Since the commit a526973e0291 ("pinctrl: mvebu: Fix mapping of pin
63 (gpo -> gpio)"), the mpp63 is no more declared as a GPO but is a
GPIO. Even if in the datasheet this pin is described as GPO, the
experience of the D-Link DNS-327L board shows that it can be used as a
GPIO.
This commits generated warnings for the board using this pin as gpo, with
this patch the dts are fixed by using the new function (gpio) instead of
the old one.
The binding documentation has also been updated accordingly.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
property
Though the driver will continue to check for and support the legacy
"isil,irq2-can-wakeup-machine" boolean property to wakeup source,
"wakeup-source" is the new standard binding.
This patch replaces the legacy "isil,irq2-can-wakeup-machine" with the
unified "wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
By default, armada-370-xp.dtsi file has internal RTC enabled.
NETGEAR ReadyNAS 102, 104 and 2120 all use an Intersil ISL12057
I2C RTC chip. The internal RTC not being disabled in the .dts
files of those devices result in the following useless first
line during boot:
[ 4.500056] rtc-mv d0010300.rtc: internal RTC not ticking
[ 4.505684] i2c /dev entries driver
[ 4.513246] rtc-isl12057 0-0068: rtc core: registered rtc-isl12057 as rtc0
This patch marks Armada internal RTC as disabled in individual .dts
files of those devices.
Reported-by: TuxOholic <tuxoholic@hotmail.de>
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
Now that alarm support for ISL12057 chip is available w/ the specific
"isil,irq2-can-wakeup-machine" property, let's use that feature of the
driver dedicated to NETGEAR ReadyNAS 102, 104 and 2120 specific routing of
RTC Alarm IRQ#2 pin; on those devices, this pin is not connected to the
SoC but to a PMIC, which allows the device to be powered up when RTC alarm
rings.
For that to work, the chip needs to be explicitly marked as a device
wakeup source using this "isil,irq2-can-wakeup-machine" boolean property.
This makes 'wakealarm' sysfs entry available to configure the alarm.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Peter Huewe <peter.huewe@infineon.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: Darshana Padmadas <darshanapadmadas@gmail.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Landley <rob@landley.net>
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Uwe Kleine-König <uwe@kleine-koenig.org>
The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Acked-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
What was done by Sebastian in 264a05e19bf5 ("ARM: mvebu: armada-xp:
Add node alias to pinctrl and add base address") and 01c434225ee6
("ARM: mvebu: armada-xp: Use pinctrl node alias") can also be done for
Armada 370, i.e.
- Rename Armada 370 pinctrl node to pin-ctrl with its address encoded
- Add a node alias to access the pinctrl node easily.
- use the newly available alias in existing Armada 370 .dts files
We can even go a bit further by putting the pinctrl node definition in
armada-370-xp.dtsi, with only its reg property defined. This allows us
to then also use the newly defined node alias in armada-xp.dtsi,
armada-370.dtsi.
Suggested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Suggested-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/b54eb45e5242728aace3ce8aef2eae4251f8dea3.1416613429.git.arno@natisbad.org
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
Currently there is a wild mixture of isl, isil, and intersil
compatibles in the kernel. At this point, changing the vendor
symbol to the most often used variant, which is equal to the
NASDAQ symbol, isil, should not hurt.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Link: https://lkml.kernel.org/r/1410167960-554-4-git-send-email-p.zabel@pengutronix.de
The bootloader on the Netgear ReadyNAS RN104 uses Hardware BCH
ECC (strength = 4), while the pxa3xx NAND driver by default uses
Hamming ECC (strength = 1).
This patch changes the ECC mode on these machines to match that
of the bootloader and of the stock firmware. That way, it is
now possible to update the kernel from userland (e.g. using
standard tools from mtd-utils package); u-boot will happily
load and boot it.
The issue was initially reported and fixed by Ben Pedell for
RN102. The RN104 shares the same Hynix H27U1G8F2BTR NAND
flash and setup. This patch is based on Ben's fix for RN102.
Fixes: 0373a558bd79 ("ARM: mvebu: Enable NAND controller in ReadyNAS 104 .dts file")
Cc: <stable@vger.kernel.org> # v3.14+
Link: https://lkml.kernel.org/r/920c7e7169dc6aaaa3eb4bced2336d38e77b8864.1410035142.git.arno@natisbad.org
This commit adds the required pin muxing for the network interfaces and
the MDIO interface to be properly initialized. For instance, this makes
it possible for a bootloader to initialize and access the network interfaces
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Link: https://lkml.kernel.org/r/1407759281-11513-6-git-send-email-ezequiel.garcia@free-electrons.com
Now that the Armada 370/375/38x/XP SoC-level Device Tree files have
the proper "clocks" property in their UART controllers node, it is no
longer useful to have the clock-frequency property defined in the
board-level Device Tree files.
Therefore, this commit gets rid of all the useless 'clock-frequency'
properties.
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1397806908-7550-5-git-send-email-thomas.petazzoni@free-electrons.com
Now that support for Intersil ISL12057 RTC chip is available
upstream, let's enable it in NETGEAR ReadyNAS 104 .dts file
so that the device stop believing it's the 70's.
Now that NAND controller support is available for Armada 370
(cb28e2537a6f: ARM: mvebu: Add support for NAND controller in
Armada 370/XP), this patch enables support for ReadyNAS 104 and
defines default partition layout as delivered by NETGEAR.
As described in similar commits 2be2bc39c6f0 (ARM: mvebu: Enable
NAND controller in Armada XP GP board) and d8c552dddfbf (ARM:
mvebu: Enable NAND controller in Armada 370 Mirabox),
"marvell,keep-config" parameter is used as current support does
not allow for setting of timing parameters yet.
The patch does some cleanup work on NETGEAR ReadyNAS 104 .dts
file. Changes are listed below:
- Completed conversion from value to macros for GPIO voltage level
- Converted all numeric input key values to macros
- Fixed all node names and labels to use respectively '-' and '_'
- Made button names more explicit
- Changed order of included files from general to local
- Removed useless clocks and gpio-keys properties
- Document ethernet PHY (Marvell 88E1318) via a comment
- Made G762 clock node name unique by including g762 in it
NETGEAR ReadyNAS 104 has a NXP PCA9554 I2C to GPIO chip. Among the 8 GPIO
lines the chip makes available, four are used on the device to control
the SATA LEDs (the four remaining ones are used for SATA disk presence).
This patch adds DT entries for NXP PCA9554 and the four SATA GPIO LEDs.
Main hardware parts of the (Armada 370 based) NETGEAR ReadyNAS 104 are
supported by mainline kernel (USB 3.0 rear ports, USB 2.0 front port,
Gigabit controller and PHYs, serial port, LEDs, buttons, SATA ports,
G762 fan controller) and referenced in provided .dts file. Some additonal
work remains for:
- Intersil ISL12057 I2C RTC and Alarm chip: working driver but needs
to be splitted for submission of RTC part first;
- Front LCD (Winstar 1602G): driver needs to be written
- Armada NAND controller (to access onboard 128MB of NAND): support
being pushed by @free-electrons people
- 4 front SATA LEDs controlled via GPIO brought by NXP PCA9554:
driver is available upstream. Not referenced/tested yet.
but the device is usable w/o those.
