path: root/arch/arm/boot/dts/arm-realview-eb.dtsi
2019-11-20ARM: dts: realview: Fix SPI controller node namesRob Herring
[ Upstream commit 016add12977bcc30f77d7e48fc9a3a024cb46645 ] SPI controller nodes should be named 'spi' rather than 'ssp'. Fixing the name enables dtc SPI bus checks. Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2016-09-09ARM: dts: fix RealView EB SMSC ethernet versionLinus Walleij
The ethernet version in the earlier RealView EB variants is LAN91C111 and not LAN9118 according to ARM DUI 0303E "RealView Emulation Baseboard User Guide" page 3-57. Make sure that this is used for the base variant of the board. As the DT bindings for LAN91C111 does not specify any power supplies, these need to be deleted from the DTS file. Fixes: 2440d29d2ae2 ("ARM: dts: realview: support all the RealView EB board variants") Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-04ARM: dts: realview: support all the RealView EB board variantsLinus Walleij
The ARM RealView Evaluation Baseboards are basically these: - The original ARMv5 EB board with an ARM926EJ-S, ARM1136 or ARM1176 core tile here described in arm-realview-eb.dts no matter which of these core tiles is being used. This can be emulated by QEMU "realview-eb" machine, which by default will have the ARM926EJ-S core tile. - The same board with one of three MPCore Core tiles: ARM11MPCore, not to be confused with the similar ARM PB11MPCore ARM11MPCore test system. This exist in two revisions: - Revision A modeled in arm-realview-eb-11mp.dts - Revision B modeled arm-realview-eb-11mp-revb.dts Revision B can be emulated by the QEMU "realview-eb-mpcore" machine, but to match the hardware also the argument -smp cpus=4 must be passed so that it has four CPU cores, like the hardware. There is also evidently from the code in the kernel a Cortex-A9 core tile for the EB, and this is modeled in arm-realview-eb-a9mp.dts based on the kernel boardfile. I have not found a user guide for this EB core tile on the ARM website and it seems uncommon. It is however included for completeness. Cc: Pawel Moll <pawel.moll@arm.com> Cc: Peter Maydell <peter.maydell@linaro.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
