2017-01-03 | ARM: dts: mvebu: Correct license text | Alexandre Belloni | |
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> | |||
2016-08-08 | ARM: dts: mvebu: armada-398: update the dtsi about missing interfaces | Grzegorz Jaszczyk | |
Beside interfaces described in the armada-39x.dtsi and armada-395.dtsi, the Armada 398 SoC family supports 2 additional SATA port (2 ports in one unit) Signed-off-by: Grzegorz Jaszczyk <jaz@semihalf.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> | |||
2015-03-04 | ARM: mvebu: add Device Tree files for Armada 39x SoC and board | Thomas Petazzoni | |
This commit adds the Device Tree files for the Armada 39x family of processors, as well as one Armada 398 Development Board. Like for other Marvell EBU families, a common armada-39x.dtsi contains the description of the common features of all Armada 39x SoCs, while armada-390.dtsi and armada-398.dtsi respectively describe the specificities of those SoCs. Finally, an armada-398-db.dts file is added to describe the Armada 398 Development Board itself. So far, the following features are supported: * SMP: dual Cortex-A9 * Basic ARM IPs: SCU, timer, GIC, L2 cache * Basic Marvell IPs: pin-muxing, clocks, system controller, MBus controller, MPIC interrupt controller, timer, CPU reset for SMP, PMSU. * I2C * SPI * SDHCI * XOR * NAND * UART * PCIe Additional features will be supported in the future. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> |
