Commit 2552fc2 changed the way the decompressor decides if it is safe
to decompress the kernel directly to its final location. Unfortunately,
it took the top of the compressed data as being the stack pointer,
which it is for ROM=n cases. However, for ROM=y, the stack pointer
is not relevant, and results in the wrong answer.
Fix this by explicitly storing the end of the biggybacked data in the
decompressor, and use that to calculate the compressed image size.
CC: <stable@kernel.org>
We used to build decompressors with -Dstatic= to avoid any local data
being generated. The problem is that local data generates GOTOFF
relocations, which means we can't relocate the data relative to the
text segment.
Global data, on the other hand, goes through the GOT, and can be
relocated anywhere.
Unfortunately, with the new decompressors, this presents a problem
since they declare static data within functions, and this leads to
stack overflow.
Fix this by separating out the decompressor code into a separate file,
and removing 'static' from BSS data in misc.c.
Also, discard the .data section - this means that should we end up
with read/write initialized data, the decompressor will fail to link
and the problem will be obvious.
Acked-by: Nicolas Pitre <nico@fluxnic.net>
This patch adds the main functionality for parsing the stack unwinding
information generated by the ARM EABI toolchains. The unwinding
information consists of an index with a pair of words per function and a
table with unwinding instructions. For more information, see "Exception
Handling ABI for the ARM Architecture" at:
http://infocenter.arm.com/help/topic/com.arm.doc.subset.swdev.abi/index.html
Arrange for all the text ends up in the right place when
-ffunction-sections is used.
infrastructure for it.
Let it rip!
