This patch fixes the following DTC warnings for am437x-sbc-t43.dtb:
"endpoint@0 has a unit name, but no reg property"
"connector@0 has a unit name, but no reg property"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Add the necessary dss configuration to drive the startek lcd on CompuLab
sbc-t43 single board computer.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Benoit Cousson <bcousson@baylibre.com>
Cc: Rob Herring <robh@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Dmitry Lifshitz <lifshitz@compulab.co.il>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
On SBC-T43 the mmc1 interface is connected to an SD-Card slot.
Add the necessary muxing and configuration to the device tree.
SB-SOM baseboard comes with an on-board EEPROM. On SBC-T43 this EEPROM
resides on the i2c1 bus. Add it to the device tree.
SB-SOM comes with a PCA9555 GPIO extender. On SBC-T43 this resides on the
Add USB support for CompuLab sbc-t43 single board computer,
defaulting to host mode.
Add basic support for SBC-T43: a CM-T43 based single board computer.
CM-T43 is an AM437x based System-on-Module designed to serve as a building
block in embedded applications. SBC-T43 is composed of CM-T43 module on
top of the SB-SOM-T43 baseboard.
Basic support includes UART, GPIO, and I2C.
Acked-by: Rob Herring <robh@kernel.org>
