ChiliSOM has 2 Ethernet subsystems with different types of possibly used
PHY interfaces (i.e. MII, RMII, GMII, RGMII). Current code configured
pinmux for RMII on 1st Ethernet subsystem and enabled Ethernet MAC with
1 slave for all boards which use ChiliSOM.
This change moves pinmux configuration of 1st Ethernet subsystem to
ChiliBoard description, as this is board-specific.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
uart0 configuration code has been in SOM. However, it is possible to
use all (or none) of 6 uart's of AM335x processor present on ChiliSOM.
This fix moves declaration of uart0 from ChiliSOM to ChiliBoard, because
use of uart is strictly board-specific.
Use the pinmux IOPAD macro to define the register absolute physical
address instead of the offset from the padconf base address. This
makes the DTS easier to read since matches the addresses listed in
the Technical Reference Manual.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Chiliboard uses ChiliSOM as its base.
Hardware specification:
* ChiliSOM (am335x, PMIC, DRAM, NAND)
* Ethernet PHY (id 0)
* USB host (usb1)
* microSD slot
* 2x GPIO LED
Signed-off-by: Rostislav Lisovy <lisovy@jablotron.cz>
