path: root/arch/arm/boot/dts/armada-370-seagate-personal-cloud.dtsi
2016-11-19ARM: dts: armada-370-xp: Remove button address and fixup namesGregory CLEMENT
The gpio-key nodes do not have a reg property, so remove the address from the unit name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370-xp: Fixup memory DT warningGregory CLEMENT
memory has a reg property so the unit name should contain an address. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370: Fixup pcie DT warningsGregory CLEMENT
PCIe has a ranges property, so the unit name should contain an address. Take the opportunity to use the node label instead of the full name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370-xp: Fixup mdio DT warningGregory CLEMENT
MDIO has a reg property so the unit name should contain an address. Take the opportunity to use the node label instead of the full name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-08-08ARM: dts: mvebu: A37x/XP/38x/39x: Move SPI controller nodes into 'soc' nodeStefan Roese
This patch moves all Armada 370/XP/38x/39x SPI controller nodes from the 'internal-regs' node down into the 'soc' node. This is in preparation to enable the usage of the SPI direct access mode. A follow-up patch will add the static MBus mappings for the SPI devices into the 'reg' property of the SPI controller DT node. By moving these SPI controller nodes, this patch also makes use of the labels rather than keeping the tree structure. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Gregory CLEMENT <gregory.clement@free-electrons.com> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Mark Brown <broonie@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-10-12ARM: mvebu: add DT support for Seagate Personal CloudSimon Guinot
This patch adds DT support for the Seagate Personal Cloud 1 and 2-Bay. Here are some information allowing to identify these devices: Product name | Personal Cloud | Personal Cloud 2-Bay Code name (board/PCB) | Cumulus | Cumulus Max Model name (case sticker) | SRN21C | SRN22C Material desc (product spec) | STCRxxxxxxx | STCSxxxxxxx Chipset list: - SoC Marvell Armada 370 88F6707, CPU @1GHz - SDRAM memory: 512MB DDR3 667MHz (16-bits bandwidth) - SPI flash 1MB (Macronix MX25L8006E) - 1 or 2 SATA internal ports - 1 Ethernet Gigabit port (PHY Marvell 88E1518) - 1 USB3 host port (PCIe controller ASM1042) - 1 USB2 host port (SoC) - 2 push buttons (power and reset) - 1 SATA LED (bi-color, white and red) Note that support for the white SATA LED is missing. A dedicated LED driver is needed. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
