dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The Marvell Armada 398 Development board contains both USB2.0 and USB3.0
ports, which can be handled by existing drivers.
Signed-off-by: Grzegorz Jaszczyk <jaz@semihalf.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
This patch moves all Armada 370/XP/38x/39x SPI controller nodes from the
'internal-regs' node down into the 'soc' node. This is in preparation
to enable the usage of the SPI direct access mode. A follow-up patch
will add the static MBus mappings for the SPI devices into the 'reg'
property of the SPI controller DT node.
By moving these SPI controller nodes, this patch also makes use of
the labels rather than keeping the tree structure.
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Mark Brown <broonie@kernel.org>
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace
"nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor"
binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op according
to the datasheets.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
This commit adds the Device Tree files for the Armada 39x family of
processors, as well as one Armada 398 Development Board.
Like for other Marvell EBU families, a common armada-39x.dtsi contains
the description of the common features of all Armada 39x SoCs, while
armada-390.dtsi and armada-398.dtsi respectively describe the
specificities of those SoCs.
Finally, an armada-398-db.dts file is added to describe the Armada 398
Development Board itself.
So far, the following features are supported:
* SMP: dual Cortex-A9
* Basic ARM IPs: SCU, timer, GIC, L2 cache
* Basic Marvell IPs: pin-muxing, clocks, system controller, MBus
controller, MPIC interrupt controller, timer, CPU reset for SMP,
PMSU.
* I2C
* SPI
* SDHCI
* XOR
* NAND
* UART
* PCIe
Additional features will be supported in the future.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
