The at24 driver allows to register I2C EEPROM chips using different vendor
and devices, but the I2C subsystem does not take the vendor into account
when matching using the I2C table since it only has device entries.
But when matching using an OF table, both the vendor and device has to be
taken into account so the driver defines only a set of compatible strings
using the "atmel" vendor as a generic fallback for compatible I2C devices.
So add this generic fallback to the device node compatible string to make
the device to match the driver using the OF device ID table.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
Add stdout-path property in /chosen node so that earlycon can be
used by just adding earlycon in bootargs.
The TPIC2810 is available on the AM437x IDK and is attached to I2C1.
Output is attached to the I/O header and 10 LEDs.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
The SN65HVS882 is available on the AM437x IDK and is attached to SPI1.
Input is attached to the I/O header.
Reviewed-by: Roger Quadros <rogerq@ti.com>
This patch fixes the following DTC warnings for many boards:
"Node /gpio_keys/button0@10 has a unit name, but no reg property"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Currently am4372.dtsi declares the MAC controller to have two
slave ports, on this board we only use one, so set the slave
count to one. This eliminates a console error message when
the non-existent PHY is not detected.
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
Use the pinmux IOPAD macro to define the register absolute physical
address instead of the offset from the padconf base address. This
makes the DTS easier to read since matches the addresses listed in
the Technical Reference Manual.
binding docs
As per mmc device tree binding documentation card detect gpio has
to be active low signal. When a hardware is designed with active
high card detect, gpio polarity has to be changed with
cd-inverted dt property.
In AM43xx the card detect gpio is designed as active low gpio.
So correcting the dt card detect gpio definition.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
rtc can either be supplied from internal 32k clock or external crystal
generated 32k clock. Internal clock is SOC specific and the external
clock is board dependent. Adding the corresponding nodes.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
i2c2 goes to an expansion connector which we
want to use.
Signed-off-by: Felipe Balbi <balbi@ti.com>
we have i2c0 sleep pinctrl state but were passing
default state anyhow. Fix that.
As it turns out, tps62362 is actually on I2C bus0,
not bus1. This has gone unnoticed because Linux
doesn't use (as of now) that regulator at all, it's
setup by the bootloader and left as is.
While at that, also add missing reg property for
our regulator.
AM437x IDK board has a User Switch which we can
program to whatever we want. Because this board
doesn't have a PMIC which can give us power button
presses, let's use this user switch as a gpio-keys
power button.
The AM437x Industrial Development Kit (IDK) is
an application development platform targeted at
industrial communication and control applications.
It comes with a 3-phase motor driver, PROFINET,
PROFIBUS and a few other industrial communication
interfaces.
The board has 1GiB of DDR3 RAM, QSPI NOR flash,
a 100% discrete power design (no PMIC) and an
on-board 2MP camera (not supported with Linux
as of this writing).
