While at it, add the dtbs for Aster Carrier Board to the Makefile.
Add support for the Computer on Module Colibri iMX6ULL and its
Bluetooth/Wifi variant along with the development/evaluation carrier
board device trees. Follow the usual hierarchic include model,
maintaining shared configuration in imx6ull-colibri.dtsi and
imx6ull-colibri-eval-v3.dtsi respectively.
Signed-off-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit c2e4987e0e02095ed3d19e958b3891954ef38243)
Add support for the Computer on Module Colibri iMX7D 1GB along
with the Colibri Evaluation Board device trees. Follow the usual
hierarchic include model, maintaining shared configuration in
imx7-colibri.dtsi and imx7-colibri-eval-v3.dtsi respectively.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit f928a4a377e476525298a552185dfd92d2780319)
Move the emmc/lpuart/sdcard/sensor/spi-slave testing features
from EVK to EVKB board.
Signed-off-by: Shenwei Wang <shenwei.wang@nxp.com>
Reviewed-by: Frank Li <frank.li@nxp.com>
For ECSPI test, add these two dts files.
imx6ul-14x14-evk-ecspi.dts: enable ecspi4 function. Because ethernet2
uses the same pins with ecspi4, so disable fec1/fec2.
imx6ul-14x14-evk-ecspi-slave.dts: Add "spi-slave" attribute to enable
slave mode.
Wire Connection:
J1704:
3 - SCS
4 - MOSI
5 - MISO
6 - SCK
7 - GND
Modify "Makefile" to build these two dts files.
Signed-off-by: Clark Wang <xiaoning.wang@nxp.com>
On IMX7ULP-EVKB board, add a new dtb 'imx7ulp-evk-rm68191
-qhd.dts' to enable the 'RK055IQH042' MIPI panel display
on this platform.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
On IMX7ULP-EVKB board, add a new dtb 'imx7ulp-evk-rm68200
-wxga.dts' to enable the 'RK055AHD042' MIPI panel display
on this platform.
The main difference for EVKB(SOMB REVA + EVKB RevA) comparing with
EVK(SOM RevB2 + BB RevB1):
- SOMB REVA change: WIFI module Cypress 1DX replace with QCA 1PJ
- BB EVKB RevA change: MIPI connector
The EVKB board focus on default functions on board without rework,
WIFI/BT, and MIPI feature test. Currently, the patch don't consider
other functions with rework needed.
Reviewed-by: Haibo Chen <haibo.chen@nxp.com>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
note for the rework:
eMMC on EVK board has pad conflict with NAND and Micro-SD.
NAND on EVK board has pin conflict with QSPI and SD2(eMMC).
Signed-off-by: Robby Cai <robby.cai@nxp.com>
Reviewed-by: Dong Aisheng <aisheng.dong@nxp.com>
The i.MX6ULZ is sw compatible with i.MX6ULL, and the EVK board has
no big difference, so include i.mx6ull evk dts file do reduce code
redundancy.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Add "spi-slave" attribute for recognizing slave mode.
If it is not in slave mode, please delete this attribute.
Usage can be found at spi-fsl-lpspi.txt.
Modify "Makefile" to build "imx7ulp-evk-spi-slave.dtb".
Signed-off-by: Xiaoning Wang <xiaoning.wang@nxp.com>
A specific node for OCRAM mapping in optee as been added in
the device tree. These dedicated optee device trees can be
removed.
Signed-off-by: Clement Faure <clement.faure@nxp.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
The default display interface on i.MX7ULP EVK board is the HDMI
interface, and a hardware rework is required to support the MIPI
panel. To match the current board design, added the HDMI node in
the imx7ulp-evk.dts and created a new file named imx7ulp-evk-mipi.dts.
Reviewed-by: Andy Duan <fugang.duan@nxp.com>
Add dedicated dts file to support optee on imx6sl/sll. The OCRAM is resized
to make sure the OCRAM space used by TEE side is not visiable to no-secure
linux kernel side.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Add dedicated dts for OP-TEE.
The modification is about ocram partition. The default dtsi
use lower ocram area for low power things. But i.MX
chips TZASC could only protect OCRAM from high address to low address.
So modify the OCRAM space for OP-TEE.
The PSCI/OPTEE firmware node will be dynamically created in OP-TEE.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Add focaltech new touch panel ft5246 support.
Set the ft5426 as default panel for dts. If want to use the old panel, then
it needs to boot with imx7ulp-evk-ft5416.dtb file.
(cherry picked from commit:963fea909ef5e42294cb2e656e5e3870a2171c01)
Sensors are connected to M4 and not to A-Core.
Sensors will not be exposed to A-Core via standard
i2c interface but via an i2c proxy layer over rpmsg.
Remove the dts entry to avoid the probe error messages and
add a separate dts file for the case where someone wishes to
rework the board themselves and connect sensors for testing purposes.
Signed-off-by: Adriana Reus <adriana.reus@nxp.com>
Create a new dts file 'imx7ulp-evk-hdmi.dts' to enable hdmi
display to avoids conflict with mipi dsi panel display. Use
endpoint to connect dsi controller and adv7535.
(cherry picked from commit 86fb9340d01a4583628d465f29fba67df93c453c)
imx6ull
Added new DTS files for:
imx6ul-9x9-evk
imx6ul-14x14-evk
imx6ull-9x9-evk
imx6ull-14x14-evk
with support for Wifi OOB interrupts.
Signed-off-by: xlin <xlin@murata.com>
Signed-off-by: Tiberiu Breana <andrei-tiberiu.breana@nxp.com>
Add one more dtb file for mfgtool purpose only, it enabled both eMMC and
QSPI to burn both BSP and M4 images in one process.
Kernel still uses the original eMMC dtb so the QSPI, which belongs to
M4 domain won't be exposed in A7 domain.
Signed-off-by: Han Xu <han.xu@nxp.com>
Add ldo enable dts
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
The latest imx6sll evk Rev A board (default board) already fix
HS400 I/O timing issue, so the default evk board support HS400
mode. But the older evk board (Rev A) board still has issue for
HS400 mode, so this patch disabled HS400 mode for the older evk
board, just support HS200 mode for imx6sll evk Rev A board.
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
On imx7ulp-evk board, the SD slot on base board is conflict with BT/WiFi.
This patch seperate the usdhc1 from imx7ulp-evk.dts, and create new dts.
Add one more dts for QSPI on i.MX7ULP1 for mfgtool purpose.
Add support for SCM i.MX6DQ 1Gb QWKS rev3
Support the next features for 1Gb qwks rev3 boards:
- Support for fix lpddr2 mode
- hdcp and enetirq
- bluetooth and wifi for Murata ZP SDIO dongle
Signed-off-by: Juan Gutierrez <juan.gutierrez@nxp.com>
Audio is in M4 domain, so we need an indepenent dts for audio.
M4 domain is controled by RTOS, this dts is for demo purpose in
linux
Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com>
Add Murata 1DX wifi/bt for evk board.
Add i.MX7ULP 14x14 arm2 board support.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add eMMC support (8 bit mode) for ulp-evk board.
Add i.MX7ULP EVK board support.
Signed-off-by: ye li <ye.li@nxp.com>
Add support for the epop i.MX6SX SCM EVB board
The epop variant contains an eMMC(512MB) within the
POP package.
Support the next features for epop 6sxscm EVB:
- Regular epop board
- M4 support
Signed-off-by: Alejandro Sierra <alejandro.sierra@nxp.com>
Add support for the 1gb i.MX6SX SCM EVB board
Support the next features for 1Gb 6sxscm EVB:
- Regular 1gb board
- M4 support
- MQS
- SAI sound card
- LCD and HDMI with sii902x support
- Bluetooth and Wifi Murata ZP SDIO dongle
Add Murata Type ZP (BCM4339) module support on i.MX6SLL platforms:
- i.MX6SLL EVK (SD3 slot + BT connector) + Murata adapter V2.0
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
Add support for SCM i.MX6DQ 1Gb Evaluation Board (EVB).
Support the next features for 1Gb EVB boards:
- Support for fix and interleave mode
- For fix mode additional dts are provided for:
- hdcp
- enetirq
Add support for SCM i.MX6DQ 1Gb Quick Start Board (QWKS).
Support the next features for 1Gb QWKS boards:
- hdcp
- Wifi with Murata ZP SDIO dongle
Add i.MX6SLL EVK board dts file.
For i.MX6SLL LPDDR2 and LPDDR3 ARM2 board, they share the same
board design but using different DDR chip. So we can reuse the
LPDDR3 ARM2 board dts on LPDDR2 ARM2 board.
ECSPI1_SCLK pin is shared by LCD power enable and SPI1 SCLK.
To use ecspi, need to disable lcdif function.
board
since there's pin conflict between camera and epdc on this board,
we add a new dts file for csi/camera function.
enabled the wm8962 and spdif out.
There is pin conflict between spdif and usdhc2. So add
dedicate spdif dts.
Add new pf1550 board support.
Add i.MX6SLL-LPDDR3-ARM2 board support.
Signed-off-by: Frank Li <Frank.Li@nxp.com>
In order to pass the pcie gen2 compliance tests on imx6qp
sd revb board, add one standalone imx6qp sd ldo pcie dtb
- disalbe fec/sata, because that the fec/sata can't work
when pll6 is in bypass mode.
NOTE: Bypass mode of pll6 is mandatory required when
external oscillator is used as pcie ref clk.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Add DTS file imx6ull-9x9-evk.dts which is originated from i.MX6UL EVK with
some changes:
1. Include imx6ull.dtsi as base
2. sim2 is removed.
3. Move GPIO5 pins setting to iomuxc-snvs
4. Enable CSI and ov5640
Signed-off-by: Ye Li <ye.li@nxp.com>
Enable eMMC for i.MX6UL EVK rework board due to the pad conflict with NAND
and Micro-SD.
Enable eMMC for i.MX6ULL EVK rework board due to the pad conflict with NAND
and Micro-SD.
