path: root/arch/arm/boot/dts/animeo_ip.dts
2014-07-09ARM: at91/dt: animeo_ip: define crystals frequenciesAlexandre Belloni
Define Somfy Animeo IP main and slow crystals frequencies. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-12-09ARM: at91: Animeo IP: fix mtd partition tableJean-Christophe PLAGNIOL-VILLARD
Update to production one. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-05-17ARM: at91: dt: switch to standard GPIO flag defines.Jean-Christophe PLAGNIOL-VILLARD
2013-05-17ARM: at91: dt: use #include for all device treesJean-Christophe PLAGNIOL-VILLARD
to prepare the switch to the macro. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2013-02-07ARM: at91: Animeo IP: enable watchdog supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Sylvain FARGIER <sylvain.fargier@somfy.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2012-11-20ARM: at91: Animeo IP: add mmc supportJean-Christophe PLAGNIOL-VILLARD
2012-11-19ARM: at91: add Somfy Animeo IP board supportJean-Christophe PLAGNIOL-VILLARD
