dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The Armada 385 Access Point Development board contains NAND FLSH which is
already enabled in existing dts. Nevertheless the default partition
description was missing.
Signed-off-by: Grzegorz Jaszczyk <jaz@semihalf.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The Armada 385 Access Point Development board contains USB port, which can
be handled by existing orion-ehci driver.
This patch moves all Armada 370/XP/38x/39x SPI controller nodes from the
'internal-regs' node down into the 'soc' node. This is in preparation
to enable the usage of the SPI direct access mode. A follow-up patch
will add the static MBus mappings for the SPI devices into the 'reg'
property of the SPI controller DT node.
By moving these SPI controller nodes, this patch also makes use of
the labels rather than keeping the tree structure.
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Mark Brown <broonie@kernel.org>
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
plus a couple of related 64-bit updates:
New SoC support:
- Allwinner A83T
- Axis Artpec-6 SoC
- Mediatek MT7623 SoC
- TI Keystone K2G SoC
- ST Microelectronics stm32f469
New board or machine support:
- ARM Juno R2
- Buffalo Linkstation LS-QVL and LS-GL
- Cubietruck plus
- D-Link DIR-885L
- DT support for ARM RealView PB1176 and PB11MPCore
- Google Nexus 7
- Homlet v2
- Itead Ibox
- Lamobo R1
- LG Optimus Black
- Logicpd dm3730
- Raspberry Pi Model A
Other changes include
- Lots of updates for Qualcomm APQ8064, MSM8974 and others
- Improved support for Nokia N900 and other OMAP machines
- Common clk support for lpc32xx
- HDLCD display on ARM
- Improved stm32f429 support
- Improved Renesas device support, r8a779x and others
- Lots of Rockchip updates
- Samsung cleanups
- ADC support for Atmel SAMA5D2
- BCM2835 (Raspberry Pi) improvements
- Broadcom Northstar Plus enhancements
- OMAP GPMC rework
- Several improvements for Atmel SAMA5D2 / Xplained
- Global change to remove inofficial "arm,amba-bus" compatible
string"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (350 commits)
ARM, ARM64: dts: drop "arm,amba-bus" in favor of "simple-bus"
ARM: dts: artpec: dual-license on artpec6.dtsi
ARM: dts: ux500: add synaptics RMI4 for Ux500 TVK DT
arm64: dts: juno/vexpress: fix node name unit-address presence warnings
arm64: dts: foundation-v8: add SBSA Generic Watchdog device node
ARM: dts: at91: sama5d2 Xplained: add leds node
ARM: dts: at91: sama5d2 Xplained: add user push button
ARM: dts: at91: sama5d2 Xplained: set pin muxing for usb gadget and usb host
ARM: dts: stm32f429: Enable Ethernet on Eval board
ARM: dts: omap3-sniper: TWL4030 keypad support
Revert "ARM: dts: DRA7: Add dt nodes for PWMSS"
ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND
ARM: dts: dm814x: dra62x: Fix NAND device nodes
ARM: dts: stm32f429: Add Ethernet support
ARM: dts: stm32f429: Add system config bank node
ARM: dts: at91: sama5d2: add nand0 and nfc0 nodes
ARM: dts: at91: sama5d2: add dma properties to UART nodes
ARM: dts: at91: sama5d2 Xplained: Correct the macb irq pinctrl node
ARM: dts: exynos: Don't overheat the Odroid XU3-Lite on high load
ARM: dts: exynos: Add cooling levels for Exynos5422/5800 CPUs
Since mvneta driver supports using hardware buffer management (BM), in
order to use it, board files have to be adjusted accordingly. This commit
enables BM on:
* A385-DB-AP - each port has its own pool for long and common pool for
short packets,
* A388-ClearFog - same as above,
* A388-DB - to each port unique 'short' and 'long' pools are mapped,
* A388-GP - same as above.
Moreover appropriate entry is added to 'soc' node ranges, as well as "okay"
status for 'bm' and 'bm-bppi' (internal SRAM) nodes.
[gregory.clement@free-electrons.com: add suppport for the ClearFog board]
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
This commit adds some comments to the Armada 385 AP Device Tree
description to indicate which Ethernet interface matches which
physical connector on the board.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Pull ARM DT updates from Olof Johansson:
"As usual, this is the massive branch we have for each release. Lots
of various updates and additions of hardware descriptions on existing
hardware, as well as the usual additions of new boards and SoCs.
This is also the first release where we've started mixing 64- and
32-bit DT updates in one branch.
(Specific details on what's actually here and new is pretty easy to
tell from the diffstat, so there's little point in duplicating listing
it here)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (499 commits)
ARM: dts: uniphier: add system-bus-controller nodes
ARM64: juno: disable NOR flash node by default
ARM: dts: uniphier: add outer cache controller nodes
arm64: defconfig: Enable PCI generic host bridge by default
arm64: Juno: Add support for the PCIe host bridge on Juno R1
Documentation: of: Document the bindings used by Juno R1 PCIe host bridge
ARM: dts: uniphier: add I2C aliases for ProXstream2 boards
dts/Makefile: Add build support for LS2080a QDS & RDB board DTS
dts/ls2080a: Add DTS support for LS2080a QDS & RDB boards
dts/ls2080a: Update Simulator DTS to add support of various peripherals
dts/ls2080a: Remove text about writing to Free Software Foundation
dts/ls2080a: Update DTSI to add support of various peripherals
doc: DTS: Update DWC3 binding to provide reference to generic bindings
doc/bindings: Update GPIO devicetree binding documentation for LS2080A
Documentation/dts: Move FSL board-specific bindings out of /powerpc
Documentation: DT: Add entry for FSL LS2080A QDS and RDB boards
arm64: Rename FSL LS2085A SoC support code to LS2080A
arm64: Use generic Layerscape SoC family naming
ARM: dts: uniphier: add ProXstream2 Vodka board support
ARM: dts: uniphier: add ProXstream2 Gentil board support
This commit enables standby support on Armada 385 DB-AP board, because
the PM initalization routine requires "marvell,armada380" compatible
string for all Armada 38x-based platforms.
Beside the compatible "marvell,armada38x" was wrong and should be fixed
in the stable kernels too.
[gregory.clement@free-electrons.com: add information, about the fixes]
Fixes: e5ee12817e9ea ("ARM: mvebu: Add Armada 385 Access Point
Development Board support")
Cc: <stable@vger.kernel.org>
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace
"nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor"
binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op according
to the datasheets.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
The Armada 385 AP board has a USB3 port exposed that uses a GPIO to drive the
VBUS line. Enable the needed drivers to support this.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
The Armada 385 Access Point Development Board has a 1GB NAND SLC chip from
Micron as its main storage. Enable it.
The A385-AP is a board produced by Marvell that holds 3 mPCIe slot, a 16MB
SPI-NOR, 3 Gigabit Ethernet ports, USB3 and NAND flash storage.
[gregory.clement@free-electrons.com: switch the license to the dual
X11/GPL with the agreement of the author]
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
