[ Upstream commit c6b16761c6908d3dc167a0a566578b4b0b972905 ]
The LCD panel on AM4 GP EVMs and ePOS boards seems to be
osd070t1718-19ts. The current dts files say osd057T0559-34ts. Possibly
the panel has changed since the early EVMs, or there has been a mistake
with the panel type.
Update the DT files accordingly.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
On am438x EPOS boards there is only one ethernet port, remove extra
port definition.
This boot log warnings during PHY detection.
Signed-off-by: Yogesh Siraswar <yogeshs@ti.com>
Signed-off-by: Andrew F. Davis <afd@ti.com>
Currently the default method of prefetch polled shows the highest
possible read and write speed when minimal non NAND background
activity is being done. But it is also very CPU intensive to reach
these high speeds (CPU load of 99% via mtd performance tests). While
DMA prefetch only uses 50% of the CPU to achieve around 23% less in
top read and write performance.
However, as the non NAND CPU load increases the read and write
performance takes a large hit when using polled prefetch. Therefore,
prefetch dma mode ends up outperforming prefetch polled in general
"system level" test. So switch to using dma prefetch by default since
it is likely what most users would prefer.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Acked-by: Roger Quadros <rogerq@ti.com>
dcdc3 supplies to DDR on AM43x series. When we set both
min and max values to the same value. The regulator framework
sets that particular voltage. This is bad as we are changing
the ddr voltage when executing from ddr. Hence remove the min and
max values. The ddr supply voltage shall be set from bootloader
when not executing from ddr and not while executing from kernel.
The previous discussion can be found here:
http://www.spinics.net/lists/devicetree/msg56399.html
Signed-off-by: Keerthy <j-keerthy@ti.com>
The at24 driver allows to register I2C EEPROM chips using different vendor
and devices, but the I2C subsystem does not take the vendor into account
when matching using the I2C table since it only has device entries.
But when matching using an OF table, both the vendor and device has to be
taken into account so the driver defines only a set of compatible strings
using the "atmel" vendor as a generic fallback for compatible I2C devices.
So add this generic fallback to the device node compatible string to make
the device to match the driver using the OF device ID table.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
Add stdout-path property in /chosen node so that earlycon can be
used by just adding earlycon in bootargs.
With the device tree parsing using the regulator framework
there is a no longer a need for separate compatibles for
individual regulator nodes. Hence removing them all.
This patch fixes the following DTC warnings for many boards:
"Node /fixedregulator@0 has a unit name, but no reg property"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
"Node /matrix_keypad@0 has a unit name, but no reg property"
This patch fixes the following DTC warnings for am43xx-epos-evm.dtb:
"endpoint@0 has a unit name, but no reg property"
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
which as usual makes up the bulk of the ARM SoC changes: 462 non-merge
changesets, 450 files changed, 23340 insertions, 5216 deletions.
The three platforms that are added with the "soc" branch are here as
well, and we add some related machine files:
- For Aspeed AST2400/AST2500, we get the evaluation platform and the
Tyan Palmetto POWER8 mainboard that uses the AST2400 BMC
- For Oxnas 810SE, the Western Digital "My Book World Edition" is
added as the only platform at the moment.
- For ARM MPS2, the AN385 (Cortex-M3) and AN399 (Cortex-M7) are
supported
On the ARM Realview development platform, we now support all machines
with device tree, previously only the board files were supported,
which in turn will likely be removed soon.
Qualcomm IPQ4019 is the second generation ARM based "Internet
Processor", following the IPQ806x that is used in many high-end WiFi
routers. This one integrates two ath10k wifi radios that were
previously on separate chips.
Other boards that got added for existing chips are:
Ti OMAP family:
- Amazon Kindle Fire, first generation, tablet and ebook reader
- OnRISC Baltos iR 2110 and 3220 embedded industrial PCs
- TI AM5728 IDK, TI AM3359 ICE-V2, and TI DRA722 Rev C EVM
development systems
Samsung EXYNOS platform:
- Samsung ARTIK5 evaluation board, see
https://www.artik.io/modules/overview/artik-5/
NXP i.MX platforms:
- Ka-Ro electronics TX6S-8034, TX6S-8035, TX6U-8033, TX6U-81xx,
TX6Q-1036, TX6Q-1110/-1130, TXUL-0010 and TXUL-0011 industrial
SoM modules
- Embest MarS Board i.MX6Dual DIY platform
- Boundary Devices i.MX6 Quad Plus Nitrogen6_MAX and SoloX
Nitrogen6sx embedded boards
- Technexion Pico i.MX6UL compute module
- ZII VF610 Development Board
Marvell embedded (mvebu, orion, kirkwood) platforms:
- Linksys Viper (E4200v2 / EA4500) WiFi router
- Buffalo Kurobox Pro NAS
Qualcomm Snapdragon:
- Arrow DragonBoard 600c (96boards) with APQ8064 Snapdragon 600
Rockchips platform:
- mqmaker MiQi single-board computer
Altera SoCFPGA:
- samtec VIN|ING 1000 vehicle communication interface
Allwinner Sunxi platforms:
- Dserve DSRV9703C tablet
- Difrnce DIT4350 tablet
- Colorfly E708 Q1 tablet
- Polaroid MID2809PXE04 tablet
- Olimex A20 OLinuXino LIME2 single board computer
- Xunlong Orange Pi 2, Orange Pi One, and Orange Pi PC single board
computers
Across many platforms, bug fixes went in to address warnings that dtc
now emits with 'make dtbs W=1'. Further changes for device enablement
went into Ti OMAP, bcm283x (Raspberry Pi), bcm47xx (wifi router), Ti
Davinci, Samsung EXYNOS, Marvell mvebu/kirkwood/orion, NXP i.MX/Vybrid
NXP LPC18xx, NXP LPC32xx, Renesas shmobile/r-mobile/r-car, Rockchips
rk3xxx, ST Ux500, ST STi, Atmel AT91/SAMA5, Altera SoCFPGA, Allwinner
Sunxi, Sigma Designs Tango, NVIDIA Tegra, Socionext Uniphier and ARM
Versatile Express"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (458 commits)
ARM: dts: tango4: Import watchdog node
ARM: dts: tango4: Update cpus node for cpufreq
ARM: dts: tango4: Update DT to match clk driver
ARM: dts: tango4: Initial thermal support
arm/dst: Add Aspeed ast2500 device tree
arm/dts: Add Aspeed ast2400 device tree
ARM: sun7i: dt: Add pll3 and pll7 clocks
ARM: dts: sunxi: Add a olinuxino-lime2-emmc
ARM: dts: at91: sama5d4: add trng node
ARM: dts: at91: sama5d3: add trng node
ARM: dts: at91: sama5d2: add trng node
ARM: dts: at91: at91sam9g45 family: reduce the trng register map size
ARM: sun4i: dt: Add pll3 and pll7 clocks
ARM: sun5i: chip: Enable the TV Encoder
ARM: sun5i: r8: Add display blocks to the DTSI
ARM: sun5i: a13: Add display and TCON clocks
ARM: dts: ux500: configure the accelerometers open drain
ARM: mx5: dts: Enable USB OTG on M53EVK
ARM: dts: imx6ul-14x14-evk: Add audio support
ARM: dts: imx6qdl: Remove unneeded unit-addresses
On these boards NAND ready pin status is avilable over
GPMC_WAIT0 pin.
For NAND we don't use GPMC wait pin monitoring but
get the NAND Ready/Busy# status using GPIOlib.
GPMC driver provides the WAIT0 pin status over GPIOlib.
Read speed increases from 16516 KiB/ to 18813 KiB/s
and write speed was unchanged at 9941 KiB/s.
Measured using mtd_speedtest.ko.
Signed-off-by: Roger Quadros <rogerq@ti.com>
This patch fixes the following DTC warning:
"sound@0 has a unit name, but no reg property"
commit 55ee7017ee31 ("arm: omap2: board-generic: use omap4_local_timer_init
for AM437x") makes synctimer32k as the clocksource on AM43xx. By default
the synctimer32k is clocked by 32K RTC OSC on AM43xx. But this 32K RTC OSC
is not available on epos boards which makes it fail to boot.
Synctimer32k can also be clocked by a peripheral PLL, so making this as
clock parent for synctimer3k on epos boards.
Fixes: 55ee7017ee31 ("arm: omap2: board-generic: use omap4_local_timer_init for AM437x")
Cc: stable@vger.kernel.org # v4.4+
Reported-by: Nishanth Menon <nm@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
Pull "Part 2 of device tree changes for omaps for v4.6 merge window" from Tony Lindgren:
- A series of GPMC related interrupt changes from
Rogeq Quadros <rogerq@ti.com> to prepare adding interrupt
support to the NAND driver
- Add RTC support for ti81xx
- Correct LogicPD Torpedo mode description
- Add basic support for LG Optimus Black phone in several
patches by Paul Kocialkowski <contact@paulk.fr>
- Change address-cells for dra7 for LPAE
- Add TBCLK for PWMSS on dra7
* tag 'omap-for-v4.6/dt-pt2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (21 commits)
ARM: dts: omap3-sniper: TWL4030 keypad support
Revert "ARM: dts: DRA7: Add dt nodes for PWMSS"
ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND
ARM: dts: dm814x: dra62x: Fix NAND device nodes
ARM: dts: DRA7: Add TBCLK for PWMSS
ARM: dts: DRA7: change address-cells and size-cells
ARM: dts: omap3-sniper: USB OTG support
ARM: dts: LG Optimus Black codename sniper basic support
ARM: dts: dm3730-torpedo-devkit: Add "Wireless" to model
ARM: dts: Add RTC entry for dm816x
ARM: dts: Add RTC entry for dm814x and dra62x
ARM: dts: omap3: Fix NAND device nodes
ARM: dts: dm8168-evm: ARM: dts: Disable wait pin monitoring for NAND
ARM: dts: dm816x: Fix NAND device nodes
ARM: dts: am335x: Disable wait pin monitoring for NAND
ARM: dts: am335x: Fix NAND device nodes
ARM: dts: am437x: Disable wait pin monitoring for NAND
ARM: dts: am437x: Fix NAND device nodes
ARM: dts: dra7: Remove redundant nand property
Device tree changes for omaps for v4.6 merge window. Mostly just
adding board specific devices and few new boards:
- N900 improvments for adp1653 and gpio keys
- Add missing bandgap data for omap3
- Add more devices for compulab cm-t335
- Add n950 WLAN support, enable modem, add pinctrl for SSI
- Correct dm814x and dra62x auxclk rate, add support for GPMC and NAND
- Add syscon node for PHY's on dra7
- Add support more devices on logicpd torpedo
- Add USB host support for igep and specify boot console
- Fix audio clock for am335x-sl50 and specify boot console
- Remove deprecated tx-fifo-resize for dwc3 that was only used on
omap5 es1.0
- Add dra7 thermal data
- Update am43x-epos-evm compatible string to am438
- Add support for logicpd dm3730 som-lv
* tag 'omap-for-v4.6/dt-pt1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (38 commits)
ARM: dts: am57xx-beagle-x15: Add eeprom information
ARM: dts: Add HSUSB2 EHCI Support to Logic PD DM37xx SOM-LV
ARM: dts: n900: Use linux input defines instead hardcoded constants
ARM: DTS: Add minimal Support for Logic PD DM3730 SOM-LV
ARM: dts: omap3logic: Add PWM-Backlight
ARM: dts: omap3-n900: Allow gpio keys to be disabled
ARM: dts: am43x-epos-evm: Add the am438 compatible string
ARM: dts: DRA7: Add missing IVA and DSPEVE thermal domain data
ARM: dts: DRA7: Add IVA thermal data
ARM: dts: DRA7: Add DSPEVE thermal data
ARM: dts: remove deprecated property dwc3
ARM: dts: OMAP3-N950-N9: Add ssi idle pinctrl state
ARM: dts: am335x-sl50: Fix audio codec setup.
ARM: dts: am335x-sl50: Specify the device to be used for boot console output.
ARM: dts: omap3-igep0030-common: Add USB Host support
ARM: dts: igep00x0: Specify the device to be used for boot console output.
ARM: dts: LogicPD Torpedo: Set HSUSB0 Pin Mux
ARM: dts: OMAP3-N950-N9: Enable modem
ARM: dts: OMAP3-N950-N9: Enable SSI module
ARM: dts: LogicPD Torpedo: Add SPI EEPROM
The NAND Ready/Busy# line is connected to GPMC_WAIT0 pin and
can't be used for wait state insertion for NAND I/O read/write.
So disable read/write wait monitoring as per Reference Manual's
suggestion [1].
[1] AM437x TRM: SPRUHL7D: 9.1.3.3.12.2 NAND Device-Ready Pin
Add compatible id, GPMC register resource and interrupt
resource to NAND controller nodes.
The GPMC node will provide an interrupt controller for the
NAND IRQs.
The SoCs on am43x-epos-evm are named am438x.
Hence add the compatibility string and remove the am4372 string.
Now IRQs for Pixcir Tangoc touchscreen are defined using
IRQ_TYPE_NONE in am437x-gp-evm.dts and am43x-epos-evm.dts wich
do not correspond HW.
Hence, update am437x-gp-evm.dts and am43x-epos-evm.dts files
and use correct flag IRQ_TYPE_EDGE_FALLING for irq types.
While here, remove duplicated irq declaration for pixcir_ts@5c node
in am437x-gp-evm.dts.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Use the pinmux IOPAD macro to define the register absolute physical
address instead of the offset from the padconf base address. This
makes the DTS easier to read since matches the addresses listed in
the Technical Reference Manual.
binding docs
As per mmc device tree binding documentation card detect gpio has
to be active low signal. When a hardware is designed with active
high card detect, gpio polarity has to be changed with
cd-inverted dt property.
In AM43xx the card detect gpio is designed as active low gpio.
So correcting the dt card detect gpio definition.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Use simple card for audio support on ePOS-EVM.
The audio on the board is: McASP1 <-> tlv320aic3111 codec.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Analog audio is using this codec on the board.
Add node for McASP1 along with the needed pinctrl entries.
The VBAT and DCDC4 regulator is needed for audio support (tlv320aic3111)
GPIO2_1 is used as a mux switch between LCD and HDMI displays. This mux
affects audio routing as well since in LCD mode HDMI audio is not possible
and when HDMI is selected analog audio is not working.
Pull ARM SoC late changes from Olof Johansson:
"We were expecting to sit on this branch through most of the merge
window since the contents was merged into our tree late, but we ended
up sitting on all of our contents so it can go in with the rest.
The contents here is:
- a large branch of cleanups of the CM/PRM blocks on OMAP.
- a couple of patches plumbing up CM/PRM on OMAP5 and DRA7.
- a branch with DT updates for Freescale i.MX. including some
shuffling from .dts to .dtsi (include) files that causes a little
churn"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits)
ARM: OMAP2+: Fix booting with configs that don't have MFD_SYSCON
ARM: OMAP4+: control: add support for initializing control module via DT
ARM: dts: dra7: add minimal l4 bus layout with control module support
ARM: dts: omap5: add minimal l4 bus layout with control module support
ARM: OMAP4+: control: remove support for legacy pad read/write
ARM: OMAP4: display: convert display to use syscon for dsi muxing
ARM: dts: omap4: add minimal l4 bus layout with control module support
ARM: dts: am4372: add minimal l4 bus layout with control module support
ARM: dts: am43xx-epos-evm: fix pinmux node layout
ARM: dts: am33xx: add minimal l4 bus layout with control module support
ARM: dts: omap3: add minimal l4 bus layout with control module support
ARM: dts: omap24xx: add minimal l4 bus layout with control module support
ARM: OMAP2+: control: add syscon support for register accesses
ARM: OMAP2+: id: cache omap_type value
ARM: OMAP2+: control: remove API for getting control module base address
ARM: OMAP2+: clock: add low-level support for regmap
ARM: OMAP4+: PRM: get rid of cpu_is_omap44xx calls from interrupt init
ARM: OMAP4+: PRM: setup prm_features from the PRM init time flags
ARM: OMAP2+: CM: move SoC specific init calls within a generic API
ARM: OMAP4+: PRM: determine prm_device_inst based on DT compatibility
Pinmux node should be a reference to the base one, not a complete re-write
of it. Having the node like this also prevents modifying the node layout
in the base am4372.dtsi file, which is needed for control module changes.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
OMAP4/5 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the WUGEN HW block, kernels with this patch applied
won't have any suspend-resume facility when booted with old DTs,
and old kernels with updated DTs won't even boot.
On a platform with this patch applied, the system looks like
this:
root@bacon-fat:~# cat /proc/interrupts
CPU0 CPU1
16: 0 0 WUGEN 37 gp_timer
19: 233799 155916 GIC 27 arch_timer
23: 0 0 WUGEN 9 l3-dbg-irq
24: 1 0 WUGEN 10 l3-app-irq
27: 282 0 WUGEN 13 omap-dma-engine
44: 0 0 4ae10000.gpio 13 DMA
294: 0 0 WUGEN 20 gpmc
297: 506 0 WUGEN 56 48070000.i2c
298: 0 0 WUGEN 57 48072000.i2c
299: 0 0 WUGEN 61 48060000.i2c
300: 0 0 WUGEN 62 4807a000.i2c
301: 8 0 WUGEN 60 4807c000.i2c
308: 2439 0 WUGEN 74 OMAP UART2
312: 362 0 WUGEN 83 mmc2
313: 502 0 WUGEN 86 mmc0
314: 13 0 WUGEN 94 mmc1
350: 0 0 PRCM pinctrl, pinctrl
406: 35155709 0 GIC 109 ehci_hcd:usb1
407: 0 0 WUGEN 7 palmas
409: 0 0 WUGEN 119 twl6040
410: 0 0 twl6040 5 twl6040_irq_ready
411: 0 0 twl6040 0 twl6040_irq_th
IPI0: 0 1 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 95334 902334 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 479 648 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 0 0 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Add device tree nodes and pinmux entries for Video Processing
Front End (VPFE) on am43x epos evm.
Signed-off-by: Benoit Parrot <bparrot@ti.com>
Signed-off-by: Darren Etheridge <detheridge@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Pull ARM SoC DT updates from Arnd Bergmann:
"The DT branch adds a lot of new stuff for additional SoC and board
support. The branch is the largest one and contains 513 out of the
total 972 non-merge arm-soc changesets for 3.19.
Most of the changes are about enabling additional on-chip devices for
existing machines, but there are also an unusual number of new SoC
types being added this time:
- AMLogic Meson8
- ARM Realview in DT mode
- Allwinner A80
- Broadcom BCM47081
- Broadcom Cygnus
- Freescale LS1021A
- Freescale Vybrid 500 series
- Mediatek MT6592, MT8127, MT8135
- STMicroelectronics STiH410
- Samsung Exynos4415
The level of support for the above differs widely, some are just stubs
with nothing more than CPU, memory and a UART, but others are fairly
complete. As usual, these get extended over time.
There are also many new boards getting added, this is the list of
model strings that are showing up in new dts files:
- ARM RealView PB1176
- Altera SOCFPGA Arria 10
- Asus RT-N18U (BCM47081)
- Buffalo WZR-1750DHP (BCM4708)
- Buffalo WZR-600DHP2 (BCM47081)
- Cygnus Enterprise Phone (BCM911360_ENTPHN)
- D-Link DIR-665
- Google Spring
- IGEP COM MODULE Rev. G (TI OMAP AM/DM37x)
- IGEPv2 Rev. F (TI OMAP AM/DM37x)
- LS1021A QDS Board
- LS1021A TWR Board
- LeMaker Banana Pi
- MarsBoard RK3066
- MediaTek MT8127 Moose Board
- MediaTek MT8135 evaluation board
- Mele M3
- Merrii A80 Optimus Board
- Netgear R6300 V2 (BCM4708)
- Nomadik STN8815NHK
- NovaTech OrionLXm
- Olimex A20-OLinuXino-LIME2
- Raspberry Pi Model B+
- STiH410 B2120
- Samsung Monk board
- Samsung Rinato board
- Synology DS213j
- Synology DS414
- TBS2910 Matrix ARM mini PC
- TI AM5728 BeagleBoard-X15
- Toradex Colibri VF50 on Colibri Evaluation Board
- Zynq ZYBO Development Board
Other notable changes include:
- exynos: cleanup of existing dts files
- mvebu: improved pinctrl support for Armada 370/XP
- nomadik: restructuring dts files
- omap: added CAN bus support
- shmobile: added clock support for some SoCs
- shmobile: added sound support for some SoCs
- sirf: reset controller support
- sunxi: continuing the relicensing under dual GPL/MIT
- sunxi: lots of new on-chip device support
- sunxi: working simplefb support (long awaited)
- various: provide stdout-path property for earlycon"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits)
ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured
Revert "ARM: dts: rockchip: temporarily disable smp on rk3288"
ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2
ARM: BCM5301X: Add DT for Asus RT-N18U
ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP
ARM: BCM5301X: Add DT for Netgear R6300 V2
ARM: BCM5301X: Add buttons for Netgear R6250
ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard
ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file
arm: dts: zynq: Add Digilent ZYBO board
arm: dts: zynq: Move crystal freq. to board level
doc: dt: vendor-prefixes: Add Digilent Inc
Documentation: devicetree: Fix Xilinx VDMA specification
ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188
ARM: dts: rockchip: add label property for leds on Radxa Rock
ARM: BCM5301X: Add LEDs for Netgear R6250 V1
ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file
ARM: dts: add sysreg phandle to i2c device nodes for exynos
ARM: dts: Remove unused bootargs from exynos3250-rinato
ARM: dts: add board dts file for Exynos3250-based Monk board
This patch adds tscadc DT entries for am437x-gp-evm
and am43x-epos-evm.
Signed-off-by: Vignesh R <vigneshr@ti.com>
DCDC3 supplies voltage to DDR. Fix DCDC3 volatge to 1.5V which is the reset
value. Programming to a non-reset value while executing from DDR will result
in random hangs.
The GPMC binding is obviously very confusing as the values
are all over the place. People seem to confuse the GPMC partition
size for the chip select, and the device IO size within the GPMC
partition easily.
The ranges entry contains the GPMC partition size. And the
reg entry contains the size of the IO registers of the
device connected to the GPMC.
Let's fix the issue according to the following table:
Device GPMC partition size Device IO size
connected in the ranges entry in the reg entry
NAND 0x01000000 (16MB) 4
16550 0x01000000 (16MB) 8
smc91x 0x01000000 (16MB) 0xf
smc911x 0x01000000 (16MB) 0xff
OneNAND 0x01000000 (16MB) 0x20000 (128KB)
16MB NOR 0x01000000 (16MB) 0x01000000 (16MB)
32MB NOR 0x02000000 (32MB) 0x02000000 (32MB)
64MB NOR 0x04000000 (64MB) 0x04000000 (64MB)
128MB NOR 0x08000000 (128MB) 0x08000000 (128MB)
256MB NOR 0x10000000 (256MB) 0x10000000 (256MB)
Let's also add comments to the fixed entries while at it.
Both QSPI and GPMC-NAND share the same Pin (A8) from the SoC for Chip Select
functionality. So both can't be enabled simultaneously.
Disable QSPI node to prevent the pin conflict as well as
be similar to 3.12 release.
CC: Sourav Poddar <sourav.poddar@ti.com>
Reviewed-by: Pekon Gupta <pekon@pek-sem.com>
NAND uses wait pin only to indicate device readiness after
a block/page operation. It is not use to extend individual
read/write cycle and so read/write wait pin monitoring must
be disabled for NAND.
Add gpmc wait pin information as the NAND uses wait pin 0
for device ready indication.
am43x-epos-evm uses a NAND chip with page size 4096 bytes
and spare area of 225 bytes per page.
For such a setup it is preferrable to use BCH16 ECC scheme over
BCH8. This also makes it compatible with ROM code ECC scheme so
we can boot with NAND after flashing from kernel.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
- big update to Wacom driver by Benjamin Tissoires, converting it to
HID infrastructure and unifying USB and Bluetooth models
- large update to ALPS driver by Hans de Goede, which adds support for
newer touchpad models as well as cleans up and restructures the code
- more changes to Atmel MXT driver, including device tree support
- new driver for iPaq x3xxx touchscreen
- driver for serial Wacom tablets
- driver for Microchip's CAP1106
- assorted cleanups and improvements to existing drover and input core
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (93 commits)
Input: wacom - update the ABI doc according to latest changes
Input: wacom - only register once the MODULE_* macros
Input: HID - remove hid-wacom Bluetooth driver
Input: wacom - add copyright note and bump version to 2.0
Input: wacom - remove passing id for wacom_set_report
Input: wacom - check for bluetooth protocol while setting OLEDs
Input: wacom - handle Intuos 4 BT in wacom.ko
Input: wacom - handle Graphire BT tablets in wacom.ko
Input: wacom - prepare the driver to include BT devices
Input: hyperv-keyboard - register as a wakeup source
Input: imx_keypad - remove ifdef round PM methods
Input: jornada720_ts - get rid of space indentation and use tab
Input: jornada720_ts - switch to using managed resources
Input: alps - Rushmore and v7 resolution support
Input: mcs5000_ts - remove ifdef around power management methods
Input: mcs5000_ts - protect PM functions with CONFIG_PM_SLEEP
Input: ads7846 - release resources on failure for clean exit
Input: wacom - add support for 0x12C ISDv4 sensor
Input: atmel_mxt_ts - use deep sleep mode when stopped
ARM: dts: am437x-gp-evm: Update binding for touchscreen size
Update the bindings for touchscreen size.
Merge "omap dts changes for v3.17 merge window, part1" from Tony Lindgren:
First set of .dts changes for omaps for v3.17 merge window:
- Enable irqchip crossbar interrupt mapping. These changes
are based on an immutable irqchip branch set up by Jason
Cooper to make it easier to merge the related .dts changes.
- Removal of omap2 related static clock data that now comes
from device tree.
- Enabling of PHY regulators for various omaps
- Enabling of PCIe for dra7
- Add support for am437x starterkit
- Enable audio for for omap5
- Enable display and am335x-evmsk
* tag 'omap-for-v3.17/dt-part1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (43 commits)
ARM: DTS: omap5-uevm: Enable basic audio (McPDM <-> twl6040)
ARM: DTS: omap5-uevm: Add node for twl6040 audio codec
ARM: DTS: omap5-uevm: Enable palmas clk32kgaudio clock
ARM: dts: dra7: Add dt data for PCIe controller
ARM: dts: dra7: Add dt data for PCIe PHY
ARM: dts: dra7: Add dt data for PCIe PHY control module
ARM: dts: dra7xx-clocks: Add missing clocks for second PCIe PHY instance
ARM: dts: dra7xx-clocks: rename pcie clocks to accommodate second PHY instance
ARM: dts: dra7xx-clocks: Add missing 32KHz clocks used for PHY
ARM: dts: dra7xx-clocks: Change the parent of apll_pcie_in_clk_mux to dpll_pcie_ref_m2ldo_ck
ARM: dts: dra7xx-clocks: Add divider table to optfclk_pciephy_div clock
ARM: dts: dra7-evm: Add regulator information to USB2 PHYs
ARM: omap2plus_defconfig: enable TPS65218 configs
ARM: dts: AM437x: Add TPS65218 device tree nodes
ARM: dts: AM437x: Fix i2c nodes indentation
ARM: dts: AM43x: Add TPS65218 device tree nodes
ARM: dts: Add devicetree for Gumstix Pepper board
ARM: dts: dra7: add crossbar device binding
ARM: dts: dra7: add routable-irqs property for gic node
ARM: OMAP24xx: clock: remove legacy clock data
Add TPS65218 device tree nodes. i2c clock frequency setting
also added as part of tps65218 nodes addition. As i2c clock
enabling is required.
Reviewed-by: Felipe Balbi <balbi@ti.com>
AM437x EPOS evm use external clock for RMII interface.
Enable the same in DT.
Signed-off-by: George Cherian <george.cherian@ti.com>
Tested-by: Nishanth Menon <nm@ti.com>
Add DT data for am43x-epos-evm's LCD panel.
MTD NAND partition for file-system should start at offset=0xA00000
Signed-off-by: Pekon Gupta <pekon@ti.com>
Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
Add device tree nodes and pinmux for hdq/1wire on
am43x epos evm.
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Fixup Y resolution and add default pin state. Also update
the compatible id.
CC: Benoit Cousson <bcousson@baylibre.com>
CC: Tony Lindgren <tony@atomide.com>
CC: Mugunthan V N <mugunthanvnm@ti.com>
This patch adds qspi nodes for am43xx SOC devices.
Enable
- USB PHY
- USB
for am43x-epos-evm
Acked-by: Felipe Balbi <balbi@ti.com>
