Utilize the new DSA binding, introduced with commit 8c5ad1d6179d ("net: dsa:
Document new binding"). The legacy binding node is kept included, but is marked
disabled.
Tested-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The gpio-key nodes do not have a reg property, so remove the address from
the unit name.
The dsa node does not have a reg property, so remove the address from the
unit name.
memory has a reg property so the unit name should contain an address.
PCIe has a ranges property, so the unit name should contain an address.
Take the opportunity to use the node label instead of the full name.
MDIO has a reg property so the unit name should contain an address.
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Florian Fainelli <florian@openwrt.org>
Acked-by: Simon Baatz <gmbnomis@gmail.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
What was done by Sebastian in 264a05e19bf5 ("ARM: mvebu: armada-xp:
Add node alias to pinctrl and add base address") and 01c434225ee6
("ARM: mvebu: armada-xp: Use pinctrl node alias") can also be done for
Armada 370, i.e.
- Rename Armada 370 pinctrl node to pin-ctrl with its address encoded
- Add a node alias to access the pinctrl node easily.
- use the newly available alias in existing Armada 370 .dts files
We can even go a bit further by putting the pinctrl node definition in
armada-370-xp.dtsi, with only its reg property defined. This allows us
to then also use the newly defined node alias in armada-xp.dtsi,
armada-370.dtsi.
Suggested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Suggested-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Link: https://lkml.kernel.org/r/b54eb45e5242728aace3ce8aef2eae4251f8dea3.1416613429.git.arno@natisbad.org
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
The 370 rd has a 7 port, mv88E6182 switch, connected to eth1. Add a
fixed-link subnode to the ethernet device tree node, to force
gigabit/full duplex. Add a dsa node, with describing the four used
ports. This requires adding an alias to the mdio node, so it can be
referenced as a phandle.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1415214121-29286-3-git-send-email-andrew@lunn.ch
Recent bootloader versions from Marvell that have DT support and
various other new features remap the internal registers at
0xf1000000. We have already done this change for most of the
development boards from Marvell, and this commit does this change for
the Marvell Armada 370 RD board.
Link: https://lkml.kernel.org/r/1410961539-10388-1-git-send-email-thomas.petazzoni@free-electrons.com
The Armada 370 RD has a GPIO controlled LED connected on MPP32, so
this commit adds the relevant hardware description to Armada 370 RD
Device Tree.
Link: https://lkml.kernel.org/r/1410429419-29820-3-git-send-email-thomas.petazzoni@free-electrons.com
The Armada 370 RD platform has a GPIO-controlled fan on MPP8, so this
commit adds the relevant hardware description to Armada 370 RD Device
Tree.
Link: https://lkml.kernel.org/r/1410429419-29820-2-git-send-email-thomas.petazzoni@free-electrons.com
This commit adds the required pin muxing for the network interfaces and
the MDIO interface to be properly initialized. For instance, this makes
it possible for a bootloader to initialize and access the network interfaces
Only the second network interface is pin muxed. The first network interface is
connected to the PHY using SGMII, which uses a dedicated SerDes lane.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Link: https://lkml.kernel.org/r/1407759281-11513-7-git-send-email-ezequiel.garcia@free-electrons.com
Now that the Armada 370/375/38x/XP SoC-level Device Tree files have
the proper "clocks" property in their UART controllers node, it is no
longer useful to have the clock-frequency property defined in the
board-level Device Tree files.
Therefore, this commit gets rid of all the useless 'clock-frequency'
properties.
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Link: https://lkml.kernel.org/r/1397806908-7550-5-git-send-email-thomas.petazzoni@free-electrons.com
Instead of harcoding keycodes specifications in the Armada 370/XP
boards, use the <dt-bindings/input/input.h> header file and its
keycode definitions.
Instead of harcoding 0 and 1 for the gpio specifications in the Armada
370/XP boards, use the <dt-bindings/gpio/gpio.h> header file and its
GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW definitions.
Marvell's Armada 370 Reference Design has a NAND flash, so enable it in
the devicetree and add the partitions as prepared in the factory images.
In order to skip the driver's custom device detection and use only ONFI
detection, the "marvell,keep-config" parameter is used. This is needed
because we have no support for setting the timings parameters yet.
The pcie-controller node needs to be relocated according the MBus
DT binding, since it's now a child of the mbus-compatible node.
In order to access the SoC BootROM, we need to declare a mapping
(through a ranges property). The mbus driver will use this property
to allocate a suitable address decoding window.
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
The Armada 370/XP SoC family has a completely configurable address
space handled by the MBus controller.
This patch introduces the device tree layout of MBus, making the
'soc' node as mbus-compatible.
Since every peripheral/controller is a child of this 'soc' node,
this makes all of them sit behind the mbus, thus describing the
hardware accurately.
A translation entry has been added for the internal-regs mapping.
This can't be done in the common armada-370-xp.dtsi because A370
and AXP have different addressing width.
The Armada 370 RD board has two internal mini-PCIe connectors. This
commit adds the necessary Device Tree informations to enable the usage
of those mini-PCIe connectors.
Cc: Florian Fainelli <florian@openwrt.org>
In order to prepare the switch to the standard MMC device tree parser
for mvsdio, adapt all current uses of mvsdio in the dts files to the
standard format.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Introduce a 'internal-regs' subnode, under which all devices are
moved. This is not really needed for now, but will be for the
mvebu-mbus driver. This generates a lot of code movement since it's
indenting by one more tab all the devices. So it was a good
opportunity to fix all the bad indentation.
This conversion will allow to keep 32 bits addresses for the internal
registers whereas the memory of the system will be 64 bits.
Later it will also ease the move of the mvebu-mbus driver to the
device tree support.
pulling in mvebu branches which changes armada*.dts? files for LPAE changes
mvebu fixes for v3.9 round 3
- Kirkwood
- a couple of small fixes for the Iomega ix2-200 board (ether and led)
- mvebu
- allow GPIO button to work on Mirabox when running SMP
The Marvell Armada 370 Reference Design board has a software-controlled
button on the front side, marked as "SW".
This patch adds minimal support for this button.
This patch modifies the Armada 370 Reference Design DTS file to enable
support for the two USB ports found on this board.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
The Armada 370 Reference Design board has one SD card slot, directly
connected to the SDIO IP of the SoC, so we enable this IP. there are no
GPIOs for card-detect and write-protect so we do not specify any.
This patch adds the DTS file to support the Marvell RD-A370-A1
(Reference Design board) also known as RD-88F6710 board. It is almost
entirely similar to the DB-A370 board except that the first Ethernet PHY
is SGMII-wired and the second is a switch which is RGMII-wired.
