dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The SPI controller in the arch/arm/boot/dts/armada-39x.dtsi file has moved
to a different location in the hierarchy, which breaks the overrides
in the board specific file:
Warning (reg_format): "reg" property in /soc/internal-regs/spi@10680/spi-flash@1 has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
Warning (avoid_default_addr_size): Relying on default #address-cells value for /soc/internal-regs/spi@10680/spi-flash@1
This changes the board to reference the spi controller by its label
(which has not changed) rather than the full path.
Fixes: 0160a4b68987 ("ARM: dts: mvebu: A37x/XP/38x/39x: Move SPI controller nodes into 'soc' node")
This commit adds description for following features for this board:
- Serial port
- I2C buses
- 16MB SPI-NOR
- USB2.0
- USB3.0
- PCIe interfaces
Signed-off-by: Grzegorz Jaszczyk <jaz@semihalf.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
