path: root/arch/arm/boot/compressed/head-xscale.S
2012-04-06ARM: remove ixp23xx and ixp2000 platformsRob Herring
ixp2xxx platforms have had no real changes since ~2006 and the maintainer has said on irc that they can be removed: 13:05 < nico> do you still care about ixp2000? 13:22 < lennert> not really, no 13:58 < nico> do you think we could remove it from the kernel tree? 14:01 < lennert> go for it, and remove ixp23xx too while you're at it Removing will help simplify ARM consolidation in general and PCI re-work specifically. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
2008-08-07[ARM] Eliminate useless includes of asm/mach-types.hRussell King
There are 43 includes of asm/mach-types.h by files that don't reference anything from that file. Remove these unnecessary includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-01[ARM] 5062/1: pxa: remove unused definition of CONFIG_ARCH_COTULLA_IDPeric miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4558/1: pxa: remove MACH_TYPE_LUBBOCK assignment and leave it to boot ↵eric miao
loader since both u-boot and blob support passing MACH_TYPE_LUBBOCK to the kernel, it should be quite safe to remove this Signed-off-by: eric miao <eric.y.miao@gmail.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4407/1: Remove in-kernel mach id setting for gtwx5715 ixp4xx boardMichael-Luke Jones
If MACH_GTWX5715 is set in Kconfig, this code sets the mach id automatically. Howeber, this means that any IXP4xx kernel which is setup to support the gtwx5715 board will not successfully boot on any other board. If the bootloader sets the wrong mach id, it should be set correctly by a kernel shim. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-03[PATCH] ARM: 2700/1: Disable IXP2000 IRQs at bootupDeepak Saxena
Patch from Deepak Saxena The IXDP2800 bootloader does not disable IRQs before jumping into the kernel and this is causing the Grand Unified KGDB to crash the system when we do an early call to trap_init() and irq handlers have not yet been registered. This patch disables IRQs before we jump into the kernel. Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
