The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
memory has a reg property so the unit name should contain an address.
PCIe has a ranges property, so the unit name should contain an address.
Take the opportunity to use the node label instead of the full name.
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
DNS-327L is a 2-bay NAS with the following specs:
- 512MiB RAM
- 128MiB NAND Flash
- 1 GbE interface (Marvell PHY)
- 1 rear USB 3.0 port (via PCIe USB 3.0 controller)
- 2 internal SATA ports handled by the Armada 370:
uses 2 gpios for power control
- two front 2-color leds (amber + white) for both discs,
controlled by the SoC
- One white LED handled by SoC (USB)
- 3 buttons. Power handled by weltrend, USB and
RESET (on the bottom) are wired via GPIOs
- Unidentified i2c device at address 0x13 (via i2cdetect)
- UART0 providing serial console
- Weltrend MCU serving for RTC, temperature, fan control,
and power button handling interfaced via UART1
(Handled via userspace dns320l-daemon)
Signed-off-by: Andrew Andrianov <andrew@ncrmnt.org>
Acked-by: Andrew Lunn <andrew@lunn.ch>
