commit d7d5a43c0d16760f25d892bf9329848167a8b8a4 upstream.
When the Crypto SRAM mappings were added to the Device Tree files
describing the Armada XP boards in commit c466d997bb16 ("ARM: mvebu:
define crypto SRAM ranges for all armada-xp boards"), the fact that
those mappings were overlaping with the PCIe memory aperture was
overlooked. Due to this, we currently have for all Armada XP platforms
a situation that looks like this:
Memory mapping on Armada XP boards with internal registers at
0xf1000000:
- 0x00000000 -> 0xf0000000 3.75G RAM
- 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB)
- 0xf1000000 -> 0xf1100000 1M internal registers
- 0xf8000000 -> 0xffe0000 126M PCIe memory aperture
- 0xf8100000 -> 0xf8110000 64KB Crypto SRAM #0 => OVERLAPS WITH PCIE !
- 0xf8110000 -> 0xf8120000 64KB Crypto SRAM #1 => OVERLAPS WITH PCIE !
- 0xffe00000 -> 0xfff00000 1M PCIe I/O aperture
- 0xfff0000 -> 0xffffffff 1M BootROM
The overlap means that when PCIe devices are added, depending on their
memory window needs, they might or might not be mapped into the
physical address space. Indeed, they will not be mapped if the area
allocated in the PCIe memory aperture by the PCI core overlaps with
one of the Crypto SRAM. Typically, a Intel IGB PCIe NIC that needs 8MB
of PCIe memory will see its PCIe memory window allocated from
0xf80000000 for 8MB, which overlaps with the Crypto SRAM windows. Due
to this, the PCIe window is not created, and any attempt to access the
PCIe window makes the kernel explode:
[ 3.302213] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.307841] pci 0000:00:09.0: enabling device (0140 -> 0143)
[ 3.313539] mvebu_mbus: cannot add window '4:f8', conflicts with another window
[ 3.320870] mvebu-pcie soc:pcie-controller: Could not create MBus window at [mem 0xf8000000-0xf87fffff]: -22
[ 3.330811] Unhandled fault: external abort on non-linefetch (0x1008) at 0xf08c0018
This problem does not occur on Armada 370 boards, because we use the
following memory mapping (for boards that have internal registers at
0xf1000000):
- 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 => OK !
Obviously, the solution is to align the location of the Crypto SRAM
mappings of Armada XP to be similar with the ones on Armada 370, i.e
have them between the "internal registers" area and the beginning of
the PCIe aperture.
However, we have a special case with the OpenBlocks AX3-4 platform,
which has a 128 MB NOR flash. Currently, this NOR flash is mapped from
0xf0000000 to 0xf8000000. This is possible because on OpenBlocks
AX3-4, the internal registers are not at 0xf1000000. And this explains
why the Crypto SRAM mappings were not configured at the same place on
Armada XP.
Hence, the solution is two-fold:
(1) Move the NOR flash mapping on Armada XP OpenBlocks AX3-4 from
0xe8000000 to 0xf0000000. This frees the 0xf0000000 ->
0xf80000000 space.
(2) Move the Crypto SRAM mappings on Armada XP to be similar to
Armada 370 (except of course that Armada XP has two Crypto SRAM
and not one).
After this patch, the memory mapping on Armada XP boards with
registers at 0xf1 is:
- 0xf1110000 -> 0xf1120000 64KB Crypto SRAM #1
And the memory mapping for the special case of the OpenBlocks AX3-4
(internal registers at 0xd0000000, NOR of 128 MB):
- 0x00000000 -> 0xc0000000 3G RAM
- 0xd0000000 -> 0xd1000000 1M internal registers
- 0xe800000 -> 0xf0000000 128M NOR flash
Fixes: c466d997bb16 ("ARM: mvebu: define crypto SRAM ranges for all armada-xp boards")
Reported-by: Phil Sutter <phil@nwl.cc>
Cc: Phil Sutter <phil@nwl.cc>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
This cosmetic patch reorder nodes under internal-regs by increasing
address order, as expected.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
By default, armada-370-xp.dtsi file has internal RTC enabled.
NETGEAR ReadyNAS 102, 104 and 2120 all use an Intersil ISL12057
I2C RTC chip. The internal RTC not being disabled in the .dts
files of those devices result in the following useless first
line during boot:
[ 4.500056] rtc-mv d0010300.rtc: internal RTC not ticking
[ 4.505684] i2c /dev entries driver
[ 4.513246] rtc-isl12057 0-0068: rtc core: registered rtc-isl12057 as rtc0
This patch marks Armada internal RTC as disabled in individual .dts
files of those devices.
Reported-by: TuxOholic <tuxoholic@hotmail.de>
Define the crypto SRAM ranges so that the resources referenced by the
sa-sram node can be properly extracted from the DT.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
This commit adds the stdout-path property in /chosen for all Armada
boards that were not yet carrying this property, and gets rid of
/chosen/bootargs which becomes unneeded: earlyprintk should not be
used by default, and the console= parameter is replaced by the
/chosen/stdout-path property.
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
Now that alarm support for ISL12057 chip is available w/ the specific
"isil,irq2-can-wakeup-machine" property, let's use that feature of the
driver dedicated to NETGEAR ReadyNAS 102, 104 and 2120 specific routing of
RTC Alarm IRQ#2 pin; on those devices, this pin is not connected to the
SoC but to a PMIC, which allows the device to be powered up when RTC alarm
rings.
For that to work, the chip needs to be explicitly marked as a device
wakeup source using this "isil,irq2-can-wakeup-machine" boolean property.
This makes 'wakealarm' sysfs entry available to configure the alarm.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Peter Huewe <peter.huewe@infineon.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: Darshana Padmadas <darshanapadmadas@gmail.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Landley <rob@landley.net>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Uwe Kleine-König <uwe@kleine-koenig.org>
The current GPL only licensing on the device tree makes it very
impractical for other software components licensed under another
license.
In order to make it easier for them to reuse our device trees,
relicense our device trees under a GPL/X11 dual-license.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Armada XP pinctrl node gained an alias, make use of it.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-By: Benoit Masson <yahoo@perenite.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
In other MVEBU SoCs, the pin controller node is called pin-ctrl with
its base address added. Also, we have a node alias to access the pinctrl
node easily. Fix this for Armada XP pinctrl nodes to be consistent with
other SoCs.
NETGEAR ReadyNAS 2120 supports its four main SATA disks via 2
Marvell 88SE9170 SATA controllers connected on the PCIe bus
of the the SoC. The two eSATA ports available at the rear of
the device are handled by the native SATA controller of the
Armada XP SoC powering the NAS. This patch enables the SoC
SATA controller in the .dts file to make those two rear ports
available.
Link: https://lkml.kernel.org/r/f3876c7a9ef11eb758b9df18c671ee740b8be614.1414250947.git.arno@natisbad.org
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
Currently there is a wild mixture of isl, isil, and intersil
compatibles in the kernel. At this point, changing the vendor
symbol to the most often used variant, which is equal to the
NASDAQ symbol, isil, should not hurt.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Link: https://lkml.kernel.org/r/1410167960-554-4-git-send-email-p.zabel@pengutronix.de
The bootloader on the Netgear ReadyNAS RN2120 uses Hardware BCH
ECC (strength = 4), while the pxa3xx NAND driver by default uses
Hamming ECC (strength = 1).
This patch changes the ECC mode on these machines to match that
of the bootloader and of the stock firmware. That way, it is
now possible to update the kernel from userland (e.g. using
standard tools from mtd-utils package); u-boot will happily
load and boot it.
The issue was initially reported and fixed by Ben Pedell for
RN102. The RN2120 shares the same Hynix H27U1G8F2BTR NAND
flash and setup. This patch is based on Ben's fix for RN102.
Fixes: ad51eddd95ad ("ARM: mvebu: Enable NAND controller in ReadyNAS 2120 .dts file")
Cc: <stable@vger.kernel.org> # v3.14+
Link: https://lkml.kernel.org/r/61f6a1b7ad0adc57a0e201b9680bc2e5f214a317.1410035142.git.arno@natisbad.org
The Netgear RN2120 was not using the same strategy as the other Armada
370/375/38x/XP boards: it was using a 'clocks' property and not the
'clock-frequency' property in its UART controller Device Tree node.
However, now that this clock reference is present at the SoC-level,
there is no point in duplicating it at the board-level.
Link: https://lkml.kernel.org/r/1397806908-7550-6-git-send-email-thomas.petazzoni@free-electrons.com
Now that support for Intersil ISL12057 RTC chip is available
upstream, let's enable it in NETGEAR ReadyNAS 2120 .dts file
so that the device stop believing it's the 70's.
Now that NAND controller support is available for Armada XP
(cb28e2537a6f: ARM: mvebu: Add support for NAND controller in
Armada 370/XP), this patch enables support for ReadyNAS 2120
and defines default partition layout as delivered by NETGEAR.
As described in similar commits 2be2bc39c6f0 (ARM: mvebu: Enable
NAND controller in Armada XP GP board) and d8c552dddfbf (ARM:
mvebu: Enable NAND controller in Armada 370 Mirabox),
"marvell,keep-config" parameter is used as current support does
not allow for setting of timing parameters yet.
All hardware parts of the (mv78230 Armada XP based) NETGEAR ReadyNAS
2120 are supported by mainline kernel (USB 3.0 and eSATA rear ports,
USB 2.0 front port, Gigabit controller and PHYs for the two rear ports,
serial port, LEDs, Buttons, 88SE9170 SATA controllers, three G762 fan
controllers, G751 temperature sensor) except for:
- the Intersil ISL12057 I2C RTC Chip,
- the Armada NAND controller.
Support for both of those is currently work in progress and does not
prevent boot.
