The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
memory has a reg property so the unit name should contain an address.
PCIe has a ranges property, so the unit name should contain an address.
Take the opportunity to use the node label instead of the full name.
MDIO has a reg property so the unit name should contain an address.
Since the commit a526973e0291 ("pinctrl: mvebu: Fix mapping of pin
63 (gpo -> gpio)"), the mpp63 is no more declared as a GPO but is a
GPIO. Even if in the datasheet this pin is described as GPO, the
experience of the D-Link DNS-327L board shows that it can be used as a
GPIO.
This commits generated warnings for the board using this pin as gpo, with
this patch the dts are fixed by using the new function (gpio) instead of
the old one.
The binding documentation has also been updated accordingly.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Acked-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Ryan Press <ryan@presslab.us>
Acked-by: Simon Baatz <gmbnomis@gmail.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
What was done by Sebastian in 264a05e19bf5 ("ARM: mvebu: armada-xp:
Add node alias to pinctrl and add base address") and 01c434225ee6
("ARM: mvebu: armada-xp: Use pinctrl node alias") can also be done for
Armada 370, i.e.
- Rename Armada 370 pinctrl node to pin-ctrl with its address encoded
- Add a node alias to access the pinctrl node easily.
- use the newly available alias in existing Armada 370 .dts files
We can even go a bit further by putting the pinctrl node definition in
armada-370-xp.dtsi, with only its reg property defined. This allows us
to then also use the newly defined node alias in armada-xp.dtsi,
armada-370.dtsi.
Suggested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Suggested-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Link: https://lkml.kernel.org/r/b54eb45e5242728aace3ce8aef2eae4251f8dea3.1416613429.git.arno@natisbad.org
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This commit adds the required pin muxing for the network interfaces and
the MDIO interface to be properly initialized. For instance, this makes
it possible for a bootloader to initialize and access the network interfaces.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Link: https://lkml.kernel.org/r/1407759281-11513-3-git-send-email-ezequiel.garcia@free-electrons.com
Now that the Armada 370/375/38x/XP SoC-level Device Tree files have
the proper "clocks" property in their UART controllers node, it is no
longer useful to have the clock-frequency property defined in the
board-level Device Tree files.
Therefore, this commit gets rid of all the useless 'clock-frequency'
properties.
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1397806908-7550-5-git-send-email-thomas.petazzoni@free-electrons.com
Instead of harcoding 0 and 1 for the gpio specifications in the Armada
370/XP boards, use the <dt-bindings/gpio/gpio.h> header file and its
GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW definitions.
The Armada 370 Mirabox has a NAND flash, so enable it in the devicetree
and add the partitions as prepared in the factory images.
In order to skip the driver's custom device detection and use only
ONFI detection, the "marvell,keep-config" parameter is used.
This is needed because we have no support for setting the timings parameters yet.
Generally, power LEDs should indicate when power is applied, and go out
once power is removed. _Not_ annoy the developer with migraine-inducing
blinking reminicent of some badly animated television series designed to
sell sugar to children.
On a more serious note, most of these OS-specific properties aren't
necessary and should be removed. I left two that are legitimately tying
disk LEDs to disk activity. Other than that, we keep the state the
bootloader left them in until userspace changes the state via sysfs.
Now that mbus has been added to the device tree, it's possible to
move the PCIe nodes out of internal registers, placing it directly
below the mbus. This is a more accurate representation of the
hardware.
Moving the PCIe nodes, we now need to introduce an extra cell to
encode the window target ID and attribute. Since this depends on
the PCIe port, we split the ranges translation entries, to correspond
to each MBus window.
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
In order to access the SoC BootROM, we need to declare a mapping
(through a ranges property). The mbus driver will use this property
to allocate a suitable address decoding window.
The Armada 370/XP SoC family has a completely configurable address
space handled by the MBus controller.
This patch introduces the device tree layout of MBus, making the
'soc' node as mbus-compatible.
Since every peripheral/controller is a child of this 'soc' node,
this makes all of them sit behind the mbus, thus describing the
hardware accurately.
A translation entry has been added for the internal-regs mapping.
This can't be done in the common armada-370-xp.dtsi because A370
and AXP have different addressing width.
In order to prepare the switch to the standard MMC device tree parser
for mvsdio, adapt all current uses of mvsdio in the dts files to the
standard format.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Introduce a 'internal-regs' subnode, under which all devices are
moved. This is not really needed for now, but will be for the
mvebu-mbus driver. This generates a lot of code movement since it's
indenting by one more tab all the devices. So it was a good
opportunity to fix all the bad indentation.
This conversion will allow to keep 32 bits addresses for the internal
registers whereas the memory of the system will be 64 bits.
Later it will also ease the move of the mvebu-mbus driver to the
device tree support.
pulling in mvebu branches which changes armada*.dts? files for LPAE changes
mvebu fixes for v3.9 round 3
- Kirkwood
- a couple of small fixes for the Iomega ix2-200 board (ether and led)
- mvebu
- allow GPIO button to work on Mirabox when running SMP
The Globalscale Mirabox platform uses one PCIe interface for an
available mini-PCIe slot, and the other PCIe interface for an internal
USB 3.0 controller. We add the necessary Device Tree informations to
enable those two interfaces.
Add the three external LED definitions to the device tree file on
the Mirabox.
The Mirabox user guide calls out one as a power LED, and the other
two are defined for WiFi, but as the current mwifiex drivers don't
have LED support, we make them status LEDs.
These have been tested working by writing to the appropriate
/sys/class/leds trigger.
Signed-off-by: Ryan Press <ryan@presslab.us>
Tested-by: Neil Greatorex <neil@fatboyfat.co.uk>
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
The previous configuration used the wrong "clk" pin. Without this
change mv_sdio worked because the bootloader would set the pin up, but
with a bootloader that does not set the pin, mv_sdio fails to detect any
card.
I have tested this change using a mwifiex_sdio wireless network adapter
over the SDIO interface.
The Globalscale Mirabox platform can be connected to the JTAG/GPIO box
through the Multi-IO port. The GPIO box use the NXP PCA9505 I/O port
expansion IC to provide 40-bit parallel input/output GPIOs. This patch
enable the use of this expander on the Mirabox.
This patch activates every USB port provided by each SoC.
Except for Armada XP Openblocks AX3-4 board,
where we enable only the first two USB ports
until we have more information on the third one usage.
Cc: Lior Amsalem <alior@marvell.com>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Tested-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Tested-by: Florian Fainelli <florian@openwrt.org>
The Globalscale Mirabox uses the SDIO interface of the Armada 370 to
connect to a Wifi/Bluetooth SD8787 chip, so we enable the SDIO
interface of this board in its Device Tree file.
nodes
The mvneta driver for the Marvell Armada 370/XP Ethernet devices has
gained proper clock framework integration, and the corresponding
Device Tree nodes now have a correct 'clocks' pointer.
The 'clock-frequency' properties in the various .dts files for Armada
370/XP boards have therefore become useless.
The Globalscale Mirabox platform has two Ethernet interfaces,
connected to the SoC with a RGMII interface.
This platform, available from Globalscale has an Armada 370. For now,
only the serial port is supported. Support for network, USB and other
peripherals will be added as drivers for them become available for
Armada 370 in mainline.
This is 3.8 material.
Changes from original version posted by Gregory:
* Renamed .dts file to armada-370-mirabox.dts
* Change compatible string to 'globalscale,mirabox'
* Remove compatible string from armada-370-xp.c
* Removed references to MBX0001
