path: root/arch/arm/boot/dts/armada-xp-gp.dts
2019-02-19ARM: dts: armada-xp: fix Armada XP boards NAND descriptionThomas Petazzoni
Commit 3b79919946cd2cf4dac47842afc9a893acec4ed7 ("ARM: dts: armada-370-xp: update NAND node with new bindings") updated some Marvell Armada DT description to use the new NAND controller bindings, but did it incorrectly for a number of boards: armada-xp-gp, armada-xp-db and armada-xp-lenovo-ix4-300d. Due to this, the NAND is no longer detected on those platforms. This commit fixes that by properly using the new NAND DT binding. This commit was runtime-tested on Armada XP GP, the two other platforms are only compile-tested. Fixes: 3b79919946cd2 ("ARM: dts: armada-370-xp: update NAND node with new bindings") Cc: Miquel Raynal <miquel.raynal@bootlin.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2018-05-18ARM: dts: armada-370-xp: update NAND node with new bindingsMiquel Raynal
Use the new bindings of the Marvell NAND controller driver. Also adapt the NAND controller node organization to distinguish which property is relevant for the controller, and which one is NAND chip specific. Expose the partitions as a subnode of the NAND chip. Remove the 'marvell,nand-enable-arbiter' property, not needed anymore as the new driver activates the arbiter by default for all boards which is either needed or harmless. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2018-03-27arm: dts: armada-*.dts: use SPDX-License-Identifier for most of the Armada ↵Gregory CLEMENT
based board Follow the recent trend for the license description, and also fix the wrongly stated X11 to MIT. As already pointed on the DT ML, the X11 license text [1] is explicitly for the X Consortium and has a couple of extra clauses. The MIT license text [2] is actually what the current DT files claim. [1] https://spdx.org/licenses/X11.html [2] https://spdx.org/licenses/MIT.html Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2017-08-03ARM: dts: marvell: fix PCI bus dtc warningsRob Herring
dtc recently added PCI bus checks. Fix these warnings. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Gregory Clement <gregory.clement@free-electrons.com> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2017-01-03ARM: dts: mvebu: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370-xp: Fixup memory DT warningGregory CLEMENT
memory has a reg property so the unit name should contain an address. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-xp: Fixup pcie DT warningsGregory CLEMENT
PCIe has a range property, so the unit name should contain an address. Take the opportunity to use the node label instead of the full name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370-xp: Fixup mdio DT warningGregory CLEMENT
MDIO has a reg property so the unit name should contain an address. Take the opportunity to use the node label instead of the full name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-08-08ARM: dts: mvebu: A37x/XP/38x/39x: Move SPI controller nodes into 'soc' nodeStefan Roese
This patch moves all Armada 370/XP/38x/39x SPI controller nodes from the 'internal-regs' node down into the 'soc' node. This is in preparation to enable the usage of the SPI direct access mode. A follow-up patch will add the static MBus mappings for the SPI devices into the 'reg' property of the SPI controller DT node. By moving these SPI controller nodes, this patch also makes use of the labels rather than keeping the tree structure. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Gregory CLEMENT <gregory.clement@free-electrons.com> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Mark Brown <broonie@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support more Realtek wireless chips, from Jes Sorenson. 2) New BPF types for per-cpu hash and arrap maps, from Alexei Starovoitov. 3) Make several TCP sysctls per-namespace, from Nikolay Borisov. 4) Allow the use of SO_REUSEPORT in order to do per-thread processing of incoming TCP/UDP connections. The muxing can be done using a BPF program which hashes the incoming packet. From Craig Gallek. 5) Add a multiplexer for TCP streams, to provide a messaged based interface. BPF programs can be used to determine the message boundaries. From Tom Herbert. 6) Add 802.1AE MACSEC support, from Sabrina Dubroca. 7) Avoid factorial complexity when taking down an inetdev interface with lots of configured addresses. We were doing things like traversing the entire address less for each address removed, and flushing the entire netfilter conntrack table for every address as well. 8) Add and use SKB bulk free infrastructure, from Jesper Brouer. 9) Allow offloading u32 classifiers to hardware, and implement for ixgbe, from John Fastabend. 10) Allow configuring IRQ coalescing parameters on a per-queue basis, from Kan Liang. 11) Extend ethtool so that larger link mode masks can be supported. From David Decotigny. 12) Introduce devlink, which can be used to configure port link types (ethernet vs Infiniband, etc.), port splitting, and switch device level attributes as a whole. From Jiri Pirko. 13) Hardware offload support for flower classifiers, from Amir Vadai. 14) Add "Local Checksum Offload". Basically, for a tunneled packet the checksum of the outer header is 'constant' (because with the checksum field filled into the inner protocol header, the payload of the outer frame checksums to 'zero'), and we can take advantage of that in various ways. From Edward Cree" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits) bonding: fix bond_get_stats() net: bcmgenet: fix dma api length mismatch net/mlx4_core: Fix backward compatibility on VFs phy: mdio-thunder: Fix some Kconfig typos lan78xx: add ndo_get_stats64 lan78xx: handle statistics counter rollover RDS: TCP: Remove unused constant RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket net: smc911x: convert pxa dma to dmaengine team: remove duplicate set of flag IFF_MULTICAST bonding: remove duplicate set of flag IFF_MULTICAST net: fix a comment typo ethernet: micrel: fix some error codes ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it bpf, dst: add and use dst_tclassid helper bpf: make skb->tc_classid also readable net: mvneta: bm: clarify dependencies cls_bpf: reset class and reuse major in da ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c ldmvsw: Add ldmvsw.c driver code ...
2016-03-14ARM: dts: armada-xp: enable buffer manager support on Armada XP boardsMarcin Wojtas
Since mvneta driver supports using hardware buffer management (BM), in order to use it, board files have to be adjusted accordingly. This commit enables BM on AXP-DB and AXP-GP in same manner - because number of ports on those boards is the same as number of possible pools, each port is supposed to use single pool for all kind of packets. Moreover appropriate entry is added to 'soc' node ranges, as well as "okay" status for 'bm' and 'bm-bppi' (internal SRAM) nodes. Signed-off-by: Marcin Wojtas <mw@semihalf.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-11ARM: mvebu: fix overlap of Crypto SRAM with PCIe memory windowThomas Petazzoni
When the Crypto SRAM mappings were added to the Device Tree files describing the Armada XP boards in commit c466d997bb16 ("ARM: mvebu: define crypto SRAM ranges for all armada-xp boards"), the fact that those mappings were overlaping with the PCIe memory aperture was overlooked. Due to this, we currently have for all Armada XP platforms a situation that looks like this: Memory mapping on Armada XP boards with internal registers at 0xf1000000: - 0x00000000 -> 0xf0000000 3.75G RAM - 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB) - 0xf1000000 -> 0xf1100000 1M internal registers - 0xf8000000 -> 0xffe0000 126M PCIe memory aperture - 0xf8100000 -> 0xf8110000 64KB Crypto SRAM #0 => OVERLAPS WITH PCIE ! - 0xf8110000 -> 0xf8120000 64KB Crypto SRAM #1 => OVERLAPS WITH PCIE ! - 0xffe00000 -> 0xfff00000 1M PCIe I/O aperture - 0xfff0000 -> 0xffffffff 1M BootROM The overlap means that when PCIe devices are added, depending on their memory window needs, they might or might not be mapped into the physical address space. Indeed, they will not be mapped if the area allocated in the PCIe memory aperture by the PCI core overlaps with one of the Crypto SRAM. Typically, a Intel IGB PCIe NIC that needs 8MB of PCIe memory will see its PCIe memory window allocated from 0xf80000000 for 8MB, which overlaps with the Crypto SRAM windows. Due to this, the PCIe window is not created, and any attempt to access the PCIe window makes the kernel explode: [ 3.302213] igb: Copyright (c) 2007-2014 Intel Corporation. [ 3.307841] pci 0000:00:09.0: enabling device (0140 -> 0143) [ 3.313539] mvebu_mbus: cannot add window '4:f8', conflicts with another window [ 3.320870] mvebu-pcie soc:pcie-controller: Could not create MBus window at [mem 0xf8000000-0xf87fffff]: -22 [ 3.330811] Unhandled fault: external abort on non-linefetch (0x1008) at 0xf08c0018 This problem does not occur on Armada 370 boards, because we use the following memory mapping (for boards that have internal registers at 0xf1000000): - 0x00000000 -> 0xf0000000 3.75G RAM - 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB) - 0xf1000000 -> 0xf1100000 1M internal registers - 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 => OK ! - 0xf8000000 -> 0xffe0000 126M PCIe memory - 0xffe00000 -> 0xfff00000 1M PCIe I/O - 0xfff0000 -> 0xffffffff 1M BootROM Obviously, the solution is to align the location of the Crypto SRAM mappings of Armada XP to be similar with the ones on Armada 370, i.e have them between the "internal registers" area and the beginning of the PCIe aperture. However, we have a special case with the OpenBlocks AX3-4 platform, which has a 128 MB NOR flash. Currently, this NOR flash is mapped from 0xf0000000 to 0xf8000000. This is possible because on OpenBlocks AX3-4, the internal registers are not at 0xf1000000. And this explains why the Crypto SRAM mappings were not configured at the same place on Armada XP. Hence, the solution is two-fold: (1) Move the NOR flash mapping on Armada XP OpenBlocks AX3-4 from 0xe8000000 to 0xf0000000. This frees the 0xf0000000 -> 0xf80000000 space. (2) Move the Crypto SRAM mappings on Armada XP to be similar to Armada 370 (except of course that Armada XP has two Crypto SRAM and not one). After this patch, the memory mapping on Armada XP boards with registers at 0xf1 is: - 0x00000000 -> 0xf0000000 3.75G RAM - 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB) - 0xf1000000 -> 0xf1100000 1M internal registers - 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 - 0xf1110000 -> 0xf1120000 64KB Crypto SRAM #1 - 0xf8000000 -> 0xffe0000 126M PCIe memory - 0xffe00000 -> 0xfff00000 1M PCIe I/O - 0xfff0000 -> 0xffffffff 1M BootROM And the memory mapping for the special case of the OpenBlocks AX3-4 (internal registers at 0xd0000000, NOR of 128 MB): - 0x00000000 -> 0xc0000000 3G RAM - 0xd0000000 -> 0xd1000000 1M internal registers - 0xe800000 -> 0xf0000000 128M NOR flash - 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 - 0xf1110000 -> 0xf1120000 64KB Crypto SRAM #1 - 0xf8000000 -> 0xffe0000 126M PCIe memory - 0xffe00000 -> 0xfff00000 1M PCIe I/O - 0xfff0000 -> 0xffffffff 1M BootROM Fixes: c466d997bb16 ("ARM: mvebu: define crypto SRAM ranges for all armada-xp boards") Reported-by: Phil Sutter <phil@nwl.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: <stable@vger.kernel.org> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-09-29ARM: mvebu: define crypto SRAM ranges for all armada-xp boardsBoris Brezillon
Define the crypto SRAM ranges so that the resources referenced by the sa-sram node can be properly extracted from the DT. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-05-25ARM: mvebu: add "jedec,spi-nor" flash compatible bindingRafał Miłecki
Starting with commit 8947e396a829 ("Documentation: dt: mtd: replace "nor-jedec" binding with "jedec, spi-nor"") we have "jedec,spi-nor" binding indicating support for JEDEC identification. Use it for all flashes that are supposed to support READ ID op according to the datasheets. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-03-04ARM: mvebu: use stdout-path in all armada-*.dtsThomas Petazzoni
This commit adds the stdout-path property in /chosen for all Armada boards that were not yet carrying this property, and gets rid of /chosen/bootargs which becomes unneeded: earlyprintk should not be used by default, and the console= parameter is replaced by the /chosen/stdout-path property. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-01-26ARM: mvebu: armada-xp-gp: Relicense the device tree under GPLv2+/X11Gregory CLEMENT
The current GPL only licensing on the device tree makes it very impractical for other software components licensed under another license. In order to make it easier for them to reuse our device trees, relicense our device trees under a GPL/X11 dual-license. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2014-11-30ARM: mvebu: add suspend/resume DT information for Armada XP GPThomas Petazzoni
This commit improves the Armada XP GP Device Tree description to describe the 3 GPIOs that are used to connect the SoC to the PIC micro-controller that we talk to shutdown the SoC when entering suspend to RAM. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Link: https://lkml.kernel.org/r/1416585613-2113-15-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-02Merge tag 'dt-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC devicetree updates from Olof Johansson: "As with previous release, this continues to be among the largest branches we merge, with lots of new contents. New things for this release are among other things: - DTSI contents for the new SoCs supported in 3.16 (see SoC pull request) - Qualcomm APQ8064 and APQ8084 SoCs and eval boards - Nvidia Jetson TK1 development board (Tegra T124-based) Two new SoCs that didn't need enough new platform code to stand out enough for me to notice when writing the SoC tag, but that adds new DT contents are: - TI DRA72 - Marvell Berlin 2Q" * tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits) ARM: dts: add secure firmware support for exynos5420-arndale-octa ARM: dts: add pmu sysreg node to exynos3250 ARM: dts: correct the usb phy node in exynos5800-peach-pi ARM: dts: correct the usb phy node in exynos5420-peach-pit ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410 ARM: dts: add dts files for exynos3250 SoC ARM: dts: add mfc node for exynos5800 ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi ARM: dts: enable fimd for exynos5800-peach-pi ARM: dts: enable display controller for exynos5800-peach-pi ARM: dts: enable hdmi for exynos5800-peach-pi ARM: dts: add dts file for exynos5800-peach-pi board ARM: dts: add dts file for exynos5800 SoC ARM: dts: add dts file for exynos5260-xyref5260 board ARM: dts: add dts files for exynos5260 SoC ARM: dts: update watchdog node name in exynos5440 ARM: dts: use key code macros on Origen and Arndale boards ARM: dts: enable RTC and WDT nodes on Origen boards ARM: dts: qcom: Add APQ8084-MTP board support ARM: dts: qcom: Add APQ8084 SoC support ...
2014-04-26ARM: mvebu: remove clock-frequency of serial port Device Tree nodesThomas Petazzoni
Now that the Armada 370/375/38x/XP SoC-level Device Tree files have the proper "clocks" property in their UART controllers node, it is no longer useful to have the clock-frequency property defined in the board-level Device Tree files. Therefore, this commit gets rid of all the useless 'clock-frequency' properties. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Link: https://lkml.kernel.org/r/1397806908-7550-5-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-25ARM: mvebu: use qsgmii phy-mode for Armada XP GP interfacesThomas Petazzoni
The Armada XP GP isn't using rgmii-id connections between the MAC and PHY, but instead a single QSGMII connection, which is a quad-SGMII connection: a double pair of differential lines that are multiplexed to convey the traffic of four network interfaces between a MAC and a PHY. Until now, the Armada XP GP was relying on the bootloader setting the correct values in various configuration registers. With this change, the mvneta driver can be used as a module on this platform. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397569821-5530-4-git-send-email-thomas.petazzoni@free-electrons.com Tested-by: Arnaud Ebalard <arno@natisbad.org> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-25ARM: mvebu: fix NOR bus-width in Armada XP GP Device TreeThomas Petazzoni
The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus width declared in the Device Tree being considered as a 16 bits bus width when configuring the hardware. This bug in mvebu-devbus driver was compensated by a symetric mistake in the Armada XP GP Device Tree: a 8 bits bus width was declared, even though the hardware actually has a 16 bits bus width connection with the NOR flash. Now that we have fixed the mvebu-devbus driver to behave according to its Device Tree binding, this commit fixes the problematic Device Tree files as well. This bug was introduced in commit da8d1b38356853c37116f9afa29f15648d7fb159 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board') which was merged in v3.10. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397489361-5833-3-git-send-email-thomas.petazzoni@free-electrons.com Fixes: da8d1b383568 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board') Cc: stable@vger.kernel.org # v3.10+ Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-03-06ARM: mvebu: switch the Armada XP GP to use internal registers at 0xf1000000Thomas Petazzoni
Marvell has now provided bootloaders that are Device Tree capable for the Armada XP GP board, and that also remap the internal register base address to 0xf1000000. In addition, the bootloader now sets the MBus Window base address to 0xf0000000, which allows to use much more RAM in the last GB of RAM before the 4 GB limit (the entire space from 0xC0000000 to 0xFFFFFFFF was not usable due to being used for I/O, not only the space from 0xF0000000 to 0xFFFFFFFF is used for I/O). Therefore this commit: * Updates the memory->reg Device Tree property with the fact that in the first bank of RAM, memory up to 0xf0000000 can be used. * Updates the soc->ranges Device Tree property with the fact that the internal registers are now mapped at 0xf1000000. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-11-24ARM: mvebu: Enable NAND controller in Armada XP GP boardEzequiel Garcia
The Armada XP GP board has a NAND flash, so enable it in the devicetree. In order to skip the driver's custom device detection and use only ONFI detection, the "marvell,keep-config" parameter is used. This is needed because we haven't support for setting the timings parameters yet and must rely in bootloader's. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Relocate Armada 370/XP PCIe device tree nodesEzequiel Garcia
Now that mbus has been added to the device tree, it's possible to move the PCIe nodes out of internal registers, placing it directly below the mbus. This is a more accurate representation of the hardware. Moving the PCIe nodes, we now need to introduce an extra cell to encode the window target ID and attribute. Since this depends on the PCIe port, we split the ranges translation entries, to correspond to each MBus window. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Relocate Armada 370/XP DeviceBus device tree nodesEzequiel Garcia
Now that mbus has been added to the device tree, it's possible to move the DeviceBus out of internal registers, placing it directly below the mbus. This is a more accurate representation of the hardware. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Add BootROM to Armada 370/XP device treeEzequiel Garcia
In order to access the SoC BootROM, we need to declare a mapping (through a ranges property). The mbus driver will use this property to allocate a suitable address decoding window. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Add MBus to Armada 370/XP device treeEzequiel Garcia
The Armada 370/XP SoC family has a completely configurable address space handled by the MBus controller. This patch introduces the device tree layout of MBus, making the 'soc' node as mbus-compatible. Since every peripheral/controller is a child of this 'soc' node, this makes all of them sit behind the mbus, thus describing the hardware accurately. A translation entry has been added for the internal-regs mapping. This can't be done in the common armada-370-xp.dtsi because A370 and AXP have different addressing width. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Use the preprocessor on Armada 370/XP device tree filesEzequiel Garcia
2013-06-20Merge tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Arnd Bergmann
into next/dt From Shawn Guo: mxs device tree changes for 3.11: * A couple of new board support, cfa10055 and cfa10057 * A few updates on cfa10036 device tree source * Some auart pinctrl data addition * Adopt soc bus infrastructure for mach-mxs * tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: mxs: dt: Add Crystalfontz CFA-10057 device tree ARM: mxs: dt: Add the Crystalfontz CFA-10055 device tree ARM: cfa10049: Switch the chip select pin of the LCD controller ARM: cfa10036: Add USB0 OTG port ARM: dts: apf28dev: Add touchscreen support for APF28dev ARM: mxs: Fix UARTs on M28EVK ARM: cfa10036: dt: Change i2c0 clock frequency ARM: dts: cfa10036: Change the OLED display to SSD1306 ARM: mx28: add auart4 2 pins pinmux to imx28.dtsi ARM: mx28: add auart3 2 pins pinmux to imx28.dtsi ARM: mx28: add auart2 2 pins pinmux to imx28.dtsi ARM: mxs: Use soc bus infrastructure ARM: dts: mx28: Adjust the digctl compatible string ARM: mxs: Remove init_irq declaration in machine description Includes an update to 3.10-rc6 Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-06arm: mvebu: armada-xp-{gp,openblocks-ax3-4}: specify PCIe rangeThomas Petazzoni
The ranges DT entry needed by the PCIe controller is defined at the SoC .dtsi level. However, some boards have a NOR flash, and to support it, they need to override the SoC-level ranges property to add an additional range. Since PCIe and NOR support came separately, some boards were not properly changed to include the PCIe range in their ranges property at the .dts level. This commit fixes those platforms. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-31Merge tag 'dt-3.11-3' of git://git.infradead.org/users/jcooper/linux into ↵Olof Johansson
next/dt From jason Cooper, mvebu dt changes for v3.11. Signed-off-by: Olof Johansson <olof@lixom.net> * tag 'dt-3.11-3' of git://git.infradead.org/users/jcooper/linux: (27 commits) arm: kirkwood: openblocks-a6: add support for Init button arm: kirkwood: openblocks-a6: group pinmux configurations arm: kirkwood: ts219: move pinmux configs to the right devices arm: kirkwood: topkick: move pinmux configs to the right devices arm: kirkwood: openblocks_a6: move pinmux configs to the right devices arm: kirkwood: nsa310: move pinmux configs to the right devices arm: kirkwood: readynas: move pinmux configs to the right devices arm: kirkwood: mplcec4: move pinmux configs to the right devices arm: kirkwood: buffalo linkstation: move pinmux configs to the right devices arm: kirkwood: keymile: move pinmux configs to the right devices arm: kirkwood: ns2: move pinmux configs to the right devices arm: kirkwood: iomega ix2-200: move pinmux configs to the right devices arm: kirkwood: iconnect: move pinmux configs to the right devices arm: kirkwood: iconnect: give meaningful names to pinmux configs arm: kirkwood: ib62x0: move pinmux configs to the right devices arm: kirkwood: guruplug: move pinmux configs to the right devices arm: kirkwood: goflexnet: move pinmux configs to the right devices arm: kirkwood: dreamplug: move pinmux configs to the right devices arm: kirkwood: dockstar: move pinmux configs to the right devices arm: kirkwood: dlink dns: move pinmux configs to the right devices ...
2013-05-21arm: mvebu: enable two USB interfaces on the Armada XP GP boardThomas Petazzoni
The Armada XP GP board has two USB slots: one on the front side and one on the back side. This commit enables the two USB host controllers that correspond to those wo USB slots. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-17ARM: mvebu: Fix ranges entry on XP GP boardEzequiel Garcia
With the latest device tree reorganization which introduced the 'internal-reg' node, now the only region translated is the internal register's. This makes the description of the hardware incomplete, for it lacks the Device Bus childs address space. In order to fix this, it's required to add a 'ranges' entry with a suitable address space to map Device Bus childs, on a per-board basis. This patch fixes the ranges property on the Armada XP GP board. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: Convert mvebu device tree files to 64 bitsGregory CLEMENT
In order to be able to use more than 4GB of RAM when the LPAE is activated, the dts must be converted in 64 bits. Only Armada XP is LPAE capable, but as it shares a common dtsi file with Armada 370, then the common file include the skeleton64. Thanks to the use of the overload capability of the device tree format, armada-370 include the 32 bit skeleton and all the armada 370 based dts can remain the same. This was heavily based on the work of Lior Amsalem. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: introduce internal-regs nodeGregory CLEMENT
Introduce a 'internal-regs' subnode, under which all devices are moved. This is not really needed for now, but will be for the mvebu-mbus driver. This generates a lot of code movement since it's indenting by one more tab all the devices. So it was a good opportunity to fix all the bad indentation. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: Convert all the mvebu files to use the range propertyGregory CLEMENT
This conversion will allow to keep 32 bits addresses for the internal registers whereas the memory of the system will be 64 bits. Later it will also ease the move of the mvebu-mbus driver to the device tree support. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15arm: mvebu: PCIe Device Tree informations for Armada XP GPThomas Petazzoni
The Marvell Armada XP GP board has 3 physical full-size PCIe slots, so we enable the corresponding PCIe interfaces in the Device Tree. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-11ARM: mvebu: Add support for NOR flash device on Armada XP-GP boardEzequiel Garcia
The Armada XP Development Board DB-MV784MP-GP has a NOR flash device connected to the Device Bus. This commit adds the device tree node to support this device. This SoC supports a flexible and dynamic decoding window allocation scheme; but since this feature is still not implemented we need to specify the window base address in the device tree node itself. This base address has been selected in a completely arbitrary fashion. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28arm: mvebu: Add SPI flash on Armada XP-GP boardEzequiel Garcia
This patch adds an SPI master device node for Armada XP-GP board. This master node is an SPI flash controller 'n25q128a13'. Since there is no 'partitions' node declared, one full sized partition named as the device will be created. Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Lior Amsalem <alior@marvell.com> Tested-by: Gregory Clement <gregory.clement@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Gregory Clement <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28arm: mvebu: support for the new Armada XP development board(DB-MV784MP-GP)Gregory CLEMENT
This is the new Armada XP evaluation board from Marvell. It comes with a RS232 port over USB, a SATA link, an internal SSD, 4 Ethernet Gigabit links. Support for USB (Host and device), SDIO, PCIe will be added as drivers when they become available for Armada XP in mainline. Tested-by: Simon Guinot <simon.guinot@sequanux.org> Tested-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
