This adds the MMC/SD card reader (MMCI) block to the
RealView PB1176 DTS file. Add a special MCLK derived clock
and a fixed regulator to represent the 3.3V rail hardwired
to the MMC reader on the board.
This adds the Keyboard Mouse Interface (KMI) blocks to the
PB1176 DTS file, and defines the special KMI clock derived
from the 24 MHz chrystal.
This adds the UART4 found on the FPGA to the PB1176 DTS
file.
Add the PL022 SSP/SPI block to the PL1176 DTS file, also
define the separate SSPCLK clock derived from the 24MHz
chrystal.
The PB1176 has two PL031 RTC clocks, one in the devchip and one
in the FPGA. Add them to the device tree.
Extend the PB1176 device tree with the character LCD device.
This adds the PL061 GPIO instances found on the PB1176 devchip
and the FPGA to the DTS file.
This creates a node in the device tree to hold the FPGA devices
as a "simple-bus" and moves the GIC found on the FPGA to this
node, so it reflects the actual topology of the system.
As a first example, add device tree and bindings for the
RealView PB1176.
