The at24 driver allows to register I2C EEPROM chips using different vendor
and devices, but the I2C subsystem does not take the vendor into account
when matching using the I2C table since it only has device entries.
But when matching using an OF table, both the vendor and device has to be
taken into account so the driver defines only a set of compatible strings
using the "atmel" vendor as a generic fallback for compatible I2C devices.
So add this generic fallback to the device node compatible string to make
the device to match the driver using the OF device ID table.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
From v4.2+ the GPMC code has been changed to reset all the bootloader
GPMC settings when the kernel starts.
As such, this DTS file now needs the external FRAM defined.
Signed-off-by: Mark Jackson <mpfj@newflow.co.uk>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch fixes the following DTC warnings for many boards:
"Node /leds/led@1 has a unit name, but no reg property"
This reverts commit 8e6ebfaa9b384088002baa10f7534efa73a0794e.
Without the patch reverted regulators will not work. This prevents
MMC to be working for example so the boards can not boot to
MMC rootfs.
Tested it on beaglebone white and bisect also points to the
reverted commit.
The issue can be also fixed by adding "regulator-compatible =" to all board
dts file for the regulators.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
remove tps65217.dtsi and adapt all boards, which
used it.
Tested-by: Keerthy <j-keerthy@ti.com>
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Rob Herring <robh@kernel.org>
Use the pinmux IOPAD macro to define the register absolute physical
address instead of the offset from the padconf base address. This
makes the DTS easier to read since matches the addresses listed in
the Technical Reference Manual.
Update dts file to reflect:-
* new flash memory layout
* add missing phy-mode property
* dual_emac now just a boolean
* rename mcp to microchip
* update gpio definition
Make sure ethernet and mdio nodes are disabled by default and enable
them explicitly only on boards that actually use them.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
NanoBone Specification:
CPU:
TI AM335x
Memory:
256MB DDR3
128MB NOR flash
128KB FRAM
Ethernet:
2 x 10/100 connected to SMSC LAN8710 PHY
USB:
1 x USB2.0 Type A
I2C:
2Kbit EEPROM (Microchip 24AA02)
RTC (Maxim DS1338)
GPIO Expander (Microchip MCP23017)
Expansion connector:
6 x UART
1 x MMC/SD
1 x USB2.0
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
