The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
The gpio-key nodes do not have a reg property, so remove the address from
the unit name.
memory has a reg property so the unit name should contain an address.
PCIe has a range property, so the unit name should contain an address.
Take the opportunity to use the node label instead of the full name.
MDIO has a reg property so the unit name should contain an address.
This patch moves all Armada 370/XP/38x/39x SPI controller nodes from the
'internal-regs' node down into the 'soc' node. This is in preparation
to enable the usage of the SPI direct access mode. A follow-up patch
will add the static MBus mappings for the SPI devices into the 'reg'
property of the SPI controller DT node.
By moving these SPI controller nodes, this patch also makes use of
the labels rather than keeping the tree structure.
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Mark Brown <broonie@kernel.org>
When the Crypto SRAM mappings were added to the Device Tree files
describing the Armada XP boards in commit c466d997bb16 ("ARM: mvebu:
define crypto SRAM ranges for all armada-xp boards"), the fact that
those mappings were overlaping with the PCIe memory aperture was
overlooked. Due to this, we currently have for all Armada XP platforms
a situation that looks like this:
Memory mapping on Armada XP boards with internal registers at
0xf1000000:
- 0x00000000 -> 0xf0000000 3.75G RAM
- 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB)
- 0xf1000000 -> 0xf1100000 1M internal registers
- 0xf8000000 -> 0xffe0000 126M PCIe memory aperture
- 0xf8100000 -> 0xf8110000 64KB Crypto SRAM #0 => OVERLAPS WITH PCIE !
- 0xf8110000 -> 0xf8120000 64KB Crypto SRAM #1 => OVERLAPS WITH PCIE !
- 0xffe00000 -> 0xfff00000 1M PCIe I/O aperture
- 0xfff0000 -> 0xffffffff 1M BootROM
The overlap means that when PCIe devices are added, depending on their
memory window needs, they might or might not be mapped into the
physical address space. Indeed, they will not be mapped if the area
allocated in the PCIe memory aperture by the PCI core overlaps with
one of the Crypto SRAM. Typically, a Intel IGB PCIe NIC that needs 8MB
of PCIe memory will see its PCIe memory window allocated from
0xf80000000 for 8MB, which overlaps with the Crypto SRAM windows. Due
to this, the PCIe window is not created, and any attempt to access the
PCIe window makes the kernel explode:
[ 3.302213] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.307841] pci 0000:00:09.0: enabling device (0140 -> 0143)
[ 3.313539] mvebu_mbus: cannot add window '4:f8', conflicts with another window
[ 3.320870] mvebu-pcie soc:pcie-controller: Could not create MBus window at [mem 0xf8000000-0xf87fffff]: -22
[ 3.330811] Unhandled fault: external abort on non-linefetch (0x1008) at 0xf08c0018
This problem does not occur on Armada 370 boards, because we use the
following memory mapping (for boards that have internal registers at
0xf1000000):
- 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 => OK !
Obviously, the solution is to align the location of the Crypto SRAM
mappings of Armada XP to be similar with the ones on Armada 370, i.e
have them between the "internal registers" area and the beginning of
the PCIe aperture.
However, we have a special case with the OpenBlocks AX3-4 platform,
which has a 128 MB NOR flash. Currently, this NOR flash is mapped from
0xf0000000 to 0xf8000000. This is possible because on OpenBlocks
AX3-4, the internal registers are not at 0xf1000000. And this explains
why the Crypto SRAM mappings were not configured at the same place on
Armada XP.
Hence, the solution is two-fold:
(1) Move the NOR flash mapping on Armada XP OpenBlocks AX3-4 from
0xe8000000 to 0xf0000000. This frees the 0xf0000000 ->
0xf80000000 space.
(2) Move the Crypto SRAM mappings on Armada XP to be similar to
Armada 370 (except of course that Armada XP has two Crypto SRAM
and not one).
After this patch, the memory mapping on Armada XP boards with
registers at 0xf1 is:
- 0xf1110000 -> 0xf1120000 64KB Crypto SRAM #1
And the memory mapping for the special case of the OpenBlocks AX3-4
(internal registers at 0xd0000000, NOR of 128 MB):
- 0x00000000 -> 0xc0000000 3G RAM
- 0xd0000000 -> 0xd1000000 1M internal registers
- 0xe800000 -> 0xf0000000 128M NOR flash
Fixes: c466d997bb16 ("ARM: mvebu: define crypto SRAM ranges for all armada-xp boards")
Reported-by: Phil Sutter <phil@nwl.cc>
Cc: Phil Sutter <phil@nwl.cc>
Cc: <stable@vger.kernel.org>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace
"nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor"
binding indicating support for JEDEC identification.
Use it for all flashes that are supposed to support READ ID op according
to the datasheets.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
The Kconfig symbol DEBUG_MVEBU_UART_ALTERNATE was renamed to
DEBUG_MVEBU_UART0_ALTERNATE. And the symbol DEBUG_MVEBU_UART1_ALTERNATE
was added to allow UART1 as a DEBUG_LL target. Make the comment at the
top of this DTS reflect those changes.
Since we're touching this DTS add comments to show which blocks describe
UART0 and UART1.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
There are currently 2 differents naming conventions used between the
existing Armada SoC DT files for pinctrl entries (*_pin(s): *-pin(s)
and pmx_*: pmx-*) with a vast majority of files using the former:
$ grep _pin arch/arm/boot/dts/armada-*.dts* | wc -l
155
$ grep pmx arch/arm/boot/dts/armada-*.dts* | wc -l
13
In fact, only some Armada XP files are using the second variant.
This patch normalizes those files (mainly ge0/1 entries) to use
the first variant.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Link: https://lkml.kernel.org/r/00114c3169e1d93259ff4150ed46ee36eae16b1e.1416670812.git.arno@natisbad.org
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This patch defines common Armada XP pinctrl settings in armada-xp.dtsi
for the supported SPI interface (MPP36-39) and use it as default
for Armada XP spi interface. That being done, it removes the now
redundant definitions in armada-xp-axpwifiap.dts.
Note: this patch has the potential to break out-of-tree users w/o
specific pinctrl settings for their spi interfaces if the default
above does not match their config (i.e. if they do not use CS0).
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/d404b7abd80ee5a0fd8e8d3586d33cd37740d589.1416613429.git.arno@natisbad.org
Pinctrl settings for GE0 and GE1 are not only usable on RD-AXPWiFiAP.
Moreover, naming the RGMII settings pmx-ge{0,1} is not precise enough
as there is also a GMII setting for GE0.
Move the pinctrl sub-nodes to the common pinctrl node and rename them
to pmx-ge{0,1}-rgmii.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-By: Benoit Masson <yahoo@perenite.com>
Armada XP pinctrl node gained an alias, make use of it.
In other MVEBU SoCs, the pin controller node is called pin-ctrl with
its base address added. Also, we have a node alias to access the pinctrl
node easily. Fix this for Armada XP pinctrl nodes to be consistent with
other SoCs.
Now that the Armada 370/375/38x/XP SoC-level Device Tree files have
the proper "clocks" property in their UART controllers node, it is no
longer useful to have the clock-frequency property defined in the
board-level Device Tree files.
Therefore, this commit gets rid of all the useless 'clock-frequency'
properties.
Link: https://lkml.kernel.org/r/1397806908-7550-5-git-send-email-thomas.petazzoni@free-electrons.com
Instead of harcoding keycodes specifications in the Armada 370/XP
boards, use the <dt-bindings/input/input.h> header file and its
keycode definitions.
Instead of harcoding 0 and 1 for the gpio specifications in the Armada
370/XP boards, use the <dt-bindings/gpio/gpio.h> header file and its
GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW definitions.
The ranges property needs to be changed to use the new MBus DT binding.
Also, the pcie-controller node needs to be relocated as according the MBus
DT binding, it's now a child of the mbus-compatible node.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
The AXP WiFi AP board is a Marvell platform based on the Armada XP
MV78230 SoC. It has two mini-PCIe connectors, one USB 3.0 port powered
by a USB 3.0 controller on PCIe, two Ethernet ports, 1 GB of RAM, 1 GB
of NAND, 16 MB of SPI flash, one SATA port and one button, two UARTs
Successfully tested: USB 3.0 port, the mini-PCIe connectors, SPI
flash, Ethernet ports, SATA port, button, UART.
Untested: NAND flash, due to lack of mainline support for the Armada
370/XP NAND controller for now.
Tested-by: Seif Mazareeb <seif@marvell.com>
