Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The clocks group properties and the clock@0 node have been obsolete for two
years, remove them.
Cc: Rodolfo Giometti <giometti@linux.it>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Define Cosino boards main and slow crystals frequencies.
Remove the properties that are not used anymore by the at91_adc driver.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch adds the Cosino at91sam9g35 based CPU module and the
Cosino Mega 2560 extension board.
Web site: http://www.cosino.it
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
[plagnioj@jcrosoft.com: added "at91-" to files, pinctrl fixed, removed unneeded stuff]
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
[nicolas.ferre@atmel.com: adapted to newer kernel, modified commit message]
