path: root/arch/arm/boot/dts/am437x-gp-evm.dts
2016-08-26ARM: dts: AM437X-GP-EVM: Remove redundant regulator compatiblesKeerthy
With the device tree parsing using the regulator framework there is a no longer a need for separate compatibles for individual regulator nodes. Hence removing them all. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-08-26ARM: dts: am437x-gp-evm: disable DDR regulator in rtc-only/poweroff modeTero Kristo
Without this, the memory will remain active during poweroff consuming extra power. Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-08-26ARM: dts: AM437X-GP-EVM: AM437X-SK-EVM: Make dcdc3 dcdc5 and dcdc6 enable ↵Keerthy
during suspend dcdc3, dcdc5, dcdc6 supply ddr and rtc respectively. These are required to be on during suspend. Hence set the state accordingly. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-08-15ARM: dts: am335x/am437x: remove unneeded unit name for gpio-matrix-keypadJavier Martinez Canillas
This patch fixes the following DTC warnings for many boards: "Node /matrix_keypad@0 has a unit name, but no reg property" Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-06-29ARM: dts: am437x-gp-evm: remove unneded unit nameJavier Martinez Canillas
This patch fixes the following DTC warnings for am437x-gp-evm.dtb: "endpoint@0 has a unit name, but no reg property" Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-06-10ARM: dts: am437x-gp-evm: Hook dcdc2 as the cpu0-supplyDave Gerlach
Hook dcdc2 as the cpu0-supply. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-04-12ARM: dts: am437x: Provide NAND ready pinRoger Quadros
On these boards NAND ready pin status is avilable over GPMC_WAIT0 pin. For NAND we don't use GPMC wait pin monitoring but get the NAND Ready/Busy# status using GPIOlib. GPMC driver provides the WAIT0 pin status over GPIOlib. Read speed increases from 16516 KiB/ to 18813 KiB/s and write speed was unchanged at 9941 KiB/s. Measured using mtd_speedtest.ko. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-04-11ARM: dts: omap: remove unneeded unit name for sound nodesJavier Martinez Canillas
This patch fixes the following DTC warning: "sound@0 has a unit name, but no reg property" Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-03-02Merge tag 'omap-for-v4.6/dt-pt2' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt Pull "Part 2 of device tree changes for omaps for v4.6 merge window" from Tony Lindgren: - A series of GPMC related interrupt changes from Rogeq Quadros <rogerq@ti.com> to prepare adding interrupt support to the NAND driver - Add RTC support for ti81xx - Correct LogicPD Torpedo mode description - Add basic support for LG Optimus Black phone in several patches by Paul Kocialkowski <contact@paulk.fr> - Change address-cells for dra7 for LPAE - Add TBCLK for PWMSS on dra7 * tag 'omap-for-v4.6/dt-pt2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (21 commits) ARM: dts: omap3-sniper: TWL4030 keypad support Revert "ARM: dts: DRA7: Add dt nodes for PWMSS" ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND ARM: dts: dm814x: dra62x: Fix NAND device nodes ARM: dts: DRA7: Add dt nodes for PWMSS ARM: dts: DRA7: Add TBCLK for PWMSS ARM: dts: DRA7: change address-cells and size-cells ARM: dts: omap3-sniper: USB OTG support ARM: dts: LG Optimus Black codename sniper basic support ARM: dts: dm3730-torpedo-devkit: Add "Wireless" to model ARM: dts: Add RTC entry for dm816x ARM: dts: Add RTC entry for dm814x and dra62x ARM: dts: omap3: Fix NAND device nodes ARM: dts: dm8168-evm: ARM: dts: Disable wait pin monitoring for NAND ARM: dts: dm816x: Fix NAND device nodes ARM: dts: am335x: Disable wait pin monitoring for NAND ARM: dts: am335x: Fix NAND device nodes ARM: dts: am437x: Disable wait pin monitoring for NAND ARM: dts: am437x: Fix NAND device nodes ARM: dts: dra7: Remove redundant nand property ...
2016-02-26ARM: dts: am437x: Disable wait pin monitoring for NANDRoger Quadros
The NAND Ready/Busy# line is connected to GPMC_WAIT0 pin and can't be used for wait state insertion for NAND I/O read/write. So disable read/write wait monitoring as per Reference Manual's suggestion [1]. [1] AM437x TRM: SPRUHL7D: 9.1.3.3.12.2 NAND Device-Ready Pin Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-02-26ARM: dts: am437x: Fix NAND device nodesRoger Quadros
Add compatible id, GPMC register resource and interrupt resource to NAND controller nodes. The GPMC node will provide an interrupt controller for the NAND IRQs. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-01-27ARM: dts: am437x: pixcir_tangoc: use correct flags for irq typesGrygorii Strashko
Now IRQs for Pixcir Tangoc touchscreen are defined using IRQ_TYPE_NONE in am437x-gp-evm.dts and am43x-epos-evm.dts wich do not correspond HW. Hence, update am437x-gp-evm.dts and am43x-epos-evm.dts files and use correct flag IRQ_TYPE_EDGE_FALLING for irq types. While here, remove duplicated irq declaration for pixcir_ts@5c node in am437x-gp-evm.dts. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-17ARM: DTS: am437x: Use the new DT bindings for the eDMA3Peter Ujfalusi
Switch to use the ti,edma3-tpcc and ti,edma3-tptc binding for the eDMA3 and enable the DMA even crossbar with ti,am335x-edma-crossbar. With the new bindings boards can customize and tweak the DMA channel priority to match their needs. With the new binding the memcpy is safe to be used since with the old binding it was not possible for a driver to know which channel is allowed to be used as non HW triggered channel. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-11-30ARM: dts: am437x-gp-evm: Use AM4372_IOPAD pinmux macroJavier Martinez Canillas
Use the pinmux IOPAD macro to define the register absolute physical address instead of the offset from the padconf base address. This makes the DTS easier to read since matches the addresses listed in the Technical Reference Manual. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-10-20ARM: dts: am437x-gp-evm: Add wakeup interrupt source for pixcir_i2c_tsVignesh R
On am437x-gp-evm, pixcir_i2c_ts can wakeup the system from low power state via pinctrl and IO daisy chain using generic wakeirq framework. With commit 3fffd1283927 ("i2c: allow specifying separate wakeup interrupt in device tree") i2c core allows optional wakeirq to be specified via device tree. Add wakeup irq entry to enable pixcir_i2c_ts to wake the system from low power state. Signed-off-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-10-12ARM: dts: am43xx: fix cd-gpios definition as per hardware design and dt ↵Mugunthan V N
binding docs As per mmc device tree binding documentation card detect gpio has to be active low signal. When a hardware is designed with active high card detect, gpio polarity has to be changed with cd-inverted dt property. In AM43xx the card detect gpio is designed as active low gpio. So correcting the dt card detect gpio definition. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-10-12ARM: dts: am437x-gp-evm: Add DCAN sleep pinsRoger Quadros
Add DCAN sleep pins to save some power during suspend. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-09-05ARM: dts: AM437x: Add the internal and external clock nodes for rtcKeerthy
rtc can either be supplied from internal 32k clock or external crystal generated 32k clock. Internal clock is SOC specific and the external clock is board dependent. Adding the corresponding nodes. Signed-off-by: Keerthy <j-keerthy@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-08-06ARM: dts: am437x-gp-evm: Add regulator-always-on and regulator-boot-on for ↵Dave Gerlach
RTC DCDCs DCDC5 and DCDC6 supply rtc and need to be on for accessing the module. On A1 revision of the TPS65218, FSEAL bit would be undefined without coin-cell present which in many cases led to it being set, causing DCDC5 and DCDC6 to stay active, but also leading to unexplained failures when it was not. On B1 revision, FSEAL is always 0 when no coin-cell is present so this patch is required on boards with B1 revision to ever work. This implementation works on boards with either A1 or B1 revision and makes sure that DCDC5 and DCDC6 always stay active. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-08-05ARM: dts: am437x-gp-evm: Add eMMC supportRoger Quadros
Add eMMC pinmux and mmc2 related bits. We keep the mmc2 controller disabled as it conflits with gpmc/NAND. To enable emmc, simply set mmc2 controller node to "okay" and set the gpmc node to "disabled" and change the SelEMMCorNAND gpio-hog to output-high. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-08-05ARM: dts: am437x-gp-evm: Add gpio-hog for configuring eMMC/NAND driverRoger Quadros
On this board either eMMC or NAND can work based on the level of spi2_cs0.gpio0_23. Add a gpio-hog to enable configuration of this pin in the device tree. Move pinmux for spi2_cs0 (SEL_eMMCorNANDn) out of NAND node into gpio0 so it is initialized with gpio0. Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-21ARM: dts: am437x: add aliases for all UART instancesSekhar Nori
Add serialN aliases for all 6 UART instances on the AM437x SoC so each board's .dts file does not have to define its own aliases. Remove the alias added for am437x-gp-evm.dts now that we have the aliases defined in am4372.dtsi file. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-14ARM: dts: am437x-gp-evm: Enable analog audio via simple-cardPeter Ujfalusi
The board uses McASP1 <-> tlv320aic3106 for analog audio and has Headphone out and Line in connectors. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-14ARM: dts: am437x-gp-evm: McASP1 node for audio supportPeter Ujfalusi
Add node for McASP1 along with the needed pinctrl entries. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-14ARM: dts: am437x-gp-evm: Add node for tlv320aic3106 audio codecPeter Ujfalusi
Analog audio is using this codec on the board. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-14ARM: dts: am437x-gp-evm: Rename fixed regulator vmmcsd_fixed to evm_v3_3dPeter Ujfalusi
The same regulator is used by other chips on the board. The power path is: VBAT -> TPS63031 - Enable signal is V1_8D regulator -> V3_3D. V3_3D is used by SD slot and tlv320aic3106 codec as well. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-07-14ARM: dts: am437x-gp-evm: Add gpio-hog for configuring the display/audio muxPeter Ujfalusi
GPIO5_8 is used as a mux switch between LCD and HDMI displays. This mux affects audio routing as well since in LCD mode HDMI audio is not possible and when HDMI is selected analog audio is not working. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-05-20ARM: dts: am437x-gp-evm: add DT nodes for ov2659 sensorLad, Prabhakar
this patch does the following: 1: adds DT node for fixed oscillator. 2: adds DT node entries for ov2659 sensor 3: adds remote-endpoint entry for VPFE. Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-05-20ARM: dts: am437x-gp-evm: add wilink8 supportEyal Reizer
enable mmc3 used for wlan and uart3 used for bluetooth configure the gpios used for wlan and bluetooth controls add fixed voltage regulator used for wlan power control Signed-off-by: Eyal Reizer <eyalr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-15ARM: omap: convert wakeupgen to stacked domainsMarc Zyngier
OMAP4/5 has been (ab)using the gic_arch_extn to provide wakeup from suspend, and it makes a lot of sense to convert this code to use stacked domains instead. This patch does just this, updating the DT files to actually reflect what the HW provides. BIG FAT WARNING: because the DTs were so far lying by not exposing the WUGEN HW block, kernels with this patch applied won't have any suspend-resume facility when booted with old DTs, and old kernels with updated DTs won't even boot. On a platform with this patch applied, the system looks like this: root@bacon-fat:~# cat /proc/interrupts CPU0 CPU1 16: 0 0 WUGEN 37 gp_timer 19: 233799 155916 GIC 27 arch_timer 23: 0 0 WUGEN 9 l3-dbg-irq 24: 1 0 WUGEN 10 l3-app-irq 27: 282 0 WUGEN 13 omap-dma-engine 44: 0 0 4ae10000.gpio 13 DMA 294: 0 0 WUGEN 20 gpmc 297: 506 0 WUGEN 56 48070000.i2c 298: 0 0 WUGEN 57 48072000.i2c 299: 0 0 WUGEN 61 48060000.i2c 300: 0 0 WUGEN 62 4807a000.i2c 301: 8 0 WUGEN 60 4807c000.i2c 308: 2439 0 WUGEN 74 OMAP UART2 312: 362 0 WUGEN 83 mmc2 313: 502 0 WUGEN 86 mmc0 314: 13 0 WUGEN 94 mmc1 350: 0 0 PRCM pinctrl, pinctrl 406: 35155709 0 GIC 109 ehci_hcd:usb1 407: 0 0 WUGEN 7 palmas 409: 0 0 WUGEN 119 twl6040 410: 0 0 twl6040 5 twl6040_irq_ready 411: 0 0 twl6040 0 twl6040_irq_th IPI0: 0 1 CPU wakeup interrupts IPI1: 0 0 Timer broadcast interrupts IPI2: 95334 902334 Rescheduling interrupts IPI3: 0 0 Function call interrupts IPI4: 479 648 Single function call interrupts IPI5: 0 0 CPU stop interrupts IPI6: 0 0 IRQ work interrupts IPI7: 0 0 completion interrupts Err: 0 Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-01-07ARM: dts: am437x-gp-evm: add VPFE device tree dataBenoit Parrot
Add device tree nodes and pinmux entries for Video Processing Front End (VPFE) on am437x gp evm. Signed-off-by: Benoit Parrot <bparrot@ti.com> Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-12-09Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Arnd Bergmann: "The DT branch adds a lot of new stuff for additional SoC and board support. The branch is the largest one and contains 513 out of the total 972 non-merge arm-soc changesets for 3.19. Most of the changes are about enabling additional on-chip devices for existing machines, but there are also an unusual number of new SoC types being added this time: - AMLogic Meson8 - ARM Realview in DT mode - Allwinner A80 - Broadcom BCM47081 - Broadcom Cygnus - Freescale LS1021A - Freescale Vybrid 500 series - Mediatek MT6592, MT8127, MT8135 - STMicroelectronics STiH410 - Samsung Exynos4415 The level of support for the above differs widely, some are just stubs with nothing more than CPU, memory and a UART, but others are fairly complete. As usual, these get extended over time. There are also many new boards getting added, this is the list of model strings that are showing up in new dts files: - ARM RealView PB1176 - Altera SOCFPGA Arria 10 - Asus RT-N18U (BCM47081) - Buffalo WZR-1750DHP (BCM4708) - Buffalo WZR-600DHP2 (BCM47081) - Cygnus Enterprise Phone (BCM911360_ENTPHN) - D-Link DIR-665 - Google Spring - IGEP COM MODULE Rev. G (TI OMAP AM/DM37x) - IGEPv2 Rev. F (TI OMAP AM/DM37x) - LS1021A QDS Board - LS1021A TWR Board - LeMaker Banana Pi - MarsBoard RK3066 - MediaTek MT8127 Moose Board - MediaTek MT8135 evaluation board - Mele M3 - Merrii A80 Optimus Board - Netgear R6300 V2 (BCM4708) - Nomadik STN8815NHK - NovaTech OrionLXm - Olimex A20-OLinuXino-LIME2 - Raspberry Pi Model B+ - STiH410 B2120 - Samsung Monk board - Samsung Rinato board - Synology DS213j - Synology DS414 - TBS2910 Matrix ARM mini PC - TI AM5728 BeagleBoard-X15 - Toradex Colibri VF50 on Colibri Evaluation Board - Zynq ZYBO Development Board Other notable changes include: - exynos: cleanup of existing dts files - mvebu: improved pinctrl support for Armada 370/XP - nomadik: restructuring dts files - omap: added CAN bus support - shmobile: added clock support for some SoCs - shmobile: added sound support for some SoCs - sirf: reset controller support - sunxi: continuing the relicensing under dual GPL/MIT - sunxi: lots of new on-chip device support - sunxi: working simplefb support (long awaited) - various: provide stdout-path property for earlycon" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits) ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured Revert "ARM: dts: rockchip: temporarily disable smp on rk3288" ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2 ARM: BCM5301X: Add DT for Asus RT-N18U ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP ARM: BCM5301X: Add DT for Netgear R6300 V2 ARM: BCM5301X: Add buttons for Netgear R6250 ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file arm: dts: zynq: Add Digilent ZYBO board arm: dts: zynq: Move crystal freq. to board level doc: dt: vendor-prefixes: Add Digilent Inc Documentation: devicetree: Fix Xilinx VDMA specification ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188 ARM: dts: rockchip: add label property for leds on Radxa Rock ARM: BCM5301X: Add LEDs for Netgear R6250 V1 ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file ARM: dts: add sysreg phandle to i2c device nodes for exynos ARM: dts: Remove unused bootargs from exynos3250-rinato ARM: dts: add board dts file for Exynos3250-based Monk board ...
2014-11-24ARM: dts: am437x-gp: Add dcan supportMugunthan V N
Add DCAN support for AM437x GP EVM with both DCAN instances. [Roger Q] Updated output pin to not use pull up. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: George Cherian <george.cherian@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-21ARM: dts: AM43xx: add tscadc DT entries for am437x-evm and am43x-epos-evmVignesh R
This patch adds tscadc DT entries for am437x-gp-evm and am43x-epos-evm. Signed-off-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-10ARM: dts: AM437x-GP-EVM: Fix DCDC3 voltageKeerthy
DCDC3 supplies voltage to DDR. Fix DCDC3 volatge to 1.5V which is the reset value. Programming to a non-reset value while executing from DDR will result in random hangs. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: dts: am437x-gp-evm: Don't use read/write wait monitoringRoger Quadros
NAND uses wait pin only to indicate device readiness after a block/page operation. It is not use to extend individual read/write cycle and so read/write wait pin monitoring must be disabled for NAND. This patch also gets rid of the below warning when NAND is accessed for the first time. omap_l3_noc 44000000.ocp: L3 application error: target 13 mod:1 (unclearable) Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: dts: am437x-gp-evm: Use BCH16 ECC scheme instead of BCH8Roger Quadros
am437x-gp-evm uses a NAND chip with page size 4096 bytes and spare area of 225 bytes per page. For such a setup it is preferrable to use BCH16 ECC scheme over BCH8. This also makes it compatible with ROM code ECC scheme so we can boot with NAND after flashing from kernel. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-03ARM: dts: am437x-gp: switch i2c0 to 100KHzNishanth Menon
On the GP EVM, the ambient light sensor is limited to 100KHz on the I2C bus. So use 100kHz for I2C on the GP EVM due to this limitation on the ambient light sensor. Reported-by: Aparna Balasubramanian <aparnab@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-08-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: - big update to Wacom driver by Benjamin Tissoires, converting it to HID infrastructure and unifying USB and Bluetooth models - large update to ALPS driver by Hans de Goede, which adds support for newer touchpad models as well as cleans up and restructures the code - more changes to Atmel MXT driver, including device tree support - new driver for iPaq x3xxx touchscreen - driver for serial Wacom tablets - driver for Microchip's CAP1106 - assorted cleanups and improvements to existing drover and input core * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (93 commits) Input: wacom - update the ABI doc according to latest changes Input: wacom - only register once the MODULE_* macros Input: HID - remove hid-wacom Bluetooth driver Input: wacom - add copyright note and bump version to 2.0 Input: wacom - remove passing id for wacom_set_report Input: wacom - check for bluetooth protocol while setting OLEDs Input: wacom - handle Intuos 4 BT in wacom.ko Input: wacom - handle Graphire BT tablets in wacom.ko Input: wacom - prepare the driver to include BT devices Input: hyperv-keyboard - register as a wakeup source Input: imx_keypad - remove ifdef round PM methods Input: jornada720_ts - get rid of space indentation and use tab Input: jornada720_ts - switch to using managed resources Input: alps - Rushmore and v7 resolution support Input: mcs5000_ts - remove ifdef around power management methods Input: mcs5000_ts - protect PM functions with CONFIG_PM_SLEEP Input: ads7846 - release resources on failure for clean exit Input: wacom - add support for 0x12C ISDv4 sensor Input: atmel_mxt_ts - use deep sleep mode when stopped ARM: dts: am437x-gp-evm: Update binding for touchscreen size ...
2014-07-28ARM: dts: am437x-gp-evm: Update binding for touchscreen sizeRoger Quadros
Update the bindings for touchscreen size. Signed-off-by: Roger Quadros <rogerq@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-07-09ARM: dts: AM437x: Add TPS65218 device tree nodesKeerthy
Add TPS65218 device tree nodes. i2c clock frequency setting also added as part of tps65218 nodes addition. As i2c clock enabling is required. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-09ARM: dts: AM437x: Fix i2c nodes indentationKeerthy
Fix i2c nodes indentation. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-06-09Merge tag 'fbdev-omap-dt-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull OMAP DT fbdev updates from Tomi Valkeinen: "Here are display related device tree data changes for OMAP. They are based on an already merged branch to satisfy the dependencies for the dts file changes. Add OMAP DT data: - omap5 display subsystem - display data for omap5 uEVM board - am43xx display subsystem - display data for am43xx ePOS and GP boards (LCD only) - display data for GTA04 board - display data for overo board - display data for duovero-parlor board - display data for omap3 evm and ldp boards" * tag 'fbdev-omap-dt-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: ARM: omap5.dtsi: Add audio related parameters to hdmi node ARM: omap4.dtsi: Add audio related parametes to hdmi node ARM: dts: duovero-parlor: Add HDMI output ARM: dts: overo: Add support for 3.5'' LCD output ARM: dts: overo: Add support for 4.3'' LCD output ARM: dts: overo: Add support for DVI output ARM: dts: Add LCD panel sharp ls037v7dw01 support for omap3-evm and ldp ARM: dts: omap3-gta04: Add display support ARM: dts: omap5-uevm.dts: add display nodes ARM: dts: omap5-uevm.dts: add tca6424a ARM: dts: omap5.dtsi: add DSS nodes ARM: dts: am43x-epos-evm: add LCD data ARM: dts: am437x-gp-evm: add LCD data ARM: dts: am4372.dtsi: add DSS information
2014-06-03ARM: dts: am437x-gp-evm: add LCD dataSathya Prakash M R
Add DT data for am437x-gp-evm's LCD panel. Signed-off-by: Sathya Prakash M R <sathyap@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-06-02Merge tag 'dt-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC devicetree updates from Olof Johansson: "As with previous release, this continues to be among the largest branches we merge, with lots of new contents. New things for this release are among other things: - DTSI contents for the new SoCs supported in 3.16 (see SoC pull request) - Qualcomm APQ8064 and APQ8084 SoCs and eval boards - Nvidia Jetson TK1 development board (Tegra T124-based) Two new SoCs that didn't need enough new platform code to stand out enough for me to notice when writing the SoC tag, but that adds new DT contents are: - TI DRA72 - Marvell Berlin 2Q" * tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits) ARM: dts: add secure firmware support for exynos5420-arndale-octa ARM: dts: add pmu sysreg node to exynos3250 ARM: dts: correct the usb phy node in exynos5800-peach-pi ARM: dts: correct the usb phy node in exynos5420-peach-pit ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410 ARM: dts: add dts files for exynos3250 SoC ARM: dts: add mfc node for exynos5800 ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi ARM: dts: enable fimd for exynos5800-peach-pi ARM: dts: enable display controller for exynos5800-peach-pi ARM: dts: enable hdmi for exynos5800-peach-pi ARM: dts: add dts file for exynos5800-peach-pi board ARM: dts: add dts file for exynos5800 SoC ARM: dts: add dts file for exynos5260-xyref5260 board ARM: dts: add dts files for exynos5260 SoC ARM: dts: update watchdog node name in exynos5440 ARM: dts: use key code macros on Origen and Arndale boards ARM: dts: enable RTC and WDT nodes on Origen boards ARM: dts: qcom: Add APQ8084-MTP board support ARM: dts: qcom: Add APQ8084 SoC support ...
2014-05-27ARM: dts: am437x-gp-evm: add support for parallel NAND flashPekon Gupta
Adds pinmux and DT node for Micron (MT29F4G08AB) x8 NAND device present on am437x-gp-evm board. (1) As NAND Flash data lines are muxed with eMMC, Thus at a given time either eMMC or NAND can be enabled. Selection between eMMC and NAND is controlled: (a) By dynamically driving following GPIO pin from software SPI2_CS0(GPIO) == 0 NAND is selected (default) SPI2_CS0(GPIO) == 1 eMMC is selected (b) By statically using Jumper (J89) on the board (2) As NAND device connnected to this board has page-size=4K and oob-size=224, So ROM code expects boot-loaders to be flashed in BCH16 ECC scheme for NAND boot. Signed-off-by: Pekon Gupta <pekon@ti.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-19ARM: dts: am437x-gp-evm: Add ethernet support for GP EVMMugunthan V N
Add CPSW ethernet support for AM437x GP EVM which has one slave pinned out Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-06ARM: dts: am437x-gp-evm: Add vtt_fixed regulatorDave Gerlach
The VTT regulator for DDR3 termination on the am437x-gp-evm is controlled by a gpio. It is configured by the bootloader so here we define an always-on, fixed voltage regulator to hold the gpio. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-06ARM: dts: am437x: Add touchscreen support for GP EVMSekhar Nori
Add touchscreen support for AM437x GP EVM using pixcir touchscreen controller. CC: Benoit Cousson <bcousson@baylibre.com> CC: Tony Lindgren <tony@atomide.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-05-06ARM: dts: am437x-gp-evm: Enable USBGeorge Cherian
Enable - USB PHY - USB for am437x-gp-evm Signed-off-by: George Cherian <george.cherian@ti.com> Acked-by: Roger Quadros <rogerq@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
