This defines the CLCD block in the PB1176 and adds a standard
640x480 VGA panel to the device tree.
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Rob Herring <robh@kernel.org>
This adds the Versatile I2C adapter and the Dallas DS1338
RTC on it to the PB1176 device tree.
The PB1176 device tree was missing the SMSC9118 ethernet adapter,
so add it. Since this peripheral is not in either development
chip but on the board itself, it gets defined in the root node
of the device tree.
The USB host controller was missing from the device tree so add
it. This device is not inside either the development chip or the
FPGA but mounted on the board, so it ends up in the root node of
the device tree.
The device tree was missing the definition of the AACI
Advanced Audio Codec Interface, so add it. Tested on the hardware
and it works.
This adds the five ICST307 clocks to the device tree, so we
can use these with e.g. CLCD.
This adds the flash memories and ROM to the PB1175 DTS file.
The secure flash is marked as "disabled" by default so as to
protect the user from overwriting the boot monitor.
The Integrators and the RealView use simple MFD devices with register bit
LEDs as subnodes, update these to use the "simple-mfd" compatible property
so that subdevices get spawned from the MFD nexi.
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Mark Rutland <mark.rutland@arm.com>
This adds the MMC/SD card reader (MMCI) block to the
RealView PB1176 DTS file. Add a special MCLK derived clock
and a fixed regulator to represent the 3.3V rail hardwired
to the MMC reader on the board.
This adds the Keyboard Mouse Interface (KMI) blocks to the
PB1176 DTS file, and defines the special KMI clock derived
from the 24 MHz chrystal.
This adds the UART4 found on the FPGA to the PB1176 DTS
file.
Add the PL022 SSP/SPI block to the PL1176 DTS file, also
define the separate SSPCLK clock derived from the 24MHz
chrystal.
The PB1176 has two PL031 RTC clocks, one in the devchip and one
in the FPGA. Add them to the device tree.
Extend the PB1176 device tree with the character LCD device.
This adds the PL061 GPIO instances found on the PB1176 devchip
and the FPGA to the DTS file.
This creates a node in the device tree to hold the FPGA devices
as a "simple-bus" and moves the GIC found on the FPGA to this
node, so it reflects the actual topology of the system.
As a first example, add device tree and bindings for the
RealView PB1176.
