path: root/arch/arm/boot/dts/am57xx-cl-som-am57x.dts
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-12ARM: dts: dra7: Separate AM57 dtsi filesRoger Quadros
AM5 and DRA7 SoC families have different set of modules in them so the SoC sepecific dtsi files need to be separated. e.g. Some of the major differences between AM576 and DRA76 DRA76x AM576x USB3 x USB4 x ATL x VCP x MLB x ISS x PRU-ICSS1 x PRU-ICSS2 x This patch only deals with disabling USB3, USB4 and ATL for AM57 variants. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-09-20ARM: dts: ti: Fix SPI and I2C bus warningsRob Herring
dtc has new checks for I2C and SPI buses. Fix the warnings in node names and unit-addresses. arch/arm/boot/dts/am437x-idk-evm.dtb: Warning (spi_bus_bridge): /ocp@44000000/qspi@47900000: node name for SPI buses should be 'spi' arch/arm/boot/dts/am437x-sk-evm.dtb: Warning (spi_bus_bridge): /ocp@44000000/qspi@47900000: node name for SPI buses should be 'spi' arch/arm/boot/dts/am43x-epos-evm.dtb: Warning (spi_bus_bridge): /ocp@44000000/qspi@47900000: node name for SPI buses should be 'spi' arch/arm/boot/dts/omap3-n9.dtb: Warning (i2c_bus_reg): /ocp@68000000/i2c@48060000/ak8975@0f: I2C bus unit address format error, expected "f" arch/arm/boot/dts/am335x-osd3358-sm-red.dtb: Warning (i2c_bus_reg): /ocp/i2c@44e0b000/pressure@78: I2C bus unit address format error, expected "76" arch/arm/boot/dts/am335x-boneblack.dtb: Warning (i2c_bus_reg): /ocp/i2c@44e0b000/tda19988: I2C bus unit address format error, expected "70" arch/arm/boot/dts/am335x-boneblack-wireless.dtb: Warning (i2c_bus_reg): /ocp/i2c@44e0b000/tda19988: I2C bus unit address format error, expected "70" arch/arm/boot/dts/am335x-sancloud-bbe.dtb: Warning (i2c_bus_reg): /ocp/i2c@44e0b000/tda19988: I2C bus unit address format error, expected "70" arch/arm/boot/dts/am571x-idk.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/am572x-idk.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/am574x-idk.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/am57xx-cl-som-am57x.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/am57xx-sbc-am57x.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/dra72-evm.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/dra72-evm-revc.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/dra76-evm.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/dra7-evm.dtb: Warning (spi_bus_bridge): /ocp/qspi@4b300000: node name for SPI buses should be 'spi' arch/arm/boot/dts/am335x-pdu001.dtb: Warning (spi_bus_reg): /ocp/spi@481a0000/cfaf240320a032t: SPI bus unit address format error, expected "0" arch/arm/boot/dts/keystone-k2g-evm.dtb: Warning (spi_bus_bridge): /soc@0/qspi@2940000: node name for SPI buses should be 'spi' arch/arm/boot/dts/keystone-k2g-ice.dtb: Warning (spi_bus_bridge): /soc@0/qspi@2940000: node name for SPI buses should be 'spi' Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Santosh Shilimkar <ssantosh@kernel.org> Cc: linux-omap@vger.kernel.org Signed-off-by: Rob Herring <robh@kernel.org> [tony@atomide.com: fixed mode to 644 for am335x-osd3358-sm-red.dts while at it] Signed-off-by: Tony Lindgren <tony@atomide.com>
2018-09-20ARM: dts: am57xx-cl-som-am57x: get rid of phy_id propertyGrygorii Strashko
The phy_id property is deprecated and phy-handle has to be used instead. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-08-31ARM: dts: am572x: Add missing unit name to memory nodesJavier Martinez Canillas
This patch fixes the following DTC warnings: "Node /memory has a reg or ranges property, but no unit name" Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-08-15ARM: dts: am335x/437x/57xx: remove unneeded unit name for gpio-leds nodesJavier Martinez Canillas
This patch fixes the following DTC warnings for many boards: "Node /leds/led@1 has a unit name, but no reg property" Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-04-11ARM: dts: omap: remove unneeded unit name for sound nodesJavier Martinez Canillas
This patch fixes the following DTC warning: "sound@0 has a unit name, but no reg property" Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-03-20Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Arnd Bergmann: "These are all the updates to device tree files for 32-bit platforms, plus a couple of related 64-bit updates: New SoC support: - Allwinner A83T - Axis Artpec-6 SoC - Mediatek MT7623 SoC - TI Keystone K2G SoC - ST Microelectronics stm32f469 New board or machine support: - ARM Juno R2 - Buffalo Linkstation LS-QVL and LS-GL - Cubietruck plus - D-Link DIR-885L - DT support for ARM RealView PB1176 and PB11MPCore - Google Nexus 7 - Homlet v2 - Itead Ibox - Lamobo R1 - LG Optimus Black - Logicpd dm3730 - Raspberry Pi Model A Other changes include - Lots of updates for Qualcomm APQ8064, MSM8974 and others - Improved support for Nokia N900 and other OMAP machines - Common clk support for lpc32xx - HDLCD display on ARM - Improved stm32f429 support - Improved Renesas device support, r8a779x and others - Lots of Rockchip updates - Samsung cleanups - ADC support for Atmel SAMA5D2 - BCM2835 (Raspberry Pi) improvements - Broadcom Northstar Plus enhancements - OMAP GPMC rework - Several improvements for Atmel SAMA5D2 / Xplained - Global change to remove inofficial "arm,amba-bus" compatible string" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (350 commits) ARM, ARM64: dts: drop "arm,amba-bus" in favor of "simple-bus" ARM: dts: artpec: dual-license on artpec6.dtsi ARM: dts: ux500: add synaptics RMI4 for Ux500 TVK DT arm64: dts: juno/vexpress: fix node name unit-address presence warnings arm64: dts: foundation-v8: add SBSA Generic Watchdog device node ARM: dts: at91: sama5d2 Xplained: add leds node ARM: dts: at91: sama5d2 Xplained: add user push button ARM: dts: at91: sama5d2 Xplained: set pin muxing for usb gadget and usb host ARM: dts: stm32f429: Enable Ethernet on Eval board ARM: dts: omap3-sniper: TWL4030 keypad support Revert "ARM: dts: DRA7: Add dt nodes for PWMSS" ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND ARM: dts: dm814x: dra62x: Fix NAND device nodes ARM: dts: stm32f429: Add Ethernet support ARM: dts: stm32f429: Add system config bank node ARM: dts: at91: sama5d2: add nand0 and nfc0 nodes ARM: dts: at91: sama5d2: add dma properties to UART nodes ARM: dts: at91: sama5d2 Xplained: Correct the macb irq pinctrl node ARM: dts: exynos: Don't overheat the Odroid XU3-Lite on high load ARM: dts: exynos: Add cooling levels for Exynos5422/5800 CPUs ...
2016-03-02Merge tag 'omap-for-v4.6/dt-pt2' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt Pull "Part 2 of device tree changes for omaps for v4.6 merge window" from Tony Lindgren: - A series of GPMC related interrupt changes from Rogeq Quadros <rogerq@ti.com> to prepare adding interrupt support to the NAND driver - Add RTC support for ti81xx - Correct LogicPD Torpedo mode description - Add basic support for LG Optimus Black phone in several patches by Paul Kocialkowski <contact@paulk.fr> - Change address-cells for dra7 for LPAE - Add TBCLK for PWMSS on dra7 * tag 'omap-for-v4.6/dt-pt2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (21 commits) ARM: dts: omap3-sniper: TWL4030 keypad support Revert "ARM: dts: DRA7: Add dt nodes for PWMSS" ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND ARM: dts: dm814x: dra62x: Fix NAND device nodes ARM: dts: DRA7: Add dt nodes for PWMSS ARM: dts: DRA7: Add TBCLK for PWMSS ARM: dts: DRA7: change address-cells and size-cells ARM: dts: omap3-sniper: USB OTG support ARM: dts: LG Optimus Black codename sniper basic support ARM: dts: dm3730-torpedo-devkit: Add "Wireless" to model ARM: dts: Add RTC entry for dm816x ARM: dts: Add RTC entry for dm814x and dra62x ARM: dts: omap3: Fix NAND device nodes ARM: dts: dm8168-evm: ARM: dts: Disable wait pin monitoring for NAND ARM: dts: dm816x: Fix NAND device nodes ARM: dts: am335x: Disable wait pin monitoring for NAND ARM: dts: am335x: Fix NAND device nodes ARM: dts: am437x: Disable wait pin monitoring for NAND ARM: dts: am437x: Fix NAND device nodes ARM: dts: dra7: Remove redundant nand property ...
2016-02-29ARM: dts: DRA7: change address-cells and size-cellsLokesh Vutla
DRA7 SoC has the capability to support DDR memory upto 4GB. In order to represent this in memory dt node, the address-cells and size cells should be 2. So, changing the address-cells and size-cells to 2 and updating the memory nodes accordingly. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-02-10ARM: dts: am335x/am57xx: replace gpio-key,wakeup with wakeup-source propertySudeep Holla
Commit 3efda00129bd ("ARM: dts: am335x: replace gpio-key,wakeup with wakeup-source property") replaces all the legacy "gpio-key,wakeup" with the unified "wakeup-source" property to prevent any further copy-paste duplication. However couple of use of these legacy property sneaked in during the merge window. This patch replaces them too. Cc: "Benoît Cousson" <bcousson@baylibre.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-01-27ARM: dts: am57xx: sbc-am57x: correct Eth PHY settingsDmitry Lifshitz
Update Eth PHY settings to make it possible to run both phys at 1Gbps. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-01-27ARM: dts: am57xx: cl-som-am57x: fix CPSW EMAC pinmuxDmitry Lifshitz
Fix CPSW EMAC pinmux Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-01-27ARM: dts: am57xx: cl-som-am57x: update SPI Flash frequencyDmitry Lifshitz
On-board SPI flash cat act at 48Mhz SPI bus frequency. Update the DT frequency property. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-01-27ARM: dts: am57xx: cl-som-am57x: set HOST mode for USB2Dmitry Lifshitz
Setup USB2 to act in "HOST" mode by default. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: skip resetting ETH PHYsDmitry Lifshitz
ETH PHYs setup on CL-SOM-AM57X is established in U-Boot along with bringing them out of reset. This is done by toggling GPIOs belonging to GPIO2/3 controllers on AM57xx. Skip resetting ETH PHYs, by adding "ti,no-reset-on-init" to GPIO2/3 controllers DT nodes. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add analog audio supportDmitry Lifshitz
Add analog audio DT nodes: 1. simple-audio-card node 2. wm8731 codec node 3. MCASP3 pinmux Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add touchscreen supportDmitry Lifshitz
Add ADS7846 touchscreen support. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add USB supportDmitry Lifshitz
Add USB support. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add dual EMAC supportDmitry Lifshitz
Add dual EMAC support. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add spi-flash supportDmitry Lifshitz
On-board spi-flash chip is used as a main boot device. Add spi-flash chip support (over QSPI bus). Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add eMMC supportDmitry Lifshitz
CM-SOM-AM57X has two options of main storage devices - eMMC or NAND. Add eMMC chip support (over MMC2 bus). Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add EEPROM supportDmitry Lifshitz
On-board EEPROM chip is used for storing a board production info. Add module EEPROM support (over I2C4 bus). Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add I2C3 supportDmitry Lifshitz
Enable I2C3 bus and add appropriate pinmux. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: dts: add RTC supportDmitry Lifshitz
Add EM3027 RTC chip support (over I2C4 bus). Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-12-03ARM: dts: am57xx: cl-som-am57x: add basic module supportDmitry Lifshitz
Add support for CompuLab CM-SOM-AM57X board. CL-SOM-AM57x is a miniature System-on-Module (SoM) based on TI Sitara AM57x ARM Cortex-A15 System-on-Chip family. https://www.compulab.co.il/products/computer-on-modules/cl-som-am57x-ti-am5728-am5718-system-on-module/ Add basic DT support for standalone module (without a carrier board): * Memory configuration * Heartbeat led * I2C1 and I2C4 * PMIC * SATA Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
