path: root/arch/arm/boot/dts/armada-385-linksys-caiman.dts
2015-05-25ARM: mvebu: add support for the new Armada 385 based Linksys boardsImre Kaloz
This patch adds support for the Linksys WRT1200AC (Caiman) and the Linksys WRT1900AC v2 (Cobra). Both boards have: - 2 Marvell 88W8864 radios - 1 USB 3.0 port - 1 USB 2.0/eSATAp port - 2 Ethernet interfaces connected to a 88E6176 switch (1x WAN + 4x LAN) - 128MB NAND flash - 512MB RAM gregory.clement@free-electrons.com: use serial0:115200n8 in stdout-path and remove the bootargs part in the chosen node Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
