on not-so-standard installs
- some more minor fixes
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: Do not reference *-n variables in the Makefile
kbuild: simplify build, clean, modbuiltin shorthands
kbuild: arm: Do not define "comma" twice
kbuild: remove obj-n and lib-n handling
kbuild: remove unnecessary variable initializaions
kbuild: remove unnecessary "obj- := dummy.o" trick
kbuild: handle C=... and M=... after entering into build directory
kbuild: use $(Q) for sub-make target
kbuild: fake the "Entering directory ..." message more simply
kconfig/lxdialog: get ncurses CFLAGS with pkg-config
kconfig: nconfig: fix multi-byte UTF handling
kconfig: lxdialog: fix spelling
kbuild: Make scripts executable
kbuild: remove redundant clean-files from scripts/kconfig/Makefile
kbuild: refactor script/kconfig/Makefile
kbuild: handle the dependency of multi-objs hostprogs appropriately
kbuild: handle multi-objs dependency appropriately
Pull ARM SoC platform changes from Arnd Bergmann:
"New and updated SoC support. Among the things new for this release
are:
- at91: Added support for the new SAMA5D4 SoC, following the earlier
SAMA5D3
- bcm: Added support for BCM63XX family of DSL SoCs
- hisi: Added support for HiP04 server-class SoC
- meson: Initial support for the Amlogic Meson6 (aka 8726MX) platform
- shmobile: added support for new r8a7794 (R-Car E2) automotive SoC
Noteworthy changes to existing SoC support are:
- imx: convert i.MX1 to device tree
- omap: lots of power management work
- omap: base support to enable moving to standard UART driver
- shmobile: lots of progress for multiplatform support, still
ongoing"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (171 commits)
ARM: hisi: depend on ARCH_MULTI_V7
CNS3xxx: Fix debug UART.
ARM: at91: fix nommu build regression
ARM: meson: add basic support for MesonX SoCs
ARM: meson: debug: add debug UART for earlyprintk support
irq: Export handle_fasteoi_irq
ARM: mediatek: Add earlyprintk support for mt6589
ARM: hisi: Fix platmcpm compilation when ARMv6 is selected
ARM: debug: fix alphanumerical order on debug uarts
ARM: at91: document Atmel SMART compatibles
ARM: at91: add sama5d4 support to sama5_defconfig
ARM: at91: dt: add device tree file for SAMA5D4ek board
ARM: at91: dt: add device tree file for SAMA5D4 SoC
ARM: at91: SAMA5D4 SoC detection code and low level routines
ARM: at91: introduce basic SAMA5D4 support
clk: at91: add a driver for the h32mx clock
ARM: pxa3xx: provide specific platform_devices for all ssp ports
ARM: pxa: ssp: provide platform_device_id for PXA3xx
ARM: OMAP4+: Remove static iotable mappings for SRAM
ARM: OMAP4+: Move SRAM data to DT
The definition of "comma" exists in scripts/Kbuild.include.
We should not double it.
Syntactically FOOTBRIDGE and ARCH_FOOTBRIDGE are identical (the former
is defined in an if ARCH_FOOTBRIDGE block and the latter selects the
former).
Sematically FOOTBRIDGE means "we have a DC21285 (aka footbridge) device
in the system" and ARCH_FOOTBRIDGE is the support for boards with a
footbridge device, so ARCH_FOOTBRIDGE is the better symbol here.
This patch adds the basic machine file for the MesonX SoCs. Only Meson6
is populated.
Signed-off-by: Carlo Caione <carlo@caione.org>
Pull ARM SoC platform changes from Olof Johansson:
"This is the bulk of new SoC enablement and other platform changes for
3.17:
- Samsung S5PV210 has been converted to DT and multiplatform
- Clock drivers and bindings for some of the lower-end i.MX 1/2
platforms
- Kirkwood, one of the popular Marvell platforms, is folded into the
mvebu platform code, removing mach-kirkwood
- Hwmod data for TI AM43xx and DRA7 platforms
- More additions of Renesas shmobile platform support
- Removal of plat-samsung contents that can be removed with S5PV210
being multiplatform/DT-enabled and the other two old platforms
being removed
New platforms (most with only basic support right now):
- Hisilicon X5HD2 settop box chipset is introduced
- Mediatek MT6589 (mobile chipset) is introduced
- Broadcom BCM7xxx settop box chipset is introduced
+ as usual a lot other pieces all over the platform code"
* tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits)
ARM: hisi: remove smp from machine descriptor
power: reset: move hisilicon reboot code
ARM: dts: Add hix5hd2-dkb dts file.
ARM: debug: Rename Hi3716 to HIX5HD2
ARM: hisi: enable hix5hd2 SoC
ARM: hisi: add ARCH_HISI
MAINTAINERS: add entry for Broadcom ARM STB architecture
ARM: brcmstb: select GISB arbiter and interrupt drivers
ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs
ARM: configs: enable SMP in bcm_defconfig
ARM: add SMP support for Broadcom mobile SoCs
Documentation: arm: misc updates to Marvell EBU SoC status
Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC
ARM: mvebu: fix build without platforms selected
ARM: mvebu: add cpuidle support for Armada 38x
ARM: mvebu: add cpuidle support for Armada 370
cpuidle: mvebu: add Armada 38x support
cpuidle: mvebu: add Armada 370 support
cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7
ARM: mvebu: export the SCU address
"This merge window brings a good size of cleanups on various platforms.
Among the bigger ones:
- Removal of Samsung s5pc100 and s5p64xx platforms. Both of these
have lacked active support for quite a while, and after asking
around nobody showed interest in keeping them around. If needed,
they could be resurrected in the future but it's more likely that
we would prefer reintroduction of them as DT and
multiplatform-enabled platforms instead.
- OMAP4 controller code register define diet. They defined a lot of
registers that were never actually used, etc.
- Move of some of the Tegra platform code (PMC, APBIO, fuse,
powergate) to drivers/soc so it can be shared with 64-bit code.
This also converts them over to traditional driver models where
possible.
- Removal of legacy gpio-samsung driver, since the last users have
been removed (moved to pinctrl)
Plus a bunch of smaller changes for various platforms that sort of
dissapear in the diffstat for the above. clps711x cleanups, shmobile
header file refactoring/moves for multiplatform friendliness, some
misc cleanups, etc"
* tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits)
drivers: CCI: Correct use of ! and &
video: clcd-versatile: Depend on ARM
video: fix up versatile CLCD helper move
MAINTAINERS: Add sdhci-st file to ARCH/STI architecture
ARM: EXYNOS: Fix build breakge with PM_SLEEP=n
MAINTAINERS: Remove Kirkwood
ARM: tegra: Convert PMC to a driver
soc/tegra: fuse: Set up in early initcall
ARM: tegra: Always lock the CPU reset vector
ARM: tegra: Setup CPU hotplug in a pure initcall
soc/tegra: Implement runtime check for Tegra SoCs
soc/tegra: fuse: fix dummy functions
soc/tegra: fuse: move APB DMA into Tegra20 fuse driver
soc/tegra: Add efuse and apbmisc bindings
soc/tegra: Add efuse driver for Tegra
ARM: tegra: move fuse exports to soc/tegra/fuse.h
ARM: tegra: export apb dma readl/writel
ARM: tegra: Use a function to get the chip ID
ARM: tegra: Sort includes alphabetically
ARM: tegra: Move includes to include/soc/tegra
Since multiple ARCH configuration will be appended into mach-hisi
directory, add ARCH_HISI as common configuration for different platforms
in mach-hisi.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Acked-by: Wei Xu <xuwei5@hisilicon.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc
Merge "Samsung S5PV210 DT support for v3.17" from Kukjin Kim:
- support common clock framework for s5pv210 clock
- add generic PHY driver on s5pv210 to support it via DT
- add dt support for s5pv210-goni, smdkc110, smdkv210 and torbreck boards
- remove board files from mach-s5pv210 and unused codes
- enable multiplatform for s5pv210
* tag 's5pv210-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
clk: samsung: s5pv210: Remove legacy board support
ARM: SAMSUNG: Remove remaining legacy code
gpio: samsung: Remove legacy support of S5PV210
ARM: S5PV210: Enable multi-platform build support
cpufreq: s5pv210: Make the driver multiplatform aware
ARM: S5PV210: Register cpufreq platform device
ARM: S5PV210: move debug-macro.S into the common space
ARM: S5PV210: Untie PM support from legacy code
ARM: S5PV210: Remove support for board files
ARM: dts: Add Device tree for s5pc110/s5pv210 boards
ARM: dts: Add Device tree for s5pv210 SoC
ARM: S5PV210: Add board file for boot using Device Tree
phy: Add support for S5PV210 to the Exynos USB 2.0 PHY driver
clk: samsung: Add S5PV210 Audio Subsystem clock driver
ARM: SAMSUNG: Remove legacy clock code
serial: samsung: Remove support for legacy clock code
cpufreq: s3c24xx: Remove some dead code
ARM: S5PV210: Migrate clock handling to Common Clock Framework
clk: samsung: Add clock driver for S5PV210 and compatible SoCs
'v3.16-rc6' into next/soc
The following samsung branches are based on these cleanups,
which are already in mainline before this branch gets pulled.
https://github.com/mbgg/linux-mediatek into next/soc
Merge basic support for the Mediatek Cortex-A7 SoCs from Matthias Brugger:
Support is quite basic, as the only component working up to now are the
timers.
* tag 'v3.17-next-mediatek-support' of https://github.com/mbgg/linux-mediatek:
arm: mediatek: add dts for Aquaris5 mobile phone
dt-bindings: add documentation for Mediatek SoC
arm: add basic support for Mediatek MT6589 boards
Signed-off-by: Matthias Brugger matthias.bgg@gmail.com
This adds a generic devicetree board file and a dtsi for boards
based on MT6589 SoCs from Mediatek.
Apart from the generic parts (gic, clocks) the only component
currently supported are the timers.
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
This makes it possible to enable the s5pv210 platform as part of a
multiplatform kernel. Also redundant Kconfig options are removed.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
The section of the makefile that determines the TEXT_OFFSET is sorted
by address so that, in multi-arch kernel builds, the architecture with the
most stringent requirements for the kernel base address gets to define
TEXT_OFFSET. The comment should reflect that.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Now that all boards have been converted to DT and all the support code
lives in mach-mvebu, we can remove mach-kirkwood.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1405028192-9623-2-git-send-email-andrew@lunn.ch
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This patch removes supporting codes for s5pc100 because no more used
now.
[jason@lakedaemon.net: for drivers/irqchip/Kconfig]
Acked-by: Jason Cooper <jason@lakedaemon.net>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
This patch removes supporting codes for s5p6440 and s5p6450 because
seems no more used now. And if its supporting is required, DT based
codes should be supprted next time.
The AXM55xx family consists of devices that may contain up to 16 ARM Cortex-A15
cores (in a 4x4 cluster configuration). The cores within each cluster share an
L2 cache, and the clusters are connected to each other via a CCN-504 cache
coherent interconnect.
This machine requires CONFIG_ARM_LPAE enabled as all peripherals are located
above 4GB in the memory map.
Signed-off-by: Anders Berg <anders.berg@lsi.com>
Pull ARM SoC cleanups from Arnd Bergmann:
"These cleanup patches are mainly move stuff around and should all be
harmless. They are mainly split out so that other branches can be
based on top to avoid conflicts.
Notable changes are:
- We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no
longer used (Uwe Kleine-König)
- The Qualcomm MSM platform is split out into legacy mach-msm and
new-style mach-qcom, to allow easier maintainance of the new
hardware support without regressions (Kumar Gala)
- A rework of some of the Kconfig logic to simplify multiplatform
support (Rob Herring)
- Samsung Exynos gets closer to supporting multiplatform (Sachin
Kamat and others)
- mach-bcm3528 gets merged into mach-bcm (Stephen Warren)
- at91 gains some common clock framework support (Alexandre Belloni,
Jean-Jacques Hiblot and other French people)"
* tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits)
ARM: hisi: select HAVE_ARM_SCU only for SMP
ARM: efm32: allow uncompress debug output
ARM: prima2: build reset code standalone
ARM: at91: add PWM clock
ARM: at91: move sam9261 SoC to common clk
ARM: at91: prepare common clk transition for sam9261 SoC
ARM: at91: updated the at91_dt_defconfig with support for the ADS7846
ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek
ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs
ARM: at91: dt: Add at91sam9261 dt SoC support
ARM: at91: switch sam9rl to common clock framework
ARM: at91/dt: define main clk frequency of at91sam9rlek
ARM: at91/dt: define at91sam9rl clocks
ARM: at91: prepare common clk transition for sam9rl SoCs
ARM: at91: prepare sam9 dt boards transition to common clk
ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek
ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs
ARM: at91: Add at91sam9rl DT SoC support
ARM: at91: prepare at91sam9rl DT transition
ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig
git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-rpi into next/cleanup
Merge "ARM: bcm2835: consolidate into mach-bcm/" from Stephen Warren:
This pull request consists of a single patch which moves files from
arch/arm/mach-bcm2835 into mach-bcm, thus consolidating them with
support for other Broadcom chips.
* tag 'bcm2835-for-3.15-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/swarren/linux-rpi:
ARM: bcm2835: Move to mach-bcm directory
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux into next/cleanup
Merge "kconfig clean-up and mach-virt removal for 3.15" from Rob Herring
- Remove common kconfig options required by multi-platform builds out
of individual platforms as they are redundant.
- Make SMP, CACHE_L2X0 and GPIO config options user visible on
multi-platform builds as most platforms enable these options and all
platforms can run with them enabled.
- Make multi-platform v6 default to more optimal v6k rather than v6
- Remove the last bit of mach-virt and convert it to just a kconfig
option.
* tag 'kconfig-cleanup-for-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
ARM: virt: select ARM_AMBA
ARM: virt: make mach-virt just a kconfig option
ARM: vt8500: enable V6K instead of plain V6
ARM: cns3xxx: enable V6K instead of plain V6
ARM: bcm2835: enable V6K instead of plain V6
ARM: Select V6K instead of V6 by default for multi-platform
ARM: select MIGHT_HAVE_CACHE_L2X0 for V6 and V7 multi-platform
ARM: select HAVE_SMP for V7 multi-platform
ARM: centralize common multi-platform kconfig options
Move the bcm2835 board file into the mach-bcm directory. This allows us
to get rid of the mach-bcm2835 directory with the associated Kconfig
and Makefile.
Signed-off-by: Markus Mayer <markus.mayer@linaro.org>
[swarren, adjust defconfig so ARCH_BCM2835 still gets enabled]
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Unlike other build products in the Linux kernel, there is no 'make
*install' mechanism to put devicetree blobs in a standard place.
This commit adds a new 'dtbs_install' make target which copies all of
the dtbs into the INSTALL_DTBS_PATH directory. INSTALL_DTBS_PATH can be
set before calling make to change the default install directory. If not
set then it defaults to:
$INSTALL_PATH/dtbs/$KERNELRELEASE.
This is done to keep dtbs from different kernel versions separate until
things have settled down. Once the dtbs are stable, and not so strongly
linked to the kernel version, the devicetree files will most likely move
to their own repo. Users will need to upgrade install scripts at that
time.
v7: (reworked by Grant Likely)
- Moved rules from arch/arm/Makefile to arch/arm/boot/dts/Makefile so
that each dtb install could have a separate target and be reported as
part of the make output.
- Fixed dependency problem to ensure $KERNELRELEASE is calculated before
attempting to install
- Removed option to call external script. Copying the files should be
sufficient and a build system can post-process the install directory.
Despite the fact an external script is used for installing the kernel,
I don't think that is a pattern that should be encouraged. I would
rather see buildroot type tools post process the install directory to
rename or move dtb files after installing to a staging directory.
- Plus it is easy to add a hook after the fact without blocking the
rest of this feature.
- Move the helper targets into scripts/Makefile.lib with the rest of the
common dtb rules
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Rob Herring <robh+dt@kernel.org>
The mach code for mach-virt is no longer needed, so we can remove all of
mach-virt except the kconfig entry.
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Introduce a new mach-qcom that will support SoCs that intend to be
multiplatform compatible while keeping mach-msm to legacy SoC/board
support that will not transition over to multiplatform.
As part of this, we move support for MSM8X60, MSM8960 and MSM8974 over
to mach-qcom.
GCC fails to build the kernel if EABI is selected, and the default FPU
is selected. Avoid this by explicitly stating that we want VFP with
EABI.
Pull ARM driver updates from Olof Johansson:
"Updates of SoC-near drivers and other driver updates that makes more
sense to take through our tree.
The largest part of this is a conversion of device registration for
some renesas shmobile/sh devices over to use resources. This has
required coordination with the corresponding arch/sh changes, and
we've agreed to merge the arch/sh changes through our tree.
Added in this branch is support for Trusted Foundations secure
firmware, which is what is used on many of the commercial Nvidia Tegra
products that are in the market, including the Nvidia Shield. The
code is local to arch/arm at this time since it's uncertain whether it
will be shared with arm64 longer-term, if needed we will refactor
later.
A couple of new RTC drivers used on ARM boards, merged through our
tree on request by the RTC maintainer.
... plus a bunch of smaller updates across the board, gpio conversions
for davinci, etc"
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (45 commits)
watchdog: davinci: rename platform driver to davinci-wdt
tty: serial: Limit msm_serial_hs driver to platforms that use it
mmc: msm_sdcc: Limit driver to platforms that use it
usb: phy: msm: Move mach dependent code to platform data
clk: versatile: fixup IM-PD1 clock implementation
clk: versatile: pass a name to ICST clock provider
ARM: integrator: pass parent IRQ to the SIC
irqchip: versatile FPGA: support cascaded interrupts from DT
gpio: davinci: don't create irq_domain in case of unbanked irqs
gpio: davinci: use chained_irq_enter/chained_irq_exit API
gpio: davinci: add OF support
gpio: davinci: remove unused variable intc_irq_num
gpio: davinci: convert to use irqdomain support.
gpio: introduce GPIO_DAVINCI kconfig option
gpio: davinci: get rid of DAVINCI_N_GPIO
gpio: davinci: use {readl|writel}_relaxed() instead of __raw_*
serial: sh-sci: Add OF support
serial: sh-sci: Add device tree bindings documentation
serial: sh-sci: Remove platform data mapbase and irqs fields
serial: sh-sci: Remove platform data scbrr_algo_id field
"New core SoC-specific changes.
New platforms:
* Introduction of a vendor, Hisilicon, and one of their SoCs with
some random numerical product name.
* Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m,
i.e. !MMU).
* Marvell Berlin series of SoCs, which include the one in Chromecast.
* MOXA platform support, ARM9-based platform used mostly in
industrial products
* Support for Freescale's i.MX50 SoC.
Other work:
* Renesas work for new platforms and drivers, and conversion over to
more multiplatform-friendly device registration schemes.
* SMP support for Allwinner sunxi platforms.
* ... plus a bunch of other stuff across various platforms"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits)
ARM: tegra: fix tegra_powergate_sequence_power_up() inline
ARM: msm_defconfig: Update for multi-platform
ARM: msm: Move MSM's DT based hardware to multi-platform support
ARM: msm: Only build timer.c if required
ARM: msm: Only build clock.c on proc_comm based platforms
ARM: ux500: Enable system suspend with WFI support
ARM: ux500: turn on PRINTK_TIME in u8500_defconfig
ARM: shmobile: r8a7790: Fix I2C controller names
ARM: msm: Simplify ARCH_MSM_DT config
ARM: msm: Add support for MSM8974 SoC
ARM: sunxi: select ARM_PSCI
MAINTAINERS: Update Allwinner sunXi maintainer files
ARM: sunxi: Select RESET_CONTROLLER
ARM: imx: improve the comment of CCM lpm SW workaround
ARM: imx: improve status check of clock gate
ARM: imx: add necessary interface for pfd
ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100
ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support
ARM: imx: Add cpu frequency scaling support
ARM i.MX35: Add devicetree support.
