[ Upstream commit ca41e244517d6d3f1600c229ff7ca615049c1e9c ]
The DMA binding for eDMA needs 2 parameters, not 1.
The second, missing parameter is the tptc to be used for the channel.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
With the device tree parsing using the regulator framework
there is a no longer a need for separate compatibles for
individual regulator nodes. Hence removing them all.
Signed-off-by: Keerthy <j-keerthy@ti.com>
The NAND Ready/Busy# line is connected to GPMC_WAIT0 pin and
can't be used for wait state insertion for NAND I/O read/write.
So disable read/write wait monitoring as per Reference Manual's
suggestion [1].
[1] AM437x TRM: SPRUHL7D: 9.1.3.3.12.2 NAND Device-Ready Pin
Signed-off-by: Roger Quadros <rogerq@ti.com>
Add compatible id, GPMC register resource and interrupt
resource to NAND controller nodes.
The GPMC node will provide an interrupt controller for the
NAND IRQs.
AM437x has an internal touchscreen controller. Add support for it
on cm-t43.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Benoit Cousson <bcousson@baylibre.com>
Cc: Rob Herring <robh@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Dmitry Lifshitz <lifshitz@compulab.co.il>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
One of the CompuLab cm-t43 configurations comes with on-board eMMC as
primary storage, residing on the mmc2 interface. Add it to the device tree.
Add USB support for CompuLab sbc-t43 single board computer,
defaulting to host mode.
CM-T43 comes with 2 ethernet ports connected to the cpsw subsystem, which
has 2 modes of operation: switch mode and dual emac mode.
Add the relevant muxing and set it up to work in dual emac mode by
default.
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
One of the CompuLab cm-t43 configurations comes with on-board NAND flash as
primary storage. It is partitioned into kernel, dtb, and rootfs partitions.
CM-T43 has an on-board 2MB SPI-flash which stores U-Boot and the U-Boot
environment. Add it to the device tree.
Add PMIC support for CompuLab cm-t43 module. For now we keep all regulators
enabled until this could be refined with power management support.
CM-T43 has an on-board EEPROM on i2c bus 0. Add it to the device tree.
Add basic support for SBC-T43: a CM-T43 based single board computer.
CM-T43 is an AM437x based System-on-Module designed to serve as a building
block in embedded applications. SBC-T43 is composed of CM-T43 module on
top of the SB-SOM-T43 baseboard.
Basic support includes UART, GPIO, and I2C.
Acked-by: Rob Herring <robh@kernel.org>
