[ Upstream commit 9bcf53f34a2c1cebc45cc12e273dcd5f51fbc099 ]
mmc2 used for wl12xx was missing the keep-power-in suspend
parameter. As a result the board couldn't reach suspend state.
Signed-off-by: Eyal Reizer <eyalr@ti.com>
binding docs
As per mmc device tree binding documentation card detect gpio has
to be active low signal. When a hardware is designed with active
high card detect, gpio polarity has to be changed with
cd-inverted dt property.
In AM335x the card detect gpio is designed as active low gpio.
So correcting the dt card detect gpio definition.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
The sound support consist only Headset output on the board and can be
handled by "simple-audio-card"
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
When McASP is not in use the pins can be put to sleep mode to conserve
power.
The section had two tabs instead of one.
While Sitara AM335x SoCs are very close to OMAP SoCs, the 32-line GPIO
controllers are numbered from 0 on AM335x and from 1 on OMAP. But when
the configuration for the TI WLAN controllers was converted from
platform data to device tree, this detail was overlooked, as 10 boards
were using OMAP with the WL12xx and WL18xx controllers, and only one
was based on AM335x.
This invalid configuration prevents the WL1271 module on the AM335x
EVM-SK from notifying interrupts to the SoC, and breaks the wlan driver.
The DTS must be corrected to use the correct GPIO controller.
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
Replace all the pdata-quirks for setting wl12xx/wl18xx
platform data with proper DT definitions.
Signed-off-by: Eliad Peller <eliad@wizery.com>
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Merge "Xilinx Zynq changes for v3.17" from Michal Simek:
arm: Xilinx Zynq dt patches for v3.17
- Document and use new cadence serial binding
* tag 'zynq-dt-for-3.17' of git://git.xilinx.com/linux-xlnx:
ARM: zynq: DT: Migrate UART to Cadence binding
tty: cadence: Document DT binding
+ Linux 3.16-rc5
The use of FIFO in McASP can reduce the risk of audio under/overrun and
lowers the load on the memories since the DMA will operate in bursts.
Add the necessary nodes to enable the LCD controller and the
LCD panel that is attached to the Texas Instruments AM335x
EVMSK platform. Also setup the necessary pin mux within the
DT file to drive the LCD connector and add the correct
pinmux settings for the lcd pins to be configured to when
the SoC goes into sleep state for the minimum power
consumption.
For the sleep mode LCD pin settings, MUX_MODE7 is chosen as
this corresponds to switching the pins into input GPIO's with
an internal pulldown. Which has been determined to offer the
lowest power solution vs leaving the pins configured in LCD
mode.
Signed-off-by: Darren Etheridge <detheridge@ti.com>
Acked-by: Wolfram Sang <wsa@sang-engineering.com>
Tested-by: Felipe Balbi <balbi@ti.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Make sure ethernet and mdio nodes are disabled by default and enable
them explicitly only on boards that actually use them.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
The VTT regulator for DDR3 termination on the am335x-evmsk is
controlled by a gpio. It is configured by the bootloader so here we
define an always-on, fixed voltage regulator to hold the gpio.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Use phandles instead of unit adresses to reference usb and dma nodes.
This makes the DT more robust and readable.
Signed-off-by: Guido Martínez <guido@vanguardiasur.com.ar>
Acked-by: Felipe Balbi <balbi@ti.com>
In "ARM: dts: am33xx: correcting dt node unit address for usb", the
usb_ctrl_mod and cppi41dma nodes were updated with the correct register
addresses. However, the dts files that reference these nodes were not
updated, and those devices are no longer being enabled.
This patch corrects the references for the affected dts files.
Signed-off-by: Leigh Brown <leigh@solinno.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
Updates to the .dts files to support more Gumstix boards.
These are sent separately from the rest of the .dts changes
as these depend on the fixes merged into v3.14-rc4, and
needed a bit more time to get updated on the fixes.
* tag 'omap-for-v3.15/dt-overo-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: dts: Add support for the Overo Summit
ARM: dts: Add support for the Overo Chestnut43
ARM: dts: Add support for the Overo Alto35
ARM: dts: Add support for the Overo Gallop43
ARM: dts: Add support for the Overo Palo43
ARM: dts: overo: Add LIS33DE accelerometer
ARM: dts: overo: Create a file for common Gumstix peripherals
ARM: dts: overo: Push uart3 pinmux down to expansion board
ARM: dts: omap3-tobi: Add AT24C01 EEPROM
ARM: dts: omap3-tobi: Use include file omap-gpmc-smsc9221
ARM: dts: omap: Add common file for SMSC9221
ARM: dts: omap3-overo: Add HSUSB PHY
ARM: dts: omap3-overo: Enable WiFi/BT combo
ARM: dts: omap3-overo: Add missing pinctrl
ARM: dts: omap3-tobi: Add missing pinctrl
ARM: dts: overo: reorganize include files
arch/arm/boot/dts/omap3-overo.dtsi
Enable DMA controller for USB
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
EVM board provides two Ethernet ports, this patch sets them into
dual_emac mode to provide two independent network interfaces.
Enable the WiLink6 connected to mmc2.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org
Enable second USB channel and set it into 'host' mode.
The clock for audio is sourced from virt_24000000_ck, so the correct
frequency is 24000000.
CC: <stable@vger.kernel.org> # 3.13.x
Add pinctrl section and cd-gpio to mmc1. Without these the SD card is not
working on EVM-SK board.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"Updates for the input subsystem. You will get an new drivers for
Hyper-V synthetic keyboard and for Neonode zForce touchscreens, plus a
bunch of driver fixes and cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (49 commits)
Revert "Input: ALPS - add support for model found on Dell XT2"
arm: dts: am335x sk: add touchscreen support
Input: ti_am335x_tsc - fix spelling mistake in TSC/ADC DT binding
Input: cyttsp4 - replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
Input: mma8450 - add missing i2c_set_clientdata() in mma8450_probe()
Input: mpu3050 - add missing i2c_set_clientdata() in mpu3050_probe()
Input: tnetv107x-keypad - make irqs signed for error handling
Input: add driver for Neonode zForce based touchscreens
Input: sh_keysc - enable the driver on all ARM platforms
Input: remove a redundant max() call
Input: mousedev - allow disabling even without CONFIG_EXPERT
Input: allow deselecting serio drivers even without CONFIG_EXPERT
Input: i8042 - add PNP modaliases
Input: evdev - fall back to vmalloc for client event buffer
Input: cypress_ps2 - do not consider data bad if palm is detected
Input: cypress_ps2 - remove useless cast
Input: fix PWM-related undefined reference errors
Input: ALPS - change secondary device's name
Input: wacom - not all multi-interface devices support touch
Input: nspire-keypad - add missing clk_disable_unprepare() on error path
Add missing nodes for the touchscreen available on AM335x EVM SK.
Signed-off-by: Felipe Balbi <balbi@ti.com>
AM335x EVM-SK have only support for audio playback (stereo jack on the
board) via tlv320aic3106 codec connected to McASP1.
Enable the support for audio playback on the board:
- McASP1 configuration
- tlv320aic3106 configuration
- Machine driver.
Signed-off-by: Jyri Sarha <jsarha@ti.com>
Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
Do not reset GPIO0 at boot-up because GPIO0 is used
on AM335x EVM-SK to control VTT regulators on DDR3.
Without this EVM-SK boards fail to boot-up because
of DDR3 corruption.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Add the generic AM33XX AES module's device tree data and
enable it for the am335x-evm, am335x-evmsk, and am335x-bone
platforms. Also add Documentation file describing the data
for the AES module.
Cc: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Mark A. Greer <mgreer@animalcreek.com>
Signed-off-by: Joel Fernandes <joelf@ti.com>
[joelf@ti.com: Dropped interrupt-parent property, documentation fixups]
Add the generic AM33XX SHAM module's device tree data and
for the SHAM module.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Set bus-width to make SD card operate in 4 bit mode.
Signed-off-by: Balaji T K <balajitk@ti.com>
The On Chip Peripherals (OCP) device node is a simplified
representation of the AM33XX SoC interconnect. An OCP dev
node is already defined in the am33xx.dtsi Device Tree
source file included by am33xx based boards so there is
no need to redefine this on each board DT file.
Also, the OCP and IP modules directly connected to it are SoC
internal details that is better to keep outside of board files.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
am33xx boards DTS include the am33xx.dtsi Device Tree
source file that already define a pinmux device node for
the AM33XX SoC Pin Multiplex.
Redefining this for each board makes the Device Tree files
harder to modify and maintain so let's just use what is
already defined in the included .dtsi file.
Adds AM33XX MMC support for am335x-bone, am335x-evm and am335x-evmsk boards.
Also added is the DMA binding definitions based on the generic DMA request
binding.
Additional changes made to DTS:
* Interrupt, reg and compatible properties added
* ti,needs-special-hs-handling added
Signed-off-by: Matt Porter <mporter@ti.com>
Pull pwm changes from Thierry Reding:
"A set of patches makes the device tree documentation for the various
PWM drivers more consistent. Device tree support is added to the
Renesas TPU driver. The sysfs interface now makes use of dev_groups.
Other than that there is a healthy assortment of fixes and
enhancements for minor issues that have shown up"
* tag 'for-3.12-rc1' of git://gitorious.org/linux-pwm/linux-pwm:
pwm: pxa: Use module_platform_driver
pwm: tiehrpwm: add missing __iomem annotation
pwm: tiecap: add CONFIG_PM_SLEEP to ecap_pwm_{save,restore}_context()
pwm: simplify use of devm_ioremap_resource
pwm: renesas-tpu: Add DT support
ARM: dts: Use the PWM polarity flags
pwm: Update DT bindings to reference pwm.txt for cells documentation
pwm: Use the DT macro directly when parsing PWM DT flags
pwm: Add PWM polarity flag macro for DT
pwm: mxs: Check the return value from stmp_reset_block()
pwm: convert class code to use dev_groups
Replace the numerical polarity flags with the PWM_POLARITY_INVERTED
symbolic constant.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
This relfects the code and dts requires changes due to recent .dts
binding updates:
- use mg prefix for the Metor Graphics specific attributes
- use power in mA not in mA/2 as specifed in the USB2.0 specification
- remove the child node for USB. This is driver specific on won't be
reflected in the device tree
- use the "mentor" prefix instead of "mg".
- use "dr_mode" istead of "mg,port-mode" for the port mode. The former
is used by a few other drivers.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: devicetree@vger.kernel.org
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
This moves the two instances from the big node into two child nodes. The
glue layer ontop does almost nothing.
There is one devices containing the control module for USB (2) phy,
(2) usb and later the dma engine. The usb device is the "glue device"
which contains the musb device as a child. This is what we do ever since.
The new file musb_am335x is just here to prob the new bus and populate
child devices.
There are a lot of changes to the dsps file as a result of the changes:
- musb_core_offset
This is gone. The device tree provides memory ressources information
for the device there is no need to "fix" things
- instances
This is gone as well. If we have two instances then we have have two
child enabled nodes in the device tree. For instance the SoC in beagle
bone has two USB instances but only one has been wired up so there is
no need to load and init the second instance since it won't be used.
- dsps_glue is now per glue device
In the past there was one of this structs but with an array of two and
each instance accessed its variable depending on the platform device
id.
- no unneeded copy of structs
I do not know why struct dsps_musb_wrapper is copied but it is not
necessary. The same goes for musb_hdrc_platform_data which allocated
on demand and then again by platform_device_add_data(). One copy is
enough.
Pull networking updates from David Miller:
"This is a re-do of the net-next pull request for the current merge
window. The only difference from the one I made the other day is that
this has Eliezer's interface renames and the timeout handling changes
made based upon your feedback, as well as a few bug fixes that have
trickeled in.
Highlights:
1) Low latency device polling, eliminating the cost of interrupt
handling and context switches. Allows direct polling of a network
device from socket operations, such as recvmsg() and poll().
Currently ixgbe, mlx4, and bnx2x support this feature.
Full high level description, performance numbers, and design in
commit 0a4db187a999 ("Merge branch 'll_poll'")
From Eliezer Tamir.
2) With the routing cache removed, ip_check_mc_rcu() gets exercised
more than ever before in the case where we have lots of multicast
addresses. Use a hash table instead of a simple linked list, from
Eric Dumazet.
3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from
Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski,
Marek Puzyniak, Michal Kazior, and Sujith Manoharan.
4) Support reporting the TUN device persist flag to userspace, from
Pavel Emelyanov.
5) Allow controlling network device VF link state using netlink, from
Rony Efraim.
6) Support GRE tunneling in openvswitch, from Pravin B Shelar.
7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from
Daniel Borkmann and Eric Dumazet.
8) Allow controlling of TCP quickack behavior on a per-route basis,
from Cong Wang.
9) Several bug fixes and improvements to vxlan from Stephen
Hemminger, Pravin B Shelar, and Mike Rapoport. In particular,
support receiving on multiple UDP ports.
10) Major cleanups, particular in the area of debugging and cookie
lifetime handline, to the SCTP protocol code. From Daniel
Borkmann.
11) Allow packets to cross network namespaces when traversing tunnel
devices. From Nicolas Dichtel.
12) Allow monitoring netlink traffic via AF_PACKET sockets, in a
manner akin to how we monitor real network traffic via ptype_all.
From Daniel Borkmann.
13) Several bug fixes and improvements for the new alx device driver,
from Johannes Berg.
14) Fix scalability issues in the netem packet scheduler's time queue,
by using an rbtree. From Eric Dumazet.
15) Several bug fixes in TCP loss recovery handling, from Yuchung
Cheng.
16) Add support for GSO segmentation of MPLS packets, from Simon
Horman.
17) Make network notifiers have a real data type for the opaque
pointer that's passed into them. Use this to properly handle
network device flag changes in arp_netdev_event(). From Jiri
Pirko and Timo Teräs.
18) Convert several drivers over to module_pci_driver(), from Peter
Huewe.
19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a
O(1) calculation instead. From Eric Dumazet.
20) Support setting of explicit tunnel peer addresses in ipv6, just
like ipv4. From Nicolas Dichtel.
21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet.
22) Prevent a single high rate flow from overruning an individual cpu
during RX packet processing via selective flow shedding. From
Willem de Bruijn.
23) Don't use spinlocks in TCP md5 signing fast paths, from Eric
Dumazet.
24) Don't just drop GSO packets which are above the TBF scheduler's
burst limit, chop them up so they are in-bounds instead. Also
from Eric Dumazet.
25) VLAN offloads are missed when configured on top of a bridge, fix
from Vlad Yasevich.
26) Support IPV6 in ping sockets. From Lorenzo Colitti.
27) Receive flow steering targets should be updated at poll() time
too, from David Majnemer.
28) Fix several corner case regressions in PMTU/redirect handling due
to the routing cache removal, from Timo Teräs.
29) We have to be mindful of ipv4 mapped ipv6 sockets in
upd_v6_push_pending_frames(). From Hannes Frederic Sowa.
30) Fix L2TP sequence number handling bugs, from James Chapman."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits)
drivers/net: caif: fix wrong rtnl_is_locked() usage
drivers/net: enic: release rtnl_lock on error-path
vhost-net: fix use-after-free in vhost_net_flush
net: mv643xx_eth: do not use port number as platform device id
net: sctp: confirm route during forward progress
virtio_net: fix race in RX VQ processing
virtio: support unlocked queue poll
net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit
Documentation: Fix references to defunct linux-net@vger.kernel.org
net/fs: change busy poll time accounting
net: rename low latency sockets functions to busy poll
bridge: fix some kernel warning in multicast timer
sfc: Fix memory leak when discarding scattered packets
sit: fix tunnel update via netlink
dt:net:stmmac: Add dt specific phy reset callback support.
dt:net:stmmac: Add support to dwmac version 3.610 and 3.710
dt:net:stmmac: Allocate platform data only if its NULL.
net:stmmac: fix memleak in the open method
ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available
net: ipv6: fix wrong ping_v6_sendmsg return value
Add pinmux configurations for RGMII based CPSW ethernet to AM335x EVMsk.
Default mode is nothing but the values required for the module during
active state. With this configurations module is functional as
expected.
Sleep mode is nothing but the values required for the module during
inactive state. The pins are configured to its reset state to optimize
energy usage for the pins for the suspend/resume cycle
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
PWM output from ecap2 uses as backlight source. Also adds low threshold
value to have a uniform divisions in brightness-levels scales with
inverse polarity.
Signed-off-by: Philip Avinash <avinashphilip@ti.com>
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
Using constants for pinctrl allows a better readability, and removes
redundancy with comments.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Tested-by: Afzal Mohammed <afzal@ti.com>
Use standard GPIO constants to enhance the readability of DT GPIOs.
Replace /include/ by #include for AM33XX and AM35XX device tree
files, in order to use the C pre-processor, making use of #define
features possible.
xdma_event_intr1.clkout2 pad can be used to source clock
from either 32K OSC or any of the PLL (except MPU) outputs.
On the existing AM335x based boards (EVM, EVM-SK and Bone),
this pad is used to feed the clock to audio codes.
So, this patch configures the pinmux to get clkout2 on the pad.
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Add pin control binding for UART0 device nodes in all
board specific DT files.
Acked-by: Matt Porter <mporter@ti.com>
With DT support, where naming convention is based on base-addr
and not id, so we should follow TRM/Spec numbering label.
This patch changes UART numbering as per TRM, as uart0-5.
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Now gpio-leds driver is using devm_pinctrl_get_select_default()
api to set default pinmux configuration required for the
functionality of the driver, so this patch moves respective
pinctrl binding inside leds node.
Add pin control binding for I2C device nodes in all
board specific DT files (as per current usage),
EVM: Both i2c0 and i2c1
EVM-SK and Bone: Only i2c0
Adding phy-mode to CPSW node for beaglebone, EVM and EVMsk.
Add phy_id device tree data to am335x-evmsk device to bring up CPSW
ethernet present on am335x starter kit.
Rename I2C and GPIO nodes according to AM33XX TRM. According to
AM33XX TRM device instances are starting from "0" like i2c0, i2c1
and i2c3.
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
[panto@antoniou-consulting.com: initial patch by pantelis's]
Signed-off-by: AnilKumar Ch <anilkumar@ti.com>
