path: root/arch/arm/boot/dts/armada-370-seagate-nas-4bay.dts
2018-03-27arm: dts: armada-*.dts: use SPDX-License-Identifier for most of the Armada ↵Gregory CLEMENT
based board Follow the recent trend for the license description, and also fix the wrongly stated X11 to MIT. As already pointed on the DT ML, the X11 license text [1] is explicitly for the X Consortium and has a couple of extra clauses. The MIT license text [2] is actually what the current DT files claim. [1] https://spdx.org/licenses/X11.html [2] https://spdx.org/licenses/MIT.html Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2016-11-19ARM: dts: armada-370: Fixup pcie DT warningsGregory CLEMENT
PCIe has a ranges property, so the unit name should contain an address. Take the opportunity to use the node label instead of the full name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370-xp: Fixup mdio DT warningGregory CLEMENT
MDIO has a reg property so the unit name should contain an address. Take the opportunity to use the node label instead of the full name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-10-12ARM: mvebu: add DT support for Seagate NAS 2 and 4-BayVincent Donnefort
This patch adds DT support for the Seagate NAS 2 and 4-Bay. Here are some information allowing to identify these devices: Product name | Seagate NAS 2-Bay | Seagate NAS 4-Bay Code name (board/PCB) | Dart 2-Bay | Dart 4-Bay Model name (case sticker) | SRPD20 | SRPD40 Material desc (product spec) | STCTxxxxxxx | STCUxxxxxxx Chipset list (common): - SoC Marvell Armada 370 88F6707, CPU @1.2GHz - SDRAM memory: 512MB DDR3 600MHz (16-bits bandwidth) - NAND flash 256MB, 8-bits (Micron MT29F2G08AAB or Hinyx H27U2G8F2CTR-BC) - 2 SATA II ports (SoC) - 1 Ethernet Gigabit ports (PHY Marvell 88E1518) - 2 USB3 host ports (PCIe controller ASM1042) - GPIO fan (4 speeds) - External I2C RTC (MCP7940NT) - 3 push buttons (power, backup and reset) - 2 SATA LEDs (bi-color, blue and red) - 1 power LED (bi-color, blue and red) Only on 4-Bay models: - 2 extra SATA III ports (PCIe AHCI controller Marvell 88SE9170) - 1 extra Ethernet Gigabit ports (PHY Marvell 88E1518) - I2C GPIO expander (PCA9554A) - 2 extra SATA LEDs (bi-color, blue and red) Note that support for the white SATA LEDs associated with HDDs 0 and 1 is missing. A dedicated LED driver is needed. Signed-off-by: Vincent Donnefort <vdonnefort@gmail.com> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
