path: root/arch/arm/boot/dts/armada-xp-openblocks-ax3-4.dts
2017-01-03ARM: dts: mvebu: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Rafał Miłecki <zajec5@gmail.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370-xp: Remove button address and fixup namesGregory CLEMENT
The gpio-key nodes do not have a reg property, so remove the address from the unit name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370-xp: Fixup memory DT warningGregory CLEMENT
memory has a reg property so the unit name should contain an address. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-xp: Fixup pcie DT warningsGregory CLEMENT
PCIe has a range property, so the unit name should contain an address. Take the opportunity to use the node label instead of the full name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-11-19ARM: dts: armada-370-xp: Fixup mdio DT warningGregory CLEMENT
MDIO has a reg property so the unit name should contain an address. Take the opportunity to use the node label instead of the full name. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support more Realtek wireless chips, from Jes Sorenson. 2) New BPF types for per-cpu hash and arrap maps, from Alexei Starovoitov. 3) Make several TCP sysctls per-namespace, from Nikolay Borisov. 4) Allow the use of SO_REUSEPORT in order to do per-thread processing of incoming TCP/UDP connections. The muxing can be done using a BPF program which hashes the incoming packet. From Craig Gallek. 5) Add a multiplexer for TCP streams, to provide a messaged based interface. BPF programs can be used to determine the message boundaries. From Tom Herbert. 6) Add 802.1AE MACSEC support, from Sabrina Dubroca. 7) Avoid factorial complexity when taking down an inetdev interface with lots of configured addresses. We were doing things like traversing the entire address less for each address removed, and flushing the entire netfilter conntrack table for every address as well. 8) Add and use SKB bulk free infrastructure, from Jesper Brouer. 9) Allow offloading u32 classifiers to hardware, and implement for ixgbe, from John Fastabend. 10) Allow configuring IRQ coalescing parameters on a per-queue basis, from Kan Liang. 11) Extend ethtool so that larger link mode masks can be supported. From David Decotigny. 12) Introduce devlink, which can be used to configure port link types (ethernet vs Infiniband, etc.), port splitting, and switch device level attributes as a whole. From Jiri Pirko. 13) Hardware offload support for flower classifiers, from Amir Vadai. 14) Add "Local Checksum Offload". Basically, for a tunneled packet the checksum of the outer header is 'constant' (because with the checksum field filled into the inner protocol header, the payload of the outer frame checksums to 'zero'), and we can take advantage of that in various ways. From Edward Cree" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits) bonding: fix bond_get_stats() net: bcmgenet: fix dma api length mismatch net/mlx4_core: Fix backward compatibility on VFs phy: mdio-thunder: Fix some Kconfig typos lan78xx: add ndo_get_stats64 lan78xx: handle statistics counter rollover RDS: TCP: Remove unused constant RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket net: smc911x: convert pxa dma to dmaengine team: remove duplicate set of flag IFF_MULTICAST bonding: remove duplicate set of flag IFF_MULTICAST net: fix a comment typo ethernet: micrel: fix some error codes ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it bpf, dst: add and use dst_tclassid helper bpf: make skb->tc_classid also readable net: mvneta: bm: clarify dependencies cls_bpf: reset class and reuse major in da ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c ldmvsw: Add ldmvsw.c driver code ...
2016-03-14ARM: dts: armada-xp-openblocks-ax3-4: Add BM supportGregory CLEMENT
Allow Openblock AX3 using hardware buffer management with mvneta. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-11ARM: mvebu: fix overlap of Crypto SRAM with PCIe memory windowThomas Petazzoni
When the Crypto SRAM mappings were added to the Device Tree files describing the Armada XP boards in commit c466d997bb16 ("ARM: mvebu: define crypto SRAM ranges for all armada-xp boards"), the fact that those mappings were overlaping with the PCIe memory aperture was overlooked. Due to this, we currently have for all Armada XP platforms a situation that looks like this: Memory mapping on Armada XP boards with internal registers at 0xf1000000: - 0x00000000 -> 0xf0000000 3.75G RAM - 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB) - 0xf1000000 -> 0xf1100000 1M internal registers - 0xf8000000 -> 0xffe0000 126M PCIe memory aperture - 0xf8100000 -> 0xf8110000 64KB Crypto SRAM #0 => OVERLAPS WITH PCIE ! - 0xf8110000 -> 0xf8120000 64KB Crypto SRAM #1 => OVERLAPS WITH PCIE ! - 0xffe00000 -> 0xfff00000 1M PCIe I/O aperture - 0xfff0000 -> 0xffffffff 1M BootROM The overlap means that when PCIe devices are added, depending on their memory window needs, they might or might not be mapped into the physical address space. Indeed, they will not be mapped if the area allocated in the PCIe memory aperture by the PCI core overlaps with one of the Crypto SRAM. Typically, a Intel IGB PCIe NIC that needs 8MB of PCIe memory will see its PCIe memory window allocated from 0xf80000000 for 8MB, which overlaps with the Crypto SRAM windows. Due to this, the PCIe window is not created, and any attempt to access the PCIe window makes the kernel explode: [ 3.302213] igb: Copyright (c) 2007-2014 Intel Corporation. [ 3.307841] pci 0000:00:09.0: enabling device (0140 -> 0143) [ 3.313539] mvebu_mbus: cannot add window '4:f8', conflicts with another window [ 3.320870] mvebu-pcie soc:pcie-controller: Could not create MBus window at [mem 0xf8000000-0xf87fffff]: -22 [ 3.330811] Unhandled fault: external abort on non-linefetch (0x1008) at 0xf08c0018 This problem does not occur on Armada 370 boards, because we use the following memory mapping (for boards that have internal registers at 0xf1000000): - 0x00000000 -> 0xf0000000 3.75G RAM - 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB) - 0xf1000000 -> 0xf1100000 1M internal registers - 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 => OK ! - 0xf8000000 -> 0xffe0000 126M PCIe memory - 0xffe00000 -> 0xfff00000 1M PCIe I/O - 0xfff0000 -> 0xffffffff 1M BootROM Obviously, the solution is to align the location of the Crypto SRAM mappings of Armada XP to be similar with the ones on Armada 370, i.e have them between the "internal registers" area and the beginning of the PCIe aperture. However, we have a special case with the OpenBlocks AX3-4 platform, which has a 128 MB NOR flash. Currently, this NOR flash is mapped from 0xf0000000 to 0xf8000000. This is possible because on OpenBlocks AX3-4, the internal registers are not at 0xf1000000. And this explains why the Crypto SRAM mappings were not configured at the same place on Armada XP. Hence, the solution is two-fold: (1) Move the NOR flash mapping on Armada XP OpenBlocks AX3-4 from 0xe8000000 to 0xf0000000. This frees the 0xf0000000 -> 0xf80000000 space. (2) Move the Crypto SRAM mappings on Armada XP to be similar to Armada 370 (except of course that Armada XP has two Crypto SRAM and not one). After this patch, the memory mapping on Armada XP boards with registers at 0xf1 is: - 0x00000000 -> 0xf0000000 3.75G RAM - 0xf0000000 -> 0xf1000000 16M NOR flashes (AXP GP / AXP DB) - 0xf1000000 -> 0xf1100000 1M internal registers - 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 - 0xf1110000 -> 0xf1120000 64KB Crypto SRAM #1 - 0xf8000000 -> 0xffe0000 126M PCIe memory - 0xffe00000 -> 0xfff00000 1M PCIe I/O - 0xfff0000 -> 0xffffffff 1M BootROM And the memory mapping for the special case of the OpenBlocks AX3-4 (internal registers at 0xd0000000, NOR of 128 MB): - 0x00000000 -> 0xc0000000 3G RAM - 0xd0000000 -> 0xd1000000 1M internal registers - 0xe800000 -> 0xf0000000 128M NOR flash - 0xf1100000 -> 0xf1110000 64KB Crypto SRAM #0 - 0xf1110000 -> 0xf1120000 64KB Crypto SRAM #1 - 0xf8000000 -> 0xffe0000 126M PCIe memory - 0xffe00000 -> 0xfff00000 1M PCIe I/O - 0xfff0000 -> 0xffffffff 1M BootROM Fixes: c466d997bb16 ("ARM: mvebu: define crypto SRAM ranges for all armada-xp boards") Reported-by: Phil Sutter <phil@nwl.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: <stable@vger.kernel.org> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-09-29ARM: mvebu: define crypto SRAM ranges for all armada-xp boardsBoris Brezillon
Define the crypto SRAM ranges so that the resources referenced by the sa-sram node can be properly extracted from the DT. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-04-27ARM: mvebu: armada-xp-openblocks-ax3-4: Disable internal RTCGregory CLEMENT
There is no crystal connected to the internal RTC on the Open Block AX3. So let's disable it in order to prevent the kernel probing the driver uselessly. Eventually this patches removes the following warning message from the boot log: "rtc-mv d0010300.rtc: internal RTC not ticking" Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Cc: <stable@vger.kernel.org> # v3.8 +
2015-03-04ARM: mvebu: use stdout-path in all armada-*.dtsThomas Petazzoni
This commit adds the stdout-path property in /chosen for all Armada boards that were not yet carrying this property, and gets rid of /chosen/bootargs which becomes unneeded: earlyprintk should not be used by default, and the console= parameter is replaced by the /chosen/stdout-path property. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-01-26ARM: mvebu: armada-xp-openblocks-ax3-4: Relicense the device tree under ↵Gregory CLEMENT
GPLv2+/X11 The current GPL only licensing on the device tree makes it very impractical for other software components licensed under another license. In order to make it easier for them to reuse our device trees, relicense our device trees under a GPL/X11 dual-license. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2014-11-02ARM: mvebu: armada-xp: Use pinctrl node aliasSebastian Hesselbarth
Armada XP pinctrl node gained an alias, make use of it. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-By: Benoit Masson <yahoo@perenite.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-02ARM: mvebu: armada-xp: Add node alias to pinctrl and add base addressSebastian Hesselbarth
In other MVEBU SoCs, the pin controller node is called pin-ctrl with its base address added. Also, we have a node alias to access the pinctrl node easily. Fix this for Armada XP pinctrl nodes to be consistent with other SoCs. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-By: Benoit Masson <yahoo@perenite.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-17ARM: mvebu: DT: fix OpenBlocks AX3-4 RAM sizeJason Cooper
The OpenBlocks AX3-4 has a non-DT bootloader. It also comes with 1GB of soldered on RAM, and a DIMM slot for expansion. Unfortunately, atags_to_fdt() doesn't work in big-endian mode, so we see the following failure when attempting to boot a big-endian kernel: 686 slab pages 17 pages shared 0 pages swap cached [ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name Kernel panic - not syncing: Out of memory and no killable processes... CPU: 1 PID: 351 Comm: kworker/u4:0 Not tainted 3.15.0-rc8-next-20140603 #1 [<c0215a54>] (unwind_backtrace) from [<c021160c>] (show_stack+0x10/0x14) [<c021160c>] (show_stack) from [<c0802500>] (dump_stack+0x78/0x94) [<c0802500>] (dump_stack) from [<c0800068>] (panic+0x90/0x21c) [<c0800068>] (panic) from [<c02b5704>] (out_of_memory+0x320/0x340) [<c02b5704>] (out_of_memory) from [<c02b93a0>] (__alloc_pages_nodemask+0x874/0x930) [<c02b93a0>] (__alloc_pages_nodemask) from [<c02d446c>] (handle_mm_fault+0x744/0x96c) [<c02d446c>] (handle_mm_fault) from [<c02cf250>] (__get_user_pages+0xd0/0x4c0) [<c02cf250>] (__get_user_pages) from [<c02f3598>] (get_arg_page+0x54/0xbc) [<c02f3598>] (get_arg_page) from [<c02f3878>] (copy_strings+0x278/0x29c) [<c02f3878>] (copy_strings) from [<c02f38bc>] (copy_strings_kernel+0x20/0x28) [<c02f38bc>] (copy_strings_kernel) from [<c02f4f1c>] (do_execve+0x3a8/0x4c8) [<c02f4f1c>] (do_execve) from [<c025ac10>] (____call_usermodehelper+0x15c/0x194) [<c025ac10>] (____call_usermodehelper) from [<c020e9b8>] (ret_from_fork+0x14/0x3c) CPU0: stopping CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.15.0-rc8-next-20140603 #1 [<c0215a54>] (unwind_backtrace) from [<c021160c>] (show_stack+0x10/0x14) [<c021160c>] (show_stack) from [<c0802500>] (dump_stack+0x78/0x94) [<c0802500>] (dump_stack) from [<c021429c>] (handle_IPI+0x138/0x174) [<c021429c>] (handle_IPI) from [<c02087f0>] (armada_370_xp_handle_irq+0xb0/0xcc) [<c02087f0>] (armada_370_xp_handle_irq) from [<c0212100>] (__irq_svc+0x40/0x50) Exception stack(0xc0b6bf68 to 0xc0b6bfb0) bf60: e9fad598 00000000 00f509a3 00000000 c0b6a000 c0b724c4 bf80: c0b72458 c0b6a000 00000000 00000000 c0b66da0 c0b6a000 00000000 c0b6bfb0 bfa0: c027bb94 c027bb24 60000313 ffffffff [<c0212100>] (__irq_svc) from [<c027bb24>] (cpu_startup_entry+0x54/0x214) [<c027bb24>] (cpu_startup_entry) from [<c0ac5b30>] (start_kernel+0x318/0x37c) [<c0ac5b30>] (start_kernel) from [<00208078>] (0x208078) ---[ end Kernel panic - not syncing: Out of memory and no killable processes... A similar failure will also occur if ARM_ATAG_DTB_COMPAT isn't selected. Fix this by setting a sane default (1 GB) in the dts file. Signed-off-by: Jason Cooper <jason@lakedaemon.net> Tested-by: Kevin Hilman <khilman@linaro.org> Cc: <stable@vger.kernel.org> #v3.13+ Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-06-02Merge tag 'dt-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull ARM SoC devicetree updates from Olof Johansson: "As with previous release, this continues to be among the largest branches we merge, with lots of new contents. New things for this release are among other things: - DTSI contents for the new SoCs supported in 3.16 (see SoC pull request) - Qualcomm APQ8064 and APQ8084 SoCs and eval boards - Nvidia Jetson TK1 development board (Tegra T124-based) Two new SoCs that didn't need enough new platform code to stand out enough for me to notice when writing the SoC tag, but that adds new DT contents are: - TI DRA72 - Marvell Berlin 2Q" * tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits) ARM: dts: add secure firmware support for exynos5420-arndale-octa ARM: dts: add pmu sysreg node to exynos3250 ARM: dts: correct the usb phy node in exynos5800-peach-pi ARM: dts: correct the usb phy node in exynos5420-peach-pit ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410 ARM: dts: add dts files for exynos3250 SoC ARM: dts: add mfc node for exynos5800 ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi ARM: dts: enable fimd for exynos5800-peach-pi ARM: dts: enable display controller for exynos5800-peach-pi ARM: dts: enable hdmi for exynos5800-peach-pi ARM: dts: add dts file for exynos5800-peach-pi board ARM: dts: add dts file for exynos5800 SoC ARM: dts: add dts file for exynos5260-xyref5260 board ARM: dts: add dts files for exynos5260 SoC ARM: dts: update watchdog node name in exynos5440 ARM: dts: use key code macros on Origen and Arndale boards ARM: dts: enable RTC and WDT nodes on Origen boards ARM: dts: qcom: Add APQ8084-MTP board support ARM: dts: qcom: Add APQ8084 SoC support ...
2014-04-26ARM: mvebu: remove clock-frequency of serial port Device Tree nodesThomas Petazzoni
Now that the Armada 370/375/38x/XP SoC-level Device Tree files have the proper "clocks" property in their UART controllers node, it is no longer useful to have the clock-frequency property defined in the board-level Device Tree files. Therefore, this commit gets rid of all the useless 'clock-frequency' properties. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Link: https://lkml.kernel.org/r/1397806908-7550-5-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-25ARM: mvebu: fix NOR bus-width in Armada XP OpenBlocks AX3 Device TreeThomas Petazzoni
The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus width declared in the Device Tree being considered as a 16 bits bus width when configuring the hardware. This bug in mvebu-devbus driver was compensated by a symetric mistake in the Armada XP OpenBlocks AX3 Device Tree: a 8 bits bus width was declared, even though the hardware actually has a 16 bits bus width connection with the NOR flash. Now that we have fixed the mvebu-devbus driver to behave according to its Device Tree binding, this commit fixes the problematic Device Tree files as well. This bug was introduced in commit a7d4f81821f7eec3175f8e23dd6949c71ab2da43 ('ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board') which was merged in v3.10. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397489361-5833-5-git-send-email-thomas.petazzoni@free-electrons.com Fixes: a7d4f81821f7 ('ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board') Cc: stable@vger.kernel.org # v3.10+ Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-02-11ARM: mvebu: use input DT defines in Armada 370/XP boardsThomas Petazzoni
Instead of harcoding keycodes specifications in the Armada 370/XP boards, use the <dt-bindings/input/input.h> header file and its keycode definitions. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-02-11ARM: mvebu: use GPIO DT defines in Armada 370/XP boardsThomas Petazzoni
Instead of harcoding 0 and 1 for the gpio specifications in the Armada 370/XP boards, use the <dt-bindings/gpio/gpio.h> header file and its GPIO_ACTIVE_HIGH and GPIO_ACTIVE_LOW definitions. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-11-23ARM: mvebu: dts: remove unneeded linux,default-state from led nodesJason Cooper
Generally, power LEDs should indicate when power is applied, and go out once power is removed. _Not_ annoy the developer with migraine-inducing blinking reminicent of some badly animated television series designed to sell sugar to children. On a more serious note, most of these OS-specific properties aren't necessary and should be removed. I left two that are legitimately tying disk LEDs to disk activity. Other than that, we keep the state the bootloader left them in until userspace changes the state via sysfs. Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Relocate Armada 370/XP PCIe device tree nodesEzequiel Garcia
Now that mbus has been added to the device tree, it's possible to move the PCIe nodes out of internal registers, placing it directly below the mbus. This is a more accurate representation of the hardware. Moving the PCIe nodes, we now need to introduce an extra cell to encode the window target ID and attribute. Since this depends on the PCIe port, we split the ranges translation entries, to correspond to each MBus window. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Relocate Armada 370/XP DeviceBus device tree nodesEzequiel Garcia
Now that mbus has been added to the device tree, it's possible to move the DeviceBus out of internal registers, placing it directly below the mbus. This is a more accurate representation of the hardware. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Add BootROM to Armada 370/XP device treeEzequiel Garcia
In order to access the SoC BootROM, we need to declare a mapping (through a ranges property). The mbus driver will use this property to allocate a suitable address decoding window. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Add MBus to Armada 370/XP device treeEzequiel Garcia
The Armada 370/XP SoC family has a completely configurable address space handled by the MBus controller. This patch introduces the device tree layout of MBus, making the 'soc' node as mbus-compatible. Since every peripheral/controller is a child of this 'soc' node, this makes all of them sit behind the mbus, thus describing the hardware accurately. A translation entry has been added for the internal-regs mapping. This can't be done in the common armada-370-xp.dtsi because A370 and AXP have different addressing width. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Use the preprocessor on Armada 370/XP device tree filesEzequiel Garcia
2013-06-20Merge tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Arnd Bergmann
into next/dt From Shawn Guo: mxs device tree changes for 3.11: * A couple of new board support, cfa10055 and cfa10057 * A few updates on cfa10036 device tree source * Some auart pinctrl data addition * Adopt soc bus infrastructure for mach-mxs * tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: mxs: dt: Add Crystalfontz CFA-10057 device tree ARM: mxs: dt: Add the Crystalfontz CFA-10055 device tree ARM: cfa10049: Switch the chip select pin of the LCD controller ARM: cfa10036: Add USB0 OTG port ARM: dts: apf28dev: Add touchscreen support for APF28dev ARM: mxs: Fix UARTs on M28EVK ARM: cfa10036: dt: Change i2c0 clock frequency ARM: dts: cfa10036: Change the OLED display to SSD1306 ARM: mx28: add auart4 2 pins pinmux to imx28.dtsi ARM: mx28: add auart3 2 pins pinmux to imx28.dtsi ARM: mx28: add auart2 2 pins pinmux to imx28.dtsi ARM: mxs: Use soc bus infrastructure ARM: dts: mx28: Adjust the digctl compatible string ARM: mxs: Remove init_irq declaration in machine description Includes an update to 3.10-rc6 Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-06arm: mvebu: armada-xp-{gp,openblocks-ax3-4}: specify PCIe rangeThomas Petazzoni
The ranges DT entry needed by the PCIe controller is defined at the SoC .dtsi level. However, some boards have a NOR flash, and to support it, they need to override the SoC-level ranges property to add an additional range. Since PCIe and NOR support came separately, some boards were not properly changed to include the PCIe range in their ranges property at the .dts level. This commit fixes those platforms. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-31Merge tag 'dt-3.11-3' of git://git.infradead.org/users/jcooper/linux into ↵Olof Johansson
next/dt From jason Cooper, mvebu dt changes for v3.11. Signed-off-by: Olof Johansson <olof@lixom.net> * tag 'dt-3.11-3' of git://git.infradead.org/users/jcooper/linux: (27 commits) arm: kirkwood: openblocks-a6: add support for Init button arm: kirkwood: openblocks-a6: group pinmux configurations arm: kirkwood: ts219: move pinmux configs to the right devices arm: kirkwood: topkick: move pinmux configs to the right devices arm: kirkwood: openblocks_a6: move pinmux configs to the right devices arm: kirkwood: nsa310: move pinmux configs to the right devices arm: kirkwood: readynas: move pinmux configs to the right devices arm: kirkwood: mplcec4: move pinmux configs to the right devices arm: kirkwood: buffalo linkstation: move pinmux configs to the right devices arm: kirkwood: keymile: move pinmux configs to the right devices arm: kirkwood: ns2: move pinmux configs to the right devices arm: kirkwood: iomega ix2-200: move pinmux configs to the right devices arm: kirkwood: iconnect: move pinmux configs to the right devices arm: kirkwood: iconnect: give meaningful names to pinmux configs arm: kirkwood: ib62x0: move pinmux configs to the right devices arm: kirkwood: guruplug: move pinmux configs to the right devices arm: kirkwood: goflexnet: move pinmux configs to the right devices arm: kirkwood: dreamplug: move pinmux configs to the right devices arm: kirkwood: dockstar: move pinmux configs to the right devices arm: kirkwood: dlink dns: move pinmux configs to the right devices ...
2013-05-20arm: mvebu: enable the third USB interface on OpenBlocks AX3Thomas Petazzoni
Besides the two "classic" USB interfaces with normal USB ports on the front side, the PlatHome OpenBlocks AX3 uses the third USB interface of the Marvell SoC in the mini-PCIe connector. This allows certain mini-PCIe cards to expose parts of their functionality as a USB peripheral. This commit enables this third USB interface in the OpenBlocks AX3 Device Tree, and also adds comments on top of the two other USB interfaces so that the Device Tree makes it clear which USB interface at the SoC level matches which USB interface visible on the board. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Atsushi Yamagata <yamagata@plathome.co.jp> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-13ARM: mvebu: Add a ranges entry to translate devbus childsEzequiel Garcia
With the latest device tree reorganization which introduced the 'internal-reg' node, now the only region translated is the internal register's. This makes the description of the hardware incomplete, for it lacks the Device Bus childs address space. In order to fix this, it's required to add a 'ranges' entry with a suitable address space to map Device Bus childs, on a per-board basis. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: Convert mvebu device tree files to 64 bitsGregory CLEMENT
In order to be able to use more than 4GB of RAM when the LPAE is activated, the dts must be converted in 64 bits. Only Armada XP is LPAE capable, but as it shares a common dtsi file with Armada 370, then the common file include the skeleton64. Thanks to the use of the overload capability of the device tree format, armada-370 include the 32 bit skeleton and all the armada 370 based dts can remain the same. This was heavily based on the work of Lior Amsalem. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: introduce internal-regs nodeGregory CLEMENT
Introduce a 'internal-regs' subnode, under which all devices are moved. This is not really needed for now, but will be for the mvebu-mbus driver. This generates a lot of code movement since it's indenting by one more tab all the devices. So it was a good opportunity to fix all the bad indentation. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: Convert all the mvebu files to use the range propertyGregory CLEMENT
This conversion will allow to keep 32 bits addresses for the internal registers whereas the memory of the system will be 64 bits. Later it will also ease the move of the mvebu-mbus driver to the device tree support. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4Thomas Petazzoni
The PlatHome OpenBlocks AX3-4 has an internal mini-PCIe slot that can be used to plug mini-PCIe devices. We therefore enable the PCIe interface that corresponds to this slot. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-11ARM: mvebu: Add support for NOR flash device on Openblocks AX3 boardEzequiel Garcia
The Plat'home Openblocks AX3 has a 128 MiB NOR flash device connected to the Device Bus. This commit adds the device tree node to support this device. The SoC supports a flexible and dynamic decoding window allocation scheme; but since this feature is still not implemented we need to specify the window base address in the device tree node itself. This base address has been selected in a completely arbitrary fashion. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28arm: mvebu: Enable USB controllers on Armada 370/XP boardsEzequiel Garcia
This patch activates every USB port provided by each SoC. Except for Armada XP Openblocks AX3-4 board, where we enable only the first two USB ports until we have more information on the third one usage. Cc: Lior Amsalem <alior@marvell.com> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Gregory CLEMENT <gregory.clement@free-electrons.com> Tested-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28arm: mvebu: add button for OpenBlocks AX3-4Thomas Petazzoni
The OpenBlocks AX3-4 board has one software-controlled button on the front side, labeled "INIT", so we add minimal support for this button in the kernel. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21ARM: mvebu: Add SATA support for OpenBlocks AX3-4Thomas Petazzoni
This patch enables SATA support on the OpenBlocks AX3-4. It has one internal SATA port, and an external eSATA port. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-21ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4Nobuhiro Iwamatsu
The OpenBlocks AX3-4 has a Seiko Instruments S-35390A as the RTC controller. This patch enables this RTC device in the OpenBlocks AX3-4 Device Tree. [Thomas Petazzoni: updated with other OpenBlocks changes, rephrased commit log.] Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-21ARM: mvebu: Add support for I2C on OpenBlocks AX3-4Nobuhiro Iwamatsu
The OpenBlocks AX3-4 board, based on the Armada XP SoC, has an I2C bus. This patch enables this bus and sets the clock frequency of the bus. [Thomas Petazzoni: updated with other changes on OpenBlocks, rephrased commit log.] Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20arm: mvebu: remove 'clock-frequency' properties from Armada 370/XP Ethernet ↵Thomas Petazzoni
nodes The mvneta driver for the Marvell Armada 370/XP Ethernet devices has gained proper clock framework integration, and the corresponding Device Tree nodes now have a correct 'clocks' pointer. The 'clock-frequency' properties in the various .dts files for Armada 370/XP boards have therefore become useless. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-16arm: mvebu: enable Ethernet controllers on OpenBlocks AX3-4 platformThomas Petazzoni
The PlatHome OpenBlocks AX3-4 platform has 4 Ethernet ports, connected to a single quad-port PHY through SGMII. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-14arm: mvebu: support for the PlatHome OpenBlocks AX3-4 boardThomas Petazzoni
This platform, available in Japan from PlatHome, has a dual-core Armada XP, the MV78260. For now, only the two serial ports and the three front LEDs are supported. Support for SMP, network, SATA, USB and other peripherals will be added as drivers for them become available for Armada XP in mainline. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> --- This is 3.8 material. Changes since v2: * Renamed the .dts file to armada-xp-openblocks-ax3-4.dts * Removed the compatible string from armada-370-xp.c (which now only lists the common SoC compatible string) Changes since v1: * Renamed the board to OpenBlocks AX3-4, since there is a variant called AX3-2 which has less RAM, and no mini PCIe port. Requested by Andrew Lunn. * Fix the amount of memory to 3 GB. In fact, the board has 1 GB soldered, and 2 GB in a SODIMM slot (which is therefore removable). But as the board is delivered as is, we'll assume it has 3 GB of memory by default.
