Commit 7dd968163f7c ("bitmap: bitmap_equal memcmp optimization") was
rather more restrictive than necessary; we can use memcmp() to implement
bitmap_equal() as long as the number of bits can be proved to be a
multiple of 8. And architectures other than s390 may be able to make
good use of this optimisation.
[arnd@arndb.de: fix build: add a memcmp() declaration]
Link: http://lkml.kernel.org/r/20170630153908.3439707-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/20170628153221.11322-5-willy@infradead.org
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Acked-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Commit 06a4b6d009a1 ("ARM: 8677/1: boot/compressed: fix decompressor
header layout for v7-M") fixed an issue in the layout of the header
of the compressed kernel image that was caused by the assembler
emitting narrow opcodes for 'mov r0, r0', and for this reason, the
mnemonic was updated to use the W() macro, which will append the .w
suffix (which forces a wide encoding) if required, i.e., when building
the kernel in Thumb2 mode.
However, this failed to take into account that on Thumb2 kernels built
for CPUs that are also ARM capable, the entry point is entered in ARM
mode, and so the instructions emitted here will be ARM instructions
that only exist in a wide encoding to begin with, which is why the
assembler rejects the .w suffix here and aborts the build with the
following message:
head.S: Assembler messages:
head.S:132: Error: width suffixes are invalid in ARM mode -- `mov.w r0,r0'
So replace the W(mov) with separate ARM and Thumb2 instructions, where
the latter will only be used for THUMB2_ONLY builds.
Fixes: 06a4b6d009a1 ("ARM: 8677/1: boot/compressed: fix decompressor ...")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
As reported by Patrice, the header layout of the decompressor is
incorrect when building for v7-M. In this case, the __nop macro
resolves to 'mov r0, r0', which is emitted as a narrow encoding,
resulting in the header data fields to end up at lower offsets than
required.
Given the variety of targets we need to support with the same code,
the startup sequence is a bit of a jumble, and uses instructions
and macros whose encoding widths cannot be specified (badr), or only
exist in a narrow encoding (bx)
So force the use of a wide encoding in __nop, and replace the start
sequence with a simple jump to the label marking the start of code,
preceded by a Thumb2 mode switch if required (using explicit wide
encodings where appropriate). The label itself can be moved to the
start of code [where it belongs] due to the larger range of branch
instructions as compared to adr instructions.
Reported-by: Patrice CHOTARD <patrice.chotard@st.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
When the compressed image needs to be relocated to avoid being
overwritten by the decompression process, we need to relocate
the hyp vectors as well so that we can find them once the
decompression has taken effect.
For that, we perform the following calculation:
u32 v = __hyp_get_vectors();
v += offset;
__hyp_set_vectors(v);
But we're guaranteed that the initial value of v as returned by
__hyp_get_vectors is always __hyp_stub_vectors, because we have
just set it by calling __hyp_stub_install.
So let's remove the use of __hyp_get_vectors, and directly use
__hyp_stub_vectors instead.
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Christoffer Dall <cdall@linaro.org>
Pull ARM updates from Russell King:
- nommu updates from Afzal Mohammed cleaning up the vectors support
- allow DMA memory "mapping" for nommu Benjamin Gaignard
- fixing a correctness issue with R_ARM_PREL31 relocations in the
module linker
- add strlen() prototype for the decompressor
- support for DEBUG_VIRTUAL from Florian Fainelli
- adjusting memory bounds after memory reservations have been
registered
- unipher cache handling updates from Masahiro Yamada
- initrd and Thumb Kconfig cleanups
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (23 commits)
ARM: mm: round the initrd reservation to page boundaries
ARM: mm: clean up initrd initialisation
ARM: mm: move initrd init code out of arm_memblock_init()
ARM: 8655/1: improve NOMMU definition of pgprot_*()
ARM: 8654/1: decompressor: add strlen prototype
ARM: 8652/1: cache-uniphier: clean up active way setup code
ARM: 8651/1: cache-uniphier: include <linux/errno.h> instead of <linux/types.h>
ARM: 8650/1: module: handle negative R_ARM_PREL31 addends correctly
ARM: 8649/2: nommu: remove Hivecs configuration is asm
ARM: 8648/2: nommu: display vectors base
ARM: 8647/2: nommu: dynamic exception base address setting
ARM: 8646/1: mmu: decouple VECTORS_BASE from Kconfig
ARM: 8644/1: Reduce "CPU: shutdown" message to debug level
ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbol
ARM: 8640/1: Add support for CONFIG_DEBUG_VIRTUAL
ARM: 8639/1: Define KERNEL_START and KERNEL_END
ARM: 8638/1: mtd: lart: Rename partition defines to be prefixed with PART_
ARM: 8637/1: Adjust memory boundaries after reservations
ARM: 8636/1: Cleanup sanity_check_meminfo
ARM: add CPU_THUMB_CAPABLE to indicate possible Thumb support
The decompress.c file contains a declaration for strstr() so we can
include some compression library code.
With the updated LZ4 implementation, we run into the same problem again
for strlen():
In file included from ../include/linux/rcupdate.h:40:0,
from ../include/linux/srcu.h:33,
from ../include/linux/notifier.h:15,
from ../include/linux/memory_hotplug.h:6,
from ../include/linux/mmzone.h:749,
from ../include/linux/gfp.h:5,
from ../include/linux/kmod.h:22,
from ../include/linux/module.h:13,
from ../arch/arm/boot/compressed/../../../../lib/lz4/lz4_decompress.c:39,
from ../arch/arm/boot/compressed/../../../../lib/decompress_unlz4.c:13,
from ../arch/arm/boot/compressed/decompress.c:55:
include/linux/cpumask.h: In function 'cpumask_parse':
include/linux/cpumask.h:592:53: error: implicit declaration of function 'strlen';did you mean 'strstr'? [-Werror=implicit-function-declaration]
This adds another declaration to work around the new problem.
Fixes: ce83d9ab80d6 ("lib: update LZ4 compressor module")
Fix typos and add the following to the scripts/spelling.txt:
swith||switch
swithable||switchable
swithed||switched
swithing||switching
While we are here, fix the "update" to "updates" in the touched hunk in
drivers/net/wireless/marvell/mwifiex/wmm.c.
Link: http://lkml.kernel.org/r/1481573103-11329-2-git-send-email-yamada.masahiro@socionext.com
If the bootloader uses the long descriptor format and jumps to
kernel decompressor code, TTBCR may not be in a right state.
Before enabling the MMU, it is required to clear the TTBCR.PD0
field to use TTBR0 for translation table walks.
The commit dbece45894d3a ("ARM: 7501/1: decompressor:
reset ttbcr for VMSA ARMv7 cores") does the reset of TTBCR.N, but
doesn't consider all the bits for the size of TTBCR.N.
Clear TTBCR.PD0 field and reset all the three bits of TTBCR.N to
indicate the use of TTBR0 and the correct base address width.
Fixes: dbece45894d3 ("ARM: 7501/1: decompressor: reset ttbcr for VMSA ARMv7 cores")
Acked-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Srinivas Ramana <sramana@codeaurora.org>
"Another mixture of changes this time around:
- Split XIP linker file from main linker file to make it more
maintainable, and various XIP fixes, and clean up a resulting
macro.
- Decompressor cleanups from Masahiro Yamada
- Avoid printing an error for a missing L2 cache
- Remove some duplicated symbols in System.map, and move
vectors/stubs back into kernel VMA
- Various low priority fixes from Arnd
- Updates to allow bus match functions to return negative errno
values, touching some drivers and the driver core. Greg has acked
these changes.
- Virtualisation platform udpates form Jean-Philippe Brucker.
- Security enhancements from Kees Cook
- Rework some Kconfig dependencies and move PSCI idle management code
out of arch/arm into drivers/firmware/psci.c
- ARM DMA mapping updates, touching media, acked by Mauro.
- Fix places in ARM code which should be using virt_to_idmap() so
that Keystone2 can work.
- Fix Marvell Tauros2 to work again with non-DT boots.
- Provide a delay timer for ARM Orion platforms"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (45 commits)
ARM: 8546/1: dma-mapping: refactor to fix coherent+cma+gfp=0
ARM: 8547/1: dma-mapping: store buffer information
ARM: 8543/1: decompressor: rename suffix_y to compress-y
ARM: 8542/1: decompressor: merge piggy.*.S and simplify Makefile
ARM: 8541/1: decompressor: drop redundant FORCE in Makefile
ARM: 8540/1: decompressor: use clean-files instead of extra-y to clean files
ARM: 8539/1: decompressor: drop more unneeded assignments to "targets"
ARM: 8538/1: decompressor: drop unneeded assignments to "targets"
ARM: 8532/1: uncompress: mark putc as inline
ARM: 8531/1: turn init_new_context into an inline function
ARM: 8530/1: remove VIRT_TO_BUS
ARM: 8537/1: drop unused DEBUG_RODATA from XIP_KERNEL
ARM: 8536/1: mm: hide __start_rodata_section_aligned for non-debug builds
ARM: 8535/1: mm: DEBUG_RODATA makes no sense with XIP_KERNEL
ARM: 8534/1: virt: fix hyp-stub build for pre-ARMv7 CPUs
ARM: make the physical-relative calculation more obvious
ARM: 8512/1: proc-v7.S: Adjust stack address when XIP_KERNEL
ARM: 8411/1: Add default SPARSEMEM settings
ARM: 8503/1: clk_register_clkdev: remove format string interface
ARM: 8529/1: remove 'i' and 'zi' targets
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- new tool 'dtx_diff' to diff DT files
- sync kernel's dtc/libfdt to current dtc repo master
- fix for reserved memory regions located in highmem
- document standard unit suffixes for DT properties
- various DT binding doc updates
* tag 'devicetree-for-4.6' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: Add vendor prefix for eGalax_eMPIA Technology Inc
Input: ads7846: Add description how to use internal reference (ADS7846)
ARM: realview: add EB syscon variants to bindings
devicetree: bindings: ARM: Use "uV" for micro-volt
serial: fsl-imx-uart: Fix typo in fsl,dte-mode description
of: add 'const' for of_property_*_string*() parameter '*np'
of/unittest: fix infinite loop in of_unittest_destroy_tracked_overlays()
of: alloc anywhere from memblock if range not specified
kbuild: Allow using host dtc instead of kernel's copy
of: resolver: Add missing of_node_get and of_node_put
of: Add United Radiant Technology Corporation vendor prefix
dt/bindings: add documentation on standard property unit suffixes
scripts/dtc: Update to upstream commit b06e55c88b9b
ARM: boot: Add an implementation of strnlen for libfdt
scripts/dtc: dtx_diff - add info to error message
dtc: create tool to diff device trees
The "$(suffix_y)" no longer appears in the file names, but it just
specifies the method of the file compression. The "compress-y" sounds
more suitable.
The files piggy.$(suffix).S are similar enough to be merged into a
single file. This also allows clean up of the Makefile.
The object "piggy.$(suffix_y).o" is created from "piggy.$(suffix).S"
by the following pattern rule defined in scripts/Makefile.build:
$(obj)/%.o: $(src)/%.S FORCE
$(call if_changed_dep,as_o_S)
FORCE is already added to the prerequisite of the object there.
This code works fine here, but it is tricky to use "extra-y" for
specifying files to be removed during "make clean". Kbuild provides
"clean-files" for this purpose.
The objects "font.o" and "misc.o" are contained in $(OBJS), and it
is already added to the "targets".
The "targets" exists to specify which files need the corresponding
".*_cmd" files to be included during the build. In other words, it
is used for files that need to detect the change of the command line
by if_changed, if_changed_dep, and if_changed_rule. While, these
files are just copied by "$(call cmd,shipped)". Adding them to the
"targets" is meaningless because $(call cmd,...) never creates
".*_cmd" files. Such files as ".lib1funcs.S.cmd", ".ashldi3.S.cmd"
do not exist in the first place.
ARMv6 CPUs do not have virtualisation extensions, but hyp-stub.S is
still included into the image to keep it generic. In order to use ARMv7
instructions during HYP initialisation, add -march=armv7-a flag to
hyp-stub's build.
On an ARMv6 CPU, __hyp_stub_install returns as soon as it detects that
the mode isn't HYP, so we will never reach those instructions.
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
hyp-stub's build.
Recent versions of libfdt add a dependency on strnlen. Copy the
implementation in lib/string.c here, so we can update libfdt.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Rob Herring <robh@kernel.org>
Building with CONFIG_CC_STACKPROTECTOR_STRONG triggers protection code
generation under CONFIG_ARM_ATAG_DTB_COMPAT but this is too early for
being able to use any of the stack_chk code. Explicitly disable it for
only the atags_to_fdt bits.
Suggested-by: zhxihu <zhxihu@marvell.com>
This patch adds EFI stub support for the ARM Linux kernel.
The EFI stub operates similarly to the x86 and arm64 stubs: it is a
shim between the EFI firmware and the normal zImage entry point, and
sets up the environment that the zImage is expecting. This includes
optionally loading the initrd and device tree from the system partition
based on the kernel command line.
Signed-off-by: Roy Franz <roy.franz@linaro.org>
Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk>
When loading x86 64bit kernel above 4GiB with patched grub2, got kernel
gunzip error.
| early console in decompress_kernel
| decompress_kernel:
| input: [0x807f2143b4-0x807ff61aee]
| output: [0x807cc00000-0x807f3ea29b] 0x027ea29c: output_len
| boot via startup_64
| KASLR using RDTSC...
| new output: [0x46fe000000-0x470138cfff] 0x0338d000: output_run_size
| decompress: [0x46fe000000-0x47007ea29b] <=== [0x807f2143b4-0x807ff61aee]
| Decompressing Linux... gz...
| uncompression error
| -- System halted
the new buffer is at 0x46fe000000ULL, decompressor_gzip is using
0xffffffb901ffffff as out_len. gunzip in lib/zlib_inflate/inflate.c cap
that len to 0x01ffffff and decompress fails later.
We could hit this problem with crashkernel booting that uses kexec loading
kernel above 4GiB.
We have decompress_* support:
1. inbuf[]/outbuf[] for kernel preboot.
2. inbuf[]/flush() for initramfs
3. fill()/flush() for initrd.
This bug only affect kernel preboot path that use outbuf[].
Add __decompress and take real out_buf_len for gunzip instead of guessing
wrong buf size.
Fixes: 1431574a1c4 (lib/decompressors: fix "no limit" output buffer length)
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Jon Medhurst <tixy@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: <stable@vger.kernel.org>
The last user of the zboot code was the KZM-A9-GT legacy board code,
which has been removed.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux
Pull devicetree updates from Grant Likely:
"A whole lot of bug fixes.
Nothing stands out here except the ability to enable CONFIG_OF on
every architecture, and an import of a newer version of dtc"
* tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: (22 commits)
of/irq: Rename "intc_desc" to "of_intc_desc" to fix OF on sh
of/irq: Fix pSeries boot failure
Documentation: DT: Fix a typo in the filename "lantiq,<chip>-pinumx.txt"
of: define of_find_node_by_phandle for !CONFIG_OF
of/address: use atomic allocation in pci_register_io_range()
of: Add vendor prefix for Zodiac Inflight Innovations
dt/fdt: add empty versions of early_init_dt_*_memory_arch
of: clean-up unnecessary libfdt include paths
of: make unittest select OF_EARLY_FLATTREE instead of depend on it
of: make CONFIG_OF user selectable
MIPS: prepare for user enabling of CONFIG_OF
of/fdt: fix argument name and add comments of unflatten_dt_node()
of: return NUMA_NO_NODE from fallback of_node_to_nid()
tps6507x.txt: Remove executable permission
of/overlay: Grammar s/an negative/a negative/
of/fdt: Make fdt blob input parameters of unflatten functions const
of: add helper function to retrive match data
of: Grammar s/property exist/property exists/
of: Move OF flags to be visible even when !CONFIG_OF
scripts/dtc: Update to upstream version 9d3649bd3be245c9
arch/arm/kernel/head.S
The branch profiling code cannot work outside of the main
kernel and just causes link errors if we try to use it in
the decompressor. Disabling it here matches what we do
for other architectures.
BSYM() was invented to allow us to work around a problem with the
assembler, where local symbols resolved by the assembler for the 'adr'
instruction did not take account of their ISA.
Since we don't want BSYM() used elsewhere, replace BSYM() with a new
macro 'badr', which is like the 'adr' pseudo-op, but with the BSYM()
mechanics integrated into it. This ensures that the BSYM()-ification
is only used in conjunction with 'adr'.
Acked-by: Dave Martin <Dave.Martin@arm.com>
In preparation for libfdt/dtc update, add the new fdt specific types.
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
Pull ARM SoC multiplatform code changes from Olof Johansson:
"The changes here belong to two main platforms:
- Atmel At91 is flipping the bit and going multiplatform. This
includes some cleanups and removal of code, and the final flip of
config dependencies
- Shmobile has several platforms that are going multiplatform, but
this branch also contains a bunch of cleanups that they weren't
able to keep separate in a good way. THere's also a removal of one
of their SoCs and the corresponding boards (sh7372 and mackerel)"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
ARM: at91/pm: move AT91_MEMCTRL_* to pm.h
ARM: at91/pm: move the standby functions to pm.c
ARM: at91: fix pm_suspend.S compilation when ARMv6 is selected
ARM: at91: add a Kconfig dependency on multi-platform
ARM: at91: drop AT91_TIMER_HZ
ARM: at91: remove hardware.h
ARM: at91: remove SoC headers
ARM: at91: remove useless mach/cpu.h
ARM: at91: remove unused headers
ARM: at91: switch at91_dt_defconfig to multiplatform
ARM: at91: switch to multiplatform
ARM: shmobile: r8a7778: enable multiplatform target
ARM: shmobile: bockw: add sound to DT
ARM: shmobile: r8a7778: add sound to DT
ARM: shmobile: bockw: add devices hooked up to i2c0 to DT
DT: i2c: add trivial binding for OKI ML86V7667 video decoder
ARM: shmobile: r8a7778: common clock framework CPG driver
ARM: shmobile: bockw dts: set extal clock frequency
ARM: shmobile: bockw dts: Move Ethernet node to BSC
ARM: shmobile: r8a73a4: Remove legacy code
This patch makes it possible to enter zImage in Thumb mode for ARMv7-M
(Cortex-M) CPUs that do not support ARM mode. The kernel entry is also
made in Thumb mode.
[ukl: fix spelling in commit log, return early in call_cache_fn]
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Tested-by: Stefan Agner <stefan@agner.ch>
Tested-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Tested-by: Chanwoo Choi <cw00.choi@samsung.com>
Occasionally, there's a question about the method we use to find the
start of physical memory. Add some documentation so we don't have to
keep repeating outselves on the mailing list.
Remove the sh7372 implementation and the shared ZBOOT MMC
and SDHI support code from the compressed ARM boot loader.
With this in place it is no longer possible to boot any
self-contained kernel for sh7372 directly from Mask ROM
via SDHI and MMCIF hardware.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
into for-next
There is currently a hardcoded limit of 64KB for the DTB to live in and
be extended with ATAG info. Some DTBs have outgrown that limit:
$ du -b arch/arm/boot/dts/omap3-n900.dtb
70212 arch/arm/boot/dts/omap3-n900.dtb
Furthermore, the actual size passed to atags_to_fdt() included the stack
size which is obviously wrong.
The initial DTB size is known, so use it to size the allocated workspace
with a 50% growth assumption and relocate the temporary stack above that.
This is also clamped to 32KB min / 1MB max for robustness against bad
DTB data.
Reported-by: Pali Rohár <pali.rohar@gmail.com>
Tested-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Nicolas Pitre <nico@linaro.org>
This comment does not correspond to the actual code.
When zImage is loaded at a lower *OR* higher address of
the destination of Image, it won't overwrite itself.
To speed up decompression, the decompressor sets up a flat, cacheable
mapping of memory. However, when there is insufficient space to hold
the page tables for this mapping, we don't bother to enable the caches
and subsequently skip all the cache maintenance hooks.
Skipping the cache maintenance before jumping to the relocated code
allows the processor to predict the branch and populate the I-cache
with stale data before the relocation loop has completed (since a
bootloader may have SCTLR.I set, which permits normal, cacheable
instruction fetches regardless of SCTLR.M).
This patch moves the cache maintenance check into the maintenance
routines themselves, allowing the v6/v7 versions to invalidate the
I-cache regardless of the MMU state.
Reported-by: Marc Carino <marc.ceeeee@gmail.com>
Tested-by: Julien Grall <julien.grall@linaro.org>
Enable gcov support for ARM based on original patches by David
Singleton and George G. Davis
Riku - updated to patch to current mainline kernel. The patch
has been submitted in 2010, 2012 - for symmetry, now in 2014 too.
https://lwn.net/Articles/390419/
http://marc.info/?l=linux-arm-kernel&m=133823081813044
v2: remove arch/arm/kernel from gcov disabled files
Cc: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Naresh Kamboju <naresh.kamboju@linaro.org>
Signed-off-by: Riku Voipio <riku.voipio@linaro.org>
Signed-off-by: Vincent Sanders <vincent.sanders@collabora.co.uk>
With patch #8067/1 ("zImage: ensure header in LE format for BE8 kernels")
applied, it is no longer possible to determine the endianness of a compiled
kernel image. This normally shouldn't matter to the boot environment,
except for those cases where the selection of a ramdisk or root filesystem
with a matching endianness has to be automated.
Let's add a flag to the zImage header indicating the actual endianness.
Four bytes from offset 0x30 can be interpreted as follows:
04 03 02 01 big endian kernel
01 02 03 04 little endian kernel
Anything else should be interpreted as "unknown", in which case it is
most likely that patch #8067/1 was not applied either and the zImage
magic number at offset 0x24 could be used instead to determine
endianness. No zImage before this patch ever produced 0x01020304 nor
0x04030201 at offset 0x30 so there is no confusion possible.
Acked-by: Kevin Hilman <khilman@linaro.org>
As we are now using the C preprocessor, we do not need to use sed to
edit constants in this file, and then pass the resulting file through
the C preprocessor. Instead, rely solely on the C preprocessor to
rewrite TEXT_START and BSS_ADDR.
All known BE8-capable systems have LE bootloaders, so we need to ensure
that the magic number and image start/end values are in little endian
format.
[ben.dooks@codethink.co.uk: from nico's original email on this subject]
[taras.kondratiuk@linaro.org: removed lds.S->lds rule, added target to extra-y]
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
memblock is now fully integrated into the kernel and is the prefered
method for tracking memory. Rather than reinvent the wheel with
meminfo, migrate to using memblock directly instead of meminfo as
an intermediate.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
addruart from the generic debug macro is doing exactly the same using
the common lowlevel uart definition, so there is no cause for this
special casing for s3c24xx.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Commit 017f161a55b4 (ARM: 7877/1: use built-in byte swap function) added
bswapsdi2.{o,S} to arch/arm/boot/compressed/Makefile, but didn't update
the .gitignore. Thus after a a build git status shows bswapsdi2.S as a
new file, which is a little annoying.
This patch updates arch/arm/boot/compressed/.gitignore to ignore
bswapsdi2.S, as we already do for ashldi3.S and others.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Pull ARM SoC platform changes from Olof Johansson:
"New core SoC-specific changes.
New platforms:
* Introduction of a vendor, Hisilicon, and one of their SoCs with
some random numerical product name.
* Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m,
i.e. !MMU).
* Marvell Berlin series of SoCs, which include the one in Chromecast.
* MOXA platform support, ARM9-based platform used mostly in
industrial products
* Support for Freescale's i.MX50 SoC.
Other work:
* Renesas work for new platforms and drivers, and conversion over to
more multiplatform-friendly device registration schemes.
* SMP support for Allwinner sunxi platforms.
* ... plus a bunch of other stuff across various platforms"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits)
ARM: tegra: fix tegra_powergate_sequence_power_up() inline
ARM: msm_defconfig: Update for multi-platform
ARM: msm: Move MSM's DT based hardware to multi-platform support
ARM: msm: Only build timer.c if required
ARM: msm: Only build clock.c on proc_comm based platforms
ARM: ux500: Enable system suspend with WFI support
ARM: ux500: turn on PRINTK_TIME in u8500_defconfig
ARM: shmobile: r8a7790: Fix I2C controller names
ARM: msm: Simplify ARCH_MSM_DT config
ARM: msm: Add support for MSM8974 SoC
ARM: sunxi: select ARM_PSCI
MAINTAINERS: Update Allwinner sunXi maintainer files
ARM: sunxi: Select RESET_CONTROLLER
ARM: imx: improve the comment of CCM lpm SW workaround
ARM: imx: improve status check of clock gate
ARM: imx: add necessary interface for pfd
ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100
ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support
ARM: imx: Add cpu frequency scaling support
ARM i.MX35: Add devicetree support.
"In this set, we have:
- Refactoring of some of the old StrongARM-1100 GPIO code to make
things simpler by Dmitry Eremin-Solenikov
- Read-only and non-executable support for modules on ARM from Laura
Abbot
- Removal of unnecessary set_drvdata() calls in AMBA code
- Some non-executable support for kernel lowmem mappings at the 1MB
section granularity, and dumping of kernel page tables via debugfs
- Some improvements for the timer/clock code on Footbridge platforms,
and cleanup some of the LED code there
- Fix fls/ffs() signatures to match x86 to prevent build warnings,
particularly where these are used with min/max() macros
- Avoid using the bootmem allocator on ARM (patches from Santosh
Shilimkar)
- Various asid/unaligned access updates from Will Deacon"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (51 commits)
ARM: SMP implementations are not supposed to return from smp_ops.cpu_die()
ARM: ignore memory below PHYS_OFFSET
Fix select-induced Kconfig warning for ZBOOT_ROM
ARM: fix ffs/fls implementations to match x86
ARM: 7935/1: sa1100: collie: add gpio-keys configuration
ARM: 7932/1: bcm: Add DEBUG_LL console support
ARM: 7929/1: Remove duplicate SCHED_HRTICK config option
ARM: 7928/1: kconfig: select HAVE_EFFICIENT_UNALIGNED_ACCESS for CPUv6+ && MMU
ARM: 7927/1: dcache: select DCACHE_WORD_ACCESS for big-endian CPUs
ARM: 7926/1: mm: flesh out and fix the comments in the ASID allocator
ARM: 7925/1: mm: keep track of last ASID allocation to improve bitmap searching
ARM: 7924/1: mm: don't bother with reserved ttbr0 when running with LPAE
ARM: PCI: add legacy IDE IRQ implementation
ARM: footbridge: cleanup LEDs code
ARM: pgd allocation: retry on failure
ARM: footbridge: add one-shot mode for DC21285 timer
ARM: footbridge: add sched_clock implementation
ARM: 7922/1: l2x0: add Marvell Tauros3 support
ARM: 7921/1: mcpm: remove redundant dsb instructions prior to sev
Enable the compiler intrinsic for byte swapping on arch ARM. This
allows the compiler to detect and be able to optimize out byte
swappings, and has a very modest benefit on vmlinux size (Linaro gcc
4.8):
2840310 123932 61960 3026202 2e2d1a vmlinux-lart #orig
2840152 123932 61960 3026044 2e2c7c vmlinux-lart #builtin-bswap
6473120 314840 5616016 12403976 bd4508 vmlinux-mxs #orig
6472586 314848 5616016 12403450 bd42fa vmlinux-mxs #builtin-bswap
7419872 318372 379556 8117800 7bde28 vmlinux-imx_v6_v7 #orig
7419170 318364 379556 8117090 7bdb62 vmlinux-imx_v6_v7 #builtin-bswap
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
This changes the stack protector config option into a choice of
"None", "Regular", and "Strong":
CONFIG_CC_STACKPROTECTOR_NONE
CONFIG_CC_STACKPROTECTOR_REGULAR
"Regular" means the old CONFIG_CC_STACKPROTECTOR=y option.
"Strong" is a new mode introduced by this patch. With "Strong" the
kernel is built with -fstack-protector-strong (available in
gcc 4.9 and later). This option increases the coverage of the stack
protector without the heavy performance hit of -fstack-protector-all.
For reference, the stack protector options available in gcc are:
-fstack-protector-all:
Adds the stack-canary saving prefix and stack-canary checking
suffix to _all_ function entry and exit. Results in substantial
use of stack space for saving the canary for deep stack users
(e.g. historically xfs), and measurable (though shockingly still
low) performance hit due to all the saving/checking. Really not
suitable for sane systems, and was entirely removed as an option
from the kernel many years ago.
-fstack-protector:
Adds the canary save/check to functions that define an 8
(--param=ssp-buffer-size=N, N=8 by default) or more byte local
char array. Traditionally, stack overflows happened with
string-based manipulations, so this was a way to find those
functions. Very few total functions actually get the canary; no
measurable performance or size overhead.
Adds the canary for a wider set of functions, since it's not
just those with strings that have ultimately been vulnerable to
stack-busting. With this superset, more functions end up with a
canary, but it still remains small compared to all functions
with only a small change in performance. Based on the original
design document, a function gets the canary when it contains any
of:
- local variable's address used as part of the right hand side
of an assignment or function argument
- local variable is an array (or union containing an array),
regardless of array type or length
- uses register local variables
https://docs.google.com/a/google.com/document/d/1xXBH6rRZue4f296vGt9YQcuLVQHeE516stHwt8M9xyU
Find below a comparison of "size" and "objdump" output when built with
gcc-4.9 in three configurations:
- defconfig
11430641 kernel text size
36110 function bodies
- defconfig + CONFIG_CC_STACKPROTECTOR_REGULAR
11468490 kernel text size (+0.33%)
1015 of 36110 functions are stack-protected (2.81%)
- defconfig + CONFIG_CC_STACKPROTECTOR_STRONG via this patch
11692790 kernel text size (+2.24%)
7401 of 36110 functions are stack-protected (20.5%)
With -strong, ARM's compressed boot code now triggers stack
protection, so a static guard was added. Since this is only used
during decompression and was never used before, the exposure
here is very small. Once it switches to the full kernel, the
stack guard is back to normal.
Chrome OS has been using -fstack-protector-strong for its kernel
builds for the last 8 months with no problems.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/1387481759-14535-3-git-send-email-keescook@chromium.org
[ Improved the changelog and descriptions some more. ]
SH-Mobile platforms are transitioning from non-multiplatform to
multiplatform kernel. A new ARCH_SHMOBILE_MULTI configuration symbol has
been created to group all multiplatform-enabled SH-Mobile SoCs. The
existing ARCH_SHMOBILE configuration symbol groups SoCs that haven't
been converted yet.
This arrangement works fine for the arch/ code, but lots of drivers
needed on both ARCH_SHMOBILE and ARCH_SHMOBILE_MULTI depend on
ARCH_SHMOBILE only. In order to avoid changing them, rename
ARCH_SHMOBILE to ARCH_SHMOBILE_LEGACY, and create a new boolean
ARCH_SHMOBILE configuration symbol that is selected by both
ARCH_SHMOBILE_LEGACY and ARCH_SHMOBILE_MULTI.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Acked-by: Magnus Damm <damm@opensource.se>
