The rv4162 compatbile string is missing the vendor part, add it.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
As the bootloader passes the NAND and the SPI flash partition tables
there is no need to keep them in the kernel device tree.
Removed them.
Signed-off-by: Teresa Remmet <t.remmet@phytec.de>
Update ethernet phy0 node to use phy-handle now.
Include the i2c temperature sensor which is optionaly mounted
on the phyCORE-AM335x-R2 module.
As we may have different SPI NOR flashes with 8MB populated on
phyCORE-AM335x SOM, set the "jedec,spi-nor" SPI Flash compatible string.
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch fixes the following DTC warnings for many boards:
"Node /fixedregulator@0 has a unit name, but no reg property"
The check for the "elm_id" binding had been removed.
This causes nand boot to fail on boards still using
the old binding. Update the bindings on those boards.
Acked-by: Brian Norris <computersforpeace@gmail.com>
Acked-by: Roger Quadros <rogerq@ti.com>
On these boards NAND ready pin status is avilable over
GPMC_WAIT0 pin.
For NAND we don't use GPMC wait pin monitoring but
get the NAND Ready/Busy# status using GPIOlib.
GPMC driver provides the WAIT0 pin status over GPIOlib.
Read speed increases from 7869 KiB/ to 8875 KiB/s
and write speed was unchanged at 5100 KiB/s.
Measured using mtd_speedtest.ko on am335x-evm.
Cc: Teresa Remmet <t.remmet@phytec.de>
Cc: Ilya Ledvich <ilya@compulab.co.il>
Cc: Yegor Yefremov <yegorslists@googlemail.com>
Cc: Rostislav Lisovy <lisovy@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
The NAND Ready/Busy# line is connected to GPMC_WAIT0 pin and
can't be used for wait state insertion for NAND I/O read/write.
So disable read/write wait monitoring as per Reference Manual's
suggestion [1].
[1] AM335x TRM: SPRUH73L: 7.1.3.3.12.2 NAND Device-Ready Pin
Add compatible id, GPMC register resource and interrupt
resource to NAND controller nodes.
The GPMC node will provide an interrupt controller for the
NAND IRQs.
Use the pinmux IOPAD macro to define the register absolute physical
address instead of the offset from the padconf base address. This
makes the DTS easier to read since matches the addresses listed in
the Technical Reference Manual.
Cleaned up the regulators on the wega board. Created a simple bus,
renamed the regulators according to the schematics and added missing
regulator on wega.
Fix the mpu voltage as it is set too low for the silicon
revision 2.1.
phyCORE-AM335x is a SoM (System on Module) containing
a AM335x SOC. The module can be connected to different
carrier boards.
Some hardware parts are configurable on the phyCORE-AM335x.
So they are disabled on default in this som dtsi file.
They will be enabled in the board dts files, when populated.
* RAM up to 1GiB
* PMIC
* NAND flash up to 1GiB
* Eth PHY on SOM: 1x RMII
* SPI NOR flash 8MiB (optional)
* i2c RTC (optional)
* i2c EEPROM 4kiB (optional)
