The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Willy Tarreau <w@1wt.eu>
Armada XP pinctrl node gained an alias, make use of it.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-By: Benoit Masson <yahoo@perenite.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
In other MVEBU SoCs, the pin controller node is called pin-ctrl with
its base address added. Also, we have a node alias to access the pinctrl
node easily. Fix this for Armada XP pinctrl nodes to be consistent with
other SoCs.
All current Armada XP SoCs have their pin controller at 0x18000/0x38.
Move the common properties of pinctrl nodes to armada-xp.dtsi to allow
to share pinctrl settings later.
In order to support dynamic frequency scaling:
* the cpuclk Device Tree node needs to be updated to describe a
second set of registers describing the PMU DFS registers.
* the clock-latency property of the CPUs must be filled, otherwise
the ondemand and conservative cpufreq governors refuse to work. The
latency is high because the cost of a frequency transition is quite
high on those CPUs.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1404920715-19834-5-git-send-email-thomas.petazzoni@free-electrons.com
This commit updates the Armada XP Device Trees (for the three variants
of Armada XP) to declare the "enable-method" property for the CPUs,
which helps operating systems find the appropriate logic to manage the
CPUs, especially to boot secondary CPUs.
Link: https://lkml.kernel.org/r/1397483648-26611-4-git-send-email-thomas.petazzoni@free-electrons.com
This commit adjusts the Armada 370 and Armada XP PCIe controllers
Device Tree informations to reference their MSI controller. In the
case of this platform, the MSI controller is implemented by the MPIC.
Tested-by: Daniel Price <daniel.price@gmail.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
From Jason Cooper:
mvebu dt changes for v3.12
- kirkwood
- add ZyXEL NSA310 board, fan for ReadyNAS Duo v2
- mvebu
- add ReadyNAS 102 board
- misc dts updates and changes.
v2:
- dropped mv64xxx-i2c change
* tag 'dt-3.12' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: Fix the Armada 370/XP timer compatible strings
ARM: mvebu: use dts pre-processor for readynas 102
ARM: kirkwood: use dts pre-processor for nsa310 boards
ARM: mvebu: use correct #interrupt-cells instead of #interrupts-cells
ARM: Kirkwood: Add support for another ZyXEL NSA310 variant
ARM: mvebu: Add Netgear ReadyNAS 102 board
arm: kirkwood: readynas duo v2: Add GMT G762 Fan Controller
arch/arm/boot/dts/kirkwood-nsa310.dts
The Device Tree information for the GPIO banks of the Armada 370 and
Armada XP SOCs was incorrectly using #interrupts-cells instead of
controller when using GPIO interrupts, since the GPIO bank DT node
wasn't recognized as a valid interrupt controller by the OF code.
Now that mbus has been added to the device tree, it's possible to
move the PCIe nodes out of internal registers, placing it directly
below the mbus. This is a more accurate representation of the
hardware.
Moving the PCIe nodes, we now need to introduce an extra cell to
encode the window target ID and attribute. Since this depends on
the PCIe port, we split the ranges translation entries, to correspond
to each MBus window.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Pull ARM SoC device tree changes from Arnd Bergmann:
"These changes from 30 individual branches for the most part update
device tree files, but there are also a few source code changes that
have crept in this time, usually in order to atomically move over a
driver from using hardcoded data to DT probing.
A number of platforms change their DT files to use the C preprocessor,
which is causing a bit of churn, but that is hopefully only this once"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits)
ARM: at91: dt: rm9200ek: add spi support
ARM: at91: dt: rm9200: add spi support
ARM: at91/DT: at91sam9n12: add SPI DMA client infos
ARM: at91/DT: sama5d3: add SPI DMA client infos
ARM: at91/DT: fix SPI compatibility string
ARM: Kirkwood: Fix the internal register ranges translation
ARM: dts: bcm281xx: change comment to C89 style
ARM: mmc: bcm281xx SDHCI driver (dt mods)
ARM: nomadik: add the new clocks to the device tree
clk: nomadik: implement the Nomadik clocks properly
ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency
ARM: dts: omap4-panda: Fix DVI EDID reads
ARM: dts: omap4-panda: Add USB Host support
arm: mvebu: enable mini-PCIe connectors on Armada 370 RD
ARM: shmobile: irqpin: add a DT property to enable masking on parent
ARM: dts: AM43x EPOS EVM support
ARM: dts: OMAP5: Add bandgap DT entry
ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM
ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk
ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone
These aliases are used when feeding the DT from ATAGS to set the
devices MAC addresses.
Signed-off-by: Willy Tarreau <w@1wt.eu>
The length of the registers area for the Marvell 370/XP Ethernet
controller was incorrect in the .dtsi: 0x2400 while it should have
been 0x4000. Until now, this problem wasn't noticed because there was
a large static mapping for all I/Os set up by ->map_io(). But since
we're going to get rid of this static mapping, we need to ensure that
the register areas are properly sized.
Introduce a 'internal-regs' subnode, under which all devices are
moved. This is not really needed for now, but will be for the
mvebu-mbus driver. This generates a lot of code movement since it's
indenting by one more tab all the devices. So it was a good
opportunity to fix all the bad indentation.
This conversion will allow to keep 32 bits addresses for the internal
registers whereas the memory of the system will be 64 bits.
Later it will also ease the move of the mvebu-mbus driver to the
device tree support.
Align the cpu node indentation with the rest of the file
[gc]: added a commit description
The Armada XP SoCs have multiple PCIe interfaces. The MV78230 has 2
PCIe units (one 4x or quad 1x, the other 1x only), the MV78260 has 3
PCIe units (two 4x or quad 1x and one 4x/1x), the MV78460 has 4 PCIe
units (two 4x or quad 1x and two 4x/1x). We therefore add the
necessary Device Tree informations to make those PCIe interfaces
usable.
The SDIO interface is only available on pins MPP30/31/32/33/34/35 on
the various Armada XP variants, so we provide a pin muxing option for
this in the Armada XP .dtsi files.
Even though those muxing options are the same for MV78230, MV78260 and
MV78460, we keep them in each .dtsi file, because the number of pins,
and therefore the declaration of the pinctrl node, is different for
each SoC variant.
The Armada XP GPIO controller has two ways of notifying interrupts:
using global interrupts or using per-CPU interrupts. In an attempt to
use the best available features, the 'marvell,armadaxp-gpio'
compatible string selects a variant of the gpio-mvebu driver that
makes use of the per-CPU interrupts.
Unfortunately, this doesn't work properly in a SMP context, because we
fall into cases where the GPIO interrupt is enabled on CPU X at the
GPIO controller level, but on CPU Y at the interrupt controller
level. It is not yet clear how to fix that easily.
So for 3.8, our approach is to switch to global interrupts for GPIOs,
so that we do not fall into this per-CPU interrupts problem.
This patch therefore fixes GPIO interrupts on Armada XP
platforms. Without this patch, GPIO interrupts simply do not work
reliably, because their proper operation depends on which CPU the code
requesting the interrupt is running.
We originally thought that the MV78230 variant of the Armada XP had
four Ethernet interfaces, like the other variants MV78260 and
MV78460. In fact, this is not true, and the MV78230 has only three
Ethernet interfaces.
So, the definitions of the Ethernet interfaces is now done as follows:
* armada-370-xp.dtsi: definitions of the first two interfaces, that
are common to Armada 370 and Armada XP
* armada-xp.dtsi: definition of the third interface, common to all
Armada XP variants.
* armada-xp-mv78260.dtsi and armada-xp-mv78460.dtsi: definition of
the fourth interface.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Tested-by Gregory CLEMENT <gregory.clement@free-electrons.com>
The gpioX aliases are needed so that the driver can use
of_alias_get_id() to get a 0-based number of the GPIO bank, which we
then use to compute the base GPIO of the bank being probed. This is
similar to what gpio-mxs.c is doing.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
This commits adds the necessary device tree information to define the
compatible property for the pinctrl driver instance of Armada XP SoCs.
Until now, the device tree representation considered the Armada XP as
a single SoC. But in fact, there are three different SoCs in the
Armada XP families, with different number of CPU cores, different
number of Ethernet interfaces... and different number of muxable pins
or functions. We therefore introduce three armada-xp-mv78xx0.dtsi for
the three SoCs of the Armada XP family. The current armada-xp-db.dts
evaluation board uses the MV78460 variant of the SoC.
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Stephen Warren <swarren@wwwdotorg.org>
